[GRASS-SVN] r50759 - in grass/trunk: . display/d.mon include/Make
lib/python/ctypes misc/m.nviz.image
raster/simwe/r.sim.sediment raster/simwe/r.sim.water
raster3d/r3.mask raster3d/r3.mkdspf raster3d/r3.null
raster3d/r3.timestamp vector/v.external.out
vector/v.lidar.correction vector/v.lidar.edgedetection
vector/v.lidar.growing vector/v.outlier vector/v.timestamp
visualization/nviz/src visualization/wximgview
svn_grass at osgeo.org
Fri Feb 10 14:38:42 EST 2012
Author: glynn
Date: 2012-02-10 11:38:42 -0800 (Fri, 10 Feb 2012)
New Revision: 50759
grass/trunk/aclocal.m4
grass/trunk/configure
grass/trunk/display/d.mon/Makefile
grass/trunk/include/Make/Grass.make
grass/trunk/include/Make/Platform.make.in
grass/trunk/lib/python/ctypes/Makefile
grass/trunk/misc/m.nviz.image/Makefile
grass/trunk/raster/simwe/r.sim.sediment/Makefile
grass/trunk/raster/simwe/r.sim.water/Makefile
grass/trunk/raster3d/r3.mask/Makefile
grass/trunk/raster3d/r3.mkdspf/Makefile
grass/trunk/raster3d/r3.null/Makefile
grass/trunk/raster3d/r3.timestamp/Makefile
grass/trunk/vector/v.external.out/Makefile
grass/trunk/vector/v.lidar.correction/Makefile
grass/trunk/vector/v.lidar.edgedetection/Makefile
grass/trunk/vector/v.lidar.growing/Makefile
grass/trunk/vector/v.outlier/Makefile
grass/trunk/vector/v.timestamp/Makefile
grass/trunk/vector/v.timestamp/main.c
grass/trunk/visualization/nviz/src/Makefile
grass/trunk/visualization/wximgview/Makefile
Fix dependencies
Fix "make GRASS_LIBRARY_TYPE=stlib"
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/aclocal.m4 2012-02-10 19:38:42 UTC (rev 50759)
@@ -410,19 +410,13 @@
if test "$shared_ok" = "yes" ; then
AC_MSG_RESULT([shared])
SHARED_BUILD=1
- GRASS_LIB_PREFIX='$(SHLIB_PREFIX)'
- GRASS_LIB_SUFFIX='$(SHLIB_SUFFIX)'
GRASS_LIBRARY_TYPE='shlib'
else
AC_MSG_RESULT([static])
SHARED_BUILD=0
AC_DEFINE(STATIC_BUILD)
- GRASS_LIB_PREFIX='$(STLIB_PREFIX)'
- GRASS_LIB_SUFFIX='$(STLIB_SUFFIX)'
GRASS_LIBRARY_TYPE='stlib'
fi
- AC_SUBST(GRASS_LIB_PREFIX)
- AC_SUBST(GRASS_LIB_SUFFIX)
AC_SUBST(GRASS_LIBRARY_TYPE)
Modified: grass/trunk/configure
--- grass/trunk/configure 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/configure 2012-02-10 19:38:42 UTC (rev 50759)
@@ -1465,8 +1465,6 @@
echo "$ac_t""shared" 1>&6
SHARED_BUILD=1
else
echo "$ac_t""static" 1>&6
@@ -1475,13 +1473,9 @@
#define STATIC_BUILD 1
EOF
fi
ac_save_ldflags="$LDFLAGS"
@@ -2290,7 +2284,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2294: checking for additional include dirs" >&5
+echo "configure:2288: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2313,7 +2307,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2317: checking for additional library dirs" >&5
+echo "configure:2311: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2347,7 +2341,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2351: checking for a BSD compatible install" >&5
+echo "configure:2345: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2400,7 +2394,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2404: checking for $ac_word" >&5
+echo "configure:2398: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2431,13 +2425,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2435: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2429: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2441 "configure"
+#line 2435 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2448,7 +2442,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2473,7 +2467,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2477: checking for $ac_word" >&5
+echo "configure:2471: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2513,7 +2507,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2517: checking for $ac_word" >&5
+echo "configure:2511: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2544,7 +2538,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2548: checking for $ac_word" >&5
+echo "configure:2542: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2582,7 +2576,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2586: checking for $ac_word" >&5
+echo "configure:2580: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2611,7 +2605,7 @@
-echo "configure:2615: checking for $ac_word" >&5
+echo "configure:2609: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2642,7 +2636,7 @@
-echo "configure:2646: checking for $ac_word" >&5
+echo "configure:2640: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2671,7 +2665,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2675: checking for $ac_word" >&5
+echo "configure:2669: checking for $ac_word" >&5
case "$PERL" in
@@ -2702,7 +2696,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2706: checking how to run the C preprocessor" >&5
+echo "configure:2700: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2715,13 +2709,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2719 "configure"
+#line 2713 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2725: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2732,13 +2726,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2736 "configure"
+#line 2730 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2742: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2749,13 +2743,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2753 "configure"
+#line 2747 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2753: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2779,10 +2773,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2783: checking for ANSI C header files" >&5
+echo "configure:2777: checking for ANSI C header files" >&5
-#line 2786 "configure"
+#line 2780 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2790,7 +2784,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2807,7 +2801,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2811 "configure"
+#line 2805 "configure"
#include <string.h>
EOF
@@ -2825,7 +2819,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2829 "configure"
+#line 2823 "configure"
#include <stdlib.h>
EOF
@@ -2846,7 +2840,7 @@
else
-#line 2850 "configure"
+#line 2844 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2857,7 +2851,7 @@
exit (0); }
EOF
-if { (eval echo configure:2861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2884,15 +2878,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2888: checking for $ac_hdr" >&5
+echo "configure:2882: checking for $ac_hdr" >&5
-#line 2891 "configure"
+#line 2885 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2921,15 +2915,15 @@
do
-echo "configure:2925: checking for $ac_hdr" >&5
+echo "configure:2919: checking for $ac_hdr" >&5
-#line 2928 "configure"
+#line 2922 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2933: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2958,15 +2952,15 @@
do
-echo "configure:2962: checking for $ac_hdr" >&5
+echo "configure:2956: checking for $ac_hdr" >&5
-#line 2965 "configure"
+#line 2959 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2995,15 +2989,15 @@
do
-echo "configure:2999: checking for $ac_hdr" >&5
+echo "configure:2993: checking for $ac_hdr" >&5
-#line 3002 "configure"
+#line 2996 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3032,15 +3026,15 @@
do
-echo "configure:3036: checking for $ac_hdr" >&5
+echo "configure:3030: checking for $ac_hdr" >&5
-#line 3039 "configure"
+#line 3033 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3044: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3066,10 +3060,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3070: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3064: checking whether time.h and sys/time.h may both be included" >&5
-#line 3073 "configure"
+#line 3067 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3078,7 +3072,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3076: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3098,10 +3092,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3102: checking for off_t" >&5
+echo "configure:3096: checking for off_t" >&5
-#line 3105 "configure"
+#line 3099 "configure"
#if STDC_HEADERS
@@ -3128,10 +3122,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3132: checking for uid_t in sys/types.h" >&5
+echo "configure:3126: checking for uid_t in sys/types.h" >&5
-#line 3135 "configure"
+#line 3129 "configure"
EOF
@@ -3159,10 +3153,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3163: checking return type of signal handlers" >&5
+echo "configure:3157: checking return type of signal handlers" >&5
-#line 3166 "configure"
+#line 3160 "configure"
#include <signal.h>
@@ -3179,7 +3173,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3183: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3177: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3197,10 +3191,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3201: checking for Cygwin environment" >&5
+echo "configure:3195: checking for Cygwin environment" >&5
-#line 3204 "configure"
+#line 3198 "configure"
int main() {
@@ -3211,7 +3205,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3215: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3209: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3229,10 +3223,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3233: checking for $ac_func" >&5
+echo "configure:3227: checking for $ac_func" >&5
-#line 3236 "configure"
+#line 3230 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3255,7 +3249,7 @@
; return 0; }
EOF
-if { (eval echo configure:3259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3281,10 +3275,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3285: checking for $ac_func" >&5
+echo "configure:3279: checking for $ac_func" >&5
-#line 3288 "configure"
+#line 3282 "configure"
@@ -3307,7 +3301,7 @@
; return 0; }
EOF
-if { (eval echo configure:3311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3333,10 +3327,10 @@
for ac_func in drand48
do
-echo "configure:3337: checking for $ac_func" >&5
+echo "configure:3331: checking for $ac_func" >&5
-#line 3340 "configure"
+#line 3334 "configure"
@@ -3359,7 +3353,7 @@
; return 0; }
EOF
-if { (eval echo configure:3363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3385,10 +3379,10 @@
for ac_func in putenv setenv
do
-echo "configure:3389: checking for $ac_func" >&5
+echo "configure:3383: checking for $ac_func" >&5
-#line 3392 "configure"
+#line 3386 "configure"
@@ -3411,7 +3405,7 @@
; return 0; }
EOF
-if { (eval echo configure:3415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3437,10 +3431,10 @@
for ac_func in nanosleep
do
-echo "configure:3441: checking for $ac_func" >&5
+echo "configure:3435: checking for $ac_func" >&5
-#line 3444 "configure"
+#line 3438 "configure"
@@ -3463,7 +3457,7 @@
; return 0; }
EOF
-if { (eval echo configure:3467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3488,13 +3482,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3492: checking whether setpgrp takes no argument" >&5
+echo "configure:3486: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3498 "configure"
+#line 3492 "configure"
#ifdef HAVE_UNISTD_H
@@ -3514,7 +3508,7 @@
EOF
-if { (eval echo configure:3518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3542,16 +3536,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3546: checking for long long int" >&5
+echo "configure:3540: checking for long long int" >&5
-#line 3548 "configure"
+#line 3542 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3555: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3549: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3571,7 +3565,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3575: checking for W11" >&5
+echo "configure:3569: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3599,7 +3593,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3603: checking for X" >&5
+echo "configure:3597: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3659,12 +3653,12 @@
