[GRASS-SVN] r54430 - grass/trunk/gui/wxpython/iclass
Thu Dec 27 12:41:13 PST 2012
Author: annakrat
Date: 2012-12-27 12:41:13 -0800 (Thu, 27 Dec 2012)
New Revision: 54430
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/iclass/toolbars.py
wxGUI/iclass: add RGB layer
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2012-12-27 18:46:15 UTC (rev 54429)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2012-12-27 20:41:13 UTC (rev 54430)
@@ -1124,6 +1124,23 @@
         self.toolbar.choice.Insert(name, 0)
         self.toolbar.choice.SetSelection(0)
+    def AddLayerRGB(self, cmd):
+        """!Adds RGB layer and update toolbar.
+        @param cmd d.rgb command as a list
+        name = []
+        for param in cmd:
+            if '=' in param:
+                name.append(param.split('=')[1])
+        name = ','.join(name)
+        self.map.AddLayer(type = 'rgb', command = cmd, l_active = True,
+                          name = name, l_hidden = False, l_opacity = 1.0, l_render = True)
+        self.frame.Render(self.mapWindow)
+        self.layerName[name] = name
+        self.toolbar.choice.Insert(name, 0)
+        self.toolbar.choice.SetSelection(0)
     def RemoveTemporaryLayer(self, name):
         """!Removes temporary layer (if exists) from Map and and updates toolbar.
@@ -1169,7 +1186,8 @@
     def SelectLayer(self, name):
         """!Moves selected layer to top"""
-        layers = self.map.GetListOfLayers(l_type = 'raster')
+        layers = self.map.GetListOfLayers(l_type = 'raster') + \
+                 self.map.GetListOfLayers(l_type = 'rgb')
         idx = None
         for i, layer in enumerate(layers):
             if self.layerName[name] == layer.GetName():
Modified: grass/trunk/gui/wxpython/iclass/toolbars.py
--- grass/trunk/gui/wxpython/iclass/toolbars.py	2012-12-27 18:46:15 UTC (rev 54429)
+++ grass/trunk/gui/wxpython/iclass/toolbars.py	2012-12-27 20:41:13 UTC (rev 54430)
@@ -23,6 +23,7 @@
 from gui_core.toolbars import BaseToolbar, BaseIcons
 from icons.icon import MetaIcon
 from iclass.dialogs import IClassMapDialog
+from gui_core.forms import GUI
 import grass.script as grass
@@ -43,6 +44,8 @@
                             label = _('Export training areas')),
         'importAreas' : MetaIcon(img = 'layer-import',
                             label = _('Import training areas')),
+        'addRgb' : MetaIcon(img = 'layer-rgb-add',
+                            label = _('Add RGB map layer')),
 class IClassMapToolbar(BaseToolbar):
@@ -250,10 +253,12 @@
         """!Toolbar data"""
         return self._getToolbarData((("addRast", BaseIcons['addRast'],
                                       self.OnAddRast),
-                                      ("delRast", iClassIcons['delCmd'],
-                                      self.OnDelRast),
-                                      ("setOpacity", iClassIcons['opacity'],
-                                      self.OnSetOpacity),
+                                     ('addRgb', iClassIcons['addRgb'],
+                                      self.OnAddRGB),
+                                     ("delRast", iClassIcons['delCmd'],
+                                     self.OnDelRast),
+                                     ("setOpacity", iClassIcons['opacity'],
+                                     self.OnSetOpacity),
     def OnSelectLayer(self, event):
@@ -269,6 +274,14 @@
         dlg.Destroy()
+    def OnAddRGB(self, event):
+        cmd = ['d.rgb']
+        GUI(parent = self.parent).ParseCommand(cmd, completed = (self.GetOptData, '', ''))
+    def GetOptData(self, dcmd, layer, params, propwin):
+        if dcmd:
+            self.mapManager.AddLayerRGB(cmd = dcmd)
     def OnDelRast(self, event):
         layer = self.choice.GetStringSelection()
         idx = self.choice.GetSelection()
