[GRASS-SVN] r50336 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Fri Jan 20 16:57:09 EST 2012
Author: neteler
Date: 2012-01-20 13:57:09 -0800 (Fri, 20 Jan 2012)
New Revision: 50336
grass/branches/develbranch_6/locale/po/grasswxpy_cs.po
grass/branches/develbranch_6/locale/po/grasswxpy_de.po
grass/branches/develbranch_6/locale/po/grasswxpy_el.po
grass/branches/develbranch_6/locale/po/grasswxpy_es.po
grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
grass/branches/develbranch_6/locale/po/grasswxpy_id.po
grass/branches/develbranch_6/locale/po/grasswxpy_it.po
grass/branches/develbranch_6/locale/po/grasswxpy_ja.po
grass/branches/develbranch_6/locale/po/grasswxpy_ml.po
grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
grass/branches/develbranch_6/locale/po/grasswxpy_pt.po
grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
grass/branches/develbranch_6/locale/po/grasswxpy_th.po
grass/branches/develbranch_6/locale/po/grasswxpy_tr.po
grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
typos discovered by Vincent Bain fixed
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_cs.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_cs.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_cs.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8247,7 +8247,7 @@
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
"Layer and category number must be integer.\n"
-"Layer number must be greater then zero."
+"Layer number must be greater than zero."
msgstr ""
"Nelze pøidat identifikátor nové vrstvy/kategorie <%(layer)s/%(category)s>.\n"
"Identifikátor vrstvy a kategorie musí být celé èíslo.\n"
@@ -9034,7 +9034,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:1177
#, python-format
msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
+"Selected data records (%d) will be permanently deleted from table. Do you want "
"to delete them?"
msgstr ""
"Vybrané záznamy dat (%d) budou natrvalo smazány z tabulky. Pøejete si je "
@@ -10449,12 +10449,12 @@
#: ../gui/wxpython/gui_modules/render.py:1173
#, python-format
-msgid "Unable render overlay <%s>."
+msgid "Unable to render overlay <%s>."
msgstr "Nelze vykreslit pøekrytí <%s>."
#: ../gui/wxpython/gui_modules/render.py:1212
#, python-format
-msgid "Unable render overlay <%s>"
+msgid "Unable to render overlay <%s>"
msgstr "Nelze vykreslit pøekrytí <%s>"
#: ../gui/wxpython/gui_modules/dbm.py:140
@@ -10712,7 +10712,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:1223
#, python-format
msgid ""
-"All data records (%d) will permanently deleted from table. Do you want to "
+"All data records (%d) will be permanently deleted from table. Do you want to "
"delete them?"
msgstr ""
"V¹echny záznamy dat (%d) budou natrvalo smazány z tabulky. pøejete se je "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_de.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_de.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_de.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -7609,7 +7609,7 @@
msgid ""
msgstr ""
"Kann den neuen Layer/Kategorie <%(layer)s/%(category)s> nicht hinzufügen.\n"
"Layer und Kategorie Nummern müssen integer sein.\n"
@@ -8372,7 +8372,7 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:4315
#, python-format
-msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
msgstr "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
#: ../gui/wxpython/gui_modules/gmodeler.py:4318
@@ -9656,12 +9656,12 @@
#, python-format
msgstr "Kann die Überlagerung <%s> nicht rendern."
#, python-format
msgstr "Kann die Überlagerung <%s> nicht rendern"
@@ -9907,7 +9907,7 @@
#, python-format
-msgid "All data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
msgstr "Alle Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
#: ../gui/wxpython/gui_modules/dbm.py:1369
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_el.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_el.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_el.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -7759,7 +7759,7 @@
msgid ""
msgstr ""
#: ../gui/wxpython/gui_modules/vdigit.py:1058
@@ -8497,7 +8497,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -9771,12 +9771,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -10025,7 +10025,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_es.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_es.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_es.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8351,7 +8351,7 @@
msgid ""
msgstr ""
"No ha sido posible añadir una nueva capa / categoría <%(layer)s/%(category)"
"s>.\n"
@@ -9141,7 +9141,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Los registros seleccionados (%d) serán borrados permanentemente de la tabla. "
@@ -10495,12 +10495,12 @@
#, python-format
msgstr "No se ha podido realizar la presentación de la superposicion <%s>."
#, python-format
@@ -10764,7 +10764,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Todos los registros (%d) serán borrados de la tabla permanentemente. ¿Desea "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_fr.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_fr.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -7958,7 +7958,7 @@
msgid ""
msgstr ""
@@ -8710,7 +8710,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10011,12 +10011,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -10265,7 +10265,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_id.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_id.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_id.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8617,7 +8617,7 @@
msgid ""
msgstr ""
"Tidak mampu menambahkan layer/kategori baru <%(layer)s/%(category)s>.\n"
"Layer dan kategori harus integer.\n"
@@ -9437,7 +9437,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Rekaman data terpilih (%d) akan dihapus secara permanen dari tabel. Anda "
@@ -10865,12 +10865,12 @@
#, python-format
msgstr "Tidak dapat merender overlay <%s>."
#, python-format
msgstr "Tidak dapat merender overlay <%s>"
@@ -11136,7 +11136,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Semua rekaman data (%d) akan dihapus secara permanen dari tabel. Apakah Anda "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_it.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_it.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -7596,7 +7596,7 @@
msgid ""
msgstr ""
"Impossibile aggiungere nuovo layer/categoria <%(layer)s/%(category)s>.\n"
"Numero di layer e categoria dev'essere intero.\n"
@@ -8360,7 +8360,7 @@
#, python-format
msgstr "I record (%d) selezionati saranno permanentemente eliminati della tabella. Vuoi eliminarli?"