# First, try using that file with no special directory specified.
-#line 3663 "configure"
+#line 3657 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3733,14 +3727,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3737 "configure"
+#line 3731 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3845,17 +3839,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3849: checking whether -R must be followed by a space" >&5
+echo "configure:3843: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3852 "configure"
+#line 3846 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3871,14 +3865,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3875 "configure"
+#line 3869 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3910,13 +3904,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3914: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3908: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3920 "configure"
+#line 3914 "configure"
@@ -3927,7 +3921,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3948,13 +3942,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3952: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3946: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3958 "configure"
+#line 3952 "configure"
@@ -3965,7 +3959,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3993,10 +3987,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3997: checking for gethostbyname" >&5
+echo "configure:3991: checking for gethostbyname" >&5
-#line 4000 "configure"
+#line 3994 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4019,7 +4013,7 @@
; return 0; }
EOF
-if { (eval echo configure:4023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4039,13 +4033,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4043: checking for gethostbyname in -lnsl" >&5
+echo "configure:4037: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4049 "configure"
+#line 4043 "configure"
@@ -4056,7 +4050,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4085,10 +4079,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4089: checking for connect" >&5
+echo "configure:4083: checking for connect" >&5
-#line 4092 "configure"
+#line 4086 "configure"
which can conflict with char connect(); below. */
@@ -4111,7 +4105,7 @@
; return 0; }
EOF
-if { (eval echo configure:4115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4131,13 +4125,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4135: checking for connect in -lsocket" >&5
+echo "configure:4129: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4141 "configure"
+#line 4135 "configure"
@@ -4148,7 +4142,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4171,10 +4165,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4175: checking for remove" >&5
+echo "configure:4169: checking for remove" >&5
-#line 4178 "configure"
+#line 4172 "configure"
which can conflict with char remove(); below. */
@@ -4197,7 +4191,7 @@
; return 0; }
EOF
-if { (eval echo configure:4201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4217,13 +4211,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4221: checking for remove in -lposix" >&5
+echo "configure:4215: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4227 "configure"
+#line 4221 "configure"
@@ -4234,7 +4228,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4257,10 +4251,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4261: checking for shmat" >&5
+echo "configure:4255: checking for shmat" >&5
-#line 4264 "configure"
+#line 4258 "configure"
which can conflict with char shmat(); below. */
@@ -4283,7 +4277,7 @@
; return 0; }
EOF
-if { (eval echo configure:4287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4303,13 +4297,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4307: checking for shmat in -lipc" >&5
+echo "configure:4301: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4313 "configure"
+#line 4307 "configure"
@@ -4320,7 +4314,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4352,13 +4346,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4356: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4350: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4362 "configure"
+#line 4356 "configure"
@@ -4369,7 +4363,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4409,12 +4403,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4413: checking for library containing cuserid" >&5
+echo "configure:4407: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4418 "configure"
+#line 4412 "configure"
@@ -4425,7 +4419,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4436,7 +4430,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4440 "configure"
+#line 4434 "configure"
@@ -4447,7 +4441,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4473,10 +4467,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4477: checking for xdrmem_create" >&5
+echo "configure:4471: checking for xdrmem_create" >&5
-#line 4480 "configure"
+#line 4474 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -4499,7 +4493,7 @@
; return 0; }
EOF
-if { (eval echo configure:4503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -4517,13 +4511,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4521: checking for xdrmem_create in -lsun" >&5
+echo "configure:4515: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 4527 "configure"
+#line 4521 "configure"
@@ -4534,7 +4528,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4553,13 +4547,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4557: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4551: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4563 "configure"
+#line 4557 "configure"
@@ -4570,7 +4564,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4589,13 +4583,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4593: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4587: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 4599 "configure"
+#line 4593 "configure"
@@ -4606,7 +4600,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4625,13 +4619,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4629: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4623: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 4635 "configure"
+#line 4629 "configure"
@@ -4642,7 +4636,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4676,10 +4670,10 @@
for ac_func in asprintf
do
-echo "configure:4680: checking for $ac_func" >&5
+echo "configure:4674: checking for $ac_func" >&5
-#line 4683 "configure"
+#line 4677 "configure"
@@ -4702,7 +4696,7 @@
; return 0; }
EOF
-if { (eval echo configure:4706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4729,10 +4723,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4733: checking for atan" >&5
+echo "configure:4727: checking for atan" >&5
-#line 4736 "configure"
+#line 4730 "configure"
which can conflict with char atan(); below. */
@@ -4755,7 +4749,7 @@
; return 0; }
EOF
-if { (eval echo configure:4759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4773,13 +4767,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4777: checking for atan in -lm" >&5
+echo "configure:4771: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4783 "configure"
+#line 4777 "configure"
@@ -4790,7 +4784,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4817,10 +4811,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4821: checking for dlsym" >&5
+echo "configure:4815: checking for dlsym" >&5
-#line 4824 "configure"
+#line 4818 "configure"
which can conflict with char dlsym(); below. */
@@ -4843,7 +4837,7 @@
; return 0; }
EOF
-if { (eval echo configure:4847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4861,13 +4855,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4865: checking for dlsym in -ldl" >&5
+echo "configure:4859: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4871 "configure"
+#line 4865 "configure"
@@ -4878,7 +4872,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4905,10 +4899,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4909: checking for iconv" >&5
+echo "configure:4903: checking for iconv" >&5
-#line 4912 "configure"
+#line 4906 "configure"
which can conflict with char iconv(); below. */
@@ -4931,7 +4925,7 @@
; return 0; }
EOF
-if { (eval echo configure:4935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4949,13 +4943,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4953: checking for iconv in -liconv" >&5
+echo "configure:4947: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4959 "configure"
+#line 4953 "configure"
@@ -4966,7 +4960,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4985,13 +4979,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4989: checking for iconv in -lgiconv" >&5
+echo "configure:4983: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4995 "configure"
+#line 4989 "configure"
@@ -5002,7 +4996,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:5006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5021,10 +5015,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:5025: checking for libiconv" >&5
+echo "configure:5019: checking for libiconv" >&5
-#line 5028 "configure"
+#line 5022 "configure"
which can conflict with char libiconv(); below. */
@@ -5047,7 +5041,7 @@
; return 0; }
EOF
-if { (eval echo configure:5051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -5065,13 +5059,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5069: checking for libiconv in -liconv" >&5
+echo "configure:5063: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5075 "configure"
+#line 5069 "configure"
@@ -5082,7 +5076,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5101,13 +5095,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5105: checking for libiconv in -lgiconv" >&5
+echo "configure:5099: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5111 "configure"
+#line 5105 "configure"
@@ -5118,7 +5112,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5155,10 +5149,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5159: checking for socket" >&5
+echo "configure:5153: checking for socket" >&5
-#line 5162 "configure"
+#line 5156 "configure"
which can conflict with char socket(); below. */
@@ -5181,7 +5175,7 @@
; return 0; }
EOF
-if { (eval echo configure:5185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5199,13 +5193,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5203: checking for socket in -lsocket" >&5
+echo "configure:5197: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5209 "configure"
+#line 5203 "configure"
@@ -5216,7 +5210,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5264,7 +5258,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5268: checking for location of zlib includes" >&5
+echo "configure:5262: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5290,15 +5284,15 @@
do
-echo "configure:5294: checking for $ac_hdr" >&5
+echo "configure:5288: checking for $ac_hdr" >&5
-#line 5297 "configure"
+#line 5291 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5332,7 +5326,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5336: checking for location of zlib library" >&5
+echo "configure:5330: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5357,13 +5351,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5361: checking for deflate in -lz" >&5
+echo "configure:5355: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5367 "configure"
+#line 5361 "configure"
@@ -5374,7 +5368,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5422,7 +5416,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5426: checking for location of External PROJ.4 includes" >&5
+echo "configure:5420: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5448,15 +5442,15 @@
do
-echo "configure:5452: checking for $ac_hdr" >&5
+echo "configure:5446: checking for $ac_hdr" >&5
-#line 5455 "configure"
