[GRASS-SVN] r50157 - sandbox/lucadelu
Thu Jan 12 11:31:27 EST 2012
Author: lucadelu
Date: 2012-01-12 08:31:27 -0800 (Thu, 12 Jan 2012)
New Revision: 50157
   sandbox/lucadelu/r.li.setup.py
r.li.setup improvement
Modified: sandbox/lucadelu/r.li.setup.py
--- sandbox/lucadelu/r.li.setup.py	2012-01-12 14:48:43 UTC (rev 50156)
+++ sandbox/lucadelu/r.li.setup.py	2012-01-12 16:31:27 UTC (rev 50157)
@@ -21,8 +21,7 @@
 import sys
 import os
-sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython',
-                                 'gui_modules'))
+sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
 import wx
 import wx.lib.mixins.listctrl as listmix
@@ -30,11 +29,11 @@
 import wx.lib.scrolledpanel as scrolled
 import time
-import globalvar
-import gselect
-import gcmd
-import utils
-from location_wizard import TitledPage as TitledPage
+from core import globalvar
+from core import gcmd
+from core import utils
+from gui_core import gselect
+from location_wizard.wizard import TitledPage as TitledPage
 from grass.script import core as grass
 from grass.script import raster as grast
@@ -50,9 +49,9 @@
 class RLiSetupFrame(wx.Frame):
     def __init__(self, parent, id = wx.ID_ANY,
-		style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
+        style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
                 title = _("r.li.setup"), **kwargs):
-	###VARIABLES
+        ###VARIABLES
         self.parent = parent
         self.cmd = "r.li.setup"
         self.major_version = int(grass.version()['version'].split('.', 1)[0])
@@ -64,37 +63,37 @@
         ###END VARIABLES
         #init of frame
         wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
-	self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
-	self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
-	#box for select configuration file
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        #box for select configuration file
         self.confilesBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
-                                    label= _('Available sampling area configuration files'))
-	self.listfileBox = wx.ListBox(parent = self.panel,  id = wx.ID_ANY,
-			      choices = self.listfiles)
-	###BUTTONS
-	#definition
+                                        label= _('Available sampling area configuration files'))
+        self.listfileBox = wx.ListBox(parent = self.panel,  id = wx.ID_ANY,
+                    choices = self.listfiles)
+        ###BUTTONS
+        #definition
         self.btn_close = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
-	self.btn_help = wx.Button(parent = self.panel, id = wx.ID_HELP)
-	self.btn_remove = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Remove"))
-	self.btn_remove.SetToolTipString(_('Remove a configuration file'))
-	self.btn_new = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Create"))
-	self.btn_new.SetToolTipString(_('Create a new configuration file'))
-	#set action for button
-	self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
-	self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
-	self.btn_remove.Bind(wx.EVT_BUTTON, self.OnRemove)
-	self.btn_new.Bind(wx.EVT_BUTTON, self.OnNew)
-	self._layout()
-	###END BUTTONS
+        self.btn_help = wx.Button(parent = self.panel, id = wx.ID_HELP)
+        self.btn_remove = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Remove"))
+        self.btn_remove.SetToolTipString(_('Remove a configuration file'))
+        self.btn_new = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Create"))
+        self.btn_new.SetToolTipString(_('Create a new configuration file'))
+        #set action for button
+        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
+        self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
+        self.btn_remove.Bind(wx.EVT_BUTTON, self.OnRemove)
+        self.btn_new.Bind(wx.EVT_BUTTON, self.OnNew)
+        self._layout()
+        ###END BUTTONS
-	###SIZE FRAME
-	self.SetMinSize(self.GetBestSize())
-	##Please check this because without this the size it is not the min
-	self.SetClientSize(self.GetBestSize())
-	###END SIZE
+        ###SIZE FRAME
+        self.SetMinSize(self.GetBestSize())
+        ##Please check this because without this the size it is not the min
+        self.SetClientSize(self.GetBestSize())
+        ###END SIZE
     def _layout(self):
-	"""Set the layout"""
+        """Set the layout"""
         sizer = wx.BoxSizer(wx.VERTICAL)
         ###CONFILES
         confilesSizer = wx.StaticBoxSizer(self.confilesBox, wx.HORIZONTAL)
@@ -108,7 +107,7 @@
         buttonSizer.Add(item = self.btn_help, flag = wx.ALL, border = 5)
         buttonSizer.Add(item = self.btn_close, flag = wx.ALL, border = 5)