#, python-format
msgstr "Impossibile visualizzare <%s> sovrapposto"
#, python-format
#, python-format
msgstr "Tutti i record (%d) saranno permanentemente eliminati della tabella. Vuoi eliminarli?"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ja.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ja.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ja.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -7614,7 +7614,7 @@
msgid ""
msgstr ""
"ã¬ã¤ã¤ã¼/ã«ãã´ãªã¼ãæ°ãã追å åºæ¥ã¾ãã <%(layer)s/%(category)s>.\n"
"ã¬ã¤ã¤ã¼ãã«ãã´ãªã¼çªå·ã¯æ´æ°ã§ç¡ããã°ãªãã¾ãã.\n"
@@ -8363,7 +8363,7 @@
#, python-format
msgstr "鏿ããã¬ã³ã¼ã (%d) ã¯ããã¼ãã«ããå®å
¨ã«æ¶å»ããã¾ã åé¤ãã¦ããããã§ãã?"
@@ -9635,12 +9635,12 @@
#, python-format
msgstr "<%s> ãã¬ã³ãã¼ãªã¼ãã¼ã¬ã¤ã§ãã¾ãã"
#, python-format
@@ -9886,7 +9886,7 @@
#, python-format
msgstr "å
¨ã¦ã®ã¬ã³ã¼ã (%d) ã¯ããã¼ãã«ããå®å
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ml.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ml.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ml.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -7979,7 +7979,7 @@
msgid ""
msgstr ""
@@ -8769,7 +8769,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10114,12 +10114,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -10368,7 +10368,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pl.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pl.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -7618,7 +7618,7 @@
msgid ""
msgstr ""
"Nie powiodÅo siÄ dodanie nowej warstwy/kategorii <%(layer)s/%(category)s>.\n"
"Numer warstwy i kategorii musi byÄ liczbÄ
caÅkowitÄ
.\n"
@@ -8375,7 +8375,7 @@
#, python-format
msgstr "Wybrane rekordy (%d) zostanÄ
caÅkowicie usuniÄte z tabeli. Chcesz je wykasowaÄ?"
@@ -9661,12 +9661,12 @@
#, python-format
msgstr "Nie można wyÅwietliÄ nakÅadki <%s>."
#, python-format
msgstr "Nie można wyÅwietliÄ nakÅadki <%s>"
@@ -9913,7 +9913,7 @@
#, python-format
msgstr "Wszystkie rekordy (%d) zostanÄ
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pt.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pt.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pt.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8891,7 +8891,7 @@
msgid ""
msgstr ""
"Não é possÃvel adicionar nova camada/categoria <%(layer)s/%(category)s>.\n"
"Número de camada e categoria deve ser um inteiro.\n"
@@ -9716,7 +9716,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Seleccionar os dados de registo (%d) irá apagar definitivamente os dados da "
@@ -11151,12 +11151,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -11418,7 +11418,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -9274,7 +9274,7 @@
msgid ""
msgstr ""
@@ -10120,7 +10120,7 @@
#, fuzzy, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -11576,12 +11576,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -11870,7 +11870,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ru.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ru.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8532,7 +8532,7 @@
msgid ""
msgstr ""
"Ðевозможно добавиÑÑ Ð½Ð¾Ð²Ñй Ñлой/каÑегоÑÐ¸Ñ <%(layer)s/%(category)s>.\n"
"ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¸ каÑегоÑии Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑелÑми ÑиÑлами.\n"
@@ -9342,7 +9342,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"ÐÑбÑаннÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
@@ -10772,12 +10772,12 @@
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>."
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>"
@@ -11044,7 +11044,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"ÐÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
ÑдалиÑÑ?"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_th.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_th.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_th.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8142,7 +8142,7 @@
msgid ""
msgstr ""
@@ -8917,7 +8917,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10285,12 +10285,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -10542,7 +10542,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_tr.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_tr.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_tr.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8388,7 +8388,7 @@
msgid ""
msgstr ""
@@ -9232,7 +9232,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10653,12 +10653,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -10920,7 +10920,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Tüm (%d) veri kayıtları tablodan kalıcı olarak silinecek. Onları silmek "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_vi.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_vi.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8489,7 +8489,7 @@
msgid ""
msgstr ""
"Không thá» thêm lá»p/phạm trù má»i <%(layer)s/%(category)s>.\n"
"â©Sá» lá»p và sá» phạm trù phải là sá» nguyên.\n"
@@ -9321,7 +9321,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Các bản ghi dữ liá»u Äã ÄÆ°á»£c chá»n (%d) sẽ bá» xóa bá» hoà n toà n khá»i bảng. Bạn "
@@ -10740,12 +10740,12 @@
#, python-format
msgstr "Không thá» vẽ chá»ng <%s>."
#, python-format
msgstr "Không thá» vẽ chá»ng <%s>"
@@ -11005,7 +11005,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Tất cả các bản ghi dữ liá»u (%d) sẽ bá» xóa bá» hoà n toà n khá»i bảng. Bạn có "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_zh.po 2012-01-20 21:56:03 UTC (rev 50335)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_zh.po 2012-01-20 21:57:09 UTC (rev 50336)
@@ -8228,7 +8228,7 @@
msgid ""
msgstr ""
@@ -9023,7 +9023,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10436,12 +10436,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -10694,7 +10694,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
