[GRASS-SVN] r50432 - grass/branches/develbranch_6/vector/v.to.rast
Wed Jan 25 02:12:04 EST 2012
Author: hamish
Date: 2012-01-24 23:12:04 -0800 (Tue, 24 Jan 2012)
New Revision: 50432
   grass/branches/develbranch_6/vector/v.to.rast/main.c
   grass/branches/develbranch_6/vector/v.to.rast/vect2rast.c
only print convert stats when interesting; move done_msg to main fn level (merge from trunk)
Modified: grass/branches/develbranch_6/vector/v.to.rast/main.c
--- grass/branches/develbranch_6/vector/v.to.rast/main.c	2012-01-25 07:08:25 UTC (rev 50431)
+++ grass/branches/develbranch_6/vector/v.to.rast/main.c	2012-01-25 07:12:04 UTC (rev 50432)
@@ -139,8 +139,10 @@
     if (vect_to_rast(input->answer, output->answer, field,
 		     col->answer, nrows, use, value, value_type,
-		     rgbcol_opt->answer, label_opt->answer, type))
-      exit(EXIT_FAILURE);
+		     rgbcol_opt->answer, label_opt->answer, type)) {
+	exit(EXIT_FAILURE);
+    G_done_msg("");
     exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/vector/v.to.rast/vect2rast.c
--- grass/branches/develbranch_6/vector/v.to.rast/vect2rast.c	2012-01-25 07:08:25 UTC (rev 50431)
+++ grass/branches/develbranch_6/vector/v.to.rast/vect2rast.c	2012-01-25 07:12:04 UTC (rev 50432)
@@ -223,10 +223,10 @@
     update_labels(raster_map, vector_map, field, labelcolumn, use, value,
 		  column);
-    G_message(_("Converted areas: %d of %d"), nareas, nareas_all);
-    G_message(_("Converted points/lines: %d of %d"), nlines, nplines_all);
-    G_done_msg(" ");
+    if (nareas_all > 0)
+	G_message(_("Converted areas: %d of %d"), nareas, nareas_all);
+    if (nplines_all > 0)
+	G_message(_("Converted points/lines: %d of %d"), nlines, nplines_all);
     return 0;
