[GRASS-SVN] r50350 - grass/trunk/vector/v.rectify
svn_grass at osgeo.org
Sat Jan 21 08:51:43 EST 2012
Author: mmetz
Date: 2012-01-21 05:51:43 -0800 (Sat, 21 Jan 2012)
New Revision: 50350
grass/trunk/vector/v.rectify/v.rectify.html
v.rectify: update manual
Modified: grass/trunk/vector/v.rectify/v.rectify.html
--- grass/trunk/vector/v.rectify/v.rectify.html 2012-01-21 13:50:48 UTC (rev 50349)
+++ grass/trunk/vector/v.rectify/v.rectify.html 2012-01-21 13:51:43 UTC (rev 50350)
@@ -20,9 +20,10 @@
<div class="code"><pre>
x y z east north height status
</pre></div>
-where x, y, z are source coordinates, east, north, height are target
-coordinates and status (0 or 1) indicates whether a given point should
-be used.
+where <em>x, y, z</em> are source coordinates, <em>east, north, height</em>
+are target coordinates and status (0 or 1) indicates whether a given
+point should be used. Numbers must be separated by space and must use a
+point (.) as decimal separator.
<p>
If no <b>group</b> is given, the rectified vector will be written to
@@ -67,7 +68,7 @@
<h4>Polynomial Transformation Matrix (2nd, 3d order transformation)</h4>
<em>v.rectify</em> uses a first, second, or third order transformation
-matrix to calculate the registration coefficients. The number
+matrix to calculate the registration coefficients. The minimum number
of control points required for a 2D transformation of the selected order
(represented by n) is
@@ -76,12 +77,12 @@
</dl>
or 3, 6, and 10 respectively. For a 3D transformation of first, second,
-or third order, the number of required control points is 4, 10, and 20
-respectively. It is strongly recommended that one or more additional
-points be identified to allow for an overly-determined transformation
-calculation which will generate the Root Mean Square (RMS) error values
-for each included point. The polynomial equations are determined using
-a modified Gaussian elimination method.
+or third order, the minimum number of required control points is 4, 10,
+and 20, respectively. It is strongly recommended that more than the
+minimum number of points be identified to allow for an overly-determined
+transformation calculation which will generate the Root Mean Square (RMS)
+error values for each included point. The polynomial equations are
+determined using a modified Gaussian elimination method.
<h2>SEE ALSO</h2>
@@ -91,6 +92,7 @@
Processing manual</a></em>
<p><em>
+ <a href="v.transform.html">v.transform</a>,
<a href="m.transform.html">m.transform</a>,
<a href="i.rectify.html">i.rectify</a>,
<a href="r.proj.html">r.proj</a>,
