[GRASS-SVN] r50349 - grass/branches/releasebranch_6_4/lib/db/dbmi_client
Sat Jan 21 08:50:48 EST 2012
Author: mmetz
Date: 2012-01-21 05:50:48 -0800 (Sat, 21 Jan 2012)
New Revision: 50349
   grass/branches/releasebranch_6_4/lib/db/dbmi_client/column.c
db lib: fix memory leak (backport from trunk)
Modified: grass/branches/releasebranch_6_4/lib/db/dbmi_client/column.c
--- grass/branches/releasebranch_6_4/lib/db/dbmi_client/column.c	2012-01-21 13:25:35 UTC (rev 50348)
+++ grass/branches/releasebranch_6_4/lib/db/dbmi_client/column.c	2012-01-21 13:50:48 UTC (rev 50349)
@@ -39,6 +39,8 @@
     dbColumn *column;
     int ncol, cl, type;
+    type = -1;
     db_init_string(&table_name);
     db_set_string(&table_name, tab);
@@ -51,11 +53,14 @@
 	column = db_get_table_column(table, cl);
 	if (strcmp(db_get_column_name(column), col) == 0) {
 	    type = db_get_column_sqltype(column);
-	    return type;
+	    type = db_get_column_sqltype(column);
+	    break;
-    return -1;
+    db_free_table(table);
+    return type;
@@ -98,7 +103,7 @@
 int db_get_column(dbDriver * Driver, const char *tname, const char *cname,
 		  dbColumn ** Column)
-    int i, ncols;
+    int i, ncols, ret;
     dbTable *Table;
     dbColumn *Col, *NCol;
     dbString tabname;
@@ -112,6 +117,7 @@
     *Column = NULL;
+    ret = DB_FAILED;
     ncols = db_get_table_number_of_columns(Table);
     G_debug(3, "ncol = %d", ncols);
@@ -138,8 +144,11 @@
 	    NCol->update = Col->update;
 	    *Column = NCol;
-	    return DB_OK;
+	    ret = DB_OK;
+	    break;
-    return DB_OK;
+    db_free_table(Table);
+    return ret;
