[GRASS-SVN] r54367 - grass-addons/grass7/imagery/i.spec.unmix
Sat Dec 22 07:38:12 PST 2012
Author: rashadkm
Date: 2012-12-22 07:38:11 -0800 (Sat, 22 Dec 2012)
New Revision: 54367
   grass-addons/grass7/imagery/i.spec.unmix/la_extra.c
   grass-addons/grass7/imagery/i.spec.unmix/main.c
i.spec.unmix: initalized all math vector
Modified: grass-addons/grass7/imagery/i.spec.unmix/la_extra.c
--- grass-addons/grass7/imagery/i.spec.unmix/la_extra.c	2012-12-22 10:23:23 UTC (rev 54366)
+++ grass-addons/grass7/imagery/i.spec.unmix/la_extra.c	2012-12-22 15:38:11 UTC (rev 54367)
@@ -19,17 +19,16 @@
   matrix = G_matrix_init(rows, cols, rows);
   int i, j, p, index = 0;
   for (i = 0; i < rows; i++)
     for (j = 0; j < cols; j++)
-    matrix->vals[index++] = in->vals[i + j * cols];
+     G_matrix_set_element(matrix, i, j,	 G_matrix_get_element(in, i, j));
+/*    matrix->vals[index++] = in->vals[i + j * cols];*/
   int old_size = in->rows * in->cols;
   int new_size = rows * cols;
   if (new_size > old_size)
     for (p = old_size; p < new_size; p++)
-      matrix->vals[p] = 0.0;
+      G_matrix_set_element(matrix, i, j, 0.0);
   return (matrix);
@@ -72,18 +71,23 @@
   unsigned int i, m, n, j;
   register doublereal sum;
-  if (A->cols != b->ldim) {
-    G_warning (_("Input matrix and vector have differing dimensions"));
+//G_message("A=%d,%d,%d", A->cols, A->rows, A->ldim);
+//G_message("B=%d,%d,%d", b->cols, b->rows, b->ldim);
+  if (A->cols != b->cols) {
+    G_warning (_("Input matrix and vector have differing dimensions1"));
     return NULL;
   if (!out) {
     G_warning (_("Output vector is uninitialized"));
     return NULL;
-  if (out->ldim != A->rows) {
-    G_warning (_("Output vector has incorrect dimension"));
-    return NULL;
+/*  if (out->ldim != A->rows) {*/
+/*    G_warning (_("Output vector has incorrect dimension"));*/
+/*    exit(1);*/
+/*    return NULL;*/
   m = A->rows;
@@ -93,7 +97,9 @@
     sum = 0.0;
     int width = A->rows;
     for (j = 0; j < n; j++) {
-	    sum += A->vals[i + j * width] * b->vals[j];
+        sum +=G_matrix_get_element(A, i, j) * G_matrix_get_element(b, 0, j);
+        /*sum += A->vals[i + j * width] * b->vals[j];*/
 	    out->vals[i] = sum;
Modified: grass-addons/grass7/imagery/i.spec.unmix/main.c
--- grass-addons/grass7/imagery/i.spec.unmix/main.c	2012-12-22 10:23:23 UTC (rev 54366)
+++ grass-addons/grass7/imagery/i.spec.unmix/main.c	2012-12-22 15:38:11 UTC (rev 54367)
@@ -273,18 +273,18 @@
     mu = 0.0001 * pow(10, -1 * ceil(log10(max_total)));
     /* TODO: Missing? startvector = G_vector_init (0, 0, RVEC); */
-    startvector = G_vector_init(A->cols, A->cols, CVEC);
+    startvector = G_vector_init(A->cols, 1, RVEC);
     if (startvector == NULL)
 	G_fatal_error(_("Unable to allocate memory for vector"));
     /* TODO: Missing? A_times_startvector = G_vector_init (0, 0, RVEC); */
-    A_times_startvector = G_vector_init(A_tilde->rows, A_tilde->rows, CVEC);	/* length: no. of bands   */
+    A_times_startvector = G_vector_init(A_tilde->rows, 1, RVEC);	/* length: no. of bands   */
     /* TODO: Missing? errorvector = G_vector_init (0, 0, RVEC); */
-    errorvector = G_vector_init(A_tilde->rows, A_tilde->rows, CVEC);	/* length: no. of bands   */
+    errorvector = G_vector_init(A_tilde->rows, 1, RVEC);	/* length: no. of bands   */
     /* TODO: Missing? temp = G_vector_init (0, 0, RVEC); */
-    temp = G_vector_init(A_tilde->cols, A_tilde->cols, CVEC);	/* length: no. of spectra */
+    temp = G_vector_init(A_tilde->cols, 1, RVEC);	/* length: no. of spectra */
@@ -332,22 +332,22 @@
 	    /* get pixel values of each band and store in b vector: */
 	    /* length: no. of bands + 1 (GAMMA) */
-	    b_gamma = G_vector_init(A_tilde->rows, A_tilde->rows, CVEC);
+	    b_gamma = G_vector_init(A_tilde->rows, 1, RVEC);
 	    if (b_gamma == NULL)
 		G_fatal_error(_("Unable to allocate memory for matrix"));
 	    for (band = 0; band < Ref.nfiles; band++)
-		G_matrix_set_element(b_gamma, band, 0, cell[band][col]);
+		G_matrix_set_element(b_gamma, 0, band, cell[band][col]);
 	    /* add GAMMA for 1. constraint as last element */
-	    G_matrix_set_element(b_gamma, Ref.nfiles, 0, GAMMA);
+	    G_matrix_set_element(b_gamma, 0, Ref.nfiles, GAMMA);
 	    for (k = 0; k < A_tilde->cols; k++)
-		G_matrix_set_element(startvector, k, 0,
+		G_matrix_set_element(startvector, 0, k,
 				     (1.0 / A_tilde->cols));
 	    /* calculate fraction vector for current pixel
@@ -360,6 +360,8 @@
 	    /* solve with iterative solution: */
 	    while (fabs(change) > 0.0001) {
 		G_mat_vector_product(A_tilde, startvector,
@@ -377,8 +379,8 @@
 		    /* no. of spectra times */
 		    /* if one element gets negative, set it to zero */
-		    if ((G_matrix_get_element(startvector, k, 0) < 0))
-			G_matrix_set_element(startvector, k, 0, 0);
+		    if ((G_matrix_get_element(startvector, 0, k) < 0))
+			G_matrix_set_element(startvector, 0, k, 0);
 		/* Check the deviation */
@@ -393,11 +395,10 @@
 		/* G_message("change=%lf, norm2=%lf",change, norm);   */
 	    vec_struct *fraction;
 	    /* G_message("fcol %d  and A->cols %d", startvector->dim, A->cols); */
-	    fraction = G_vector_init(A->cols, A->cols, CVEC);	/* length: no. of spectra */
+	    fraction = G_vector_init(A->cols,1, RVEC);	/* length: no. of spectra */
 	    error = deviation / G_vector_norm_euclid(b_gamma);
 	    fraction = G_vector_copy(startvector, NO_COMPACT);
@@ -406,7 +407,7 @@
 	    /* write result in full percent */
 	    for (i = 0; i < A->cols; i++)	/* no. of spectra */
 		result_cell[i][col] =
-		    (CELL) (100 * G_matrix_get_element(fraction, i, 0));
+		    (CELL) (100 * G_matrix_get_element(fraction, 0, i));
 	    /* save error and iterations */
 	    error_cell[col] = (CELL) (100 * error);