+#line 5449 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5454: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5493,7 +5487,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5497: checking External PROJ.4 version" >&5
+echo "configure:5491: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5501,7 +5495,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5505 "configure"
+#line 5499 "configure"
#include <stdio.h>
@@ -5513,7 +5507,7 @@
EOF
-if { (eval echo configure:5517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5538,7 +5532,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5542: checking for location of External PROJ.4 library" >&5
+echo "configure:5536: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5563,13 +5557,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5567: checking for pj_get_def in -lproj" >&5
+echo "configure:5561: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5573 "configure"
+#line 5567 "configure"
@@ -5580,7 +5574,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5614,7 +5608,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5618: checking for location of External PROJ.4 data files" >&5
+echo "configure:5612: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5638,14 +5632,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5642: checking for epsg" >&5
+echo "configure:5636: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5649: checking for $PROJSHARE/epsg" >&5
+echo "configure:5643: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5677,7 +5671,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5681: checking for $ac_word" >&5
+echo "configure:5675: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5717,7 +5711,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5721: checking whether to use regex" >&5
+echo "configure:5715: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5737,7 +5731,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5741: checking for location of regex includes" >&5
+echo "configure:5735: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5763,15 +5757,15 @@
do
-echo "configure:5767: checking for $ac_hdr" >&5
+echo "configure:5761: checking for $ac_hdr" >&5
-#line 5770 "configure"
+#line 5764 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5805,7 +5799,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5809: checking for location of regex library" >&5
+echo "configure:5803: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5830,10 +5824,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5834: checking for regcomp" >&5
+echo "configure:5828: checking for regcomp" >&5
-#line 5837 "configure"
+#line 5831 "configure"
which can conflict with char regcomp(); below. */
@@ -5856,7 +5850,7 @@
; return 0; }
EOF
-if { (eval echo configure:5860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5883,13 +5877,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5887: checking for regcomp in -lregex" >&5
+echo "configure:5881: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5893 "configure"
+#line 5887 "configure"
@@ -5900,7 +5894,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5950,7 +5944,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5954: checking whether to use Readline" >&5
+echo "configure:5948: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5971,7 +5965,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5975: checking for location of Readline includes" >&5
+echo "configure:5969: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5997,15 +5991,15 @@
do
-echo "configure:6001: checking for $ac_hdr" >&5
+echo "configure:5995: checking for $ac_hdr" >&5
-#line 6004 "configure"
+#line 5998 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6003: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6041,15 +6035,15 @@
do
-echo "configure:6045: checking for $ac_hdr" >&5
+echo "configure:6039: checking for $ac_hdr" >&5
-#line 6048 "configure"
+#line 6042 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6053: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6083,7 +6077,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6087: checking for location of Readline library" >&5
+echo "configure:6081: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6108,13 +6102,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6112: checking for readline in -lreadline" >&5
+echo "configure:6106: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6118 "configure"
+#line 6112 "configure"
@@ -6125,7 +6119,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6160,13 +6154,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6164: checking for add_history in -lhistory" >&5
+echo "configure:6158: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6170 "configure"
+#line 6164 "configure"
@@ -6177,7 +6171,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6220,7 +6214,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:6224: checking whether to use JPEG" >&5
+echo "configure:6218: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -6240,7 +6234,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:6244: checking for location of JPEG includes" >&5
+echo "configure:6238: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -6266,15 +6260,15 @@
do
-echo "configure:6270: checking for $ac_hdr" >&5
+echo "configure:6264: checking for $ac_hdr" >&5
-#line 6273 "configure"
+#line 6267 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6308,7 +6302,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:6312: checking for location of JPEG library" >&5
+echo "configure:6306: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -6335,13 +6329,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:6339: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6333: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 6345 "configure"
+#line 6339 "configure"
@@ -6352,7 +6346,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:6356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6371,13 +6365,13 @@
-echo "configure:6375: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6369: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 6381 "configure"
+#line 6375 "configure"
@@ -6388,7 +6382,7 @@
; return 0; }
EOF
-if { (eval echo configure:6392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6437,7 +6431,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6441: checking whether to use GDAL" >&5
+echo "configure:6435: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6455,7 +6449,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6459: checking for $ac_word" >&5
+echo "configure:6453: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6510,14 +6504,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6514 "configure"
+#line 6508 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6526,14 +6520,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6530 "configure"
+#line 6524 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6565,7 +6559,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6569: checking whether to use libLAS" >&5
+echo "configure:6563: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6582,7 +6576,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6586: checking for $ac_word" >&5
+echo "configure:6580: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6630,14 +6624,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6634 "configure"
+#line 6628 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6645,14 +6639,14 @@
rm -rf conftest*
-#line 6649 "configure"
+#line 6643 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6684,7 +6678,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6688: checking whether to use GEOS" >&5
+echo "configure:6682: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -6702,7 +6696,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6706: checking for $ac_word" >&5
+echo "configure:6700: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6750,15 +6744,15 @@
do
-echo "configure:6754: checking for $ac_hdr" >&5
+echo "configure:6748: checking for $ac_hdr" >&5
-#line 6757 "configure"
+#line 6751 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6762: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6756: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6794,13 +6788,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6798: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6792: checking for initGEOS in -lgeos_c_i" >&5
ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c_i $LIBS"
-#line 6804 "configure"
+#line 6798 "configure"
@@ -6811,7 +6805,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6847,13 +6841,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6851: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6845: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6857 "configure"
+#line 6851 "configure"
@@ -6864,7 +6858,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6908,7 +6902,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6912: checking whether to use TIFF" >&5
+echo "configure:6906: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6928,7 +6922,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6932: checking for location of TIFF includes" >&5
+echo "configure:6926: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6954,15 +6948,15 @@
do
-echo "configure:6958: checking for $ac_hdr" >&5
+echo "configure:6952: checking for $ac_hdr" >&5
-#line 6961 "configure"
+#line 6955 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6966: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6996,7 +6990,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7000: checking for location of TIFF library" >&5
+echo "configure:6994: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7027,13 +7021,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7031: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7025: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7037 "configure"
+#line 7031 "configure"
@@ -7044,7 +7038,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7063,13 +7057,13 @@
-echo "configure:7067: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7061: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7073 "configure"
+#line 7067 "configure"
@@ -7080,7 +7074,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7099,13 +7093,13 @@
-echo "configure:7103: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7097: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7109 "configure"
+#line 7103 "configure"
@@ -7116,7 +7110,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7135,13 +7129,13 @@
-echo "configure:7139: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7133: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7145 "configure"
+#line 7139 "configure"
@@ -7152,7 +7146,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7171,13 +7165,13 @@
-echo "configure:7175: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7169: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7181 "configure"
+#line 7175 "configure"
@@ -7188,7 +7182,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7207,13 +7201,13 @@
-echo "configure:7211: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7205: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7217 "configure"
+#line 7211 "configure"
@@ -7224,7 +7218,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7243,13 +7237,13 @@
-echo "configure:7247: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7241: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7253 "configure"
+#line 7247 "configure"
@@ -7260,7 +7254,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7279,13 +7273,13 @@
-echo "configure:7283: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7277: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7289 "configure"
+#line 7283 "configure"
@@ -7296,7 +7290,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7394,7 +7388,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7398: checking whether to use PNG" >&5
