[GRASS-SVN] r54429 - in grass/trunk/gui/wxpython: core gui_core iclass mapdisp mapswipe
svn_grass at osgeo.org
Thu Dec 27 10:46:15 PST 2012
Author: annakrat
Date: 2012-12-27 10:46:15 -0800 (Thu, 27 Dec 2012)
New Revision: 54429
grass/trunk/gui/wxpython/core/events.py
grass/trunk/gui/wxpython/gui_core/mapdisp.py
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
grass/trunk/gui/wxpython/mapswipe/frame.py
grass/trunk/gui/wxpython/mapswipe/mapwindow.py
wxGUI: synchronize displays in wxIClass; improve implementation
Modified: grass/trunk/gui/wxpython/core/events.py
--- grass/trunk/gui/wxpython/core/events.py 2012-12-27 17:23:12 UTC (rev 54428)
+++ grass/trunk/gui/wxpython/core/events.py 2012-12-27 18:46:15 UTC (rev 54429)
@@ -30,6 +30,7 @@
from wx.lib.newevent import NewCommandEvent
+from wx.lib.newevent import NewEvent
# Notification event intended to update statusbar.
@@ -41,3 +42,5 @@
# attributes: name: map name, ltype: map type,
# add: if map should be added to layer tree (questionable attribute)
gMapCreated, EVT_MAP_CREATED = NewCommandEvent()
+gZoomChanged, EVT_ZOOM_CHANGED = NewEvent()
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py 2012-12-27 17:23:12 UTC (rev 54428)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py 2012-12-27 18:46:15 UTC (rev 54429)
@@ -25,8 +25,9 @@
import wx
import wx.aui
-from core import globalvar
-from core.debug import Debug
+from core import globalvar
+from core.debug import Debug
+from core.events import EVT_ZOOM_CHANGED
from grass.script import core as grass
@@ -468,12 +469,13 @@
self.firstMap = firstMap
self.secondMap = secondMap
self.Map = firstMap
# initialize region values
self._initMap(Map = self.firstMap)
self._initMap(Map = self.secondMap)
+ self._bindRegions = False
def _bindWindowsActivation(self):
self.GetFirstWindow().Bind(wx.EVT_ENTER_WINDOW, self.ActivateFirstMap)
@@ -514,17 +516,63 @@
return self.MapWindow
def ActivateFirstMap(self, event = None):
- """!Make first Map and MapWindow active"""
+ """!Make first Map and MapWindow active and (un)bind regions of the two Maps."""
self.Map = self.firstMap
self.MapWindow = self.firstMapWindow
self.GetMapToolbar().SetActiveMap(0)
+ # bind/unbind regions
+ if self._bindRegions:
+ self.firstMapWindow.Bind(EVT_ZOOM_CHANGED, self.OnZoomChangedFirstMap)
+ else:
+ self.firstMapWindow.Unbind(EVT_ZOOM_CHANGED)
+ self.secondMapWindow.Unbind(EVT_ZOOM_CHANGED)
def ActivateSecondMap(self, event = None):
- """!Make second Map and MapWindow active"""
+ """!Make second Map and MapWindow active and (un)bind regions of the two Maps."""
self.Map = self.secondMap
self.MapWindow = self.secondMapWindow
self.GetMapToolbar().SetActiveMap(1)
+ self.secondMapWindow.Bind(EVT_ZOOM_CHANGED, self.OnZoomChangedSecondMap)
+ else:
+ def SetBindRegions(self, on):
+ """!Set or unset binding display regions."""
+ self._bindRegions = on
+ if on:
+ if self.MapWindow == self.firstMapWindow:
+ else:
+ else:
+ def OnZoomChangedFirstMap(self, event):
+ """!Display region of the first window (Map) changed.
+ Synchronize the region of the second map and re-render it.
+ This is the default implementation which can be overridden.
+ region = self.GetFirstMap().GetCurrentRegion()
+ self.GetSecondMap().region.update(region)
+ self.Render(mapToRender = self.GetSecondWindow())
+ def OnZoomChangedSecondMap(self, event):
+ """!Display region of the second window (Map) changed.
+ region = self.GetSecondMap().GetCurrentRegion()
+ self.GetFirstMap().region.update(region)
+ self.Render(mapToRender = self.GetFirstWindow())
def OnZoomIn(self, event):
"""!Zoom in the map.
Set mouse cursor, zoombox attributes, and zoom direction
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2012-12-27 17:23:12 UTC (rev 54428)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2012-12-27 18:46:15 UTC (rev 54429)
@@ -342,7 +342,7 @@
def IsStandalone(self):
"""!Check if Map display is standalone"""
return True
def OnUpdateActive(self, event):
@todo move to DoubleMapFrame?
