[GRASS-SVN] r50217 - in grass-addons: grass6/vector/v.vect.stats grass7/vector grass7/vector/v.vect.stats
Mon Jan 16 23:01:58 EST 2012
Author: hamish
Date: 2012-01-16 20:01:58 -0800 (Mon, 16 Jan 2012)
New Revision: 50217
Added:
   grass-addons/grass7/vector/v.vect.stats/
Removed:
   grass-addons/grass6/vector/v.vect.stats/grass7.patch
   grass-addons/grass7/vector/v.vect.stats/grass65.patch
   grass-addons/grass7/vector/v.vect.stats/grass7.patch
   grass-addons/grass7/vector/v.vect.stats/main.c
split off grass7-specific version
Deleted: grass-addons/grass6/vector/v.vect.stats/grass7.patch
--- grass-addons/grass6/vector/v.vect.stats/grass7.patch	2012-01-17 00:41:15 UTC (rev 50216)
+++ grass-addons/grass6/vector/v.vect.stats/grass7.patch	2012-01-17 04:01:58 UTC (rev 50217)
@@ -1,63 +0,0 @@
-Index: main.c
---- main.c	(revision 44581)
-+++ main.c	(working copy)
-@@ -24,7 +24,7 @@
- #include <grass/glocale.h>
- #include <grass/stats.h>
- #include <grass/dbmi.h>
--#include <grass/Vect.h>
-+#include <grass/vector.h>
- struct menu
-@@ -108,7 +108,7 @@
-     char buf[2000];
-     int update_ok, update_err;
-     struct ilist *List;
--    BOUND_BOX box;
-+    struct bound_box box;
-     dbCatValArray cvarr;
-     dbColumn *column;
-     struct pvalcat
-@@ -125,7 +125,9 @@
-     G_gisinit(argv[0]);
-     module = G_define_module();
--    module->keywords = _("vector, database, attribute table");
-+    G_add_keyword(_("vector"));
-+    G_add_keyword(_("database"));
-+    G_add_keyword(_("attribute table"));
-     module->description = _("Count points in areas, calculate statistics.");
-     point_opt = G_define_standard_option(G_OPT_V_INPUT);
-@@ -169,7 +171,7 @@
-     method_opt->options = p;
-     method_opt->description = _("Method for aggregate statistics");
--    point_column_opt = G_define_standard_option(G_OPT_COLUMN);
-+    point_column_opt = G_define_standard_option(G_OPT_DB_COLUMN);
-     point_column_opt->key = "pcolumn";
-     point_column_opt->required = NO;
-     point_column_opt->multiple = NO;
-@@ -477,10 +479,6 @@
-     pvalcats =
- 	(struct pvalcat *)G_calloc(npvalcatsalloc, sizeof(struct pvalcat));
--    /* remove for GRASS 7 */
--    G_verbose_message(_("creating spatial index"));
--    Vect_build_spatial_index(&PIn);
-     G_message(_("Selecting points for each area..."));
-     count = 0;
-     for (area = 1; area <= nareas; area++) {
-@@ -656,7 +654,8 @@
- 	if (Area_cat[i].count > 0 && method_opt->answer) {
- 	    /* get stats */
--	    statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues);
-+	    statsvalue(&result, Area_cat[i].values, Area_cat[i].nvalues,
-+			NULL);
- 	    if (half)
- 		result += 0.5;
Deleted: grass-addons/grass7/vector/v.vect.stats/grass65.patch
--- grass-addons/grass6/vector/v.vect.stats/grass65.patch	2012-01-17 00:41:15 UTC (rev 50216)
+++ grass-addons/grass7/vector/v.vect.stats/grass65.patch	2012-01-17 04:01:58 UTC (rev 50217)
@@ -1,14 +0,0 @@
-Index: main.c
-@@ -656,7 +656,8 @@
- 	    /* get stats */
-+			NULL);
- 	    if (half)
- 		result += 0.5;
Deleted: grass-addons/grass7/vector/v.vect.stats/grass7.patch
+++ grass-addons/grass7/vector/v.vect.stats/grass7.patch	2012-01-17 04:01:58 UTC (rev 50217)
@@ -1,63 +0,0 @@
-Index: main.c
-@@ -24,7 +24,7 @@
- struct menu
-     char buf[2000];
--    BOUND_BOX box;
-     dbColumn *column;
-     struct pvalcat
-     pvalcats =
-     count = 0;
- 	    /* get stats */
-+			NULL);
- 	    if (half)
- 		result += 0.5;
Modified: grass-addons/grass7/vector/v.vect.stats/main.c
--- grass-addons/grass6/vector/v.vect.stats/main.c	2012-01-17 00:41:15 UTC (rev 50216)
+++ grass-addons/grass7/vector/v.vect.stats/main.c	2012-01-17 04:01:58 UTC (rev 50217)
@@ -24,7 +24,7 @@
 struct menu
@@ -108,7 +108,7 @@
     char buf[2000];
     struct ilist *List;
-    BOUND_BOX box;
     dbColumn *column;
     struct pvalcat
@@ -125,7 +125,9 @@
     G_gisinit(argv[0]);
@@ -169,7 +171,7 @@
     pvalcats =
     count = 0;
@@ -656,7 +654,8 @@
 	    /* get stats */
+			NULL);
 	    if (half)
 		result += 0.5;
