[GRASS-SVN] r52318 - grass-addons/grass7/imagery/i.segment
Thu Jul 5 22:20:52 PDT 2012
Author: momsen
Date: 2012-07-05 22:20:52 -0700 (Thu, 05 Jul 2012)
New Revision: 52318
   grass-addons/grass7/imagery/i.segment/Makefile
   grass-addons/grass7/imagery/i.segment/create_isegs.c
   grass-addons/grass7/imagery/i.segment/iseg.h
   grass-addons/grass7/imagery/i.segment/open_files.c
   grass-addons/grass7/imagery/i.segment/parse_args.c
   grass-addons/grass7/imagery/i.segment/times.txt
   grass-addons/grass7/imagery/i.segment/write_output.c
BROKEN - added seg_time method to check timings of various structures.
Modified: grass-addons/grass7/imagery/i.segment/Makefile
--- grass-addons/grass7/imagery/i.segment/Makefile	2012-07-06 00:47:48 UTC (rev 52317)
+++ grass-addons/grass7/imagery/i.segment/Makefile	2012-07-06 05:20:52 UTC (rev 52318)
@@ -2,7 +2,7 @@
 PGM = i.segment
-LIBES = $(IMAGERYLIB) $(RASTERLIB) $(SEGMENTLIB) $(GISLIB) $(LINKMLIB)
+LIBES = $(IMAGERYLIB) $(RASTERLIB) $(SEGMENTLIB) $(GISLIB) $(LINKMLIB) $(BTREE2LIB)
 DEPENDENCIES = $(IMAGERYDEP) $(RASTERDEP) $(SEGMENTDEP) $(GISDEP) $(LINKMDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-06 00:47:48 UTC (rev 52317)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c	2012-07-06 05:20:52 UTC (rev 52318)
@@ -10,8 +10,14 @@
 #include <grass/raster.h>
 #include <grass/segment.h>	/* segmentation library */
 #include <grass/linkm.h>	/* memory manager for linked lists */
+#include <grass/rbtree.h>	/* Red Black Tree library functions */
 #include "iseg.h"
+#ifdef DEBUG
+	#include <time.h>
+	#include <stdbool.h> /* TODO decide if _bool is needed for FLAGs */
+#endif
 #define LINKM
 /* #define REVERSE */
@@ -50,6 +56,9 @@
 	else if (functions->method == 2)
 	    successflag = ll_test(files, functions);
+	else if (functions->method == 3)
+	    successflag = seg_speed_test(files, functions);
     }				/* end outer loop for processing polygons */
@@ -59,6 +68,7 @@
     return successflag;
+#ifdef DEBUG
 /* writes row+col to the output raster.  Also using for the linkm speed test. */
 int io_debug(struct files *files, struct functions *functions)
@@ -282,6 +292,188 @@
+int seg_speed_test(struct files *files, struct functions *functions)
+	int i, j, n, max;
+	clock_t start, end;
+    double temp, cpu_time_used;
+    int (*get) (struct files *, int, int); /* files, row, col */
+	struct RB_TREE *no_check_tree;
+	struct RB_TRAV trav;
+	struct pixels *to_check, *newpixel, *current;
+	G_message("checking speed of RAM vs SEG vs get function performance");
+	G_message("Access in the same region, so shouldn't have any disk I/O");
+	max = 100000000;
+	G_message("repeating everything %d times.", max);
+	{ /* Array vs. SEG ... when working in local area */
+	start = clock();
+	for (i=0; i<max; i++){
+		segment_get(&files->bands_seg, (void *)files->bands_val, 12, 12);
+		temp = files->bands_val[0];
+	end = clock();
+	cpu_time_used = ((double) (end - start)) / CLOCKS_PER_SEC;
+	G_message("Using SEG: %g", cpu_time_used);
+	start = clock();
+		temp = files->iseg[12][12];
+	end = clock();
+	G_message("Using array in RAM: %g", cpu_time_used);
+	get = &get_segID_SEG;
+	start = clock();
+		temp = get(files, 12, 12);
