[GRASS-SVN] r54470 - in grass/branches/releasebranch_6_4/raster: r.cost r.walk
Mon Dec 31 04:29:35 PST 2012
Author: mmetz
Date: 2012-12-31 04:29:35 -0800 (Mon, 31 Dec 2012)
New Revision: 54470
   grass/branches/releasebranch_6_4/raster/r.cost/description.html
   grass/branches/releasebranch_6_4/raster/r.cost/main.c
   grass/branches/releasebranch_6_4/raster/r.cost/stash.h
   grass/branches/releasebranch_6_4/raster/r.walk/description.html
   grass/branches/releasebranch_6_4/raster/r.walk/main.c
   grass/branches/releasebranch_6_4/raster/r.walk/stash.h
r.cost / r.walk: backport direction output
Modified: grass/branches/releasebranch_6_4/raster/r.cost/description.html
--- grass/branches/releasebranch_6_4/raster/r.cost/description.html	2012-12-30 17:23:10 UTC (rev 54469)
+++ grass/branches/releasebranch_6_4/raster/r.cost/description.html	2012-12-31 12:29:35 UTC (rev 54470)
@@ -6,11 +6,13 @@
 other user-specified cell(s) whose locations are specified by their
 geographic coordinate(s). Each cell in the original cost surface map
 will contain a category value which represents the cost of traversing
-that cell. <em>r.cost</em> will produce an <b>output</b> raster map in
+that cell. <em>r.cost</em> will produce 1) an <b>output</b> raster map in
 which each cell contains the lowest total cost of traversing the
-space between each cell and the user-specified points. (Diagonal
+space between each cell and the user-specified points (diagonal
 costs are multiplied by a factor that depends on the dimensions of
-the cell.) This program uses the current geographic region settings.
+the cell) and 2) a second raster map layer showing the movement
+direction to the next cell on the path back to the start point (see
+<a href="#move">Movement Direction</a>). This program uses the current geographic region settings.
 The <b>output</b> map will be of the same data format as the <b>input</b>
 map, integer or floating point.
@@ -18,7 +20,8 @@
 The <b>input</b> <em>name</em> is the name of a raster map whose category values
 represent the surface cost. The <b>output</b> <em>name</em> is the name of the
-resultant raster map of cumulative cost.
+resultant raster map of cumulative cost. The <b>outdir</b> <em>name</em> is the
+name of the resultant raster map of movement directions (see <a href="#move">Movement Direction</a>).
 <p>
 <em>r.cost</em> can be run with three different methods of identifying the
@@ -203,11 +206,11 @@
 The output map can be viewed, for example, as an elevation model in which
 the starting location(s) is/are the lowest point(s). Outputs from  <em>r.cost</em>
-can be used as inputs to <em><a href="r.drain.html">r.drain</a></em>, in order
-to trace the least-cost path given by this model between any given cell
-and the <em>r.cost</em> starting location(s). The two programs, when
-used together, generate least-cost paths or corridors between any two
-map locations (cells).
+can be used as inputs to <em><a href="r.drain.html">r.drain</a></em> with
+the direction flag <b>-d</b>, in order to trace the least-cost path given by this
+model between any given cell and the <em>r.cost</em> starting location(s). The
+two programs, when used together, generate least-cost paths or corridors between any
+two map locations (cells).
 <h3>Shortest distance surfaces</h3>
 The <em>r.cost</em> module allows for computing the shortest distance
@@ -228,6 +231,26 @@
   d.rast dist_meters
 </pre></div>
+<a name="move"></a>
+<h2>Movement Direction</h2>
+<p>
+The movement direction surface is created to record the sequence of
+movements that created the cost accumulation surface. Without it
+<em>r.drain</em> would not correctly create a path from an end point
+back to the start point. The direction shown in each cell points <b>away</b>
+from the cell that came before it. The directions are recorded as
+GRASS standard directions:<div class="code"><pre>
+       112.5 90  67.5         i.e. a cell with the value 135
+157.5  135   0   45   22.5    means the cell <b>before</b> it is
+       180   x   0            to the south-east.