+echo "configure:7392: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7413,7 +7407,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7417: checking for location of PNG includes" >&5
+echo "configure:7411: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7439,15 +7433,15 @@
do
-echo "configure:7443: checking for $ac_hdr" >&5
+echo "configure:7437: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 7446 "configure"
+#line 7440 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7451: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7445: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7481,7 +7475,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7485: checking for location of PNG library" >&5
+echo "configure:7479: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7506,13 +7500,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7510: checking for png_read_image in -lpng" >&5
+echo "configure:7504: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7516 "configure"
+#line 7510 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7523,7 +7517,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7565,7 +7559,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7569: checking whether to use PostgreSQL" >&5
+echo "configure:7563: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7592,7 +7586,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7596: checking for location of PostgreSQL includes" >&5
+echo "configure:7590: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7618,15 +7612,15 @@
do
-echo "configure:7622: checking for $ac_hdr" >&5
+echo "configure:7616: checking for $ac_hdr" >&5
-#line 7625 "configure"
+#line 7619 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7630: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7624: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7664,7 +7658,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7668: checking for location of PostgreSQL library" >&5
+echo "configure:7662: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7693,13 +7687,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7697: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7691: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7703 "configure"
+#line 7697 "configure"
@@ -7710,7 +7704,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7729,13 +7723,13 @@
-echo "configure:7733: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7727: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7739 "configure"
+#line 7733 "configure"
@@ -7746,7 +7740,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7765,13 +7759,13 @@
-echo "configure:7769: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7763: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7775 "configure"
+#line 7769 "configure"
@@ -7782,7 +7776,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7801,13 +7795,13 @@
-echo "configure:7805: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7799: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7811 "configure"
+#line 7805 "configure"
@@ -7818,7 +7812,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7875,13 +7869,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7879: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7873: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7885 "configure"
+#line 7879 "configure"
@@ -7892,7 +7886,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7914,13 +7908,13 @@
-echo "configure:7918: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7912: checking for PQcmdTuples in -lpq" >&5
-#line 7924 "configure"
+#line 7918 "configure"
@@ -7931,7 +7925,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7974,7 +7968,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7978: checking whether to use MySQL" >&5
+echo "configure:7972: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7994,7 +7988,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7998: checking for location of MySQL includes" >&5
+echo "configure:7992: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8020,15 +8014,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8024: checking for $ac_hdr" >&5
+echo "configure:8018: checking for $ac_hdr" >&5
-#line 8027 "configure"
+#line 8021 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8026: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8065,7 +8059,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8069: checking for location of MySQL library" >&5
+echo "configure:8063: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8096,13 +8090,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8100: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8094: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 8106 "configure"
+#line 8100 "configure"
@@ -8113,7 +8107,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8132,13 +8126,13 @@
-echo "configure:8136: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8130: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8142 "configure"
+#line 8136 "configure"
@@ -8149,7 +8143,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8168,13 +8162,13 @@
-echo "configure:8172: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8166: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8178 "configure"
+#line 8172 "configure"
@@ -8185,7 +8179,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8204,13 +8198,13 @@
-echo "configure:8208: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8202: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8214 "configure"
+#line 8208 "configure"
@@ -8221,7 +8215,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8240,13 +8234,13 @@
-echo "configure:8244: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8238: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8250 "configure"
+#line 8244 "configure"
@@ -8257,7 +8251,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8276,13 +8270,13 @@
-echo "configure:8280: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8274: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8286 "configure"
+#line 8280 "configure"
@@ -8293,7 +8287,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8312,13 +8306,13 @@
-echo "configure:8316: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8310: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8322 "configure"
+#line 8316 "configure"
@@ -8329,7 +8323,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8348,13 +8342,13 @@
-echo "configure:8352: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8346: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8358 "configure"
+#line 8352 "configure"
@@ -8365,7 +8359,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8455,7 +8449,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8459: checking for $ac_word" >&5
+echo "configure:8453: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8504,10 +8498,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8508: checking for mysql_server_init" >&5
+echo "configure:8502: checking for mysql_server_init" >&5
-#line 8511 "configure"
+#line 8505 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -8533,7 +8527,7 @@
; return 0; }
EOF
-if { (eval echo configure:8537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8585,7 +8579,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8589: checking whether to use SQLite" >&5
+echo "configure:8583: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8605,7 +8599,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8609: checking for location of SQLite includes" >&5
+echo "configure:8603: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8631,15 +8625,15 @@
do
-echo "configure:8635: checking for $ac_hdr" >&5
+echo "configure:8629: checking for $ac_hdr" >&5
-#line 8638 "configure"
+#line 8632 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8643: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8682,7 +8676,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8686: checking for location of SQLite library" >&5
+echo "configure:8680: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8711,13 +8705,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8715: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8709: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8721 "configure"
+#line 8715 "configure"
@@ -8728,7 +8722,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8747,13 +8741,13 @@
-echo "configure:8751: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8745: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8757 "configure"
+#line 8751 "configure"
@@ -8764,7 +8758,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8783,13 +8777,13 @@
-echo "configure:8787: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8781: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8793 "configure"
+#line 8787 "configure"
@@ -8800,7 +8794,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8819,13 +8813,13 @@
-echo "configure:8823: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8817: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8829 "configure"
+#line 8823 "configure"
@@ -8836,7 +8830,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8905,7 +8899,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8909: checking whether to use FFMPEG" >&5
+echo "configure:8903: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8925,7 +8919,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8929: checking for location of FFMPEG includes" >&5
+echo "configure:8923: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8951,15 +8945,15 @@
do
-echo "configure:8955: checking for $ac_hdr" >&5
+echo "configure:8949: checking for $ac_hdr" >&5
-#line 8958 "configure"
+#line 8952 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8963: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8995,15 +8989,15 @@
do
-echo "configure:8999: checking for $ac_hdr" >&5
+echo "configure:8993: checking for $ac_hdr" >&5
-#line 9002 "configure"
+#line 8996 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9039,15 +9033,15 @@
do
-echo "configure:9043: checking for $ac_hdr" >&5
+echo "configure:9037: checking for $ac_hdr" >&5
-#line 9046 "configure"
+#line 9040 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9051: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9090,7 +9084,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:9094: checking for location of FFMPEG library" >&5
+echo "configure:9088: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -9117,13 +9111,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:9121: checking for av_free in -lavutil" >&5
+echo "configure:9115: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 9127 "configure"
+#line 9121 "configure"
@@ -9134,7 +9128,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9153,13 +9147,13 @@
-echo "configure:9157: checking for av_free in -lavutil" >&5
+echo "configure:9151: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 9163 "configure"
+#line 9157 "configure"
@@ -9170,7 +9164,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9215,13 +9209,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9219: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9213: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 9225 "configure"
+#line 9219 "configure"
@@ -9232,7 +9226,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9251,13 +9245,13 @@
-echo "configure:9255: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9249: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9261 "configure"
+#line 9255 "configure"
@@ -9268,7 +9262,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9313,13 +9307,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9317: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9311: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9323 "configure"
+#line 9317 "configure"
@@ -9330,7 +9324,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9349,13 +9343,13 @@
