[GRASS-SVN] r54368 - grass-addons/grass7/raster/r.in.wms2
svn_grass at osgeo.org
Sat Dec 22 15:27:15 PST 2012
Author: turek
Date: 2012-12-22 15:27:15 -0800 (Sat, 22 Dec 2012)
New Revision: 54368
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
grass-addons/grass7/raster/r.in.wms2/wms_base.py
grass-addons/grass7/raster/r.in.wms2/wms_cap_parsers.py
grass-addons/grass7/raster/r.in.wms2/wms_drv.py
r.in.wms2: improved wms capabilities check, other minor improvements
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py 2012-12-22 15:38:11 UTC (rev 54367)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py 2012-12-22 23:27:15 UTC (rev 54368)
@@ -154,14 +154,14 @@
#%end
#%option G_OPT_F_INPUT
-#% key: cfile
+#% key: capfile
#% required: no
#% gisprompt: old,file,bin_input
#% description: Capabilities file
#%end
#%option G_OPT_F_OUTPUT
-#% key: csfile
+#% key: capfile_output
#% required: no
#% description: File where capabilities will be saved (only with 'c' flag).
Modified: grass-addons/grass7/raster/r.in.wms2/wms_base.py
--- grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-12-22 15:38:11 UTC (rev 54367)
+++ grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-12-22 23:27:15 UTC (rev 54368)
@@ -5,21 +5,20 @@
- wms_base::WMSBase
- wms_base::GRASSImporter
- wms_base::WMSDriversInfo
(C) 2012 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
- at TODO use username and password for getting capabilities
@author Stepan Turek <stepan.turek seznam.cz> (Mentor: Martin Landa)
import os
from math import ceil
-from urllib2 import urlopen, HTTPError, URLError
+import base64
+import urllib2
from httplib import HTTPException
import grass.script as grass
@@ -57,7 +56,7 @@
driver_props = drv_info.GetDrvProperties(options['driver'])
self._checkIgnoeredParams(options, flags, driver_props)
- self.params['cfile'] = options['cfile'].strip()
+ self.params['capfile'] = options['capfile'].strip()
for key in ['url', 'layers', 'styles', 'method']:
self.params[key] = options[key].strip()
@@ -164,8 +163,7 @@
(','.join(not_relevant_flags), options['driver'])))
def GetMap(self, options, flags):
- """!Download data from WMS server and import data
- (using GDAL library) into GRASS as a raster map."""
+ """!Download data from WMS server."""
self._initializeParameters(options, flags)
@@ -183,7 +181,7 @@
def _fetchCapabilities(self, options):
"""!Download capabilities from WMS server
- # download capabilities file
+ grass.debug('Fetching capabilities file.')
cap_url = options['url']
if 'WMTS' in options['driver']:
@@ -194,22 +192,34 @@
cap_url += "?SERVICE=WMS&REQUEST=GetCapabilities&VERSION=" + options['wms_version']
try:
- cap = urlopen(cap_url)
- except (IOError, HTTPError, HTTPException):
- grass.fatal(_("Unable to get capabilities from '%s'") % options['url'])
+ cap = self._fetchDataFromServer(cap_url, options['username'], options['password'])
+ except (IOError, HTTPException), e:
+ if urllib2.HTTPError == type(e) and e.code == 401:
+ grass.fatal(_("Authorization failed to '%s' when fetching capabilities.") % options['url'])
+ else:
