[GRASS-SVN] r54469 - grass/trunk/scripts/v.in.geonames
svn_grass at osgeo.org
Sun Dec 30 09:23:10 PST 2012
Author: martinl
Date: 2012-12-30 09:23:10 -0800 (Sun, 30 Dec 2012)
New Revision: 54469
grass/trunk/scripts/v.in.geonames/v.in.geonames.html
grass/trunk/scripts/v.in.geonames/v.in.geonames.py
v.geonames: update manual page, add example
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.html
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.html 2012-12-30 14:15:48 UTC (rev 54468)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.html 2012-12-30 17:23:10 UTC (rev 54469)
@@ -1,23 +1,34 @@
<h2>DESCRIPTION</h2>
-<em>v.in.geonames</em> imports Geonames.org country
-files (Gazetteer data) into a GRASS vector points map. The country files
-can be downloaded from the
-<a href="http://download.geonames.org/export/dump/">GeoNames Data Dump Server</a>.
-The script generates a vector point map. Only original files can be processed
-(unzip compressed file first). These Geonames files are encoded in UTF-8 which
-is maintained in the GRASS database.
+<em>v.in.geonames</em> imports Geonames.org country files (Gazetteer
+data) into a GRASS vector points map. The country files can be
+downloaded from the
+<a href="http://download.geonames.org/export/dump/">GeoNames Data Dump
+Server</a>. Only original files can be processed (unzip compressed
+file first). These Geonames files are encoded in UTF-8 which is
+maintained in the GRASS database.
<h2>NOTES</h2>
-The current DB connection is used to write the database table.
-<p>If importing into a DBF database, the original column names longer that 10 characters
-are shortened to 10 characters to meet the DBF column name restrictions. If this is a
-problem consider choosing another database driver with <em>db.connect</em>.
+<p>
+calls <em><a href="v.in.ascii.html">v.in.ascii</a></em> to import data
+into GRASS.
+<p>
+The current DB connection is used to write the database table
+(see <em><a href="db.connect.html">db.connect</a></em>). If importing
+into a <a href="grass-dbf.html">DBF database</a>, the original column
+names longer that 10 characters are shortened to 10 characters to meet
+the DBF column name restrictions. If this is a problem consider
+choosing another database driver
+with <em><a href="db.connect.html">db.connect</a></em>
+(eg. to <a href="grass-sqlite.html">SQLite driver</a>).
+<p>
The main 'geoname' table has the following fields
-<pre>
+<div class="code"><pre>
geonameid : integer id of record in geonames database
name : name of geographical point (utf8) varchar(200)
asciiname : name of geographical point in plain ascii characters, varchar(200)
@@ -37,23 +48,37 @@
gtopo30 : average elevation of 30'x30' (ca 900mx900m) area in meters, integer
timezone : the timezone id (see file http://download.geonames.org/export/dump/timeZones.txt)
modification date : date of last modification in yyyy-MM-dd format
-</pre>
+</pre></div>
+<h2>EXAMPLE</h2>
+Download and import geonames for Czech Republic.
+wget http://download.geonames.org/export/dump/CZ.zip
+unzip CZ.zip
+v.in.geonames input=CZ.txt output=geonames_cz
+</pre></div>
+<h2>REFERENCES</h2>
+<ul>
+ <li><a href="http://www.geonames.org">GeoNames Web site</a></li>
+ <li><a href="http://download.geonames.org/export/dump/">GeoNames Data Dump Server</a></li>
+</ul>
<h2>SEE ALSO</h2>
<em>
-<a href="db.connect.html">db.connect</a>,
-<a href="v.select.html">v.select</a>
+ <a href="db.connect.html">db.connect</a>,
+ <a href="v.in.ascii.html">v.in.ascii</a>,
+ <a href="v.select.html">v.select</a>
</em>
-<h2>REFERENCES</h2>
-<a href="http://www.geonames.org">GeoNames Web site</a><br>
<h2>AUTHOR</h2>
<a href="http://www.grassbook.org/">Markus Neteler</a>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2012-12-30 14:15:48 UTC (rev 54468)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2012-12-30 17:23:10 UTC (rev 54469)
@@ -62,8 +62,8 @@
if dbfdriver:
grass.warning(_("Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content"))
- #let's go
- #change TAB to vertical bar
+ # let's go
+ # change TAB to vertical bar
num_places = 0
inf = file(infile)
outf = file(tmpfile, 'wb')
@@ -75,7 +75,7 @@
outf.close()
inf.close()
- grass.message(_("Converted %d place names.") % num_places)
+ grass.message(_("Converting %d place names...") % num_places)
# pump data into GRASS:
# http://download.geonames.org/export/dump/readme.txt
