[GRASS-SVN] r50718 - in grass/branches/releasebranch_6_4/gui/tcltk:
d.m gis.m
svn_grass at osgeo.org
Tue Feb 7 23:35:38 EST 2012
Author: hamish
Date: 2012-02-07 20:35:38 -0800 (Tue, 07 Feb 2012)
New Revision: 50718
grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl
grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl
r.le.trace needs a display monitor and an interactive terminal (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl
--- grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl 2012-02-08 04:29:56 UTC (rev 50717)
+++ grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl 2012-02-08 04:35:38 UTC (rev 50718)
@@ -308,7 +308,7 @@
{separator}
{command {[G_msg "Analyze landscape characteristics"]} {} "r.le.pixel" {} -command {execute r.le.pixel }}
{command {[G_msg "Analyze landscape patch characteristics"]} {} " r.le.patch" {} -command {execute r.le.patch }}
- {command {[G_msg "Output landscape patch information"]} {} "r.le.trace" {} -command {execute r.le.trace }}
+ {command {[G_msg "Output landscape patch information"]} {} "r.le.trace" {} -command {guarantee_xmon; term r.le.trace}}
{cascad {[G_msg "Wildfire modeling"]} {} "" $tmenu {
{command {[G_msg "Generate rate of spread (ROS) maps"]} {} "r.ros" {} -command {execute r.ros }}
Modified: grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl
--- grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl 2012-02-08 04:29:56 UTC (rev 50717)
+++ grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl 2012-02-08 04:35:38 UTC (rev 50718)
@@ -337,7 +337,11 @@
{separator}
{command {[G_msg "Analyze landscape"]} {} "r.le.pixel: Analyze landscape characteristics" {} -command {execute r.le.pixel }}
{command {[G_msg "Analyze patches"]} {} " r.le.patch: Analyze landscape patch characteristics" {} -command {execute r.le.patch }}
- {command {[G_msg "Output"]} {} "r.le.trace: Output landscape patch information" {} -command {execute r.le.trace }}
+ {command {[G_msg "Summary and display"]} {} "r.le.trace: Output landscape patch information" {} -command {
+ unset env(GRASS_RENDER_IMMEDIATE)
+ guarantee_xmon
+ term r.le.trace
+ set env(GRASS_RENDER_IMMEDIATE) "TRUE"}}
{cascad {[G_msg "Landscape patch analysis"]} {} "" $tmenu {
{command {[G_msg "Set up sampling and analysis framework"]} {} "r.li.setup: Configure and create patch map for analysis" {} -command {execute r.li.setup }}