+ grass.fatal(_("Unable to fetch capabilities from: '%s'") % options['url'])
return cap
+ def _fetchDataFromServer(self, url, username = None, password = None):
+ """!Fetch data from server
+ request = urllib2.Request(url)
+ if username and password:
+ base64string = base64.encodestring('%s:%s' % (username, password)).replace('\n', '')
+ request.add_header("Authorization", "Basic %s" % base64string)
+ return urllib2.urlopen(request)
def GetCapabilities(self, options):
"""!Get capabilities from WMS server
cap = self._fetchCapabilities(options)
- csfile = options['csfile'].strip()
+ capfile_output = options['capfile_output'].strip()
# save to file
- if csfile:
+ if capfile_output:
try:
- temp = open(csfile, "w")
+ temp = open(capfile_output, "w")
temp.write(cap.read())
temp.close()
return
@@ -505,7 +515,7 @@
props = {}
props['ignored_flags'] = ['o']
- props['ignored_params'] = ['bgcolor', 'styles', 'csfile',
+ props['ignored_params'] = ['bgcolor', 'styles', 'capfile_output',
'format', 'srs', 'wms_version']
props['req_multiple_layers'] = False
@@ -514,7 +524,7 @@
def _WMSProperties(self):
props = {}
- props['ignored_params'] = ['cfile']
+ props['ignored_params'] = ['capfile']
props['ignored_flags'] = []
props['req_multiple_layers'] = True
@@ -533,7 +543,7 @@
props = {}
- props['ignored_params'] = ['urlparams', 'bgcolor', 'cfile', 'csfile',
+ props['ignored_params'] = ['urlparams', 'bgcolor', 'capfile', 'capfile_output',
'username', 'password']
Modified: grass-addons/grass7/raster/r.in.wms2/wms_cap_parsers.py
--- grass-addons/grass7/raster/r.in.wms2/wms_cap_parsers.py 2012-12-22 15:38:11 UTC (rev 54367)
+++ grass-addons/grass7/raster/r.in.wms2/wms_cap_parsers.py 2012-12-22 23:27:15 UTC (rev 54368)
@@ -1,5 +1,5 @@
- at brief Parsers for WMS capabilities files.
+ at brief Parsers for WMS/WMTS/NASA OnEarth capabilities files.
List of classes:
- wms_cap_parsers::BaseCapabilitiesTree
@@ -22,7 +22,7 @@
class BaseCapabilitiesTree(etree.ElementTree):
def __init__(self, cap_file):
- """!Initializes xml.etree.ElementTree
+ """!Initialize xml.etree.ElementTree
try:
etree.ElementTree.__init__(self, file = cap_file)
@@ -94,14 +94,14 @@
self._checkFormats(capability)
self._checkLayerTree(root_layer)
- grass.debug('Checking of WMS capabilities tree was finished.', 4)
+ grass.debug('Check of WMS capabilities tree was finished.', 4)
def _checkFormats(self, capability):
"""!Check if format element is defined.
request = self._find(capability, "Request")
get_map = self._find(request, "GetMap")
- self._find(get_map, "Format")
+ formats = self._findall(get_map, "Format")
def _checkLayerTree(self, parent_layer, first = True):
"""!Recursively check layer tree and manage inheritance in the tree
@@ -145,7 +145,7 @@
self._inhNotSame(self.proj_tag, "element_content", layer, parent_layer)
self._inhNotSame("BoundingBox", "attribute", layer, parent_layer, self.proj_tag)
- #remove invalid Styles
+ # remove invalid Styles
styles = layer.findall(self.xml_ns.Ns('Style'))
for s in styles:
s_name = s.find(self.xml_ns.Ns('Name'))
@@ -160,9 +160,9 @@
"""Inherit elements which have unique values.
