[GRASS-SVN] r50758 - grass/trunk/tools
svn_grass at osgeo.org
Fri Feb 10 14:37:24 EST 2012
Author: glynn
Date: 2012-02-10 11:37:24 -0800 (Fri, 10 Feb 2012)
New Revision: 50758
grass/trunk/tools/sql.sh
Fix for 64-bit systems
Modified: grass/trunk/tools/sql.sh
--- grass/trunk/tools/sql.sh 2012-02-10 17:53:04 UTC (rev 50757)
+++ grass/trunk/tools/sql.sh 2012-02-10 19:37:24 UTC (rev 50758)
@@ -103,8 +103,8 @@
( cd dist.*
-LD_LIBRARY_PATH=`pwd`/lib
-export LD_LIBRARY_PATH
+#LD_LIBRARY_PATH=`pwd`/lib
+#export LD_LIBRARY_PATH
find . -type f -perm +111 \! -name '*.so.*' \
| while read file ; do ldd $file | sed 's!^!'$file'!' ; done 2>/dev/null \
@@ -115,14 +115,14 @@
find . -type f -perm +111 \! -name '*.so' \
| xargs nm -AD 2>/dev/null \
- | egrep ': {8} U ' \
+ | egrep ': {8}{1,2} U ' \
| sed -e 's/:/ /g' -e 's/\.\///' \
| awk -vOFS='\t' '{print $1,$3}' \
> "$tmpdir/prog_imp.lst"
- | egrep ':[0-9a-f]{8} [BCDGRSTW] ' \
+ | egrep ':[0-9a-f]{8}{1,2} [BCDGRSTW] ' \
| awk -vOFS='\t' '{print $1,$4}' \
> "$tmpdir/prog_exp.lst"
@@ -131,42 +131,42 @@
find * -type f -name 'lib?*.a' \
| xargs nm -A \
| sed 's/:/ /g' \
| awk -vOFS='\t' '{print gensub("^[^ ]*/","",1,$1),$2,$5}' \
> "$tmpdir/stlib_exp.lst"
find * -type f -name 'lib?*.so' \
| xargs nm -AD \
| sed 's/:/ /g' \
| awk -vOFS='\t' '{print gensub("^[^ ]*/","",1,$1),$4}' \
> "$tmpdir/shlib_exp.lst"
find * -type f -name '*.o' \
| xargs nm -A \
| sed 's/:/ /g' \
> "$tmpdir/obj_exp.lst"
| xargs nm -A \
| sed 's/:/ /g' \
| awk -vOFS='\t' '{print gensub("^[^ ]*/","",1,$1),$2,$4}' \
> "$tmpdir/stlib_imp.lst"
| xargs nm -AD \
| sed 's/:/ /g' \
| awk -vOFS='\t' '{print gensub("^[^ ]*/","",1,$1),$3}' \
> "$tmpdir/shlib_imp.lst"
| xargs nm -A \
| sed 's/:/ /g' \
> "$tmpdir/obj_imp.lst"
@@ -174,7 +174,7 @@
libs=`awk '{print $3}' "$tmpdir/ldd.lst" | uniq | sort | uniq`
nm -AD $libs \
- | egrep ':[0-9a-f]{8} [TWDRC] ' \
+ | egrep ':[0-9a-f]{8}{1,2} [TWDRC] ' \
| sed 's/:/ /g' \
> "$tmpdir/libs.lst"
@@ -351,7 +351,7 @@
CREATE TABLE ldd (
program VARCHAR(80) NOT NULL,
- library VARCHAR(80) NOT NULL,
+ library VARCHAR(256) NOT NULL,
path VARCHAR(256)