+	end = clock();
+	G_message("Using SEG w/ get(): %g", cpu_time_used);
+	get = &get_segID_RAM;
+	start = clock();
+	end = clock();
+	G_message("Using RAM w/ get(): %g", cpu_time_used);
+	G_message("to check storage requirements... system dependent... :");
+	G_message("unsigned char: %lu", sizeof(unsigned char));
+	G_message("unsigned char pointer: %lu", sizeof(unsigned char *));
+	G_message("_Bool: %lu", sizeof(_Bool));
+	G_message("int: %lu", sizeof(int));
+	G_message("unsigned int: %lu", sizeof(unsigned int));
+	G_message("double: %lu", sizeof(double));
+	max = 100000;
+	{ /* compare rbtree with linked list */
+	//~ no_check_tree = rbtree_create(compare_ids, sizeof(int));
+	//~ rbtree_init_trav(&trav, no_check_tree);
+	n = 100;
+	start = clock();
+		no_check_tree = rbtree_create(compare_ids, sizeof(int));
+		rbtree_init_trav(&trav, no_check_tree);
+		/*build*/
+		for(j=0; j<n; j++){
+			rbtree_insert(no_check_tree, &j);
+		//~ /*access*/
+		//~ while ((data = rbtree_traverse(&trav)) != NULL) {
+			//~ if (my_compare_fn(data, threshold_data) == 0) break;
+				//~ G_message("%d", data);
+		/*free memory*/
+		rbtree_destroy(no_check_tree);
+	end = clock();
+	G_message("Using rbtree (just build/destroy), %d elements, time: %g", n, cpu_time_used);
+	to_check = NULL;
+	start = clock();
+		/*build*/
+			newpixel = (struct pixels *)link_new(files->token);
+			newpixel->next = to_check;	/*point the new pixel to the current first pixel */
+			newpixel->row = j;
+			newpixel->col = i;
+			to_check = newpixel;	/*change the first pixel to be the new pixel. */
+		/*access*/
+		for (current = to_check; current != NULL; current = current->next) {	/* for each of Ri's neighbors */
+			temp = current->row;
+		/*free memory*/
+		my_dispose_list(files->token, &to_check);
+	end = clock();
+	G_message("Using linked list and linkm (build/access/free), %d elements, time: %g", n, cpu_time_used);
+	n=1000;
+	//repeat for both with larger membership
+		start = clock();
+		/*build*/
+		//~ /*access*/
+		/*free memory*/
+	end = clock();
+	G_message("Using rbtree, %d elements, time: %g", n, cpu_time_used);
+	to_check = NULL;
+	start = clock();
+		/*build*/
+		/*access*/
+		/*free memory*/
+	end = clock();
+	G_message("Using linked list and linkm, %d elements, time: %g", n, cpu_time_used);
+	return TRUE;
+int get_segID_SEG(struct files *files, int row, int col)
+	segment_get(&files->bands_seg, (void *)files->bands_val, row, col);
+	return files->bands_val[0]; /*todo for accurate comparison, is converting double to int a time penalty? */
+int get_segID_RAM(struct files *files, int row, int col)
+	return files->iseg[row][col];
+#endif
 int region_growing(struct files *files, struct functions *functions)
     int row, col, t;
@@ -423,6 +615,7 @@
 		       current->col);
 		       G_debug(4, "also passing Ri_count: %d", Ri_count);
 		    /* find segment neighbors */
 		    if (find_segment_neighbors
 			(&Ri_head, &Rin_head, &Ri_count, files,
@@ -442,19 +635,21 @@
 		    else {	/*found neighbors, go ahead until find mutually agreeing neighbors */
 			G_debug(4, "2b, Found Ri's pixels");
+			#ifdef DEBUG
 			/*print out neighbors */
 			for (current = Ri_head; current != NULL;