         ###END BUTTONS
-	#add to sizer
+        #add to sizer
         sizer.Add(item = confilesSizer, proportion = 0,
                   flag = wx.ALIGN_LEFT | wx.EXPAND | wx.ALL, border = 3)
         sizer.Add(item = buttonSizer, proportion = 0,
@@ -120,16 +119,16 @@
         self.Layout()
     def CheckFolder(self):
-	"""!Check if the folder of r.li it is present in the .grass7 path"""
-	if os.path.exists(self.rlipath):
-	    return
-	else:
-	    os.mkdir(self.rlipath)
-	    return
+        """!Check if the folder of r.li it is present in the .grass7 path"""
+        if os.path.exists(self.rlipath):
+            return
+        else:
+            os.mkdir(self.rlipath)
+            return
     def ListFiles(self):
-	"""!Check the configuration files inside the path"""
-	return os.listdir(self.rlipath)
+        """!Check the configuration files inside the path"""
+        return os.listdir(self.rlipath)
     def OnClose(self,event):
         """!Close window"""
@@ -140,15 +139,15 @@
         gcmd.RunCommand('g.manual', parent = self, entry = self.cmd)
     def OnRemove(self, event):
-	"""!Remove configuration file from path and update the list"""
-	confile = self.listfiles[self.listfileBox.GetSelections()[0]]
-	self.listfileBox.Delete(self.listfileBox.GetSelections()[0])
-	grass.try_remove(os.path.join(self.rlipath,confile))
-	return
+        """!Remove configuration file from path and update the list"""
+        confile = self.listfiles[self.listfileBox.GetSelections()[0]]
+        self.listfileBox.Delete(self.listfileBox.GetSelections()[0])
+        grass.try_remove(os.path.join(self.rlipath,confile))
+        return
     def OnNew(self, event):
-	RLIWizard(self)
+        RLIWizard(self)
 class RLIWizard(object):
@@ -161,31 +160,31 @@
         #pages
         self.startpage = FirstPage(self.wizard, self)
-	self.keyboardpage = KeybordPage(self.wizard, self)
-	self.samplingareapage = SamplingAreasPage(self.wizard, self)
-	self.summarypage = SummaryPage(self.wizard, self)
-	self.samplingunitskey = SampleUnitsKeyPage(self.wizard, self)
+        self.keyboardpage = KeybordPage(self.wizard, self)
+        self.samplingareapage = SamplingAreasPage(self.wizard, self)
+        self.summarypage = SummaryPage(self.wizard, self)
+        self.samplingunitskey = SampleUnitsKeyPage(self.wizard, self)
-	#order of pages
-	self.startpage.SetNext(self.samplingareapage)
-	self.keyboardpage.SetPrev(self.startpage)
-	self.keyboardpage.SetNext(self.samplingareapage)
-	self.samplingareapage.SetPrev(self.startpage)
-	self.samplingareapage.SetNext(self.summarypage)
-	self.samplingunitskey.SetPrev(self.samplingareapage)
-	self.samplingunitskey.SetNext(self.summarypage)
-	self.summarypage.SetPrev(self.samplingareapage)
-	#layout
-	self.startpage.DoLayout()
-	self.keyboardpage.DoLayout()
-	self.samplingareapage.DoLayout()
-	self.summarypage.DoLayout()
-	self.samplingunitskey.DoLayout()
-	self.wizard.FitToPage(self.startpage)
-	#run_wizard
-	self.wizard.RunWizard(self.startpage)
+        #order of pages
+        self.startpage.SetNext(self.samplingareapage)
+        self.keyboardpage.SetPrev(self.startpage)
+        self.keyboardpage.SetNext(self.samplingareapage)
+        self.samplingareapage.SetPrev(self.startpage)
+        self.samplingareapage.SetNext(self.summarypage)
+        self.samplingunitskey.SetPrev(self.samplingareapage)
+        self.samplingunitskey.SetNext(self.summarypage)
+        self.summarypage.SetPrev(self.samplingareapage)
+        #layout
+        self.startpage.DoLayout()
+        self.keyboardpage.DoLayout()
+        self.samplingareapage.DoLayout()
+        self.summarypage.DoLayout()
+        self.samplingunitskey.DoLayout()
+        self.wizard.FitToPage(self.startpage)
+        #run_wizard
+        self.wizard.RunWizard(self.startpage)
 class FirstPage(TitledPage):
@@ -203,46 +202,45 @@
         self.vect = ''
         self.sizer.AddGrowableCol(2)
-	#name of output configuration file
-	self.newconflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Name for new configuration file to create'))
+        #name of output configuration file
+        self.newconflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Name for new configuration file to create'))
-	self.newconftxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-	wx.CallAfter(self.newconftxt.SetFocus)
-	self.sizer.Add(item = self.newconflabel, border=5, pos=(1, 1),
-                       flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
-	self.sizer.Add(item = self.newconftxt, border=5, pos=(1, 2),
-	#raster
-	self.mapsellabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					label = _('Raster map to use to select areas'))