@param element_name - name of inherited element
- @param cmp_type - 'element_content' - the value is text of <Layer> element
- @param cmp_type - 'child_element_content' - the value is text of a child of the <Layer> element
- @param cmp_type - 'attribute' - the value is text of the <Layer> element attribute
+ @param cmp_type - 'element_content' - compared value is text of <Layer> element
+ @param cmp_type - 'child_element_content' - compared value is text of a child of the <Layer> element
+ @param cmp_type - 'attribute' - compared value is text of the <Layer> element attribute
@param layer - <Layer> element which inherits
@param parent_layer - <Layer> element which is inherited from
@param add_arg - name of child element or attribute
@@ -174,7 +174,7 @@
parent_elems = parent_layer.findall(self.xml_ns.Ns(element_name))
for par_elem in parent_elems:
- parent_cmp_text = ""
+ parent_cmp_text = None
if cmp_type == "attribute":
if add_arg in par_elem.attrib:
parent_cmp_text = par_elem.attrib[add_arg];
@@ -183,9 +183,11 @@
parent_cmp_text = par_elem.text
elif cmp_type == "child_element_content":
- parent_cmp_text = par_elem.find(self.xml_ns.Ns(add_arg)).text
+ parent_cmp = par_elem.find(self.xml_ns.Ns(add_arg))
+ if parent_cmp is not None:
+ parent_cmp_text = parent_cmp.text
- if parent_cmp_text == "":
+ if parent_cmp_text is None:
continue
is_there = False
@@ -199,9 +201,12 @@
cmp_text = elem.text
- cmp_text = elem.find(self.xml_ns.Ns(add_arg)).text
+ cmp = elem.find(self.xml_ns.Ns(add_arg))
+ if cmp is not None:
+ cmp_text = cmp.text
- if cmp_text.lower() == parent_cmp_text.lower():
+ if cmpt_text is None or \
+ cmp_text.lower() == parent_cmp_text.lower():
is_there = True
break
@@ -283,7 +288,6 @@
self._findall(contents, 'TileMatrixSet', self.xml_ns.NsWmts)
layers = self._findall(contents, 'Layer', self.xml_ns.NsWmts)
for l in layers:
if not self._checkLayer(l):
grass.debug('Removed invalid <Layer> element.', 4)
@@ -292,7 +296,7 @@
# are there any <Layer> elements after the check
- grass.debug('Checking WMTS capabilities tree was finished.', 4)
+ grass.debug('Check of WMTS capabilities tree was finished.', 4)
def _checkMatSet(self, mat_set):
"""!Check <TileMatrixSet>.
@@ -303,16 +307,9 @@
mat_set_srs = mat_set.find(self.xml_ns.NsOws('SupportedCRS'))
if mat_set_srs is None or \
- not mat_set_srs.text or \
- len(mat_set_srs.text) < 6 or \
- not mat_set_srs.text.lower()[:5] == ("epsg:"):
+ not mat_set_srs.text:
return False
- try:
- int(mat_set_srs.text[5:])
- except ValueError:
- return False
tile_mats = mat_set.findall(self.xml_ns.NsWmts('TileMatrix'))
if not tile_mats:
return False
@@ -373,7 +370,6 @@
def _checkLayer(self, layer):
"""!Check <Layer> element.
- contents = self.getroot().find(self.xml_ns.NsWmts('Contents'))
layer_id = layer.find(self.xml_ns.NsOws('Identifier'))
if layer_id is None or not layer_id.text:
return False
@@ -392,42 +388,51 @@
grass.debug('Removed invalid <Style> element.', 4)
layer.remove(s_name)
- tileMatrixSets = contents.findall(self.xml_ns.NsWmts('TileMatrixSet'))
+ contents = self.getroot().find(self.xml_ns.NsWmts('Contents'))
+ mat_sets = contents.findall(self.xml_ns.NsWmts('TileMatrixSet'))
for link in mat_set_links:
- found = False
- mat_set_link_id = link.find(self.xml_ns.NsWmts('TileMatrixSet')).text
+ # <TileMatrixSetLink> does not point to existing <TileMatrixSet>
+ if not self._checkMatSetLink(link, mat_sets):
+ grass.debug('Removed invalid <TileMatrixSetLink> element.', 4)
+ layer.remove(link)
- for mat_set in tileMatrixSets:
- mat_set_id = mat_set.find(self.xml_ns.NsOws('Identifier')).text
+ return True
- if mat_set_id != mat_set_link_id:
- continue
+ def _checkMatSetLink(self, link, mat_sets):
+ """!Check <TileMatrixSetLink> element.
