[GRASS-SVN] r52434 - grass/branches/develbranch_6/vector
Sat Jul 21 10:52:59 PDT 2012
Author: neteler
Date: 2012-07-21 10:52:58 -0700 (Sat, 21 Jul 2012)
New Revision: 52434
   grass/branches/develbranch_6/vector/vectorintro.html
minor updates
Modified: grass/branches/develbranch_6/vector/vectorintro.html
--- grass/branches/develbranch_6/vector/vectorintro.html	2012-07-21 17:52:52 UTC (rev 52433)
+++ grass/branches/develbranch_6/vector/vectorintro.html	2012-07-21 17:52:58 UTC (rev 52434)
@@ -107,7 +107,7 @@
 consist of one or more areas and are used internally to maintain correct
 topology for areas.
-<P>
+<p>
 The <a href="v.type.html">v.type</a> module can be used to convert
 between vector types if possible. The <a href="v.build.html">v.build</a>
 module is used to generate topology. It optionally allows to extract
@@ -117,11 +117,11 @@
 A dedicated vector editing module is <a href="v.edit.html">v.edit</a>
 which supports global and local editing operations. Additionally,
 new advanced topological operations are available in the
-<a href="wxGUI.Vector_Digitizer.html">new digitizing tool</a>.
+<a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a>.
 Adjacent polygons can be found by <a href="v.to.db.html">v.to.db</a>
 (see 'sides' option).
-<P>
+<p>
 Many operations including extraction, queries, overlay, and export will
 only act on features which have been assigned a category number. Typically
 a centroid will hold the attribute data for the area between it and its
@@ -381,10 +381,10 @@
 <li><a href="raster3dintro.html">Introduction to GRASS 3D raster map (voxel) processing</a></li>
 </ul>
-<HR>
-<BR>
+<hr>
+<br>
 <a href="index.html">Main index</a> - <a href="vector.html">vector index</a> - <a href="full_index.html">full index</a>
-<P>© 2008-2011 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
+<P>© 2008-2012 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
 </body>
 </html>