+        self.newconftxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        wx.CallAfter(self.newconftxt.SetFocus)
+        self.sizer.Add(item = self.newconflabel, border=5, pos=(1, 1),
+                        flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+        self.sizer.Add(item = self.newconftxt, border=5, pos=(1, 2),
+        #raster
+        self.mapsellabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Raster map to use to select areas'))
         self.mapselect = gselect.Select(parent = self, id = wx.ID_ANY, size = (250, -1),
-                                        type = 'cell', multiple = False)
-	self.sizer.Add(item = self.mapsellabel, border=5, pos=(2, 1),
-	self.sizer.Add(item = self.mapselect, border=5, pos=(2, 2),
-	#vector
-	self.vectsellabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                            type = 'cell', multiple = False)
+        self.sizer.Add(item = self.mapsellabel, border=5, pos=(2, 1),
+        self.sizer.Add(item = self.mapselect, border=5, pos=(2, 2),
+        #vector
+        self.vectsellabel = wx.StaticText(parent = self, id = wx.ID_ANY,
         self.vectselect = gselect.Select(parent = self, id = wx.ID_ANY, size = (250, -1),
-                                        type = 'vector', multiple = False)
-	self.sizer.Add(item = self.vectsellabel, border=5, pos=(3, 1),
-	self.sizer.Add(item = self.vectselect, border=5, pos=(3, 2),
+                                            type = 'vector', multiple = False)
+        self.sizer.Add(item = self.vectsellabel, border=5, pos=(3, 1),
+        self.sizer.Add(item = self.vectselect, border=5, pos=(3, 2),
         #define sempling region
         self.sempling_reg = wx.RadioBox(parent=self, id=wx.ID_ANY,
-                                      label= _("Define sempling region (region for analysis)"),
-                                      choices=[_('Whole map layer'),
-                                      _('Keyboard setting'), _('Draw the sempling frame')],
-                                      majorDimension=wx.RA_SPECIFY_COLS)
+                                        label= _("Define sempling region (region for analysis)"),
+                                        choices=[_('Whole map layer'),
+                                        _('Keyboard setting'), _('Draw the sempling frame')],
+                                        majorDimension=wx.RA_SPECIFY_COLS)
         self.sizer.Add(item=self.sempling_reg,
-                       flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
-                       pos=(5, 1), span=(5, 2))
-	#bindings
+                        flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
+                        pos=(5, 1), span=(5, 2))
+        #bindings
         self.sempling_reg.Bind(wx.EVT_RADIOBOX, self.OnSempling)
         self.newconftxt.Bind(wx.EVT_KILL_FOCUS, self.OnName)
         self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
@@ -250,7 +248,7 @@
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
-	wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+        wx.FindWindowById(wx.ID_FORWARD).Enable(False)
     def OnSempling(self,event):
         """!Change map type"""
@@ -265,19 +263,19 @@
 	    #to remove when I know how to connect or create a monitor
 	    gcmd.GMessage(parent = self,
                               message = _("Function not supported yet"))
-            #event.Veto()
-            return
+        #event.Veto()
+        return
 	    #wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-	if self.conf_name != '' and self.rast != '' and not self.region == 'draw' \
-                        and not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
-	    wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+        if self.conf_name != '' and self.rast != '' and not self.region == 'draw' \
+                            and not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
+            wx.FindWindowById(wx.ID_FORWARD).Enable(True)
     def OnName(self,event):
-	"""!Sets the name of configuration file"""
-	self.conf_name = self.newconftxt.GetValue()
-	if self.region != '' and self.rast != '' and self.conf_name != '' and not \
-				wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
+        """!Sets the name of configuration file"""
+        self.conf_name = self.newconftxt.GetValue()
+        if self.region != '' and self.rast != '' and self.conf_name != '' and not \
+                    wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
     def OnRast(self, event):
         """!Sets raster map"""
@@ -289,25 +287,25 @@
     def OnVector(self, event):
         """!Sets vector map"""
         self.vect = event.GetString()