 			    G_debug(4, "Ri: row: %d, col: %d", current->row,
 				    current->col);
+			#endif
 			G_debug(4, "2b, Found Ri's neighbors");
+			#ifdef DEBUG
 			for (current = Rin_head; current != NULL;
 			    G_debug(4, "Rin: row: %d, col: %d", current->row,
 				    current->col);
+			#endif
 			/* find Ri's most similar neighbor */
 			Ri_bestn = NULL;
@@ -518,19 +713,22 @@
 			    find_segment_neighbors(&Rk_head, &Rkn_head, &Rk_count, files, functions);	/* data structure for Rk's neighbors, and pixels in Rk if we don't already have it */
 			    G_debug(4, "Found Rk's pixels");
+			    #ifdef DEBUG
 			    for (current = Rk_head; current != NULL;
 				G_debug(4, "Rk: row: %d, col: %d",
 					current->row, current->col);
+				#endif
 			    G_debug(4, "Found Rk's neighbors");
+			    #ifdef DEBUG
 			    for (current = Rkn_head; current != NULL;
 				G_debug(4, "Rkn: row: %d, col: %d",
+				#endif
 			    /*find Rk's most similar neighbor */
 			    Rk_similarity = Ri_similarity;	/*Ri gets first priority - ties won't change anything, so we'll accept Ri and Rk as mutually best neighbors */
 			    segment_get(&files->bands_seg, (void *)files->bands_val, Rk_head->row, Rk_head->col);	/* current segment values */
@@ -608,11 +806,14 @@
     while (t <= functions->end_t && endflag == FALSE) ;
     /*end t loop *//*TODO, should there be a max t that it can iterate for?  Include t in G_message? */
-	if(endflag == FALSE) G_warning(_("Merging processes stopped due to reaching max iteration limit, more merges may be possible"));
+	if(endflag == FALSE) G_message(_("Merging processes stopped due to reaching max iteration limit, more merges may be possible"));
 	/* final pass, ignore threshold and force a merge for small segments with their best neighbor */
 	if (functions->min_segment_size > 1) {
 		G_verbose_message("Final iteration, force merges for small segments.");
@@ -703,21 +904,22 @@
 				else /* Merge with most similar neighbor */
-					G_debug(4, "2b, Found Ri's pixels");
-					/*print out neighbors */
-					for (current = Ri_head; current != NULL;
-						 current = current->next)
-						G_debug(4, "Ri: row: %d, col: %d", current->row,
-							current->col);
+					//~ TODO DELETE?
+					//~ G_debug(4, "2b, Found Ri's pixels");
+					//~ /*print out neighbors */
+					//~ for (current = Ri_head; current != NULL;
+						 //~ current = current->next)
+						//~ G_debug(4, "Ri: row: %d, col: %d", current->row,
+							//~ current->col);
+					//~ G_debug(4, "2b, Found Ri's neighbors");
+					//~ for (current = Rin_head; current != NULL;
+						//~ G_debug(4, "Rin: row: %d, col: %d", current->row,
-					G_debug(4, "2b, Found Ri's neighbors");
-					for (current = Rin_head; current != NULL;
-						G_debug(4, "Rin: row: %d, col: %d", current->row,
-							current->col);
 					Ri_bestn = NULL;
 					Ri_similarity = LDBL_MAX;	/* set current similarity to max value */
@@ -765,20 +967,21 @@
 						/* using this just to get the full pixel/cell membership list for Rk */
-						G_debug(4, "Found Rk's pixels");
-						for (current = Rk_head; current != NULL;
-						G_debug(4, "Rk: row: %d, col: %d",
-							current->row, current->col);
+//~ TODO DELETE?
