[GRASS-SVN] r50719 - grass/trunk/raster/r.le/r.le.trace
svn_grass at osgeo.org
Tue Feb 7 23:46:51 EST 2012
Author: hamish
Date: 2012-02-07 20:46:51 -0800 (Tue, 07 Feb 2012)
New Revision: 50719
grass/trunk/raster/r.le/r.le.trace/main.c
grass/trunk/raster/r.le/r.le.trace/user_input.c
better support for map at othermapset;
remove some unused variables;
d.colormode not ported to grass6;
minor whitespace cleanup;
initialize the 'pat' pointer to NULL;
i18n; use G_std_opt()
(sync from devbr6)
Modified: grass/trunk/raster/r.le/r.le.trace/main.c
--- grass/trunk/raster/r.le/r.le.trace/main.c 2012-02-08 04:35:38 UTC (rev 50718)
+++ grass/trunk/raster/r.le/r.le.trace/main.c 2012-02-08 04:46:51 UTC (rev 50719)
@@ -42,7 +42,6 @@
struct Cell_head window;
int bot, right, t0, b0, l0, r0, clear = 0;
double Rw_l, Rscr_wl;
- char tmp[20];
void set_map();
setbuf(stdout, NULL); /* unbuffered */
@@ -62,8 +61,7 @@
user_input(argc, argv);
/* setup the current window for display */
- G_system(" d.colormode float");
- G_system(" d.frame -e");
+ G_system("d.frame -e");
Rw_l = (double)Rast_window_cols() / Rast_window_rows();
R_open_driver();
R_font("romant");
@@ -108,14 +106,13 @@
- /* DISPLAY A MESSAGE AND THE MAP, THEN
- TRACE THE PATCHES AND DISPLAY THEM */
+ /* DISPLAY A MESSAGE AND THE MAP, THEN
+ TRACE THE PATCHES AND DISPLAY THEM */
void set_map(char *name, struct Cell_head window, int top, int bot, int left,
int right, char *fn)
char cmd[30];
- int i, k = 0, j, btn, d, class;
double msc[2];
void scr_cell(), cell_clip_drv(), show_patch();
@@ -124,9 +121,8 @@
G_system("clear");
puts("\n\nR.LE.TRACE IS WORKING...\n");
- G_system("d.colormode mode=fixed");
- sprintf(cmd, "d.rast %s", name);
G_system("d.erase");
+ sprintf(cmd, "d.rast %s", name);
G_system(cmd);
/* setup the screen-cell array coordinate
@@ -149,14 +145,11 @@
+ /* DISPLAY THE PATCH INFORMATION */
- /* DISPLAY THE PATCH INFORMATION */
void show_patch(char *fn, double *msc, char *cmd)
PATCH *tmp, *tmp0;
- register int i;
int num;
char c;
void draw_patch(), patch_attr();
@@ -276,7 +269,7 @@
- /* DISPLAY PATCH ATTRIBUTES ON THE SCREEN */
+ /* DISPLAY PATCH ATTRIBUTES ON THE SCREEN */
void patch_attr(FILE * fp, PATCH * p, int show)
@@ -328,7 +321,7 @@
- /* PLACE PATCH NUMBERS ON THE SCREEN */
+ /* PLACE PATCH NUMBERS ON THE SCREEN */
void draw_patch(PATCH * p, double *m)
@@ -370,8 +363,8 @@
- /* DRIVER FOR CELL CLIPPING, TRACING,
- AND CALCULATIONS */
+ /* DRIVER FOR CELL CLIPPING, TRACING,
+ AND CALCULATIONS */
void cell_clip_drv(int col0, int row0, int ncols, int nrows, double **value,
int index)
@@ -429,11 +422,12 @@
list_head = point to the patch list
+ pat = NULL;
total_patches = 0;
name = choice->fn;
- mapset = G_mapset();
+ mapset = G_find_raster2(name, "");
data_type = Rast_map_type(name, mapset);
/* dynamically allocate storage for the
@@ -495,8 +489,8 @@
- /* OPEN THE RASTER FILE TO BE CLIPPED,
- AND DO THE CLIPPING */
+ /* OPEN THE RASTER FILE TO BE CLIPPED,
+ AND DO THE CLIPPING */
void cell_clip(DCELL ** buf, DCELL ** null_buf, int row0, int col0, int nrows,
int ncols, int index, int *centernull)
@@ -505,7 +499,7 @@
FCELL *ftmp;
DCELL *dtmp;
void *rastptr;
- char *tmpname;
+ char *tmpname, *name, *mapset;
int fr, x;
register int i, j;
double center_row = 0.0, center_col = 0.0;
@@ -551,22 +545,13 @@
/* check for input raster map and open it; this
map remains open on finput while all the programs
run, so it is globally available */
+ name = choice->fn;
- if (0 > (finput = Rast_open_old(choice->fn, G_mapset()))) {
- fprintf(stderr, "\n");
- fprintf(stderr,
- " ********************************************************\n");
- fprintf(stderr,
- " The raster map you specified with the 'map=' parameter \n");
- fprintf(stderr,
- " was not found in your mapset. \n");
- fprintf(stderr,
- exit(1);
+ if (0 > (finput = Rast_open_old(name, "")))
+ G_fatal_error(_("Unable to open raster map <%s>"), name);
- else
- data_type = Rast_map_type(choice->fn, G_mapset());