+ mat_set_link_id = link.find(self.xml_ns.NsWmts('TileMatrixSet')).text
+ found = False
- # the link points to existing <TileMatrixSet>
- found = True
+ for mat_set in mat_sets:
+ mat_set_id = mat_set.find(self.xml_ns.NsOws('Identifier')).text
- tile_mat_set_limits = link.find(self.xml_ns.NsWmts('TileMatrixSetLimits'))
- if tile_mat_set_limits is None:
- continue
+ if mat_set_id != mat_set_link_id:
+ continue
- tile_mat_limits = tile_mat_set_limits.findall(self.xml_ns.NsWmts('TileMatrixLimits'))
- for limit in tile_mat_limits:
- if not self._checkMatSetLimit(limit):
- grass.debug('Removed invalid <TileMatrixLimits> element.', 4)
- tile_mat_limits.remove(limit)
+ # the link points to existing <TileMatrixSet>
+ found = True
- # are there any <TileMatrixLimits> elements after the check
- if not tile_mat_limits:
- grass.debug('Removed invalid <TileMatrixSetLimits> element.', 4)
- link.remove(tile_mat_set_limits)
+ tile_mat_set_limits = link.find(self.xml_ns.NsWmts('TileMatrixSetLimits'))
+ if tile_mat_set_limits is None:
+ continue
- # TileMatrixSetLink does not point to existing <TileMatrixSet>
- if not found:
- grass.debug('Removed invalid <Layer> element.', 4)
- layer.remove(link)
+ tile_mat_limits = tile_mat_set_limits.findall(self.xml_ns.NsWmts('TileMatrixLimits'))
+ for limit in tile_mat_limits:
+ if not self._checkMatSetLimit(limit):
+ grass.debug('Removed invalid <TileMatrixLimits> element.', 4)
+ tile_mat_limits.remove(limit)
+ # are there any <TileMatrixLimits> elements after the check
+ if not tile_mat_limits:
+ grass.debug('Removed invalid <TileMatrixSetLimits> element.', 4)
+ link.remove(tile_mat_set_limits)
+ if not found:
+ return False
return True
def _checkMatSetLimit(self, limit):
@@ -484,7 +489,7 @@
class OnEarthCapabilitiesTree(BaseCapabilitiesTree):
- """!Parses NASA OnEarth tile service file.
+ """!Parse NASA OnEarth tile service file.
If the file cannot be parsed it raises xml.etree.ElementTree.ParseError.
The class also removes elements which are in invalid form and are needed
@@ -492,20 +497,19 @@
@param cap_file - capabilities file
- #TODO check also TilePattern urls
BaseCapabilitiesTree.__init__(self, cap_file)
grass.debug('Checking OnEarth capabilities tree.', 4)
self._checkLayerTree(self.getroot())
- grass.debug('Checking OnEarth capabilities tree was finished.', 4)
+ grass.debug('Check if OnEarth capabilities tree was finished.', 4)
"""!Recursively check layer tree.
if first:
- tiled_patterns = self.find(parent_layer, 'TiledPatterns')
+ tiled_patterns = self._find(parent_layer, 'TiledPatterns')
layers = tiled_patterns.findall('TiledGroup')
layers += tiled_patterns.findall('TiledGroups')
parent_layer = tiled_patterns
@@ -520,7 +524,7 @@
if l.tag == 'TiledGroups':
self._checkLayerTree(l, False)
- def find(self, etreeElement, tag):
+ def _find(self, etreeElement, tag):
"""!Find child element.
If the element is not found it raises xml.etree.ElementTree.ParseError.
@@ -532,18 +536,6 @@
return res
- def findall(self, etreeElement, tag):
- """!Find all children element.
- If no element is found it raises xml.etree.ElementTree.ParseError.
- res = etreeElement.findall(tag)
- if not res:
- raise etree.ParseError(_("Unable to parse tile service file. \n\
- Tag <%s> was not found.") % tag)
- return res
"""!Check <TiledGroup>/<TiledGroups> elements.
@@ -556,9 +548,88 @@
t_patts = layer.findall('TilePattern')
+ for patt in t_patts:
+ urls = self._getUrls(patt)
+ for url in urls:
+ if not self.gettilepatternurldata(url):
+ urls.remove(url)
+ # check if there are any vaild urls
+ if not urls:
+ grass.debug('<TilePattern> was removed. It has no valid url.', 4)
+ layer.remove(patt)
+ patt.text = '\n'.join(urls)
+ t_patts = layer.findall('TilePattern')
if not t_patts:
return False
return True
+ def _getUrls(self, tile_pattern):
+ """!Get all urls from tile pattern.
+ urls = []
+ if tile_pattern.text is not None:
+ tile_patt_lines = tile_pattern.text.split('\n')
+ for line in tile_patt_lines:
+ if 'request=GetMap' in line:
+ urls.append(line.strip())
+ return urls
+ def gettilepatternurldata(self, url):
+ """!Parse url string in Tile Pattern.