+						//~ G_debug(4, "Found Rk's pixels");
+						//~ for (current = Rk_head; current != NULL;
+						//~ G_debug(4, "Rk: row: %d, col: %d",
+							//~ current->row, current->col);
+						//~ G_debug(4, "Found Rk's neighbors");
+						//~ for (current = Rkn_head; current != NULL;
+						//~ G_debug(4, "Rkn: row: %d, col: %d",
-						G_debug(4, "Found Rk's neighbors");
-						for (current = Rkn_head; current != NULL;
-						G_debug(4, "Rkn: row: %d, col: %d",
 						merge_values(Ri_head, Rk_head, Ri_count, Rk_count, files);	/* TODO error trap */
 						/* merge_values sets Ri and Rk candidate flag to FALSE.  Put Rk back to TRUE if the size is too small. */
@@ -791,16 +994,17 @@
 				}		/* end else - pixel count was below minimum allowed */
 		    } /* end if neighbors found */
-		    else
-				G_warning("no neighbors found, this should NOT happen on merge step.");
+		    else{ /* no neighbors were found */
+				G_warning("no neighbors found, this means only one segment was created.");
+				set_candidate_flag(Ri_head, FALSE, files);
 		}		/*end if pixel is candidate pixel */
 	}			/*next column */
-	G_percent(row, files->nrows, 1);
+	G_percent(row, files->nrows-1, 1);
     }			/*next row */
 	} /* end if for force merge */
 	else
-		G_verbose_message(_("Minimum pixels for group was set to 1, no final forced merge iteration for small segments."));
+		G_message(_("Input for minimum pixels in a segment was 1, skipping final iteration for joining small segments."));
     /* free memory *//*TODO: anything ? */
@@ -813,11 +1017,18 @@
-	int n, Ri_seg_ID = -1;
+	int n, current_seg_ID, Ri_seg_ID = -1;
 	struct pixels *newpixel, *current, *to_check;	/* need to check the pixel neighbors of to_check */
 	int pixel_neighbors[8][2];	/* TODO: data type?  put in files to allocate memory once? */
+//TODO remove...	/* files->no_check is a FLAG structure, only used here but allocating memory in open_files */
+	struct RB_TREE *no_check_tree; /* SEGMENT ID that should no longer be checked on this current find_neighbors() run */
-	/* files->no_check is a FLAG structure, only used here but allocating memory in open_files */
+#ifdef DEBUG
+#endif
+	/* TODO, any time savings to move any variables to files (mem allocation in open_files) */
 	/* neighbor list will be a listing of pixels that are neighbors?  Include segment numbers?  Only include unique segments?
 	 * Maybe the most complete return would be a structure array, structure to include the segment ID and a list of points in it?
@@ -827,7 +1038,6 @@
 	/* parameter: R, current segment membership, could be single pixel or list of pixels.
 	 * parameter: neighbors/Rin/Rik, neighbor pixels, could have a list already, or could be empty ?
 	 * files->out_seg is currently an array [0] for seg ID and [1] for "candidate pixel"
-	 * files->no_check is a segmentation data structure, if the pixel should no longer be checked on this current find_neighbors() run
 	 * functions->num_pn  int, 4 or 8, for number of pixel neighbors
@@ -839,17 +1049,19 @@
 	   G_debug(5, "neig: row: %d, col: %d", current->row, current->col);
 	   G_debug(5, "also passing Ri_count: %d", *seg_count); */
-	/*initialize data.... TODO: maybe remember min max row/col that was looked at each time, initialize in open_files, and reset smaller region at end of this functions */
-	/*todo, dlete this loop for (n = 0; n < files->nrows; n++) {
-	   for (m = 0; m < files->ncols; m++) {
-	   val_no_check = FALSE;
-	   segment_put(&files->no_check, &val_no_check, n, m);
-	flag_clear_all(files->no_check);
+	/* *** initialize data *** */
+	/* get Ri's segment ID */
+	Ri_seg_ID = files->iseg[(*R_head)->row][(*R_head)->col];	/* old data structure needed, this... keep for readability? */
+//	flag_clear_all(files->no_check);
 	to_check = NULL;
+#ifdef DEBUG
+#endif