+202.5  225  270  315  337.5
+       247.5     292.5
+</pre></div>
+<p>
+Once <em>r.cost</em> computes the cumulative cost map, <em>r.drain</em>
+can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
+and the movement direction raster map when running r.drain to ensure
+the path is computed according to the proper movement directions.
 <h2>BUGS</h2>
Modified: grass/branches/releasebranch_6_4/raster/r.cost/main.c
--- grass/branches/releasebranch_6_4/raster/r.cost/main.c	2012-12-30 17:23:10 UTC (rev 54469)
+++ grass/branches/releasebranch_6_4/raster/r.cost/main.c	2012-12-31 12:29:35 UTC (rev 54470)
@@ -8,6 +8,9 @@
  *               Pierre de Mouveaux <pmx audiovu com>
  *               Eric G. Miller <egm2 jps net>
+ *               Updated for calculation errors and directional surface generation
+ *                 Colin Nielsen <colin.nielsen gmail com>
  * PURPOSE:      Outputs a raster map layer showing the cumulative cost
  *               of moving between different geographic locations on an
  *               input raster map layer whose cell category values
@@ -72,25 +75,26 @@
 int main(int argc, char *argv[])
-    void *cell, *cell2;
-    SEGMENT in_seg, out_seg;
-    char *cost_mapset;
-    char *in_file, *out_file;
+    void *cell, *cell2, *dir_cell;
+    SEGMENT in_seg, out_seg, out_seg2;
+    char *cost_mapset, *move_dir_mapset;
+    char *in_file, *out_file, *dir_out_file;
     char *search_mapset;
     double *value;
     extern struct Cell_head window;
     double NS_fac, EW_fac, DIAG_fac, H_DIAG_fac, V_DIAG_fac;
     double fcost;
     double min_cost, old_min_cost;
+    double cur_dir, old_cur_dir;
     double zero = 0.0;
     int at_percent = 0;
     int col, row, nrows, ncols;
     int maxcost;
     int maxmem;
     double cost;
-    int cost_fd, cum_fd;
-    int have_stop_points = 0;
-    int in_fd, out_fd;
+    int cost_fd, cum_fd, dir_fd;
+    int have_stop_points = 0, dir = 0;
+    int in_fd, out_fd, dir_out_fd;
     double my_cost;
     double null_cost;
     int srows, scols;
@@ -104,13 +108,13 @@
     struct GModule *module;
     struct Flag *flag2, *flag3, *flag4;
     struct Option *opt1, *opt2, *opt3, *opt4, *opt5, *opt6, *opt7, *opt8;
-    struct Option *opt9, *opt10;
+    struct Option *opt9, *opt10, *opt11;
     struct cost *pres_cell, *new_cell;
     struct start_pt *pres_start_pt = NULL;
     struct start_pt *pres_stop_pt = NULL;
     void *ptr2;
-    RASTER_MAP_TYPE data_type;
+    RASTER_MAP_TYPE data_type, dir_data_type = DCELL_TYPE;
     struct History history;
     double peak = 0.0;
     int dsize;
@@ -134,6 +138,14 @@
     opt1 = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt11 = G_define_option();
+    opt11->key = "outdir";
+    opt11->type = TYPE_STRING;
+    opt11->required = NO;
+    opt11->gisprompt = "new,cell,raster";
+    opt11->description =
+	_("Name of output raster map to contain movement directions");
     opt7 = G_define_standard_option(G_OPT_V_INPUT);
     opt7->key = "start_points";
     opt7->required = NO;
@@ -227,10 +239,16 @@
 		    "in future. Please use '--verbose' instead."));
+    /* If no outdir is specified, set flag to skip all dir */
+    if (opt11->answer != NULL)
+	dir = 1;
     /* Initalize access to database and create temporary files */
     in_file = G_tempfile();
     out_file = G_tempfile();
+    if (dir == 1)
+	dir_out_file = G_tempfile();
     /*  Get database window parameters      */
@@ -321,11 +339,23 @@
