[GRASS-SVN] r50337 - grass/trunk/locale/po
svn_grass at osgeo.org
Fri Jan 20 16:58:06 EST 2012
Author: neteler
Date: 2012-01-20 13:58:06 -0800 (Fri, 20 Jan 2012)
New Revision: 50337
grass/trunk/locale/po/grasswxpy_cs.po
grass/trunk/locale/po/grasswxpy_de.po
grass/trunk/locale/po/grasswxpy_el.po
grass/trunk/locale/po/grasswxpy_es.po
grass/trunk/locale/po/grasswxpy_fr.po
grass/trunk/locale/po/grasswxpy_id.po
grass/trunk/locale/po/grasswxpy_it.po
grass/trunk/locale/po/grasswxpy_ja.po
grass/trunk/locale/po/grasswxpy_ml.po
grass/trunk/locale/po/grasswxpy_pl.po
grass/trunk/locale/po/grasswxpy_pt.po
grass/trunk/locale/po/grasswxpy_pt_br.po
grass/trunk/locale/po/grasswxpy_ru.po
grass/trunk/locale/po/grasswxpy_th.po
grass/trunk/locale/po/grasswxpy_tr.po
grass/trunk/locale/po/grasswxpy_vi.po
grass/trunk/locale/po/grasswxpy_zh.po
typos discovered by Vincent Bain fixed
Modified: grass/trunk/locale/po/grasswxpy_cs.po
--- grass/trunk/locale/po/grasswxpy_cs.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_cs.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9269,7 +9269,7 @@
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
"Layer and category number must be integer.\n"
-"Layer number must be greater then zero."
+"Layer number must be greater than zero."
msgstr ""
"Nelze pøidat identifikátor nové vrstvy/kategorie <%(layer)s/%(category)s>.\n"
"Identifikátor vrstvy a kategorie musí být celé èíslo.\n"
@@ -10055,7 +10055,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:1177
#, python-format
msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
+"Selected data records (%d) will be permanently deleted from table. Do you want "
"to delete them?"
msgstr ""
"Vybrané záznamy dat (%d) budou natrvalo smazány z tabulky. Pøejete si je "
@@ -11465,12 +11465,12 @@
#: ../gui/wxpython/gui_modules/render.py:1238
#, python-format
-msgid "Unable render overlay <%s>."
+msgid "Unable to render overlay <%s>."
msgstr "Nelze vykreslit pøekrytí <%s>."
#: ../gui/wxpython/gui_modules/render.py:1277
#, python-format
-msgid "Unable render overlay <%s>"
+msgid "Unable to render overlay <%s>"
msgstr "Nelze vykreslit pøekrytí <%s>"
#: ../gui/wxpython/gui_modules/dbm.py:140
@@ -11728,7 +11728,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:1223
#, python-format
msgid ""
-"All data records (%d) will permanently deleted from table. Do you want to "
+"All data records (%d) will be permanently deleted from table. Do you want to "
"delete them?"
msgstr ""
"V¹echny záznamy dat (%d) budou natrvalo smazány z tabulky. pøejete se je "
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_de.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -8661,7 +8661,7 @@
msgid ""
msgstr ""
"Kann den neuen Layer/Kategorie <%(layer)s/%(category)s> nicht hinzufügen.\n"
"Layer und Kategorie Nummern müssen integer sein.\n"
@@ -9424,7 +9424,7 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:4309
#, python-format
-msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
msgstr "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
#: ../gui/wxpython/gui_modules/gmodeler.py:4312
@@ -10702,12 +10702,12 @@
#, python-format
msgstr "Kann die Überlagerung <%s> nicht rendern."
#, python-format
msgstr "Kann die Überlagerung <%s> nicht rendern"
@@ -10953,7 +10953,7 @@
#, python-format
-msgid "All data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
msgstr "Alle Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
#: ../gui/wxpython/gui_modules/dbm.py:1369
Modified: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_el.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -8589,7 +8589,7 @@
msgid ""
msgstr ""
#: ../gui/wxpython/gui_modules/vdigit.py:1058
@@ -9327,7 +9327,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10595,12 +10595,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -10849,7 +10849,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_es.po
--- grass/trunk/locale/po/grasswxpy_es.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_es.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9379,7 +9379,7 @@
msgid ""
msgstr ""
"No ha sido posible añadir una nueva capa / categoría <%(layer)s/%(category)"
"s>.\n"
@@ -10168,7 +10168,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Los registros seleccionados (%d) serán borrados permanentemente de la tabla. "
@@ -11516,12 +11516,12 @@
#, python-format
msgstr "No se ha podido realizar la presentación de la superposicion <%s>."