 	/* Copy R in to_check and no_check data structures (don't expand them if we find them again) */
 	/* NOTE: in pseudo code also have a "current segment" list, but think we can just pass Ri and use it directly */
@@ -860,15 +1072,22 @@
 	    newpixel->row = current->row;
 	    newpixel->col = current->col;
-	    flag_set(files->no_check, current->row, current->col);
+//todo delete	    flag_set(files->no_check, current->row, current->col);
+//~ G_message("starting to insert dummy no_check values");
+//~ current_seg_ID = -5;
+//~ rbtree_insert(no_check_tree, &current_seg_ID);
+//~ G_message("inserted -5");
+//~ current_seg_ID = -10;
+//~ G_message("inserted -10");
+	rbtree_insert(no_check_tree, &Ri_seg_ID);
+	G_debug(5, "inserted Ri_seg_ID number %d into RBtree.", Ri_seg_ID);
 	/* empty "neighbor" list  Note: this step is in pseudo code, but think we just pass in Rin - it was already initialized, and later could have Ri data available to start from */
-	/* get Ri's segment ID */
-	Ri_seg_ID = files->iseg[(*R_head)->row][(*R_head)->col];	/* old data structure needed, this... keep for readability? */
 	while (to_check != NULL) {	/* removing from to_check list as we go, NOT iterating over the list. */
 	    G_debug(5,
 		    "\tfind_pixel_neighbors for row: %d , col %d",
@@ -885,6 +1104,7 @@
 	    link_dispose(files->token, (VOID_T *) current);
 	    /*print out to_check */
+	    #ifdef DEBUG
 	    G_debug(5, "remaining pixel's in to_check, after popping:");
 		G_debug(5, "to_check... row: %d, col: %d", current->row,
@@ -893,7 +1113,8 @@
 		G_debug(5, "Rn... row: %d, col: %d", current->row,
 			current->col);
+		#endif
 	    /*now check the pixel neighbors and add to the lists */
 	    /*debug what neighbors were found: */
@@ -903,14 +1124,40 @@
 	    for (n = 0; n < functions->num_pn; n++) {	/* with pixel neighbors */
-		G_debug(5,
-			"\twith pixel neigh %d, row: %d col: %d, val_no_check = %d",
-			n, pixel_neighbors[n][0], pixel_neighbors[n][1],
-			flag_get(files->no_check, pixel_neighbors[n][0],
-				 pixel_neighbors[n][1]));
-		if (flag_get(files->no_check, pixel_neighbors[n][0], pixel_neighbors[n][1]) == FALSE) {	/* want to check this neighbor */
-		    flag_set(files->no_check, pixel_neighbors[n][0], pixel_neighbors[n][1]);	/* don't check it again */
+		//~TODO delete    G_debug(5,
+			//~ "\twith pixel neigh %d, row: %d col: %d, val_no_check = %d",
+			//~ n, pixel_neighbors[n][0], pixel_neighbors[n][1],
+			//~ flag_get(files->no_check, pixel_neighbors[n][0],
+				 //~ pixel_neighbors[n][1]));
+		// TODO delete   if (flag_get(files->no_check, pixel_neighbors[n][0], pixel_neighbors[n][1]) == FALSE)
+		current_seg_ID = files->iseg[pixel_neighbors[n][0]][pixel_neighbors[n][1]];
+		G_debug(5, "\tcurrent_seg_ID = %d", current_seg_ID);
+		G_debug(5, "********* rbtree_find(no_check_tree, &current_seg_ID) = %p", rbtree_find(no_check_tree, &current_seg_ID));
+		G_debug(5, "if evaluation: %d", rbtree_find(no_check_tree, &current_seg_ID) == FALSE);
+ * bad logic... previously, was tracking no_check pixels
+ * want to get both neighbors AND membership of R
+ * Changing to no_check saving the segment ID's - need someway to find membership!
+ * do speed check on Rbtree vs. linked list membership list???
+ * A.  revert to saving no_check pixels. could still use tree for no_check pixels,
+ * 		 compare function could use row then col.
+ *   Could have RBtree to save unique segment id's as well, so neighbor list could be reduced as well.
+ * return membership and neighbors would still be lists.
+ * B.  save membership pixels in a tree.  So with each new pixel to check:
+ * 			if current seg ID equals R_segID && can't find it in the tree, then add it to membership tree
+ * 			else if current seg ID is not in neighbor tree, then add it to neighbor list
+ * with B, would it be worth changing the neighbor list to a tree?
