[GRASS-SVN] r52433 - grass/branches/releasebranch_6_4/vector
svn_grass at osgeo.org
Sat Jul 21 10:52:52 PDT 2012
Author: neteler
Date: 2012-07-21 10:52:52 -0700 (Sat, 21 Jul 2012)
New Revision: 52433
grass/branches/releasebranch_6_4/vector/vectorintro.html
minor updates
Modified: grass/branches/releasebranch_6_4/vector/vectorintro.html
--- grass/branches/releasebranch_6_4/vector/vectorintro.html 2012-07-21 02:18:03 UTC (rev 52432)
+++ grass/branches/releasebranch_6_4/vector/vectorintro.html 2012-07-21 17:52:52 UTC (rev 52433)
@@ -107,7 +107,7 @@
consist of one or more areas and are used internally to maintain correct
topology for areas.
-<P>
+<p>
The <a href="v.type.html">v.type</a> module can be used to convert
between vector types if possible. The <a href="v.build.html">v.build</a>
module is used to generate topology. It optionally allows to extract
@@ -117,11 +117,11 @@
A dedicated vector editing module is <a href="v.edit.html">v.edit</a>
which supports global and local editing operations. Additionally,
new advanced topological operations are available in the
-<a href="wxGUI.Vector_Digitizer.html">new digitizing tool</a>.
+<a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a>.
Adjacent polygons can be found by <a href="v.to.db.html">v.to.db</a>
(see 'sides' option).
-<P>
+<p>
Many operations including extraction, queries, overlay, and export will
only act on features which have been assigned a category number. Typically
a centroid will hold the attribute data for the area between it and its
@@ -372,10 +372,10 @@
<li><a href="raster3dintro.html">Introduction to GRASS 3D raster map (voxel) processing</a></li>
</ul>
-<HR>
-<BR>
+<hr>
+<br>
<a href="index.html">Main index</a> - <a href="vector.html">vector index</a> - <a href="full_index.html">full index</a>
-<P>© 2008-2011 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
+<P>© 2008-2012 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
</body>
</html>
