[GRASS-SVN] r50218 - grass-addons/grass7/vector/v.vect.stats
Mon Jan 16 23:03:27 EST 2012
Author: hamish
Date: 2012-01-16 20:03:26 -0800 (Mon, 16 Jan 2012)
New Revision: 50218
Added:
   grass-addons/grass7/vector/v.vect.stats/v.vect.stats.html
Removed:
   grass-addons/grass7/vector/v.vect.stats/description.html
rename for grass7
Deleted: grass-addons/grass7/vector/v.vect.stats/description.html
--- grass-addons/grass7/vector/v.vect.stats/description.html	2012-01-17 04:01:58 UTC (rev 50217)
+++ grass-addons/grass7/vector/v.vect.stats/description.html	2012-01-17 04:03:26 UTC (rev 50218)
@@ -1,95 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.vect.stats</em> counts the number of points in vector map
-<em>points</em> falling into each area in vector map <em>areas</em>.
-Optionally statistics on point attributes in <em>points</em> are
-calculated for each area. The results are either uploaded to the
-attribute table of the vector map <em>areas</em> or printed to stdout.
-<h3>OPTIONS</h3>
-<em>Statistical Methods:</em>
-Using numeric attribute values of all points falling into a given area,
-a new value is detmined with the selected method.
-<em>v.vect.stats</em> can perform the following operations:
-<p>
-<dl>
-<dt><b>sum</b>
-<dd>The sum of values.
-<dt><b>average</b>
-<dd>The average value of all point attributes (sum / count).
-<dt><b>median</b>
-<dd>The value found half-way through a list of the
-attribute values, when these are ranged in numerical order.
-<dt><b>mode</b>
-<dd>The most frequently occurring value.
-<dt><b>minimum</b>
-<dd>The minimum observed value.
-<dt><b>min_cat</b>
-<dd>The point category corresponding to the minimum observed value.
-<dt><b>maximum</b>
-<dd>The maximum observed value.
-<dt><b>max_cat</b>
-<dd>The point category corresponding to the maximum observed value.
-<dt><b>range</b>
-<dd>The range of the observed values.
-<dt><b>stddev</b>
-<dd>The statistical standard deviation of the attribute values.
-<dt><b>variance</b>
-<dd>The statistical variance of the attribute values.
-<dt><b>diversity</b>
-<dd>The number of different attribute values.
-</dl>
-<h2>NOTES</h2>
-Points not falling into any area are ignored. Areas without category
-(no centroid attached or centroid without category) are ignored.
-If no points are falling into a given area, the point count is set to 0
-(zero) and the statistics result to "null".
-<p>
-The columns <em>count_column</em> and <em>stats_column</em> are created if not
-existing. If they do already exist, the <em>count_column</em> must be of
-type integer and the <em>stats_column</em> of type double.
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.distance.html">v.distance</a>,
-<a href="r.distance.html">r.distance</a>,
-<a href="v.what.vect.html">v.what.vect</a>
-</em>
-<h2>AUTHOR</h2>
-Markus Metz
-<p><i>Last changed: $Date: 2008-08-13 21:52:37 +0200 (Wed, 13 Aug 2008) $</i>
Copied: grass-addons/grass7/vector/v.vect.stats/v.vect.stats.html (from rev 50217, grass-addons/grass7/vector/v.vect.stats/description.html)
--- grass-addons/grass7/vector/v.vect.stats/v.vect.stats.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.vect.stats/v.vect.stats.html	2012-01-17 04:03:26 UTC (rev 50218)
@@ -0,0 +1,95 @@
+<h2>DESCRIPTION</h2>
+<em>v.vect.stats</em> counts the number of points in vector map
+<em>points</em> falling into each area in vector map <em>areas</em>.
+Optionally statistics on point attributes in <em>points</em> are
+calculated for each area. The results are either uploaded to the
+attribute table of the vector map <em>areas</em> or printed to stdout.
+<h3>OPTIONS</h3>
+<em>Statistical Methods:</em>
+Using numeric attribute values of all points falling into a given area,
+a new value is detmined with the selected method.
+<em>v.vect.stats</em> can perform the following operations:
+<p>
+<dl>
+<dt><b>sum</b>
+<dd>The sum of values.
+<dt><b>average</b>
+<dd>The average value of all point attributes (sum / count).
+<dt><b>median</b>
+<dd>The value found half-way through a list of the
+attribute values, when these are ranged in numerical order.
+<dt><b>mode</b>
+<dd>The most frequently occurring value.
+<dt><b>minimum</b>
+<dd>The minimum observed value.
+<dt><b>min_cat</b>
+<dd>The point category corresponding to the minimum observed value.
+<dt><b>maximum</b>
+<dd>The maximum observed value.
+<dt><b>max_cat</b>
+<dd>The point category corresponding to the maximum observed value.
+<dt><b>range</b>
+<dd>The range of the observed values.
+<dt><b>stddev</b>
+<dd>The statistical standard deviation of the attribute values.
+<dt><b>variance</b>
+<dd>The statistical variance of the attribute values.
+<dt><b>diversity</b>
+<dd>The number of different attribute values.
+</dl>
+<h2>NOTES</h2>
+Points not falling into any area are ignored. Areas without category
+(no centroid attached or centroid without category) are ignored.
+If no points are falling into a given area, the point count is set to 0
+(zero) and the statistics result to "null".
+<p>
+The columns <em>count_column</em> and <em>stats_column</em> are created if not
+existing. If they do already exist, the <em>count_column</em> must be of
+type integer and the <em>stats_column</em> of type double.
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.distance.html">v.distance</a>,
+<a href="r.distance.html">r.distance</a>,
+<a href="v.what.vect.html">v.what.vect</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date: 2008-08-13 21:52:37 +0200 (Wed, 13 Aug 2008) $</i>