-echo "configure:9353: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9347: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9359 "configure"
+#line 9353 "configure"
@@ -9366,7 +9360,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9425,7 +9419,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9429: checking whether to use OpenGL" >&5
+echo "configure:9423: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9459,7 +9453,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9463: checking for location of OpenGL includes" >&5
+echo "configure:9457: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9485,15 +9479,15 @@
do
-echo "configure:9489: checking for $ac_hdr" >&5
+echo "configure:9483: checking for $ac_hdr" >&5
-#line 9492 "configure"
+#line 9486 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9491: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9527,7 +9521,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9531: checking for location of OpenGL library" >&5
+echo "configure:9525: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9556,13 +9550,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9560: checking for glBegin in -lGL" >&5
+echo "configure:9554: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9566 "configure"
+#line 9560 "configure"
@@ -9573,7 +9567,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9592,13 +9586,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:9596: checking for glBegin in -lGL" >&5
+echo "configure:9590: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9602 "configure"
+#line 9596 "configure"
@@ -9609,7 +9603,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9628,13 +9622,13 @@
-echo "configure:9632: checking for glBegin in -lGL" >&5
+echo "configure:9626: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9638 "configure"
+#line 9632 "configure"
@@ -9645,7 +9639,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9664,13 +9658,13 @@
-echo "configure:9668: checking for glBegin in -lGL" >&5
+echo "configure:9662: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9674 "configure"
+#line 9668 "configure"
@@ -9681,7 +9675,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9743,13 +9737,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9747: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9741: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9753 "configure"
+#line 9747 "configure"
@@ -9760,7 +9754,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9779,13 +9773,13 @@
-echo "configure:9783: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9777: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9789 "configure"
+#line 9783 "configure"
@@ -9796,7 +9790,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9843,10 +9837,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9847: checking for glXCreatePbuffer" >&5
+echo "configure:9841: checking for glXCreatePbuffer" >&5
-#line 9850 "configure"
+#line 9844 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9869,7 +9863,7 @@
; return 0; }
EOF
-if { (eval echo configure:9873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9906,10 +9900,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9910: checking for glXCreateGLXPixmap" >&5
+echo "configure:9904: checking for glXCreateGLXPixmap" >&5
-#line 9913 "configure"
+#line 9907 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9932,7 +9926,7 @@
; return 0; }
EOF
-if { (eval echo configure:9936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9975,7 +9969,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9979: checking for location of OpenGL framework" >&5
+echo "configure:9973: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9999,15 +9993,15 @@
do
-echo "configure:10003: checking for $ac_hdr" >&5
+echo "configure:9997: checking for $ac_hdr" >&5
-#line 10006 "configure"
+#line 10000 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10043,10 +10037,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10047: checking for glBegin" >&5
+echo "configure:10041: checking for glBegin" >&5
-#line 10050 "configure"
+#line 10044 "configure"
which can conflict with char glBegin(); below. */
@@ -10069,7 +10063,7 @@
; return 0; }
EOF
-if { (eval echo configure:10073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -10106,10 +10100,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10110: checking for gluBeginCurve" >&5
+echo "configure:10104: checking for gluBeginCurve" >&5
-#line 10113 "configure"
+#line 10107 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -10132,7 +10126,7 @@
; return 0; }
EOF
-if { (eval echo configure:10136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -10180,7 +10174,7 @@
-echo "configure:10184: checking for location of OpenGL includes" >&5
+echo "configure:10178: checking for location of OpenGL includes" >&5
@@ -10206,15 +10200,15 @@
do
-echo "configure:10210: checking for $ac_hdr" >&5
+echo "configure:10204: checking for $ac_hdr" >&5
-#line 10213 "configure"
+#line 10207 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10248,7 +10242,7 @@
-echo "configure:10252: checking for location of OpenGL library" >&5
+echo "configure:10246: checking for location of OpenGL library" >&5
@@ -10273,18 +10267,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10277: checking for OpenGL library" >&5
+echo "configure:10271: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 10281 "configure"
+#line 10275 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:10288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -10308,18 +10302,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10312: checking for GLU library" >&5
+echo "configure:10306: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10316 "configure"
+#line 10310 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10368,7 +10362,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10372: checking whether to use Tcl/Tk" >&5
+echo "configure:10366: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -10388,7 +10382,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10392: checking for location of Tcl/Tk includes" >&5
+echo "configure:10386: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10414,15 +10408,15 @@
do
-echo "configure:10418: checking for $ac_hdr" >&5
+echo "configure:10412: checking for $ac_hdr" >&5
-#line 10421 "configure"
+#line 10415 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10459,15 +10453,15 @@
do
-echo "configure:10463: checking for $ac_hdr" >&5
+echo "configure:10457: checking for $ac_hdr" >&5
-#line 10466 "configure"
+#line 10460 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10471: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10465: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10501,7 +10495,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10505: checking Tcl version" >&5
+echo "configure:10499: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -10509,7 +10503,7 @@
else
-#line 10513 "configure"
+#line 10507 "configure"
#include <stdio.h>
@@ -10521,7 +10515,7 @@
EOF
-if { (eval echo configure:10525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -10539,7 +10533,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10543: checking Tk version" >&5
+echo "configure:10537: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10547,7 +10541,7 @@
else
-#line 10551 "configure"
+#line 10545 "configure"
#include <stdio.h>
@@ -10559,7 +10553,7 @@
EOF
-if { (eval echo configure:10563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -10588,7 +10582,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10592: checking for location of Tcl/Tk library" >&5
+echo "configure:10586: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10628,13 +10622,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10632: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10626: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 10638 "configure"
+#line 10632 "configure"
@@ -10645,7 +10639,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10664,13 +10658,13 @@
-echo "configure:10668: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10662: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10674 "configure"
+#line 10668 "configure"
@@ -10681,7 +10675,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10708,13 +10702,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10712: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10706: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10718 "configure"
+#line 10712 "configure"
@@ -10725,7 +10719,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10744,13 +10738,13 @@
-echo "configure:10748: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10742: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10754 "configure"
+#line 10748 "configure"
@@ -10761,7 +10755,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10788,13 +10782,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10792: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10786: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10798 "configure"
+#line 10792 "configure"
@@ -10805,7 +10799,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10824,13 +10818,13 @@
-echo "configure:10828: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10822: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10834 "configure"
+#line 10828 "configure"
@@ -10841,7 +10835,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10919,13 +10913,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10923: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10917: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10929 "configure"
+#line 10923 "configure"
@@ -10936,7 +10930,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10955,13 +10949,13 @@
-echo "configure:10959: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10953: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10965 "configure"
+#line 10959 "configure"
@@ -10972,7 +10966,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10999,13 +10993,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11003: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10997: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11009 "configure"
+#line 11003 "configure"
@@ -11016,7 +11010,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11035,13 +11029,13 @@
-echo "configure:11039: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11033: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11045 "configure"
+#line 11039 "configure"
@@ -11052,7 +11046,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11079,13 +11073,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11083: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11077: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11089 "configure"
+#line 11083 "configure"
@@ -11096,7 +11090,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11115,13 +11109,13 @@
-echo "configure:11119: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11113: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11125 "configure"
+#line 11119 "configure"
@@ -11132,7 +11126,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11222,13 +11216,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:11226: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:11220: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 11232 "configure"
+#line 11226 "configure"
@@ -11239,7 +11233,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11289,7 +11283,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11293: checking whether to use ODBC" >&5
+echo "configure:11287: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11308,7 +11302,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11312: checking for location of ODBC includes" >&5
+echo "configure:11306: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11334,15 +11328,15 @@
do
-echo "configure:11338: checking for $ac_hdr" >&5