     if (cost_mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), cost_layer);
+    if (dir == 1) {
+	strcpy(move_dir_layer, opt11->answer);
+	search_mapset = "";
+	move_dir_mapset = G_find_cell2(move_dir_layer, search_mapset);
     /*  Check if specified output layer name is legal   */
     if (G_legal_filename(cum_cost_layer) < 0)
 	G_fatal_error(_("<%s> is an illegal file name"), cum_cost_layer);
+    if (dir == 1) {
+	if (G_legal_filename(move_dir_layer) < 0)
+	    G_fatal_error(_("<%s> is an illegal file name"), move_dir_layer);
     /*  Find number of rows and columns in window    */
     nrows = G_window_rows();
@@ -379,6 +409,13 @@
     segment_format(out_fd, nrows, ncols, srows, scols, sizeof(double));
     close(out_fd);
+    if (dir == 1) {
+	dir_out_fd = creat(dir_out_file, 0600);
+	segment_format(dir_out_fd, nrows, ncols, srows, scols,
+		       sizeof(double));
+	close(dir_out_fd);
     /*   Open initialize and segment all files  */
     in_fd = open(in_file, 2);
@@ -388,6 +425,11 @@
     out_fd = open(out_file, 2);
     segment_init(&out_seg, out_fd, segments_in_memory);
+    if (dir == 1) {
+	dir_out_fd = open(dir_out_file, 2);
+	segment_init(&out_seg2, dir_out_fd, segments_in_memory);
     /*   Write the cost layer in the segmented file  */
     G_message(_("Reading raster map <%s>..."),
@@ -494,6 +536,31 @@
 	G_free(fbuff);
+    if (dir == 1) {
+	G_message(_("Initializing directional output "));
+	    double *fbuff;
+	    int i;
+	    fbuff =
+		(double *)G_malloc((unsigned int)(ncols * sizeof(double)));
+	    G_set_d_null_value(fbuff, ncols);
+	    for (row = 0; row < nrows; row++) {
+		    G_percent(row, nrows, 2);
+		for (i = 0; i < ncols; i++) {
+		    segment_put(&out_seg2, &fbuff[i], row, i);
+	    G_percent(1, 1, 1);
+	    segment_flush(&out_seg2);
+	    G_free(fbuff);
     /*   Scan the start_points layer searching for starting points.
      *   Create a btree of starting points ordered by increasing costs.
@@ -721,55 +788,71 @@
 	    case 1:
 		row = pres_cell->row;
 		col = pres_cell->col - 1;
+		cur_dir = 180.0;
 		break;
 	    case 2:
 		col = pres_cell->col + 1;
+		cur_dir = 0.0;
 		break;
 	    case 3:
 		row = pres_cell->row - 1;
 		col = pres_cell->col;
+		cur_dir = 90.0;
 		break;
 	    case 4:
 		row = pres_cell->row + 1;
+		cur_dir = 270.0;
 		break;
 	    case 5:
+		cur_dir = 135.0;
 		break;
 	    case 6:
+		cur_dir = 45.0;
 		break;
 	    case 7:
+		cur_dir = 315.0;
 		break;
 	    case 8:
+		cur_dir = 225.0;
 		break;
 	    case 9:
 		row = pres_cell->row - 2;
+		cur_dir = 112.5;
 		break;
 	    case 10:
+		cur_dir = 67.5;
 		break;
 	    case 11:
 		row = pres_cell->row + 2;
+		cur_dir = 292.5;
 		break;
 	    case 12:
+		cur_dir = 247.5;
 		break;
 	    case 13:
 		col = pres_cell->col - 2;
+		cur_dir = 157.5;
 		break;
 	    case 14:
 		col = pres_cell->col + 2;
+		cur_dir = 22.5;
 		break;
 	    case 15:
+		cur_dir = 337.5;
 		break;
 	    case 16:
+		cur_dir = 202.5;
 		break;
@@ -883,15 +966,24 @@
 		continue;
 	    segment_get(&out_seg, &old_min_cost, row, col);
+	    if (dir == 1) {
+		segment_get(&out_seg2, &old_cur_dir, row, col);
 	    if (G_is_d_null_value(&old_min_cost)) {
 		segment_put(&out_seg, &min_cost, row, col);
 		new_cell = insert(min_cost, row, col);
+		if (dir == 1) {
+		    segment_put(&out_seg2, &cur_dir, row, col);
 	    else {
 		if (old_min_cost > min_cost) {
+		    if (dir == 1) {
 		else {
@@ -917,9 +1009,17 @@
     cum_fd = G_open_raster_new(cum_cost_layer, data_type);