-	if self.region != '' and self.conf_name != '' and self.rast != '' and not \
+        if self.region != '' and self.conf_name != '' and self.rast != '' and not \
     def OnExitPage(self, event=None):
         """!Function during exiting"""
-	if self.region == '' or self.conf_name == '' or self.rast == '':
+        if self.region == '' or self.conf_name == '' or self.rast == '':
         else:
         if event.GetDirection():
-	    if self.region == 'key':
-		self.SetNext(self.parent.keyboardpage)
-		self.parent.samplingareapage.SetPrev(self.parent.keyboardpage)
-	    elif self.region == 'whole':
-		self.SetNext(self.parent.samplingareapage)
-		self.parent.samplingareapage.SetPrev(self)
-	    elif self.region == 'draw':
-		gcmd.GMessage(parent = self,
+            if self.region == 'key':
+                self.SetNext(self.parent.keyboardpage)
+                self.parent.samplingareapage.SetPrev(self.parent.keyboardpage)
+            elif self.region == 'whole':
+                self.SetNext(self.parent.samplingareapage)
+                self.parent.samplingareapage.SetPrev(self)
+            elif self.region == 'draw':
+                gcmd.GMessage(parent = self,
                 event.Veto()
                 return
@@ -322,111 +320,122 @@
-	self.col_len = ''
-	self.row_len = ''
+        self.col_len = ''
+        self.row_len = ''
-	#column up/left
-	self.ColUpLeftlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Column of upper left corner'))
+        #column up/left
+        self.ColUpLeftlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Column of upper left corner'))
-	self.ColUpLefttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-	wx.CallAfter(self.ColUpLeftlabel.SetFocus)
-	self.sizer.Add(item = self.ColUpLeftlabel, border=5, pos=(1, 1),
-	self.sizer.Add(item = self.ColUpLefttxt, border=5, pos=(1, 2),
- 	#row up/left
-	self.RowUpLeftlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Row of upper left corner'))
+        self.ColUpLefttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        wx.CallAfter(self.ColUpLeftlabel.SetFocus)
+        self.sizer.Add(item = self.ColUpLeftlabel, border=5, pos=(1, 1),
+        self.sizer.Add(item = self.ColUpLefttxt, border=5, pos=(1, 2),
+        #row up/left
+        self.RowUpLeftlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Row of upper left corner'))
-	self.RowUpLefttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-	wx.CallAfter(self.RowUpLeftlabel.SetFocus)
-	self.sizer.Add(item = self.RowUpLeftlabel, border=5, pos=(2, 1),
-	self.sizer.Add(item = self.RowUpLefttxt, border=5, pos=(2, 2),
-	#row lenght
-	self.RowLenlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Row lenght of sampling frame'))
+        self.RowUpLefttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        wx.CallAfter(self.RowUpLeftlabel.SetFocus)
+        self.sizer.Add(item = self.RowUpLeftlabel, border=5, pos=(2, 1),
+        self.sizer.Add(item = self.RowUpLefttxt, border=5, pos=(2, 2),
+        #row lenght
+        self.RowLenlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Row lenght of sampling frame'))
-	self.RowLentxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-	wx.CallAfter(self.RowLenlabel.SetFocus)
-	self.sizer.Add(item = self.RowLenlabel, border=5, pos=(3, 1),
-	self.sizer.Add(item = self.RowLentxt, border=5, pos=(3, 2),
-	#column lenght
-	self.ColLenlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+        self.RowLentxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        wx.CallAfter(self.RowLenlabel.SetFocus)
+        self.sizer.Add(item = self.RowLenlabel, border=5, pos=(3, 1),
+        self.sizer.Add(item = self.RowLentxt, border=5, pos=(3, 2),
+        #column lenght
+        self.ColLenlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-	self.ColLentxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-	wx.CallAfter(self.ColLenlabel.SetFocus)
-	self.sizer.Add(item = self.ColLenlabel, border=5, pos=(4, 1),
-	self.sizer.Add(item = self.ColLentxt, border=5, pos=(4, 2),
+        self.ColLentxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        wx.CallAfter(self.ColLenlabel.SetFocus)
+        self.sizer.Add(item = self.ColLenlabel, border=5, pos=(4, 1),
+        self.sizer.Add(item = self.ColLentxt, border=5, pos=(4, 2),
-	self.ColUpLefttxt.Bind(wx.EVT_KILL_FOCUS, self.OnColLeft)
-	self.RowUpLefttxt.Bind(wx.EVT_KILL_FOCUS, self.OnRowLeft)
-	self.ColLentxt.Bind(wx.EVT_KILL_FOCUS, self.OnColLen)
-	self.RowLentxt.Bind(wx.EVT_KILL_FOCUS, self.OnRowLeft)
-	self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+        self.ColUpLefttxt.Bind(wx.EVT_KILL_FOCUS, self.OnColLeft)