+ par_url = bbox = width = height = None
+ bbox_idxs = self.geturlparamidxs(url, "bbox=")
+ if bbox_idxs is None:
+ return None
+ par_url = [url[:bbox_idxs[0] - 1], url[bbox_idxs[1]:]]
+ bbox = url[bbox_idxs[0] + len('bbox=') : bbox_idxs[1]]
+ bbox_list = bbox.split(',')
+ if len(bbox_list) < 4:
+ return None
+ try:
+ bbox = map(float, bbox.split(','))
+ except ValueError:
+ return None
+ width_idxs = self.geturlparamidxs(url, "width=")
+ if width_idxs is None:
+ return None
+ try:
+ width = int(url[width_idxs[0] + len('width=') : width_idxs[1]])
+ return None
+ height_idxs = self.geturlparamidxs(url, "height=")
+ if height_idxs is None:
+ return None
+ try:
+ height = int(url[height_idxs[0] + len('height=') : height_idxs[1]])
+ return None
+ if height < 0 or width < 0:
+ return None
+ return par_url, bbox, width, height
+ def geturlparamidxs(self, params_str, param_key):
+ """!Find start and end index of parameter and it's value in url string
+ start_i = params_str.lower().find(param_key)
+ if start_i < 0:
+ return None
+ end_i = params_str.find("&", start_i)
+ if end_i < 0:
+ end_i = len(params_str)
+ return (start_i, end_i)
\ No newline at end of file
Modified: grass-addons/grass7/raster/r.in.wms2/wms_drv.py
--- grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-12-22 15:38:11 UTC (rev 54367)
+++ grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-12-22 23:27:15 UTC (rev 54368)
@@ -17,9 +17,6 @@
-import base64
-from httplib import HTTPException
try:
from osgeo import gdal
@@ -27,13 +24,14 @@
except:
grass.fatal(_("Unable to load GDAL python bindings"))
-import urllib2
-from xml.etree.ElementTree import ParseError
import numpy as Numeric
Numeric.arrayrange = Numeric.arange
from math import pi, floor
+from urllib2 import HTTPError
+from httplib import HTTPException
+from xml.etree.ElementTree import ParseError
from wms_base import WMSBase
from wms_cap_parsers import WMTSCapabilitiesTree, OnEarthCapabilitiesTree
@@ -46,10 +44,10 @@
grass.message(_("Downloading data from WMS server..."))
- if not self.params['cfile']:
+ if not self.params['capfile']:
self.cap_file = self._fetchCapabilities(self.params)
else:
- self.cap_file = self.params['cfile']
+ self.cap_file = self.params['capfile']
# initialize correct manager according to chosen OGC service
if self.params['driver'] == 'WMTS_GRASS':
@@ -80,18 +78,14 @@
# the tile size and offset in pixels for placing it into raster where tiles are joined
tile_ref = tile[1]
- grass.debug(query_url)
+ grass.debug(query_url, 2)
try:
- request = urllib2.Request(query_url)
- if self.params['username']:
- base64string = base64.encodestring('%s:%s' % (self.params['username'], self.params['password'])).replace('\n', '')
- request.add_header("Authorization", "Basic %s" % base64string)
- wms_data = urllib2.urlopen(request)
+ wms_data = self._fetchDataFromServer(query_url, self.params['username'], self.params['password'])
if HTTPError == type(e) and e.code == 401:
- grass.fatal(_("Authorization failed"))
+ grass.fatal(_("Authorization failed to '%s' when fetching data.") % self.params['url'])
else:
- grass.fatal(_("Unable to fetch data from server"))
+ grass.fatal(_("Unable to fetch data from: '%s'") % self.params['url'])
temp_tile = self._tempfile()
@@ -441,6 +435,8 @@
# parse capabilities file
try:
+ # checks all elements needed by this class,
+ # invalid elements are removed
cap_tree = WMTSCapabilitiesTree(cap_file)
except ParseError as error:
grass.fatal(_("Unable to parse tile service file.\n%s\n") % str(error))
@@ -649,11 +645,13 @@
"""!Initializes data needed for iteration through tiles.