+    if (dir == 1) {
+	dir_fd = G_open_raster_new(move_dir_layer, dir_data_type);
+	dir_cell = G_allocate_raster_buf(dir_data_type);
     /*  Write pending updates by segment_put() to output map   */
     segment_flush(&out_seg);
+    if (dir == 1) {
     /*  Copy segmented map to output map  */
     G_message(_("Writing raster map <%s>..."), cum_cost_layer);
@@ -1029,19 +1129,52 @@
     G_percent(1, 1, 1);
+    if (dir == 1) {
+	G_message(_("Writing movement direction file %s..."), move_dir_layer);
+	    double *p = dir_cell;
+	    for (col = 0; col < ncols; col++) {
+		segment_get(&out_seg2, &cur_dir, row, col);
+		*(p + col) = cur_dir;
+	    G_put_raster_row(dir_fd, dir_cell, dir_data_type);
     segment_release(&in_seg);	/* release memory  */
     segment_release(&out_seg);
+    if (dir == 1) {
+	segment_release(&out_seg2);
     G_close_cell(cost_fd);
     G_close_cell(cum_fd);
+    if (dir == 1) {
+	G_close_cell(dir_fd);
     close(in_fd);		/* close all files */
     close(out_fd);
+    if (dir == 1) {
     unlink(in_file);		/* remove submatrix files  */
     unlink(out_file);
+    if (dir == 1) {
+	unlink(dir_out_file);
     G_short_history(cum_cost_layer, "raster", &history);
     G_command_history(&history);
     G_write_history(cum_cost_layer, &history);
+    if (dir == 1) {
+	G_short_history(move_dir_layer, "raster", &history);
+	G_command_history(&history);
+	G_write_history(move_dir_layer, &history);
     /*  Create colours for output map    */
@@ -1052,7 +1185,7 @@
     G_done_msg(_("Peak cost value: %f."), peak);
     exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_6_4/raster/r.cost/stash.h
--- grass/branches/releasebranch_6_4/raster/r.cost/stash.h	2012-12-30 17:23:10 UTC (rev 54469)
+++ grass/branches/releasebranch_6_4/raster/r.cost/stash.h	2012-12-31 12:29:35 UTC (rev 54470)
@@ -29,6 +29,7 @@
 #define      CUM_COST_LAYER        1
 #define      COST_LAYER            2
 #define      START_PT              3
+#define      MOVE_DIR_LAYER        4
 struct start_pt
@@ -49,17 +50,18 @@
     "output", CUM_COST_LAYER}, {
     "input", COST_LAYER}, {
-    "coor", START_PT}
+    "coor", START_PT}, {
+    "outdir", MOVE_DIR_LAYER}
-char cum_cost_layer[GNAME_MAX];
+char cum_cost_layer[GNAME_MAX], move_dir_layer[GNAME_MAX];
 char cost_layer[GNAME_MAX];
 struct start_pt *head_start_pt = NULL;
 struct start_pt *head_end_pt = NULL;
 #else
-extern char cum_cost_layer[];
+extern char cum_cost_layer[], move_dir_layer[];
 extern char cost_layer[];
 extern struct start_pt *head_start_pt;
 extern struct start_pt *head_end_pt;
Modified: grass/branches/releasebranch_6_4/raster/r.walk/description.html
--- grass/branches/releasebranch_6_4/raster/r.walk/description.html	2012-12-30 17:23:10 UTC (rev 54469)
+++ grass/branches/releasebranch_6_4/raster/r.walk/description.html	2012-12-31 12:29:35 UTC (rev 54470)
@@ -1,8 +1,10 @@
 <h2>DESCRIPTION</h2>
-<em>r.walk</em> outputs a raster map layer showing the lowest
+<em>r.walk</em> outputs 1) a raster map layer showing the lowest
 cumulative cost of moving between each cell and the user-specified
-starting points. It uses an input elevation raster map layer whose
+starting points and 2) a second raster map layer showing the movement
+<a href="#move">Movement Direction</a>). It uses an input elevation raster map layer whose
 cell category values represent elevation, combined with a second input
 raster map layer whose cell values represent friction costs.