+        self.RowUpLefttxt.Bind(wx.EVT_KILL_FOCUS, self.OnRowLeft)
+        self.ColLentxt.Bind(wx.EVT_KILL_FOCUS, self.OnColLen)
+        self.RowLentxt.Bind(wx.EVT_KILL_FOCUS, self.OnRowLeft)
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
     def OnColLeft(self,event):
-	self.col_up = self.ColUpLefttxt.GetValue()
+        self.col_up = self.ColUpLefttxt.GetValue()
         checkValue(self.col_up)
+        if self.col_up == '':
+        else:
     def OnRowLeft(self,event):
-	self.row_up = self.RowUpLefttxt.GetValue()
-	checkValue(self.row_up)
-	#if self.row_up == '':
-	    #wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-	#else:
-	    #wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+        self.row_up = self.RowUpLefttxt.GetValue()
+        checkValue(self.row_up)
+        if self.row_up == '':
+        else:
     def OnColLen(self,event):
-	self.col_len = self.ColLentxt.GetValue()
-	checkValue(self.col_len)
-	#if self.col_len == '':
-	#else:
+        self.col_len = self.ColLentxt.GetValue()
+        checkValue(self.col_len)
+        if self.col_len == '':
+        else:
-	self.row_len = self.RowLentxt.GetValue()
-	checkValue(self.row_len)
-	#if self.row_len == '':
-	#else:
+        self.row_len = self.RowLentxt.GetValue()
+        checkValue(self.row_len)
+        if self.row_len == '':
+        else:
     def OnEnterPage(self, event):
         """!Sets the default values, for the entire map
-	self.col_up = '0'
-	self.row_up = '0'
-	if self.col_len == '' and self.row_len == '':
-	    rastinfo = grast.raster_info(self.parent.startpage.rast)
-	    self.col_len = rastinfo['cols']
-	    self.row_len = rastinfo['rows']
-	self.ColUpLefttxt.SetValue(self.col_up)
-	self.RowUpLefttxt.SetValue(self.row_up)
-	self.ColLentxt.SetValue(self.col_len)
-	self.RowLentxt.SetValue(self.row_len)
+        self.col_up = '0'
+        self.row_up = '0'
+        if self.col_len == '' and self.row_len == '':
+            rastinfo = grast.raster_info(self.parent.startpage.rast)
+            self.col_len = rastinfo['cols']
+            self.row_len = rastinfo['rows']
+        self.ColUpLefttxt.SetValue(self.col_up)
+        self.RowUpLefttxt.SetValue(self.row_up)
+        self.ColLentxt.SetValue(self.col_len)
+        self.RowLentxt.SetValue(self.row_len)
+    def OnExitPage(self, event=None):
+        """!Function during exiting"""
+        if self.row_len == '' or self.col_len == '' or self.row_up == '' or self.col_up == '':
+        else:
 class SamplingAreasPage(TitledPage):
     Set name of configuration file, choose raster and optionally vector/sites
@@ -434,7 +443,7 @@
     def __init__(self, wizard, parent):
         TitledPage.__init__(self, wizard, _("Insert sempling areas"))
-	self.samplingtype = 'whole'
+        self.samplingtype = 'whole'
         # toggles
@@ -456,8 +465,8 @@
         self.sizer.Add(item = self.radio3, flag = wx.ALIGN_LEFT, pos = (3, 1))
         self.sizer.Add(item = self.radio4, flag = wx.ALIGN_LEFT, pos = (4, 1))
         # bindings
         self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio1.GetId())
         self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio2.GetId())
@@ -469,18 +478,18 @@
         """!Insert values into text controls for summary of location
         creation options
-	try:
+        try:
             self.sizer.Hide(self.radio5)
-	    self.sizer.Remove(self.radio5)
-	    self.sizer.Layout()
-	except:
-	    pass
-        if self.parent.startpage.vect != '':
-            self.radio5 = wx.RadioButton(parent = self, id = wx.ID_ANY,
-                                        label = _("Select areas from the "
-                                        "overlayed vector map"))
-            self.sizer.Add(item = self.radio5, flag = wx.ALIGN_LEFT, pos = (5, 1))
-            self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio5.GetId())
+            self.sizer.Remove(self.radio5)
+            self.sizer.Layout()
+        except:
+            pass
+            if self.parent.startpage.vect != '':
+                self.radio5 = wx.RadioButton(parent = self, id = wx.ID_ANY,
+                                            label = _("Select areas from the "
+                                            "overlayed vector map"))
+                self.sizer.Add(item = self.radio5, flag = wx.ALIGN_LEFT, pos = (5, 1))
+                self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio5.GetId())
     def SetVal(self, event):
         """!Choose method"""
@@ -492,9 +501,11 @@
 	    self.Region()
         elif event.GetId() == self.radio3.GetId():
 	    self.samplingtype = 'units'
+	    self.SetNext(self.parent.samplingunitskey)
 	    self.KeyDraw()
         elif event.GetId() == self.radio4.GetId():