+echo "configure:11332: checking for $ac_hdr" >&5
-#line 11341 "configure"
+#line 11335 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11346: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11376,7 +11370,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11380: checking for location of ODBC library" >&5
+echo "configure:11374: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11401,13 +11395,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11405: checking for SQLConnect in -lodbc" >&5
+echo "configure:11399: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11411 "configure"
+#line 11405 "configure"
@@ -11418,7 +11412,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11443,13 +11437,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11447: checking for SQLConnect in -liodbc" >&5
+echo "configure:11441: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11453 "configure"
+#line 11447 "configure"
@@ -11460,7 +11454,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11485,11 +11479,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11489: checking for ODBC library" >&5
+echo "configure:11483: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11493 "configure"
+#line 11487 "configure"
#include <windows.h>
#include <sql.h>
@@ -11497,7 +11491,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11546,7 +11540,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11550: checking whether to use FFTW" >&5
+echo "configure:11544: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11565,7 +11559,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11569: checking for location of FFTW includes" >&5
+echo "configure:11563: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11591,15 +11585,15 @@
do
-echo "configure:11595: checking for $ac_hdr" >&5
+echo "configure:11589: checking for $ac_hdr" >&5
-#line 11598 "configure"
+#line 11592 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11603: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11597: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11627,15 +11621,15 @@
do
-echo "configure:11631: checking for $ac_hdr" >&5
+echo "configure:11625: checking for $ac_hdr" >&5
-#line 11634 "configure"
+#line 11628 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11639: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11633: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11663,15 +11657,15 @@
do
-echo "configure:11667: checking for $ac_hdr" >&5
+echo "configure:11661: checking for $ac_hdr" >&5
-#line 11670 "configure"
+#line 11664 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11675: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11717,7 +11711,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11721: checking for location of FFTW library" >&5
+echo "configure:11715: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11742,13 +11736,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11746: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11740: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11752 "configure"
+#line 11746 "configure"
@@ -11759,7 +11753,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:11763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11784,13 +11778,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11788: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11782: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 11794 "configure"
+#line 11788 "configure"
@@ -11801,7 +11795,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11826,13 +11820,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11830: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11824: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11836 "configure"
+#line 11830 "configure"
@@ -11843,7 +11837,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11900,7 +11894,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11904: checking whether to use BLAS" >&5
+echo "configure:11898: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -11921,7 +11915,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11925: checking for location of BLAS includes" >&5
+echo "configure:11919: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11941,7 +11935,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11945: checking for location of BLAS library" >&5
+echo "configure:11939: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11967,15 +11961,15 @@
do
-echo "configure:11971: checking for $ac_hdr" >&5
+echo "configure:11965: checking for $ac_hdr" >&5
-#line 11974 "configure"
+#line 11968 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11979: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12010,13 +12004,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12014: checking for dnrm2_ in -lblas" >&5
+echo "configure:12008: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12020 "configure"
+#line 12014 "configure"
@@ -12027,7 +12021,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12046,13 +12040,13 @@
-echo "configure:12050: checking for dnrm2_ in -lblas" >&5
+echo "configure:12044: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12056 "configure"
+#line 12050 "configure"
@@ -12063,7 +12057,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12107,13 +12101,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12111: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12105: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12117 "configure"
+#line 12111 "configure"
@@ -12124,7 +12118,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12139,13 +12133,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12143: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12137: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12149 "configure"
+#line 12143 "configure"
@@ -12156,7 +12150,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12171,13 +12165,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12175: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12169: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12181 "configure"
+#line 12175 "configure"
@@ -12188,7 +12182,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12234,16 +12228,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12238: checking for sgemm in $vlib_flags" >&5
+echo "configure:12232: checking for sgemm in $vlib_flags" >&5
-#line 12240 "configure"
+#line 12234 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12261,13 +12255,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12265: checking for sgemm_ in -lblas" >&5
+echo "configure:12259: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12271 "configure"
+#line 12265 "configure"
@@ -12278,7 +12272,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12293,13 +12287,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12297: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12291: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12303 "configure"
+#line 12297 "configure"
@@ -12310,7 +12304,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12325,13 +12319,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12329: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12323: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12335 "configure"
+#line 12329 "configure"
@@ -12342,7 +12336,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12376,13 +12370,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12380: checking for acosp in -lsunmath" >&5
+echo "configure:12374: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12386 "configure"
+#line 12380 "configure"
@@ -12393,7 +12387,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12408,13 +12402,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12412: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12406: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 12418 "configure"
+#line 12412 "configure"
#include "confdefs.h"
@@ -12425,7 +12419,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12455,13 +12449,13 @@
# Generic BLAS library
-echo "configure:12459: checking for sgemm_ in -lblas" >&5
+echo "configure:12453: checking for sgemm_ in -lblas" >&5
ac_save_LIBS="$LIBS"
LIBS="-lblas $LIBS"
-#line 12465 "configure"
+#line 12459 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12472,7 +12466,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12511,7 +12505,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12515: checking whether to use LAPACK" >&5
+echo "configure:12509: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12536,7 +12530,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12540: checking for location of LAPACK includes" >&5
+echo "configure:12534: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12556,7 +12550,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12560: checking for location of LAPACK library" >&5
+echo "configure:12554: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12582,15 +12576,15 @@
do
-echo "configure:12586: checking for $ac_hdr" >&5
+echo "configure:12580: checking for $ac_hdr" >&5
-#line 12589 "configure"
+#line 12583 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12594: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12622,10 +12616,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12626: checking for dsegv_" >&5
+echo "configure:12620: checking for dsegv_" >&5
-#line 12629 "configure"
+#line 12623 "configure"
which can conflict with char dsegv_(); below. */
@@ -12648,7 +12642,7 @@
; return 0; }
EOF
-if { (eval echo configure:12652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12675,13 +12669,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12679: checking for desgv_ in -llapack" >&5
+echo "configure:12673: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12685 "configure"
+#line 12679 "configure"
@@ -12692,7 +12686,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12724,13 +12718,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12728: checking for dgesv_ in -llapack" >&5
+echo "configure:12722: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 12734 "configure"
+#line 12728 "configure"
@@ -12741,7 +12735,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12760,13 +12754,13 @@
-echo "configure:12764: checking for dgesv_ in -llapack" >&5
+echo "configure:12758: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12770 "configure"
+#line 12764 "configure"
@@ -12777,7 +12771,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12833,7 +12827,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12837: checking whether to use Cairo" >&5
+echo "configure:12831: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -12865,7 +12859,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12869: checking for location of cairo includes" >&5
+echo "configure:12863: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12891,15 +12885,15 @@
do
-echo "configure:12895: checking for $ac_hdr" >&5
+echo "configure:12889: checking for $ac_hdr" >&5
-#line 12898 "configure"
+#line 12892 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12897: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12935,7 +12929,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12939: checking for location of cairo library" >&5
+echo "configure:12933: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12955,7 +12949,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12959: checking for cairo linking flags" >&5
+echo "configure:12953: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12971,10 +12965,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12975: checking for cairo_create" >&5
+echo "configure:12969: checking for cairo_create" >&5
-#line 12978 "configure"
+#line 12972 "configure"
which can conflict with char cairo_create(); below. */
@@ -12997,7 +12991,7 @@
; return 0; }
EOF