@@ -69,11 +71,28 @@
 The minimum cumulative costs are computed using Dijkstra's
 algorithm, that find an optimum solution (for more details see
 <em>r.cost</em>, that uses the same algorithm).
 <p>
+<EM>r.drain</EM> would not correctly create a path from an end point
+       247.5     292.5
+</pre></div>
+<p>
 Once <em>r.walk</em> computes the cumulative cost map as a linear
 combination of friction cost (from friction map) and the altitude and
 distance covered (from the digital elevation model), <em>r.drain</em>
-can be used to find the minimum cost path.
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_6_4/raster/r.walk/main.c
--- grass/branches/releasebranch_6_4/raster/r.walk/main.c	2012-12-30 17:23:10 UTC (rev 54469)
+++ grass/branches/releasebranch_6_4/raster/r.walk/main.c	2012-12-31 12:29:35 UTC (rev 54470)
@@ -25,6 +25,8 @@
  *               Updated for GRASS 6.1
  *                 Roberto Flor and Markus Neteler
  *                 Glynn Clements <glynn gclements.plus.com>, Soeren Gebbert <soeren.gebbert gmx.de>
  * PURPOSE:      anisotropic movements on cost surfaces
  * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
@@ -115,12 +117,12 @@
-    void *dtm_cell, *cost_cell, *cum_cell, *cell2 = NULL;
-    SEGMENT dtm_in_seg, cost_in_seg, out_seg;
+    void *dtm_cell, *cost_cell, *cum_cell, *dir_cell, *cell2 = NULL;
+    SEGMENT dtm_in_seg, cost_in_seg, out_seg, out_seg2;
     char *dtm_mapset, *cost_mapset;
-    char *cum_cost_mapset;
+    char *cum_cost_mapset, *move_dir_mapset;
     char *current_mapset;
-    char *dtm_in_file, *cost_in_file, *out_file;
+    char *dtm_in_file, *cost_in_file, *out_file, *dir_out_file;
     double *dtm_value, *cost_value, *value_start_pt;
     char buf[400];
@@ -128,16 +130,17 @@
     double fcost_dtm, fcost_cost;
     double zero = 0.0;
     int at_percent = 0;
     int col = 0, row = 0, nrows = 0, ncols = 0;
     int maxcost, par_number;
     int maxmem;
     int nseg;
-    int cost_fd, cum_fd, dtm_fd;
-    int have_start_points;
+    int cost_fd, cum_fd, dtm_fd, dir_fd;
+    int have_start_points, dir = 0;
     int have_stop_points;
-    int dtm_in_fd, cost_in_fd, out_fd;
+    int dtm_in_fd, cost_in_fd, out_fd, dir_out_fd;
     double my_dtm, my_cost;
     double null_cost;
     double a, b, c, d, lambda, slope_factor;
@@ -152,7 +155,7 @@
-    struct Option *opt9, *opt10, *opt11, *opt12, *opt13, *opt14;
+    struct Option *opt9, *opt10, *opt11, *opt12, *opt13, *opt14, *opt15;
@@ -160,7 +163,7 @@
     void *ptr2;
     RASTER_MAP_TYPE dtm_data_type, data_type2, cost_data_type, cum_data_type =
-	DCELL_TYPE, cat;
+	DCELL_TYPE, dir_data_type = DCELL_TYPE, cat;
     double peak = 0.0;
     int dtm_dsize, cost_dsize;
@@ -202,6 +205,14 @@
     opt1->gisprompt = "new,cell,raster";
     opt1->description = _("Name of raster map to contain results");
+    opt15 = G_define_option();
+    opt15->key = "outdir";
+    opt15->type = TYPE_STRING;
+    opt15->required = NO;
+    opt15->gisprompt = "new,cell,raster";
+    opt15->description =
     opt7 = G_define_option();
     opt7->type = TYPE_STRING;
@@ -310,11 +321,17 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    if (opt15->answer != NULL)
+	dir = 1;
     dtm_in_file = G_tempfile();
     cost_in_file = G_tempfile();
+    if (dir == 1)
@@ -508,7 +525,13 @@
     search_mapset = "";
     cum_cost_mapset = G_find_cell2(cum_cost_layer, search_mapset);
+    if (dir == 1) {
+	strcpy(move_dir_layer, opt15->answer);
     /*  Check if dtm  layer exists in data base  */
     strcpy(dtm_layer, opt2->answer);
@@ -530,6 +553,11 @@
+    if (dir == 1) {
@@ -665,6 +693,13 @@
     close(out_fd);
+    if (dir == 1) {
+		       sizeof(double));
     dtm_in_fd = open(dtm_in_file, 2);
@@ -676,6 +711,11 @@
+    if (dir == 1) {
@@ -836,6 +876,34 @@
 	G_free(fbuff);
+    if (dir == 1) {
+	    double *fbuff;
+	    int i;
+	    fbuff =
+	    if (fbuff == NULL)
+		G_fatal_error(_("Unable to allocate memory for segment fbuff == NULL"));
+	    G_free(fbuff);
     /*   Scan the existing cum_cost_layer searching for starting points.
