[GRASS-SVN] r54471 - grass/branches/releasebranch_6_4/raster/r.drain
svn_grass at osgeo.org
Mon Dec 31 04:30:00 PST 2012
Author: mmetz
Date: 2012-12-31 04:30:00 -0800 (Mon, 31 Dec 2012)
New Revision: 54471
grass/branches/releasebranch_6_4/raster/r.drain/main.c
r.drain: backport direction input
Modified: grass/branches/releasebranch_6_4/raster/r.drain/main.c
--- grass/branches/releasebranch_6_4/raster/r.drain/main.c 2012-12-31 12:29:35 UTC (rev 54470)
+++ grass/branches/releasebranch_6_4/raster/r.drain/main.c 2012-12-31 12:30:00 UTC (rev 54471)
@@ -10,6 +10,9 @@
* 24 July 2004: WebValley 2004, error checking and vector points added by
* Matteo Franchi Liceo Leonardo Da Vinci Trento
* Roberto Flor ITC-irst
+ * New code added by Colin Nielsen <colin.nielsen at gmail dot com> *
+ * to use movement direction surface from r.walk and r.cost, and to
+ * output vector paths 2/2009
* PURPOSE: This is the main program for tracing out the path that a
* drop of water would take if released at a certain location
@@ -39,6 +42,7 @@
#include <grass/gis.h>
#include <grass/site.h>
#include <grass/glocale.h>
+#include <grass/Vect.h>
#define DEBUG
#include "tinf.h"
@@ -59,23 +63,25 @@
int main(int argc, char **argv)
- int fe, fd;
+ int fe, fd, dir_fd;
int i, have_points = 0;
int new_id;
int nrows, ncols, points_row[MAX_POINTS], points_col[MAX_POINTS], npoints;
int cell_open(), cell_open_new();
- int map_id;
- char map_name[GNAME_MAX], *map_mapset, new_map_name[GNAME_MAX];
- char *tempfile1, *tempfile2;
+ int map_id, dir_id;
+ char map_name[GNAME_MAX], *map_mapset, new_map_name[GNAME_MAX],
+ dir_name[GNAME_MAX], *dir_mapset;
+ char *tempfile1, *tempfile2, *tempfile3;
char *search_mapset;
struct History history;
struct Cell_head window;
- struct Option *opt1, *opt2, *coordopt, *vpointopt;
- struct Flag *flag1, *flag2, *flag3;
+ struct Option *opt1, *opt2, *coordopt, *vpointopt, *opt3, *opt4;
+ struct Flag *flag1, *flag2, *flag3, *flag4;
struct GModule *module;
- int in_type;
+ int in_type, dir_data_type;
void *in_buf;
+ void *dir_buf;
CELL *out_buf;
struct band3 bnd, bndC;
struct metrics *m = NULL;
@@ -83,10 +89,18 @@
struct point *list;
struct point *thispoint;
int ival, bsz, start_row, start_col, mode;
+ int costmode = 0;
double east, north, val;
struct point *drain(int, struct point *, int, int);
+ struct point *drain_cost(int, struct point *, int, int);
int bsort(int, struct point *);
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ struct Map_info vout;
+ int cat;
+ double x, y;
+ char vect[GNAME_MAX], *vect_mapset;
G_gisinit(argv[0]);
@@ -97,9 +111,25 @@
opt1 = G_define_standard_option(G_OPT_R_ELEV);
opt1->key = "input";
+ opt3 = G_define_option();
+ opt3->key = "indir";
+ opt3->type = TYPE_STRING;
+ opt3->gisprompt = "old,cell,raster";
+ opt3->description =
+ _("Name of movement direction map associated with the cost surface");
+ opt3->required = NO;
opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt4 = G_define_option();
+ opt4->key = "voutput";
+ opt4->type = TYPE_STRING;
+ opt4->gisprompt = "new,vector,vector";
+ opt4->required = NO;
+ opt4->description =
+ _("Output drain vector map (recommended for cost surface made using knight's move)");
coordopt = G_define_option();
coordopt->key = "coordinate";
coordopt->type = TYPE_STRING;
