[GRASS-SVN] r52319 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Jul 6 03:39:51 PDT 2012
Author: wenzeslaus
Date: 2012-07-06 03:39:51 -0700 (Fri, 06 Jul 2012)
New Revision: 52319
grass/trunk/lib/vector/Vlib/cats.c
grass/trunk/lib/vector/Vlib/line.c
Vlib: dox: note about freeing
Modified: grass/trunk/lib/vector/Vlib/cats.c
--- grass/trunk/lib/vector/Vlib/cats.c 2012-07-06 05:20:52 UTC (rev 52318)
+++ grass/trunk/lib/vector/Vlib/cats.c 2012-07-06 10:39:51 UTC (rev 52319)
@@ -30,6 +30,8 @@
This structure is used for reading and writing vector cats. The
library routines handle all memory allocation.
+ To free allocated memory call Vect_destroy_cats_struct().
\return struct line_cats *
\return NULL on error
Modified: grass/trunk/lib/vector/Vlib/line.c
--- grass/trunk/lib/vector/Vlib/line.c 2012-07-06 05:20:52 UTC (rev 52318)
+++ grass/trunk/lib/vector/Vlib/line.c 2012-07-06 10:39:51 UTC (rev 52319)
@@ -35,6 +35,8 @@
polygons. The library routines handle all memory allocation. If 3
lines in memory are needed at the same time, then simply 3 line_pnts
structures have to be used.
+ To free allocated memory call Vect_destroy_line_struct().
Calls G_fatal_error() on error.