@@ -370,7 +370,7 @@
if mapTb.GetActiveMap() != (win == self.secondMapWindow):
mapTb.SetActiveMap((win == self.secondMapWindow))
self.StatusbarUpdate()
def GetMapToolbar(self):
"""!Returns toolbar with zooming tools"""
return self.toolbars['iClassMap']
@@ -399,6 +399,16 @@
zoommenu.AppendItem(zoomtarget)
self.Bind(wx.EVT_MENU, self.OnZoomToTraining, zoomtarget)
+ zoombind = wx.MenuItem(zoommenu, wx.ID_ANY, _("Display synchronization ON"))
+ zoommenu.AppendItem(zoombind)
+ self.Bind(wx.EVT_MENU, lambda event: self.SetBindRegions(True), zoombind)
+ zoomunbind = wx.MenuItem(zoommenu, wx.ID_ANY, _("Display synchronization OFF"))
+ zoommenu.AppendItem(zoomunbind)
+ self.Bind(wx.EVT_MENU, lambda event: self.SetBindRegions(False), zoomunbind)
+ zoomunbind.Enable(self._bindRegions)
+ zoombind.Enable(not self._bindRegions)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.PopupMenu(zoommenu)
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-12-27 17:23:12 UTC (rev 54428)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-12-27 18:46:15 UTC (rev 54429)
@@ -34,6 +34,7 @@
from core.gcmd import RunCommand, GException, GError, GMessage
from core.settings import UserSettings
+from core.events import gZoomChanged
from gui_core.mapwindow import MapWindow
try:
import grass.lib.gis as gislib
@@ -1536,6 +1537,8 @@
# update statusbar
self.frame.StatusbarUpdate()
+ wx.PostEvent(self, gZoomChanged())
def ZoomHistory(self, n, s, e, w):
"""!Manages a list of last 10 zoom extents
@@ -1565,6 +1568,8 @@
toolbar = self.frame.GetMapToolbar()
toolbar.Enable('zoomBack', enable)
return removed
Modified: grass/trunk/gui/wxpython/mapswipe/frame.py
--- grass/trunk/gui/wxpython/mapswipe/frame.py 2012-12-27 17:23:12 UTC (rev 54428)
+++ grass/trunk/gui/wxpython/mapswipe/frame.py 2012-12-27 18:46:15 UTC (rev 54429)
@@ -65,8 +65,8 @@
self.secondMapWindow = SwipeBufferedWindow(parent = self.splitter, giface = self._giface,
Map = self.secondMap, frame = self)
self.MapWindow = self.firstMapWindow # current by default
- self.firstMap.region = self.secondMap.region
self.firstMapWindow.zoomhistory = self.secondMapWindow.zoomhistory
+ self.SetBindRegions(True)
self._mode = 'swipe'
@@ -270,18 +270,6 @@
LeftDockable(True).RightDockable(True).
Right().Layer(1).BestSize((self.sliderV.GetBestSize())))
- def UpdateRegion(self):
- Rerender the second window
- when the region of the first changed.
- Debug.msg(3, "SwipeMapFrame.UpdateRegion()")
- if self.GetWindow() == self.GetSecondWindow():
- self.Render(self.GetFirstWindow())
- else:
- self.Render(self.GetSecondWindow())
def ZoomToMap(self):
Set display extents to match selected raster (including NULLs)
@@ -291,8 +279,6 @@
self.GetFirstWindow().ZoomToMap(layers = self.firstMap.GetListOfLayers())
if self.rasters['second']:
self.GetSecondWindow().ZoomToMap(layers = self.secondMap.GetListOfLayers())
- # needed again, don't know why
def OnZoomToMap(self, event):
"""!Zoom to map"""
Modified: grass/trunk/gui/wxpython/mapswipe/mapwindow.py
--- grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2012-12-27 17:23:12 UTC (rev 54428)
+++ grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2012-12-27 18:46:15 UTC (rev 54429)
@@ -113,16 +113,6 @@
if not self.movingSash:
super(SwipeBufferedWindow, self).OnSize(event)
- def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
- super(SwipeBufferedWindow, self).ZoomToMap(layers, ignoreNulls, render)
- self.frame.UpdateRegion()
- def ZoomBack(self):
- """!Zoom last (previously stored position)
- super(SwipeBufferedWindow, self).ZoomBack()
def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0, 0, 0, 0]):
"""!Draws image (map) with translated coordinates.
@@ -180,17 +170,6 @@
'rotation': 0, 'text': name,
'active': True}
- def MouseActions(self, event):
- """!Handle mouse events and if needed let parent frame know"""
- super(SwipeBufferedWindow, self).MouseActions(event)
- if event.GetWheelRotation() != 0 or \
- event.LeftUp() or \
- event.MiddleUp():
- event.Skip()
def MouseDraw(self, pdc = None, begin = None, end = None):
"""!Overriden method to recompute coordinates back to original values
so that e.g. drawing of zoom box is done properly"""