@@ -127,6 +157,11 @@
flag3->key = 'n';
flag3->description = _("Count cell numbers along the path");
+ flag4 = G_define_flag();
+ flag4->key = 'd';
+ flag4->description =
+ _("The input surface is a cost surface (if checked, a direction surface must also be specified");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -134,6 +169,49 @@
strcpy(map_name, opt1->answer);
strcpy(new_map_name, opt2->answer);
+ if (flag4->answer) {
+ costmode = 1;
+ G_message(_
+ ("Directional drain selected... checking for direction raster"));
+ else {
+ G_message(_("Surface/Hydrology drain selected"));
+ if (costmode == 1) {
+ if (!opt3->answer) {
+ G_fatal_error(_
+ ("Direction raster not specified, if direction flag is on, a direction raster must be given"));
+ strcpy(dir_name, opt3->answer);
+ dir_mapset = G_find_cell2(dir_name, "");
+ if (dir_mapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), dir_name);
+ else {
+ G_message(_("Direction raster found <%s>"), dir_name);
+ dir_data_type = G_raster_map_type(dir_name, dir_mapset);
+ if (costmode == 0) {
+ if (opt3->answer) {
+ G_fatal_error(_
+ ("Direction map <%s> should not be specified for Surface/Hydrology drains"),
+ opt3->answer);
+ if (opt4->answer) {
+ G_message(_("Outputting a vector path"));
+ if (G_legal_filename(opt4->answer) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), opt4->answer);
+ /*G_ask_vector_new("",vect); */
+ if (0 > Vect_open_new(&vout, opt4->answer, 0)) {
+ G_fatal_error(_("Unable to create vector map <%s>"),
+ opt4->answer);
+ Vect_hist_command(&vout);
/* get the name of the elevation map layer for filling */
map_mapset = G_find_cell(map_name, "");
if (!map_mapset)
@@ -160,6 +238,10 @@
G_get_window(&window);
nrows = G_window_rows();
ncols = G_window_cols();
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
/* calculate true cell resolution */
m = (struct metrics *)G_malloc(nrows * sizeof(struct metrics));
@@ -297,14 +379,30 @@
G_close_cell(map_id);
- G_verbose_message(_("Calculating flow directions..."));
+ dir_buf = G_allocate_d_raster_buf();
+ dir_id = G_open_cell_old(dir_name, dir_mapset);
+ tempfile3 = G_tempfile();
+ dir_fd = open(tempfile3, O_RDWR | O_CREAT, 0666);
- /* fill one-cell pits and take a first stab at flow directions */
- filldir(fe, fd, nrows, &bnd, m);
+ for (i = 0; i < nrows; i++) {
+ G_get_d_raster_row(dir_id, dir_buf, i);
+ write(dir_fd, dir_buf, ncols * sizeof(DCELL));
+ G_close_cell(dir_id);
- /* determine flow directions for more ambiguous cases */
- resolve(fd, nrows, &bndC);
+ /* only necessary for non-dir drain */
+ G_verbose_message(_("Calculating flow directions..."));
+ /* fill one-cell pits and take a first stab at flow directions */
+ filldir(fe, fd, nrows, &bnd, m);
+ /* determine flow directions for more ambiguous cases */
+ resolve(fd, nrows, &bndC);
/* free the buffers already used */
G_free(bndC.b[0]);
G_free(bndC.b[1]);
@@ -323,7 +421,13 @@
thispoint->row = points_row[i];
thispoint->col = points_col[i];
thispoint->next = NULL;
- thispoint = drain(fd, thispoint, nrows, ncols);
+ /* drain algorithm selection (dir or non-dir) */
+ thispoint = drain(fd, thispoint, nrows, ncols);
+ thispoint = drain_cost(dir_fd, thispoint, nrows, ncols);
/* do the output */
@@ -429,6 +533,38 @@
G_percent(1, 1, 1);
+ /* Output a vector path */