#, python-format
@@ -11785,7 +11785,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Todos los registros (%d) serán borrados de la tabla permanentemente. ¿Desea "
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_fr.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -8949,7 +8949,7 @@
msgid ""
msgstr ""
@@ -9701,7 +9701,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10996,12 +10996,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -11250,7 +11250,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_id.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9588,7 +9588,7 @@
msgid ""
msgstr ""
"Tidak mampu menambahkan layer/kategori baru <%(layer)s/%(category)s>.\n"
"Layer dan kategori harus integer.\n"
@@ -10408,7 +10408,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Rekaman data terpilih (%d) akan dihapus secara permanen dari tabel. Anda "
@@ -11833,12 +11833,12 @@
#, python-format
msgstr "Tidak dapat merender overlay <%s>."
#, python-format
msgstr "Tidak dapat merender overlay <%s>"
@@ -12104,7 +12104,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Semua rekaman data (%d) akan dihapus secara permanen dari tabel. Apakah Anda "
Modified: grass/trunk/locale/po/grasswxpy_it.po
--- grass/trunk/locale/po/grasswxpy_it.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_it.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -8591,7 +8591,7 @@
msgid ""
msgstr ""
"Impossibile aggiungere nuovo layer/categoria <%(layer)s/%(category)s>.\n"
"Numero di layer e categoria dev'essere intero.\n"
@@ -9355,7 +9355,7 @@
#, python-format
msgstr "I record (%d) selezionati saranno permanentemente eliminati della tabella. Vuoi eliminarli?"
@@ -10646,12 +10646,12 @@
#, python-format
msgstr "Impossibile visualizzare <%s> sovrapposto"
#, python-format
@@ -10897,7 +10897,7 @@
#, python-format
msgstr "Tutti i record (%d) saranno permanentemente eliminati della tabella. Vuoi eliminarli?"
Modified: grass/trunk/locale/po/grasswxpy_ja.po
--- grass/trunk/locale/po/grasswxpy_ja.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_ja.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -8658,7 +8658,7 @@
msgid ""
msgstr ""
"ã¬ã¤ã¤ã¼/ã«ãã´ãªã¼ãæ°ãã追å åºæ¥ã¾ãã <%(layer)s/%(category)s>.\n"
"ã¬ã¤ã¤ã¼ãã«ãã´ãªã¼çªå·ã¯æ´æ°ã§ç¡ããã°ãªãã¾ãã.\n"
@@ -9408,7 +9408,7 @@
#, python-format
msgstr "鏿ããã¬ã³ã¼ã (%d) ã¯ããã¼ãã«ããå®å
¨ã«æ¶å»ããã¾ã åé¤ãã¦ããããã§ãã?"
@@ -10674,12 +10674,12 @@
#, python-format
msgstr "<%s> ãã¬ã³ãã¼ãªã¼ãã¼ã¬ã¤ã§ãã¾ãã"
#, python-format
@@ -10925,7 +10925,7 @@
#, python-format
msgstr "å
¨ã¦ã®ã¬ã³ã¼ã (%d) ã¯ããã¼ãã«ããå®å
Modified: grass/trunk/locale/po/grasswxpy_ml.po
--- grass/trunk/locale/po/grasswxpy_ml.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_ml.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -8852,7 +8852,7 @@
msgid ""
msgstr ""
@@ -9642,7 +9642,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -10979,12 +10979,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -11233,7 +11233,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_pl.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -8641,7 +8641,7 @@
msgid ""
msgstr ""
"Nie powiodÅo siÄ dodanie nowej warstwy/kategorii <%(layer)s/%(category)s>.\n"
"Numer warstwy i kategorii musi byÄ liczbÄ
caÅkowitÄ
.\n"
@@ -9396,7 +9396,7 @@
#, python-format
msgstr "Wybrane rekordy (%d) zostanÄ
caÅkowicie usuniÄte z tabeli. Chcesz je wykasowaÄ?"