-if { (eval echo configure:13001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13031,10 +13025,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13035: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13029: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13038 "configure"
+#line 13032 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -13057,7 +13051,7 @@
; return 0; }
EOF
-if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -13090,10 +13084,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13094: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13088: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13097 "configure"
+#line 13091 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -13116,7 +13110,7 @@
; return 0; }
EOF
-if { (eval echo configure:13120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -13158,7 +13152,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13162: checking whether to use FreeType" >&5
+echo "configure:13156: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13177,7 +13171,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13181: checking for location of FreeType includes" >&5
+echo "configure:13175: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13203,15 +13197,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13207: checking for $ac_hdr" >&5
+echo "configure:13201: checking for $ac_hdr" >&5
-#line 13210 "configure"
+#line 13204 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13245,7 +13239,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13249: checking for location of FreeType library" >&5
+echo "configure:13243: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13270,13 +13264,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13274: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13268: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 13280 "configure"
+#line 13274 "configure"
@@ -13287,7 +13281,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13328,7 +13322,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13332: checking whether to use NLS" >&5
+echo "configure:13326: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13348,10 +13342,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13352: checking for gettext" >&5
+echo "configure:13346: checking for gettext" >&5
-#line 13355 "configure"
+#line 13349 "configure"
which can conflict with char gettext(); below. */
@@ -13374,7 +13368,7 @@
; return 0; }
EOF
-if { (eval echo configure:13378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13392,13 +13386,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13396: checking for gettext in -lintl" >&5
+echo "configure:13390: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13402 "configure"
+#line 13396 "configure"
@@ -13409,7 +13403,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13444,7 +13438,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13448: checking whether to use C++" >&5
+echo "configure:13442: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13460,7 +13454,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13464: checking for $ac_word" >&5
+echo "configure:13458: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13489,7 +13483,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13493: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13487: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13500,12 +13494,12 @@
cat > conftest.$ac_ext << EOF
-#line 13504 "configure"
+#line 13498 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13531,19 +13525,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13535: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13529: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13540: checking whether we are using GNU C++" >&5
+echo "configure:13534: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13547: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13541: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13561,7 +13555,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13565: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13559: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13602,7 +13596,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13606: checking whether to use openDWG" >&5
+echo "configure:13600: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13622,7 +13616,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13626: checking for location of openDGW includes" >&5
+echo "configure:13620: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13648,15 +13642,15 @@
do
-echo "configure:13652: checking for $ac_hdr" >&5
+echo "configure:13646: checking for $ac_hdr" >&5
-#line 13655 "configure"
+#line 13649 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13690,7 +13684,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13694: checking for location of openDWG library" >&5
+echo "configure:13688: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13731,7 +13725,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13735: checking whether to use POSIX threads" >&5
+echo "configure:13729: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -13751,7 +13745,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13755: checking for location of POSIX threads includes" >&5
+echo "configure:13749: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13777,15 +13771,15 @@
do
-echo "configure:13781: checking for $ac_hdr" >&5
+echo "configure:13775: checking for $ac_hdr" >&5
-#line 13784 "configure"
+#line 13778 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13789: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13783: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13819,7 +13813,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13823: checking for location of POSIX threads library" >&5
+echo "configure:13817: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13844,10 +13838,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13848: checking for pthread_create" >&5
+echo "configure:13842: checking for pthread_create" >&5
-#line 13851 "configure"
+#line 13845 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -13870,7 +13864,7 @@
; return 0; }
EOF
-if { (eval echo configure:13874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -13897,13 +13891,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13901: checking for pthread_create in -lpthread" >&5
+echo "configure:13895: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 13907 "configure"
+#line 13901 "configure"
@@ -13914,7 +13908,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:13918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13964,7 +13958,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13968: checking whether to use OpenMP" >&5
+echo "configure:13962: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -13985,7 +13979,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13989: checking for location of OpenMP includes" >&5
+echo "configure:13983: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -14011,15 +14005,15 @@
do
-echo "configure:14015: checking for $ac_hdr" >&5
+echo "configure:14009: checking for $ac_hdr" >&5
-#line 14018 "configure"
+#line 14012 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14017: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14057,7 +14051,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:14061: checking for location of OpenMP library" >&5
+echo "configure:14055: checking for location of OpenMP library" >&5
case "$with_gomp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -14082,10 +14076,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:14086: checking for GOMP_parallel_start" >&5
+echo "configure:14080: checking for GOMP_parallel_start" >&5
-#line 14089 "configure"
+#line 14083 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -14108,7 +14102,7 @@
; return 0; }
EOF
-if { (eval echo configure:14112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -14135,13 +14129,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:14139: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:14133: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 14145 "configure"
+#line 14139 "configure"
@@ -14152,7 +14146,7 @@
; return 0; }
EOF
-if { (eval echo configure:14156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14231,7 +14225,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14235: checking for special C compiler options needed for large files" >&5
+echo "configure:14229: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14239,7 +14233,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14243 "configure"
+#line 14237 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14255,7 +14249,7 @@
; return 0; }
EOF
-if { (eval echo configure:14259: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14253: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14264,7 +14258,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14268 "configure"
+#line 14262 "configure"
@@ -14280,7 +14274,7 @@
; return 0; }
EOF
-if { (eval echo configure:14284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14278: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14300,11 +14294,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14304: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14298: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14308 "configure"
+#line 14302 "configure"
@@ -14320,14 +14314,14 @@
; return 0; }
EOF
-if { (eval echo configure:14324: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14318: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14331 "configure"
+#line 14325 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14345,7 +14339,7 @@
; return 0; }
EOF
-if { (eval echo configure:14349: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14343: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14364,11 +14358,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14368: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14362: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14372 "configure"
+#line 14366 "configure"
@@ -14384,14 +14378,14 @@
; return 0; }
EOF
-if { (eval echo configure:14388: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14382: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14395 "configure"
+#line 14389 "configure"
#define _LARGE_FILES 1
@@ -14409,7 +14403,7 @@
; return 0; }
EOF
-if { (eval echo configure:14413: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14407: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14428,25 +14422,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14432: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14426: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14436 "configure"
+#line 14430 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14443: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14437: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14450 "configure"
+#line 14444 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14455,7 +14449,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14459: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14453: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14476,25 +14470,25 @@
fi
-echo "configure:14480: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14474: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14484 "configure"
+#line 14478 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14491: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14485: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14498 "configure"
+#line 14492 "configure"
#include <stdio.h>
@@ -14503,7 +14497,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14507: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -14526,18 +14520,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14530: checking for fseeko" >&5
+echo "configure:14524: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 14534 "configure"