+ /* Need to modify for multiple paths */
+ thispoint = list;
+ i = 1;
+ while (thispoint->next != NULL) {
+ if (thispoint->row == INT_MAX) {
+ thispoint = thispoint->next;
+ Vect_cat_set(Cats, 1, i);
+ Vect_write_line(&vout, GV_LINE, Points, Cats);
+ Vect_reset_line(Points);
+ Vect_reset_cats(Cats);
+ i++;
+ continue;
+ if (Vect_cat_get(Cats, 1, &cat) == 0) {
+ /* Need to convert row and col to coordinates
+ * y = cell_head.north - ((double) p->row + 0.5) * cell_head.ns_res;
+ * x = cell_head.west + ((double) p->col + 0.5) * cell_head.ew_res;
+ x = window.west + ((double)thispoint->col + 0.5) * window.ew_res;
+ y = window.north - ((double)thispoint->row + 0.5) * window.ns_res;
+ Vect_append_point(Points, x, y, 0.0);
+ } /* End while */
+ Vect_build(&vout);
+ Vect_close(&vout);
/* close files and free buffers */
G_close_cell(new_id);
@@ -446,6 +582,11 @@
G_free(in_buf);
G_free(out_buf);
+ close(dir_fd);
+ unlink(tempfile3);
+ G_free(dir_buf);
G_done_msg(" ");
exit(EXIT_SUCCESS);
@@ -509,3 +650,134 @@
return list;
+struct point *drain_cost(int dir_fd, struct point *list, int nrow, int ncol)
+ * The idea is that each cell of the direction surface has a value representing
+ * the direction towards the next cell in the path. The direction is read from
+ * the input raster, and a simple case/switch is used to determine which cell to
+ * read next. This is repeated via a while loop until a null direction is found.
+ int neighbour, row, col, next_row, next_col, go = 1;
+ DCELL direction;
+ DCELL *dir_buf;
+ next_row = list->row;
+ next_col = list->col;
+ while (go) {
+ go = 0;
+ /* Directional algorithm
+ * 1) read cell direction
+ * 2) shift to cell in that direction
+ /* find the direction recorded at row,col */
+ lseek(dir_fd, (off_t) list->row * ncol * sizeof(DCELL), SEEK_SET);
+ read(dir_fd, dir_buf, ncol * sizeof(DCELL));
+ direction = *(dir_buf + list->col);
+ neighbour = direction * 10;
+ if (G_verbose() > 2)
+ G_message(_("direction read: %lf, neighbour found: %i"),
+ direction, neighbour);
+ switch (neighbour) {
+ case 1800:
+ next_col = list->col + 1;
+ break;
+ case 0:
+ next_col = list->col - 1;
+ break;
+ case 900:
+ next_row = list->row + 1;
+ break;
+ case 2700:
+ next_row = list->row - 1;
+ break;
+ case 1350:
+ break;
+ case 450:
+ break;
+ case 3150:
+ break;
+ case 2250:
+ break;
+ case 1125:
+ next_row = list->row + 2;
+ break;
+ case 675:
+ break;
+ case 2925:
+ next_row = list->row - 2;
+ break;
+ case 2475:
+ break;
+ case 1575:
+ next_col = list->col + 2;
+ break;
+ case 225:
+ next_col = list->col - 2;
+ break;
+ case 3375:
+ break;
+ case 2025:
+ break;
+ /* default:
+ break;
+ Should probably add something here for the possibility of a non-direction map
+ G_fatal_error(_("Invalid direction given (possibly not a direction map)")); */
+ } /* end switch/case */
+ if (next_col >= 0 && next_col < ncol && next_row >= 0 &&
+ next_row < nrow) {
+ list->next = (struct point *)G_malloc(sizeof(struct point));
+ list = list->next;
+ list->row = next_row;
+ list->col = next_col;
+ next_row = -1;
+ next_col = -1;
+ go = 1;
+ } /* end while */
+ /* allocate and fill the end-of-path flag */
+ list->row = INT_MAX;
+ /* return a pointer to an empty structure */
+ list->next = NULL;
+ G_free(dir_buf);
+ return list;