@@ -10676,12 +10676,12 @@
#, python-format
msgstr "Nie można wyÅwietliÄ nakÅadki <%s>."
#, python-format
msgstr "Nie można wyÅwietliÄ nakÅadki <%s>"
@@ -10928,7 +10928,7 @@
#, python-format
msgstr "Wszystkie rekordy (%d) zostanÄ
Modified: grass/trunk/locale/po/grasswxpy_pt.po
--- grass/trunk/locale/po/grasswxpy_pt.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_pt.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9840,7 +9840,7 @@
msgid ""
msgstr ""
"Não é possÃvel adicionar nova camada/categoria <%(layer)s/%(category)s>.\n"
"Número de camada e categoria deve ser um inteiro.\n"
@@ -10665,7 +10665,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Seleccionar os dados de registo (%d) irá apagar definitivamente os dados da "
@@ -12096,12 +12096,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -12363,7 +12363,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pt_br.po
--- grass/trunk/locale/po/grasswxpy_pt_br.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_pt_br.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -10239,7 +10239,7 @@
msgid ""
msgstr ""
@@ -11087,7 +11087,7 @@
#, fuzzy, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -12532,12 +12532,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -12826,7 +12826,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ru.po
--- grass/trunk/locale/po/grasswxpy_ru.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_ru.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9514,7 +9514,7 @@
msgid ""
msgstr ""
"Ðевозможно добавиÑÑ Ð½Ð¾Ð²Ñй Ñлой/каÑегоÑÐ¸Ñ <%(layer)s/%(category)s>.\n"
"ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¸ каÑегоÑии Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑелÑми ÑиÑлами.\n"
@@ -10325,7 +10325,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"ÐÑбÑаннÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
@@ -11752,12 +11752,12 @@
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>."
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>"
@@ -12024,7 +12024,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"ÐÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
ÑдалиÑÑ?"
Modified: grass/trunk/locale/po/grasswxpy_th.po
--- grass/trunk/locale/po/grasswxpy_th.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_th.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9026,7 +9026,7 @@
msgid ""
msgstr ""
@@ -9800,7 +9800,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -11165,12 +11165,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -11422,7 +11422,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_tr.po
--- grass/trunk/locale/po/grasswxpy_tr.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_tr.po 2012-01-20 21:58:06 UTC (rev 50337)
msgid ""
msgstr ""
@@ -10240,7 +10240,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -11657,12 +11657,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -11924,7 +11924,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Tüm (%d) veri kayıtları tablodan kalıcı olarak silinecek. Onları silmek "
Modified: grass/trunk/locale/po/grasswxpy_vi.po
--- grass/trunk/locale/po/grasswxpy_vi.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_vi.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9483,7 +9483,7 @@
msgid ""
msgstr ""
"Không thá» thêm lá»p/phạm trù má»i <%(layer)s/%(category)s>.\n"
"â©Sá» lá»p và sá» phạm trù phải là sá» nguyên.\n"
@@ -10315,7 +10315,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Các bản ghi dữ liá»u Äã ÄÆ°á»£c chá»n (%d) sẽ bá» xóa bá» hoà n toà n khá»i bảng. Bạn "
@@ -11731,12 +11731,12 @@
#, python-format
msgstr "Không thá» vẽ chá»ng <%s>."
#, python-format
msgstr "Không thá» vẽ chá»ng <%s>"
@@ -11996,7 +11996,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Tất cả các bản ghi dữ liá»u (%d) sẽ bá» xóa bá» hoà n toà n khá»i bảng. Bạn có "
Modified: grass/trunk/locale/po/grasswxpy_zh.po
--- grass/trunk/locale/po/grasswxpy_zh.po 2012-01-20 21:57:09 UTC (rev 50336)
+++ grass/trunk/locale/po/grasswxpy_zh.po 2012-01-20 21:58:06 UTC (rev 50337)
@@ -9112,7 +9112,7 @@
msgid ""
msgstr ""
@@ -9905,7 +9905,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -11279,12 +11279,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -11537,7 +11537,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