 	    self.samplingtype = 'moving'
 	    self.KeyDraw()
         elif event.GetId() == self.radio5.GetId():
 	    self.samplingtype = 'vector'
@@ -502,42 +513,42 @@
     def Region(self):
 	"""show this only if radio2 it is selected"""
-	try:
+        try:
             self.sizer.Hide(self.regionBox)
-	    self.sizer.Remove(self.regionBox)
-	except:
-	    pass
-	#self.regionBox = wx.GridBagSizer(vgap = 1, hgap = 2)
-	#self.regionLabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  #label = _('Enter the number of region to draw'))
-	#self.regionTxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(50, -1))
-	#self.regionBox.Add(self.regionLabel, pos = (1, 1))
-	#self.regionBox.Add(self.regionTxt, pos = (1, 2))
-	#self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
-	#self.sizer.Layout()
-	#self.SetNext(self.parent.draw)
-	gcmd.GMessage(parent = self, message = _("Function not supported yet"))
+            self.sizer.Remove(self.regionBox)
+        except:
+            pass
+        #self.regionBox = wx.GridBagSizer(vgap = 1, hgap = 2)
+        #self.regionLabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        #label = _('Enter the number of region to draw'))
+        #self.regionTxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(50, -1))
+        #self.regionBox.Add(self.regionLabel, pos = (1, 1))
+        #self.regionBox.Add(self.regionTxt, pos = (1, 2))
+        #self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
+        #self.sizer.Layout()
+        #self.SetNext(self.parent.draw)
+        gcmd.GMessage(parent = self, message = _("Function not supported yet"))
         return
     def KeyDraw(self):
-	"""Show this only if radio3 and radio4 it is selected"""
-	try:
+        """Show this only if radio3 and radio4 it is selected"""
+        try:
-	except:
-	    pass
-	self.regionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
-				      label= _("Choose a method"),
-				      choices=[_('Use keyboard to enter sampling area'),
-				      _('Use mouse to draw sampling area')],
-	self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
-	self.regionbox = 'keybord'
-	self.regionBox.Bind(wx.EVT_RADIOBOX, self.OnRegionDraw)
+        except:
+            pass
+        self.regionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                        label= _("Choose a method"),
+                        choices=[_('Use keyboard to enter sampling area'),
+                        _('Use mouse to draw sampling area')],
+        self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
+        self.regionbox = 'keybord'
+        self.regionBox.Bind(wx.EVT_RADIOBOX, self.OnRegionDraw)
     def OnRegionDraw(self,event):
         """Function called by KeyDraw to find what method is choosed"""
@@ -556,14 +567,14 @@
     def DrawNothing(self):
-	try:
+        try:
-	except:
-	    pass
-	self.SetNext(self.parent.summarypage)
+        except:
+            pass
+        self.SetNext(self.parent.summarypage)
 class SampleUnitsKeyPage(TitledPage):
     """!Set values from keyboard for sample units"""
@@ -572,91 +583,176 @@
         TitledPage.__init__(self, wizard, _("Units"))
-        self.sizer.AddGrowableCol(2)
-	self.typeBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
+        self.sizer.AddGrowableCol(2)
+        self.sizew = ''
+        self.sizeh = ''
+        # type of shape
+        self.typeBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
 				      label= _("Select type of shape"),
 				      choices=[_('Rectangle'), _('Circle')],
-	self.distributionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
-				      label= _("Select method of sampling unit distribution"),
-				      choices=[_('Random non overlapping'),
-				      _('Systematic contiguos'), _('Stratified random'),
-				      _('Systematic non contiguos'), _('Centered over sites')],
-	self.sizer.Add(self.typeBox, flag = wx.ALIGN_LEFT, pos = (1, 1))
-	self.sizer.Add(self.distributionBox, flag = wx.ALIGN_LEFT, pos = (2, 1))
+				      style=wx.VERTICAL)
+        self.sizer.Add(self.typeBox, pos = (1, 1),
+                      flag = wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+        choicess = [_('Random non overlapping'), _('Systematic contiguos'),
+                    _('Stratified random'), _('Systematic non contiguos')]
+        self.distributionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                      label= _("Select method of sampling unit distribution"),
+                      choices = choicess, style=wx.VERTICAL)
+        self.sizer.Add(self.distributionBox, pos = (1, 2),
+        # size width
+        self.sizewidth =   wx.StaticText(parent = self, id = wx.ID_ANY,