+#line 14528 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:14541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -14554,10 +14548,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14558: checking if system supports Large Files at all" >&5
+echo "configure:14552: checking if system supports Large Files at all" >&5
-#line 14561 "configure"
+#line 14555 "configure"
#include <stdio.h>
@@ -14589,7 +14583,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14593: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14587: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14618,7 +14612,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14622: checking whether to use wxWidgets" >&5
+echo "configure:14616: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14639,7 +14633,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14643: checking for $ac_word" >&5
+echo "configure:14637: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14687,7 +14681,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14691: checking wxWidgets version" >&5
+echo "configure:14685: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14710,15 +14704,15 @@
do
-echo "configure:14714: checking for $ac_hdr" >&5
+echo "configure:14708: checking for $ac_hdr" >&5
-#line 14717 "configure"
+#line 14711 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14716: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14911,8 +14905,6 @@
s%@MACOSX_ARCHS@%$MACOSX_ARCHS%g
s%@MACOSX_SDK@%$MACOSX_SDK%g
s%@INSTDIR@%$INSTDIR%g
-s%@GRASS_LIB_PREFIX@%$GRASS_LIB_PREFIX%g
-s%@GRASS_LIB_SUFFIX@%$GRASS_LIB_SUFFIX%g
s%@GRASS_LIBRARY_TYPE@%$GRASS_LIBRARY_TYPE%g
s%@PLAT_OBJS@%$PLAT_OBJS%g
s%@CC_SEARCH_FLAGS@%$CC_SEARCH_FLAGS%g
Modified: grass/trunk/display/d.mon/Makefile
--- grass/trunk/display/d.mon/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/display/d.mon/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM = d.mon
-LIBES = $(DISPLAYLIB) $(GISLIB)
-DEPENDENCIES= $(DISPLAYDEP) $(GISDEP)
+LIBES = $(GISLIB)
+DEPENDENCIES= $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/include/Make/Grass.make 2012-02-10 19:38:42 UTC (rev 50759)
@@ -216,9 +216,9 @@
ROWIODEPS = $(GISLIB)
RTREEDEPS = $(GISLIB) $(MATHLIB)
SEGMENTDEPS = $(GISLIB)
-#SIMDEPS = $(VECTLIB) $(BITMAPLIB) $(GMATHLIB) $(LINKMLIB) $(SITESLIB) $(DBMILIB) $(GISLIB)
+SIMDEPS = $(VECTLIB) $(RASTERLIB)
SITESDEPS = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(DATETIMELIB)
-STATSDEPS = $(RASTERLIB) $(GISLIB) $(MATHLIB) # NB: doesn't use libgis directly
+STATSDEPS = $(RASTERLIB) $(GISLIB) $(MATHLIB)
SYMBDEPS = $(GISLIB) $(MATHLIB)
TEMPORALDEPS = $(DBMILIB) $(GISLIB) $(DATETIMELIB)
VECTORDEPS = $(DBMILIB) $(GRAPHLIB) $(DIG2LIB) $(LINKMLIB) $(RTREELIB) $(GISLIB) $(GEOSLIBS) $(GDALLIBS) $(MATHLIB) $(BTREE2LIB) $(GPROJLIB) $(RASTERDEP) $(PQLIBPATH) $(PQLIB)
@@ -254,6 +254,11 @@
ifeq ($(GRASS_LIBRARY_TYPE),stlib)
NEED_DEPS = 1
+LIB_PREFIX = $(STLIB_PREFIX)
+LIB_SUFFIX = $(STLIB_SUFFIX)
+else
+LIB_PREFIX = $(SHLIB_PREFIX)
+LIB_SUFFIX = $(SHLIB_SUFFIX)
endif
define lib_rules
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/include/Make/Platform.make.in 2012-02-10 19:38:42 UTC (rev 50759)
@@ -56,8 +56,6 @@
LD_LIBRARY_PATH_VAR = @LD_LIBRARY_PATH_VAR@
#generate static (ST) or shared (SH)
-LIB_PREFIX = @GRASS_LIB_PREFIX@
-LIB_SUFFIX = @GRASS_LIB_SUFFIX@
GRASS_LIBRARY_TYPE = @GRASS_LIBRARY_TYPE@
#static libs:
Modified: grass/trunk/lib/python/ctypes/Makefile
--- grass/trunk/lib/python/ctypes/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/lib/python/ctypes/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -13,7 +13,7 @@
dbmi raster3d arraystats cluster vedit ogsf nviz
date_LIBS = $(DATETIMELIB)
-gis_LIBS = $(GISLIB)
+gis_LIBS = $(GISLIB)
raster_LIBS = $(RASTERLIB)
gmath_LIBS = $(GMATHLIB)
proj_LIBS = $(GPROJLIB)
@@ -69,10 +69,13 @@
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__ ctypes_preamble ctypes_loader)
LPYFILES := $(patsubst %,$(OBJDIR)/%.py,$(MODULES))
-ifneq ($(strip $(CTYPESGEN)),)
+ifeq ($(strip $(GRASS_LIBRARY_TYPE)),shlib)
default:
$(MAKE) $(DSTDIR)
$(MAKE) $(LPYFILES) $(PYFILES) $(PYCFILES)
+else
+default:
+ @echo "Cannot build Python wrappers for static libraries" >&2
endif
$(DSTDIR)/__init__.py: __init__.py | $(DSTDIR)
Modified: grass/trunk/misc/m.nviz.image/Makefile
--- grass/trunk/misc/m.nviz.image/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/misc/m.nviz.image/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,16 +2,6 @@
PGM = m.nviz.image
-ifeq ($(OPENGL_X11),1)
-OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) $(XLIBPATH) $(XLIB) -lXmu -lXext $(XEXTRALIBS) $(MATHLIB)
-endif
-ifeq ($(OPENGL_WINDOWS),1)
-OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) -lgdi32 $(MATHLIB)
-endif
-ifeq ($(OPENGL_AQUA),1)
-OGL_LIBS := $(OPENGLULIB) $(OPENGLLIB) $(MATHLIB)
-endif
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(INC) \
$(TIFFINCPATH) $(DSPINC) \
@@ -22,11 +12,9 @@
EXTRA_CFLAGS += $(XCFLAGS)
endif
-EXTRA_LDFLAGS = $(OGL_LIBS)
+LIBES = $(GISLIB) $(OGSFLIB) $(NVIZLIB) $(VECTORLIB) $(DBMILIB)
+DEPENDENCIES = $(GISDEP) $(OGSFDEP) $(NVIZDEP) $(VECTORDEP) $(DBMIDEP)
-LIBES = $(GISLIB) $(OGSFLIB) $(NVIZLIB) $(RASTER3DLIB) $(VECTORLIB) $(DBMILIB)
-DEPENDENCIES = $(GISDEP) $(NVIZDEP) $(VECTORDEP) $(DBMIDEP)
ifneq ($(USE_OPENGL),)
Modified: grass/trunk/raster/simwe/r.sim.sediment/Makefile
--- grass/trunk/raster/simwe/r.sim.sediment/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/raster/simwe/r.sim.sediment/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -4,11 +4,8 @@
EXTRA_CLEAN_DIRS=doxygenhtml
-LIBES = $(SIMLIB) $(BITMAPLIB) $(LINKMLIB) \
- $(SITESLIB) $(VECTLIB) $(VECTLIB_REAL) \
- $(DBMILIB) $(GISLIB) $(DATETIMELIB) $(GMATHLIB) $(RASTERLIB)
-DEPENDENCIES = $(SIMDEP) $(BITMAPDEP) $(LINKMDEP) \
- $(VECTDEP) $(DBMIDEP) $(GISDEP) $(DATETIMEDEP) $(GMATHDEP) $(RASTERDEP)
+LIBES = $(SIMLIB) $(GMATHLIB) $(GISLIB)
+DEPENDENCIES = $(SIMDEP) $(GMATHDEP) $(GISDEP)
EXTRA_CFLAGS = -I ../simlib $(VECT_CFLAGS)
Modified: grass/trunk/raster/simwe/r.sim.water/Makefile
--- grass/trunk/raster/simwe/r.sim.water/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/raster/simwe/r.sim.water/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -4,10 +4,8 @@
- $(SITESLIB) $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB) $(DATETIMELIB) $(GMATHLIB) $(RASTERLIB)
Modified: grass/trunk/raster3d/r3.mask/Makefile
--- grass/trunk/raster3d/r3.mask/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/raster3d/r3.mask/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM=r3.mask
-LIBES = $(GPDELIB) $(RASTER3DLIB) $(GISLIB)
-DEPENDENCIES = $(GPDEDEP) $(RASTER3DDEP) $(GISDEP)
+LIBES = $(RASTER3DLIB) $(GISLIB)
+DEPENDENCIES = $(RASTER3DDEP) $(GISDEP)
Modified: grass/trunk/raster3d/r3.mkdspf/Makefile
--- grass/trunk/raster3d/r3.mkdspf/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/raster3d/r3.mkdspf/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -8,7 +8,7 @@
EXTRA_CFLAGS = -I$(LDIR)
# -I$(INCLUDE_DIR)
-LIBES = $(DSPFLIB) $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
-DEPENDENCIES = $(DSPFDEP) $(RASTER3DDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(DSPFLIB) $(RASTER3DLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(DSPFDEP) $(RASTER3DDEP) $(GISDEP)
default: cmd
Modified: grass/trunk/raster3d/r3.null/Makefile
--- grass/trunk/raster3d/r3.null/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/raster3d/r3.null/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM=r3.null
Modified: grass/trunk/raster3d/r3.timestamp/Makefile
--- grass/trunk/raster3d/r3.timestamp/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/raster3d/r3.timestamp/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM=r3.timestamp
-LIBES = $(RASTER3DLIB) $(GISLIB)
-DEPENDENCIES = $(RASTER3DDEP) $(GISDEP)
+LIBES = $(GISLIB)
Modified: grass/trunk/vector/v.external.out/Makefile
--- grass/trunk/vector/v.external.out/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/vector/v.external.out/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM=v.external.out
-LIBES = $(VECTORLIB) $(GISLIB) $(GDALLIBS)
-DEPENDENCIES = $(VECTORDEP) $(GISDEP)
+LIBES = $(GISLIB) $(GDALLIBS)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/vector/v.lidar.correction/Makefile
--- grass/trunk/vector/v.lidar.correction/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/vector/v.lidar.correction/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM = v.lidar.correction
-LIBES = $(LIDARLIB) $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(SEGMENTLIB) $(MATHLIB)
-DEPENDENCIES = $(LIDARDEP) $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(SEGMENTDEP)
+LIBES = $(LIDARLIB) $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(MATHLIB)
+DEPENDENCIES = $(LIDARDEP) $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP)
@@ -11,4 +11,3 @@
default: cmd
Modified: grass/trunk/vector/v.lidar.edgedetection/Makefile
--- grass/trunk/vector/v.lidar.edgedetection/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/vector/v.lidar.edgedetection/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM = v.lidar.edgedetection
-LIBES = $(LIDARLIB) $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(SEGMENTLIB) $(GISLIB) $(MATHLIB)
-DEPENDENCIES = $(LIDARDEP) $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(SEGMENTDEP) $(GISDEP)
+LIBES = $(LIDARLIB) $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
@@ -11,4 +11,3 @@
default: cmd
Modified: grass/trunk/vector/v.lidar.growing/Makefile
--- grass/trunk/vector/v.lidar.growing/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/vector/v.lidar.growing/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM = v.lidar.growing
-LIBES = $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(SEGMENTLIB) $(GISLIB)
-DEPENDENCIES = $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(SEGMENTDEP) $(GISDEP)
+LIBES = $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
@@ -11,4 +11,3 @@
default: cmd
Modified: grass/trunk/vector/v.outlier/Makefile
--- grass/trunk/vector/v.outlier/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/vector/v.outlier/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,8 +2,8 @@
PGM = v.outlier
Modified: grass/trunk/vector/v.timestamp/Makefile
--- grass/trunk/vector/v.timestamp/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/vector/v.timestamp/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -2,10 +2,8 @@
PGM = v.timestamp
-LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP)
-EXTRA_INC = $(VECT_INC)
-EXTRA_CFLAGS = $(VECT_CFLAGS)
+LIBES = $(GISLIB)
Modified: grass/trunk/vector/v.timestamp/main.c
--- grass/trunk/vector/v.timestamp/main.c 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/vector/v.timestamp/main.c 2012-02-10 19:38:42 UTC (rev 50759)
@@ -18,7 +18,6 @@
#include <stdio.h>
#include <string.h>
#include <grass/gis.h>
-#include <grass/vector.h>
#include <grass/glocale.h>
int main(int argc, char *argv[])
Modified: grass/trunk/visualization/nviz/src/Makefile
--- grass/trunk/visualization/nviz/src/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/visualization/nviz/src/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -40,9 +40,8 @@
EXTRA_LIBS = $(TCLTKLIBS) $(OGL_LIBS)
LIBES = $(SURFLIB) \
- $(BITMAPLIB) $(LINKMLIB) $(VECTLIB) $(SITESLIB) $(FORMLIB) $(DBMILIB) \
- $(RASTER3DLIB) $(GISLIB) \
- $(DATETIMELIB) $(TIFFLIBPATH) $(TIFFLIB)
+ $(VECTLIB) $(FORMLIB) $(DBMILIB) \
+ $(GISLIB)
DEPENDENCIES = $(VECTDEP) $(BITMAPDEP) $(LINKMDEP) $(FORMDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/visualization/wximgview/Makefile
--- grass/trunk/visualization/wximgview/Makefile 2012-02-10 19:37:24 UTC (rev 50758)
+++ grass/trunk/visualization/wximgview/Makefile 2012-02-10 19:38:42 UTC (rev 50759)
@@ -4,8 +4,8 @@
EXTRA_CFLAGS = $(WXWIDGETSCXXFLAGS) -DWXINTL_NO_GETTEXT_MACRO
-LIBES = $(RASTERLIB) $(GISLIB) $(WXWIDGETSLIB)
-DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+LIBES = $(GISLIB) $(WXWIDGETSLIB)
