[GRASS-SVN] r50720 - grass/trunk/gui/wxpython/xml
Tue Feb 7 23:49:45 EST 2012
Author: hamish
Date: 2012-02-07 20:49:45 -0800 (Tue, 07 Feb 2012)
New Revision: 50720
   grass/trunk/gui/wxpython/xml/menudata.xml
r.le.trace needs an Xmon and a terminal, so drop from menu
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2012-02-08 04:46:51 UTC (rev 50719)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2012-02-08 04:49:45 UTC (rev 50720)
@@ -1514,13 +1514,7 @@
 	      <handler>OnMenuCmd</handler>
 	      <command>r.le.patch</command>
 	    </menuitem>
-	    <menuitem>
-	      <label>Output</label>
-	      <help>Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file.</help>
-	      <keywords>raster</keywords>
-	      <handler>OnMenuCmd</handler>
-	      <command>r.le.trace</command>
-	    </menuitem>
 	  </items>
 	</menu>
 	<menu>