+                         label = _('What wide size (in cells)'))
+        self.sizewidthtxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        self.sizer.Add(self.sizewidth, pos = (2, 1),
+        self.sizer.Add(self.sizewidthtxt, border=5, pos=(2, 2),
+        # size width
+        wx.CallAfter(self.sizewidthtxt.SetFocus)
+        self.sizehight = wx.StaticText(parent = self, id = wx.ID_ANY,
+										label = _('What high size (in cells)'))
+        self.sizehighttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        self.sizer.Add(self.sizehight, pos = (3, 1),
+        self.sizer.Add(self.sizehighttxt, border=5, pos=(3, 2),
-	self.typeBox.Bind(wx.EVT_RADIOBOX, self.OnType)
-	self.distributionBox.Bind(wx.EVT_RADIOBOX, self.OnMethod)
+        self.typeBox.Bind(wx.EVT_RADIOBOX, self.OnType)
+        self.distributionBox.Bind(wx.EVT_RADIOBOX, self.OnMethod)
+        self.sizewidthtxt.Bind(wx.EVT_KILL_FOCUS, self.OnNameW)
+        self.sizehighttxt.Bind(wx.EVT_KILL_FOCUS, self.OnNameH)
-    def OnType(self):
-	if event.GetInt() == 0:
-	    print "activate the textctrl for rectangle"
-	elif event.GetInt() == 1:
-	    print "activate the textctrl for circle"
+    def OnEnterPage(self, event):
+        """!Check if sites vector it is present"""
+        # method of distribution
+            self.distributionBox.SetItemLabel(5, _('Centered over sites'))
+        if self.sizew == '' or self.sizeh == '':
+        else:
+    def OnNameW(self,event):
+        self.sizew = self.sizewidthtxt.GetValue()
+    def OnNameH(self,event):
+        self.sizeh = self.sizehighttxt.GetValue()
+    def OnType(self,event):
+        if event.GetInt() == 0:
+            try:
+                self.sizer.Hide(self.sizewidth)
+                self.sizer.Remove(self.sizewidth)
+                self.sizer.Hide(self.sizehight)
+                self.sizer.Remove(self.sizehight)
+            except:
+                pass
+        elif event.GetInt() == 1:
+            try:
+            except:
+                pass
+                            label = _('What radius size (in meters)'))
+                            label = _('Name for the circle mask'))
-    def OnMethod(self):
-	    print "Random non overlapping"
-	    print "Systematic contiguos"
-	elif event.GetInt() == 2:
-	    print "Stratified random"
-	elif event.GetInt() == 3:
-	    print "Systematic non contiguos"
-	elif event.GetInt() == 4:
-	    print "Centered over sites"
+    def OnMethod(self,event):
+                # exit a window asking "What number of sampling units to use"
+            print "Random non overlapping"
+                # no window more
+            print "Systematic contiguos"
+        elif event.GetInt() == 2:
+                # exit a window asking "Insert distance between units"
+            print "Stratified random"
+        elif event.GetInt() == 3:
+                # exit a window asking "Insert number of row strates" and "Insert number of column strates"
+            print "Systematic non contiguos"
+        elif event.GetInt() == 4:
+            print "Centered over sites"
 class SummaryPage(TitledPage):
     """!Shows summary result of choosing data"""
         TitledPage.__init__(self, wizard, _("Summary"))
-	global rlisettings
+        global rlisettings
- 	#configuration file name
-	self.conflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Configuration file name:'))
-	self.conftxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = "")
-	self.sizer.Add(item = self.conflabel, border=5, pos=(1, 1),
-	self.sizer.Add(item = self.conftxt, border=5, pos=(1, 2),
+        #configuration file name
+        self.conflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Configuration file name:'))
+        self.conftxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = "")
+        self.sizer.Add(item = self.conflabel, border=5, pos=(1, 1),
+        self.sizer.Add(item = self.conftxt, border=5, pos=(1, 2),
-	#raster name
-	self.rastlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Raster name:'))
-	self.rasttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = "")
-	self.sizer.Add(item = self.rastlabel, border=5, pos=(2, 1),
-	self.sizer.Add(item = self.rasttxt, border=5, pos=(2, 2),
- 	#region type name
-	self.regionlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Region type:'))
-	self.regiontxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = "")
-	self.sizer.Add(item = self.regionlabel, border=5, pos=(4, 1),
-	self.sizer.Add(item = self.regiontxt, border=5, pos=(4, 2),
+        #raster name
+        self.rastlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Raster name:'))
+        self.rasttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = "")