+		if(rbtree_find(no_check_tree, &current_seg_ID) == FALSE) {	/* want to check this neighbor */
+		    if(rbtree_insert(no_check_tree, &current_seg_ID)==0)	/* don't check it again */
+				G_warning("could not insert data!?");
 		    if (!(FLAG_GET(files->null_flag, pixel_neighbors[n][0], pixel_neighbors[n][1]))) {	/* all pixels, not just valid pixels */
 			G_debug(5, "\tfiles->iseg[][] = %d Ri_seg_ID = %d",
@@ -960,19 +1207,31 @@
 		}		/*end if for pixel_neighbor was in "don't check" list */
 	    }			/* end for loop - next pixel neighbor */
+	    #ifdef DEBUG
 	    G_debug(5,
 		    "remaining pixel's in to_check, after processing the last pixel's neighbors:");
-		G_debug(5, "to_check... row: %d, col: %d", current->row,
-			current->col);
+			G_debug(5, "to_check... row: %d, col: %d", current->row,
+				current->col);
+		/* todo? just to see if it worked?  G_message("no_check segment ID's: hmm, how implement?"); */
+	while ((data = rbtree_traverse(&trav)) != NULL) {
+		if (my_compare_fn(data, threshold_data) == 0) break;
+			G_message("%d", data);
 	    G_debug(5, "\t### end of pixel neighors");
+	    #endif
 	}			/* while to_check has more elements */
+	/* TODO - anything to free??? */
+	/* clean up */
 	return TRUE;
     int find_four_pixel_neighbors(int p_row, int p_col,
 				  int pixel_neighbors[8][2],
 				  struct files *files)
@@ -1146,3 +1405,26 @@
 	return TRUE;
+/* function used by binary tree to compare items */
+/* TODO, I don't understand the purpose of all this C syntax...will this give me just a simple numeric comparison??? */
+/* TODO
+ * "static" was used in break_polygons.c  extern was suggested in docs.  */
+int compare_ids(const void *first, const void *second)
+	int *a = (int *)first, *b = (int *)second;
+	if (*a < *b)
+		return -1;
+	else if (*a > *b)
+		return 1;
+	else if (*a == *b)
+		return 0;
+	G_warning(_("find neighbors: Bug in binary tree!"));
+	return 1;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-06 00:47:48 UTC (rev 52317)
+++ grass-addons/grass7/imagery/i.segment/iseg.h	2012-07-06 05:20:52 UTC (rev 52318)
@@ -16,6 +16,8 @@
 #include "flag.h"
+#define DEBUG
 /* pixel stack */
 struct pixels
@@ -52,7 +54,7 @@
     /* processing flags */
     FLAG *candidate_flag, *null_flag;	/*TODO, need some way to remember MASK/NULL values.  Was using -1, 0, 1 in int array.  Better to use 2 FLAG structures, better readibility? */
-    FLAG *no_check;		/* pixels that have already been checked during this neighbor finding routine */
+//    FLAG *no_check;		/* pixels that have already been checked during this neighbor finding routine */
     /* memory management, linked lists */
     struct link_head *token;	/* for linkm linked list memory management. */
@@ -109,6 +111,9 @@
 int io_debug(struct files *, struct functions *);
 int ll_test(struct files *, struct functions *);
 int test_pass_token(struct pixels **, struct files *);
+int seg_speed_test(struct files *, struct functions *);
+int get_segID_SEG(struct files *, int, int);
+int get_segID_RAM(struct files *, int, int);
 int region_growing(struct files *, struct functions *);
 int find_segment_neighbors(struct pixels **, struct pixels **, int *,
@@ -119,6 +124,7 @@
 double calculate_euclidean_similarity(struct pixels *, struct pixels *,
 int my_dispose_list(struct link_head *, struct pixels **);
+int compare_ids(const void *, const void *);
 /* write_output.c */
 int write_output(struct files *);
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c	2012-07-06 00:47:48 UTC (rev 52317)
+++ grass-addons/grass7/imagery/i.segment/open_files.c	2012-07-06 05:20:52 UTC (rev 52318)
@@ -20,7 +20,7 @@
     /*allocate memory for flags */
     files->null_flag = flag_create(files->nrows, files->ncols);
