[GRASS-SVN] r50433 - grass/branches/develbranch_6/lib/gis
svn_grass at osgeo.org
Wed Jan 25 02:23:17 EST 2012
Author: hamish
Date: 2012-01-24 23:23:17 -0800 (Tue, 24 Jan 2012)
New Revision: 50433
grass/branches/develbranch_6/lib/gis/closecell.c
msg cosmetics
Modified: grass/branches/develbranch_6/lib/gis/closecell.c
--- grass/branches/develbranch_6/lib/gis/closecell.c 2012-01-25 07:12:04 UTC (rev 50432)
+++ grass/branches/develbranch_6/lib/gis/closecell.c 2012-01-25 07:23:17 UTC (rev 50433)
@@ -1,4 +1,3 @@
* G_close_cell(fd)
@@ -229,14 +228,14 @@
else {
if (remove(fcb->null_temp_name) != 0)
- G_warning(_("Unable to remove the temporary null-cells file"));
+ G_warning(_("Unable to delete the temporary null-cells file"));
else {
if (remove(path) != 0)
- G_warning(_("Unable to remove the null-cells file"));
+ G_warning(_("Unable to delete the null-cells file"));
} /* null_cur_row > 0 */
if (fcb->open_mode == OPEN_NEW_COMPRESSED) { /* auto compression */
@@ -315,7 +314,7 @@
else {
if (remove(fcb->temp_name) != 0)
- G_warning(_("Unable to remove the temporary 'cell' file"));
+ G_warning(_("Unable to delete the temporary 'cell' file"));
@@ -372,7 +371,7 @@
G__file_name_misc(path, "cell_misc", QUANT_FILE, fcb->name,
fcb->mapset);
- G_warning(_("Unable to remove the %s file"), QUANT_FILE);
+ G_warning(_("Unable to delete the %s file"), QUANT_FILE);
/* create empty cats file */
@@ -417,7 +416,7 @@
int stat;
if (fcb->map_type == CELL_TYPE) {
- G_warning(_("unable to write f_format file for CELL maps"));
+ G_warning(_("Unable to write f_format file for CELL maps"));
return 0;
format_kv = G_create_key_value();