+        self.sizer.Add(item = self.rastlabel, border=5, pos=(2, 1),
+        self.sizer.Add(item = self.rasttxt, border=5, pos=(2, 2),
+        #region type name
+        self.regionlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Region type:'))
+        self.regiontxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = "")
+        self.sizer.Add(item = self.regionlabel, border=5, pos=(4, 1),
+        self.sizer.Add(item = self.regiontxt, border=5, pos=(4, 2),
-	#sampling area
-	self.samplinglabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Sempling area type:'))
-	self.samplingtxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = "")
-	self.sizer.Add(item = self.samplinglabel, border=5, pos=(6, 1),
-	self.sizer.Add(item = self.samplingtxt, border=5, pos=(6, 2),
+        #sampling area
+        self.samplinglabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = _('Sempling area type:'))
+        self.samplingtxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+                        label = "")
+        self.sizer.Add(item = self.samplinglabel, border=5, pos=(6, 1),
+        self.sizer.Add(item = self.samplingtxt, border=5, pos=(6, 2),
@@ -667,48 +763,48 @@
         self.rasttxt.SetLabel(self.parent.startpage.rast)
         self.samplingtxt.SetLabel(self.parent.samplingareapage.samplingtype)
         self.regiontxt.SetLabel(self.parent.startpage.region)
-	try:
-	    #try to remove label and text of vector and region key
-	    self.sizer.Hide(self.vectlabel)
-	    self.sizer.Hide(self.vecttxt)
-	    self.sizer.Remove(self.vectlabel)
-	    self.sizer.Remove(self.vecttxt)
-	    self.sizer.Hide(self.regionkeylabel)
-	    self.sizer.Hide(self.regionkeytxt)
-	    self.sizer.Remove(self.regionkeylabel)
-	    self.sizer.Remove(self.regionkeytxt)
-	except:
-	    pass
+        try:
+            #try to remove label and text of vector and region key
+            self.sizer.Hide(self.vectlabel)
+            self.sizer.Hide(self.vecttxt)
+            self.sizer.Remove(self.vectlabel)
+            self.sizer.Remove(self.vecttxt)
+            self.sizer.Hide(self.regionkeylabel)
+            self.sizer.Hide(self.regionkeytxt)
+            self.sizer.Remove(self.regionkeylabel)
+            self.sizer.Remove(self.regionkeytxt)
+        except:
+            pass
-	    #vector name
-	    self.vectlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					      label = _('Vector name:'))
-	    self.vecttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-					      label = "")
-	    self.sizer.Add(item = self.vectlabel, border=5, pos=(3, 1),
-	    self.sizer.Add(item = self.vecttxt, border=5, pos=(3, 2),
-	    self.vecttxt.SetLabel(self.parent.startpage.vect)
+            #vector name
+            self.vectlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                label = _('Vector name:'))
+            self.vecttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                label = "")
+            self.sizer.Add(item = self.vectlabel, border=5, pos=(3, 1),
+            self.sizer.Add(item = self.vecttxt, border=5, pos=(3, 2),
+            self.vecttxt.SetLabel(self.parent.startpage.vect)
         if self.parent.startpage.region == 'key':
-	    #region keybord values
-	    self.regionkeylabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					      label = _('Region keybord values:'))
+            #region keybord values
+            self.regionkeylabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                label = _('Region keybord values:'))
-	    self.regionkeytxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-					      label = "")
-	    self.sizer.Add(item = self.regionkeylabel, border=5, pos=(5, 1),
-	    self.sizer.Add(item = self.regionkeytxt, border=5, pos=(5, 2),
-	    regKeyVals = "Column left up: %s - Row left up: %s\nColumn length: %s - Row length: %s\n" \
-			  % (self.parent.keyboardpage.col_up, self.parent.keyboardpage.row_up,
-			  self.parent.keyboardpage.col_len, self.parent.keyboardpage.row_len)
-	    self.regionkeytxt.SetLabel(regKeyVals)
+            self.regionkeytxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                label = "")
+            self.sizer.Add(item = self.regionkeylabel, border=5, pos=(5, 1),
+            self.sizer.Add(item = self.regionkeytxt, border=5, pos=(5, 2),
+            regKeyVals = "Column left up: %s - Row left up: %s\nColumn length: %s - Row length: %s\n" \
+                    % (self.parent.keyboardpage.col_up, self.parent.keyboardpage.row_up,
+                    self.parent.keyboardpage.col_len, self.parent.keyboardpage.row_len)
+            self.regionkeytxt.SetLabel(regKeyVals)
 if __name__ == "__main__":