     files->candidate_flag = flag_create(files->nrows, files->ncols);
-    files->no_check = flag_create(files->nrows, files->ncols);
+//    files->no_check = flag_create(files->nrows, files->ncols);
     G_debug(1, "Checking image group...");
     /* references: i.cost r.watershed/seg and http://grass.osgeo.org/programming7/segmentlib.html */
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c	2012-07-06 00:47:48 UTC (rev 52317)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c	2012-07-06 05:20:52 UTC (rev 52318)
@@ -33,14 +33,18 @@
     method->type = TYPE_STRING;
     method->required = YES;
     method->answer = "region_growing";
-    method->options = "region_growing, io_debug, ll_test";	/* TODO at end, remove these from list: io_debug just writes row+col to each output pixel, ll_test for testing linked list data structure */
+    #ifdef DEBUG
+    method->options = "region_growing, io_debug, ll_test, seg_time";
+    #else
+    method->options = "region_growing";
+    #endif
     method->description = _("Segmentation method.");
 	min_segment_size = G_define_option();
 	min_segment_size->key = "min"; /*TODO is there a preference for long or short key names? min is pretty generic...but short... */
 	min_segment_size->type = TYPE_INTEGER;
 	min_segment_size->required = YES;
-	min_segment_size->answer = "10"; /* TODO, should a "typical" default be provided? */
+	min_segment_size->answer = "1"; /* TODO, should a "typical" default be provided? */
 	min_segment_size->options = "1-100000"; /*must be positive number, is >0 allowed in "options" or is 100,000 suitably large? */
 	min_segment_size->description = _("Minimum number of pixels (cells) in a segment.  The final merge step will ignore the threshold for any segments with fewer pixels.");
@@ -126,6 +130,8 @@
 	functions->method = 1;
     else if (strncmp(method->answer, "ll_test", 5) == 0)
 	functions->method = 2;
+	else if (strncmp(method->answer, "seg_time", 5) == 0)
+	functions->method = 3;
     else
 	G_fatal_error("Couldn't assign segmentation method.");	/*shouldn't be able to get here */
Modified: grass-addons/grass7/imagery/i.segment/times.txt
--- grass-addons/grass7/imagery/i.segment/times.txt	2012-07-06 00:47:48 UTC (rev 52317)
+++ grass-addons/grass7/imagery/i.segment/times.txt	2012-07-06 05:20:52 UTC (rev 52318)
@@ -1,3 +1,34 @@
+Segment ID storage - RAM vs SEG and speed access.
+i.segment -w --overwrite --verbose group=landsat_1band at samples output=temp threshold=5 method=seg_time min=1
+checking speed of RAM vs SEG vs get function performance
+Access in the same region, so shouldn't have any disk I/O
+repeating everything 100000000 times.
+Using SEG: 2.63
+Using array in RAM: 0.25
+Using SEG w/ get(): 3.27
+Using RAM w/ get(): 0.68
+to check storage requirements... system dependent... :
+unsigned char: 1
+unsigned char pointer: 8
+_Bool: 1
+int: 4
+unsigned int: 4
+double: 8
+repeating everything 100000 times.
+Using rbtree (just build/destroy), 100 elements, time: 3.94
+Using linked list and linkm (build/access/free), 100 elements, time: 0.3
+Using rbtree, 1000 elements, time: 51.03
+Using linked list and linkm, 1000 elements, time: 3.21
+Storage requirement:
+100,000,000 pixels
 NC sample landsat images, lsat7_2000_10
 g.region rast=lsat7_2000_10 at landsat
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c	2012-07-06 00:47:48 UTC (rev 52317)
+++ grass-addons/grass7/imagery/i.segment/write_output.c	2012-07-06 05:20:52 UTC (rev 52318)
@@ -97,7 +97,7 @@
     flag_destroy(files->null_flag);
     flag_destroy(files->candidate_flag);
-    flag_destroy(files->no_check);
+//    flag_destroy(files->no_check);
     G_debug(1, "close_files() before link_cleanup()");
     link_cleanup(files->token);
     G_debug(1, "close_files() after link_cleanup()");