+ data_type = Rast_map_type(name, mapset);
/* allocate memory to store a row of the
raster map, depending on the type of
@@ -727,14 +712,15 @@
- /* DRIVER TO LOOK FOR NEW PATCHES, CALL
- THE TRACING ROUTINE, AND ADD NEW PATCHES
- TO THE PATCH LIST */
-void trace(int nrows, int ncols, DCELL ** buf, DCELL ** null_buf, CELL ** pat)
+ /* DRIVER TO LOOK FOR NEW PATCHES, CALL
+ THE TRACING ROUTINE, AND ADD NEW PATCHES
+ TO THE PATCH LIST */
+void trace(int nrows, int ncols, DCELL **buf, DCELL **null_buf, CELL **pat)
double class = 0.0;
- register int i, j, x;
+ register int i, j;
PATCH *tmp, *find_any, *list_head;
@@ -744,20 +730,20 @@
nrows = total number of rows in the area where tracing will occur
ncols = total number of cols in the area where tracing will occur
buf = pointer to array containing only the pixels inside the area
- that was clipped and within which tracing will now occur, so
- a smaller array than the original raster map
+ that was clipped and within which tracing will now occur, so
+ a smaller array than the original raster map
null_buf = pointer to array containing 0.0 if pixel in input raster map is
- not null and 1.0 if pixel in input raster map is null
+ not null and 1.0 if pixel in input raster map is null
pat = pointer to array containing the map of patch numbers; this map
- can only be integer
+ can only be integer
INTERNAL:
class = the attribute of each pixel
i, j = counts the row and column as the program goes through the area
tmp = pointer to a member of the PATCH list data structure, used to
- advance through the patch list
+ advance through the patch list
find_any = pointer to a member of the patch list to hold the results after
- routine get_bd is called to trace the boundary of the patch and
- save the patch information in the PATCH data structure
+ routine get_bd is called to trace the boundary of the patch and
+ save the patch information in the PATCH data structure
list_head = pointer to the first member of the patch list
@@ -786,7 +772,7 @@
list_head = patch_list;
- if (find_any = get_bd(i, j, nrows, ncols, class, buf, null_buf, list_head, pat)) { /*4 */
+ if ((find_any = get_bd(i, j, nrows, ncols, class, buf, null_buf, list_head, pat))) { /*4 */
/* if the first patch, make tmp point to
the patch list and add the first patch
@@ -840,12 +826,10 @@
+ /* TRACE THE BOUNDARY OF A PATCH AND
+ SAVE THE PATCH CHARACTERISTICS IN
+ THE PATCH STRUCTURE */
- /* TRACE THE BOUNDARY OF A PATCH AND
- SAVE THE PATCH CHARACTERISTICS IN
- THE PATCH STRUCTURE */
PATCH *get_bd(int row0, int col0, int nrows, int ncols, double class,
DCELL ** buf, DCELL ** null_buf, PATCH * p_list, CELL ** pat)
Modified: grass/trunk/raster/r.le/r.le.trace/user_input.c
--- grass/trunk/raster/r.le/r.le.trace/user_input.c 2012-02-08 04:35:38 UTC (rev 50718)
+++ grass/trunk/raster/r.le/r.le.trace/user_input.c 2012-02-08 04:46:51 UTC (rev 50719)
@@ -18,6 +18,7 @@
#include <grass/config.h>
+#include <grass/glocale.h>
#include "r.le.trace.h"
extern struct CHOICE *choice;
@@ -31,23 +32,17 @@
bound = G_define_flag();
bound->key = 'p';
- bound->description = "Include sampling area boundary as perimeter";
+ bound->description = _("Include sampling area boundary as perimeter");
trace = G_define_flag();
trace->key = 't';
- trace->description = "Use 4 neighbor tracing instead of 8 neighbor";
+ trace->description = _("Use 4 neighbor tracing instead of 8 neighbor");
- name = G_define_option();
- name->key = "map";
- name->description = "Raster map to be analyzed";
- name->type = TYPE_STRING;
- name->gisprompt = "old,cell,raster";
- name->required = YES;
+ name = G_define_standard_option(G_OPT_R_MAP);
+ name->description = _("Raster map to be analyzed");
- out = G_define_option();
- out->key = "out";
- out->description = "Name of output file to store patch data";
- out->type = TYPE_STRING;
+ out = G_define_standard_option(G_OPT_F_OUTPUT);
+ out->description = _("Name of output file to store patch data");
out->required = NO;
if (G_parser(argc, argv))