try:
- cap_tree = OnEarthCapabilitiesTree(tile_service)
+ self.cap_tree = OnEarthCapabilitiesTree(tile_service)
- root = cap_tree.getroot()
+ root = self.cap_tree.getroot()
# parse tile service file and get needed data for making tile requests
url, self.tile_span, t_patt_bbox, self.tile_size = self._parseTileService(root, bbox, region, params)
@@ -688,10 +686,7 @@
group_t_patts = req_group.findall('TilePattern')
best_patt = self._parseTilePattern(group_t_patts, bbox, region)
- if best_patt is None:
- grass.fatal("Unable to parse any url in '%s' of %s '%s'" % ('TilePattern', params['layers'], 'TiledGroup'))
- urls = self._getUrls(best_patt)
+ urls = best_patt.text.split('\n')
if params['urlparams']:
url = self._insTimeToTilePatternUrl(params['urlparams'], urls)
else:
@@ -700,7 +695,7 @@
if not 'time=${' in u:
url = u
- url, t_bbox, width, height = self._parseUrl(url)
+ url, t_bbox, width, height = self.cap_tree.gettilepatternurldata(url)
tile_span = {}
tile_span['x'] = abs(t_bbox[0] - t_bbox[2])
tile_span['y'] = abs(t_bbox[1] - t_bbox[3])
@@ -745,16 +740,8 @@
t_res = {}
best_patt = None
for pattern in group_t_patts:
- urls = self._getUrls(pattern)
- if not urls:
- continue
+ url, t_bbox, width, height = self.cap_tree.gettilepatternurldata(pattern.text.split('\n')[0])
- ret = self._parseUrl(urls[0])
- if not ret:
- continue
- url, t_bbox, width, height = ret
t_res['x'] = abs(t_bbox[0] - t_bbox[2]) / width
t_res['y'] = abs(t_bbox[1] - t_bbox[3]) / height
@@ -775,44 +762,6 @@
return best_patt
- def _getUrls(self, tile_pattern):
- """!Get all urls from tile pattern.
- urls = []
- if tile_pattern.text is not None:
- tile_patt_lines = tile_pattern.text.split('\n')
- for line in tile_patt_lines:
- if 'request=GetMap' in line:
- urls.append(line.strip())
- return urls
- def _parseUrl(self, url):
- """!Parse url string in Tile Pattern.
- par_url = bbox = width = height = None
- bbox_idxs = self._getParameterIdxs(url, "bbox=")
- if bbox_idxs is None:
- return None
- par_url = [url[:bbox_idxs[0] - 1], url[bbox_idxs[1]:]]
- bbox = url[bbox_idxs[0] + len('bbox=') : bbox_idxs[1]]
- bbox = map(float, bbox.split(','))
- width_idxs = self._getParameterIdxs(url, "width=")
- if width_idxs is None:
- return None
- width = int(url[width_idxs[0] + len('width=') : width_idxs[1]])
- height_idxs = self._getParameterIdxs(url, "height=")
- if height_idxs is None:
- return None
- height = int(url[height_idxs[0] + len('height=') : height_idxs[1]])
- return par_url, bbox, width, height
def _insTimeToTilePatternUrl(self, url_params, urls):
"""!Time can be variable in some urls in OnEarth TMS.
Insert requested time from 'urlparams' into the variable if any url of urls contains the variable.
@@ -834,7 +783,7 @@
has_time_var = False
for url in urls:
- url_p_idxs = self._getParameterIdxs(url, k)
+ url_p_idxs = self.geturlparamidxs(url, k)
if not url_p_idxs:
continue
@@ -855,18 +804,6 @@
return url
- def _getParameterIdxs(self, params_str, param_key):
- """!Find start and end index of parameter and it's value in url string
- start_i = params_str.lower().find(param_key)
- if start_i < 0:
- return None
- end_i = params_str.find("&", start_i)
- if end_i < 0:
- end_i = len(params_str)
- return (start_i, end_i)
def _computeRequestData(self, bbox, t_patt_bbox, tile_span, tile_size):
"""!Initialize data needed for iteration through tiles.