@@ -980,66 +1048,82 @@
 	    case 1:
+		cur_dir = 180.0;
 		break;
 	    case 2:
+		cur_dir = 0.0;
 		break;
 	    case 3:
+		cur_dir = 90.0;
 		break;
 	    case 4:
+		cur_dir = 270.0;
 		break;
 	    case 5:
+		cur_dir = 135.0;
 		break;
 	    case 6:
+		cur_dir = 45.0;
 		break;
 	    case 7:
+		cur_dir = 315.0;
 		break;
 	    case 8:
+		cur_dir = 225.0;
 		break;
 	    case 9:
+		cur_dir = 112.5;
 		break;
 	    case 10:
+		cur_dir = 67.5;
 		break;
 	    case 11:
+		cur_dir = 292.5;
 		break;
 	    case 12:
+		cur_dir = 247.5;
 		break;
 	    case 13:
+		cur_dir = 157.5;
 		break;
 	    case 14:
+		cur_dir = 22.5;
 		break;
 	    case 15:
+		cur_dir = 337.5;
 		break;
 	    case 16:
+		cur_dir = 202.5;
 		break;
@@ -1351,15 +1435,24 @@
 		continue;
+	    if (dir == 1) {
+		if (dir == 1) {
 	    else {
+		    if (dir == 1) {
 		else {
@@ -1386,9 +1479,17 @@
     cum_fd = G_open_raster_new(cum_cost_layer, cum_data_type);
     cum_cell = G_allocate_raster_buf(cum_data_type);
+    if (dir == 1) {
+    if (dir == 1) {
@@ -1506,7 +1607,21 @@
+    if (dir == 1) {
@@ -1514,15 +1629,27 @@
     segment_release(&dtm_in_seg);	/* release memory  */
+    if (dir == 1) {
     G_close_cell(dtm_fd);
+    if (dir == 1) {
     close(dtm_in_fd);		/* close all files */
     close(out_fd);
     close(cost_in_fd);
+    if (dir == 1) {
     unlink(dtm_in_file);	/* remove submatrix files  */
     unlink(cost_in_file);
     unlink(out_file);
+    if (dir == 1) {
@@ -1538,6 +1665,12 @@
+    if (dir == 1) {
     exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_6_4/raster/r.walk/stash.h
--- grass/branches/releasebranch_6_4/raster/r.walk/stash.h	2012-12-30 17:23:10 UTC (rev 54469)
+++ grass/branches/releasebranch_6_4/raster/r.walk/stash.h	2012-12-31 12:29:35 UTC (rev 54470)
@@ -17,6 +17,7 @@
 #define      START_PT              3
 struct start_pt
@@ -38,17 +39,18 @@
-    "coor", START_PT}
-char cum_cost_layer[64];
-char cost_layer[64], dtm_layer[64];
+char cost_layer[GNAME_MAX], dtm_layer[GNAME_MAX];
 #else
 extern char cost_layer[], dtm_layer[];
