[GRASS-SVN] r51920 - grass-addons/grass7/imagery/i.segment
Fri Jun 1 09:41:31 PDT 2012
Author: momsen
Date: 2012-06-01 09:41:31 -0700 (Fri, 01 Jun 2012)
New Revision: 51920
   grass-addons/grass7/imagery/i.segment/get_input.c
   grass-addons/grass7/imagery/i.segment/iseg.h
   grass-addons/grass7/imagery/i.segment/main.c
untested, first pass framework using segmentation library and groups
Modified: grass-addons/grass7/imagery/i.segment/get_input.c
--- grass-addons/grass7/imagery/i.segment/get_input.c	2012-06-01 15:28:53 UTC (rev 51919)
+++ grass-addons/grass7/imagery/i.segment/get_input.c	2012-06-01 16:41:31 UTC (rev 51920)
@@ -16,18 +16,29 @@
 #include <stdlib.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
-#include "segment.h"
+#include <grass/imagery.h>
-int get_input(int argc, char *argv[])
+#include <grass/segment.h> /* segmentation library */
+#include "iseg.h"
+int get_input(int argc, char *argv[], struct files *files, struct functions *functions)
 	//reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing
-	input = G_define_standard_option(G_OPT_R_INPUT);   /* Request a pointer to memory for each option */
-	input->key = "input"; /* TODO: update to allow groups.  Maybe this needs a group/subgroup variables, or we can check if the input is group/subgroup/raster */
-	input->type = TYPE_STRING;
-	input->required = YES;
-	input->description = _("Raster map to be segmented.");
+	struct Option *group, *subgroup, *seeds, *output, *method, *threshold; //*input,     /* Establish an Option pointer for each option */
+	struct Flag *diagonal;        /* Establish a Flag pointer for each option */
+	group = G_define_standard_option(G_OPT_I_GROUP);
+	subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
+	//OK to require the user to create a group?  Otherwise later add an either/or option to give just a single raster map...
+	//~ input = G_define_standard_option(G_OPT_R_INPUT);   /* Request a pointer to memory for each option */
+	//~ input->key = "input"; /* TODO: update to allow groups.  Maybe this needs a group/subgroup variables, or we can check if the input is group/subgroup/raster */
+	//~ input->type = TYPE_STRING;
+	//~ input->required = YES;
+	//~ input->description = _("Raster map to be segmented.");
 	//~ seeds = G_define_standard_option(G_OPT_V_INPUT);
 	//~ seeds->key = "seeds";
 	//~ seeds->type = TYPE_STRING;
@@ -45,10 +56,12 @@
 	seeds->description = _("Optional raster map with starting seeds.");
 	output = G_define_standard_option(G_OPT_R_OUTPUT);
-	output->key = "output";
-	output->type = TYPE_STRING;
-	output->required = YES;
-	output->description = _("Name of output raster map.");
+//seems API handles this part...
+	//~ output->key = "output";
+	//~ output->type = TYPE_STRING;
+	//~ output->required = YES;
+	//~ output->description = _("Name of output raster map.");
 //TODO: when put in a new raster map, error message:
 //~ Command 'd.rast map=testing at samples' failed
 //~ Details: Raster map <testing at samples> not found
@@ -86,8 +99,141 @@
 	//~ Unable to fetch interface description for command 'i.segment'.
 	//~ Details: D1/1: testing debug!
+	//~ G_debug(1, "For the option <%s> you chose: <%s>",
+	  //~ input->description, input->answer);
+		  //~ seeds->description, seeds->answer);
+		  //~ output->description, output->answer);
+		  //~ method->description, method->answer);
+		  //~ threshold->description, threshold->answer);
+    //~ G_debug(1, "The value of the diagonal flag is: %d", diagonal->answer);
 	if (G_parser(argc, argv))
         exit (EXIT_FAILURE);
+// Open Files (file segmentation) //
+	struct Ref Ref;             /* subgroup reference list */
+	int *in_fd, out_fd, *seg_in_fd, seg_out_fd;
+	RASTER_MAP_TYPE data_type;
+	int n, row, col, nrows, ncols, srows, scols, seg_in_mem;
+	void *inbuf;
+    int buf[NCOLS]; /* for copying into segmentation file */
+    const char *in_file, out_file;
+    // ****** open the input rasters ******* //
+    // i.smap/openfiles.c  lines 17-23 checked if subgroup had maps, does API handles the checks?
+    // can no subgroup be entered, just a group?
+	if (!I_get_subgroup_ref(group->answer,subgroup->answer, &Ref))
+		G_fatal_error(_("Unable to read REF file for subgroup <%s> in group <%s>"),
+			subgroup->answer, group->answer);
+	if (Ref.nfiles <= 0)
+		G_fatal_error(_("Subgroup <%s> in group <%s> contains no raster maps"),
+	// open input group maps for reading
+	for(n = 0; n < Ref.nfiles; n++)
+		in_fd[n] = Rast_open_old(Ref.file[n].name, Ref.file[n].mapset);  //    in_fd = Rast_open_old(input->answer, "");
+    // ********** find out file segmentation size ************ //
+    //loop again... need to get largest option
+	//for today assume all are the same
+		//data_type = Rast_get_map_type(in_fd[n]);
+	data_type = Rast_get_map_type(in_fd[0]);
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+	//TODO: i.cost and i.watershed take different approaches...
+	//hardcode for now
+	srows = nrows / 8;
+	scols = ncols / 8;
+	//TODO: make calculations for this
+	seg_in_mem = 4;
+//    G_debug(1, "  %d rows, %d cols", nrows, ncols);
+    // ******** create temporary segmentation failes **********//
+    /* Initalize access to database and create temporary files */
+		in_file[n] = G_tempfile();
+	out_file = G_tempfile();
+    /* Format segmented files */
+		seg_in_fd[n] = creat(in_file[n], 0666);
+		if (segment_format(seg_in_fd[n], nrows, ncols, srows, scols, sizeof(data_type)) != 1) //TODO: this data_type should be from each map
+		G_fatal_error("can not create temporary file");
+		close(seg_in_fd[n]);
+	seg_out_fd = creat(out_file, 0666);
+	if (segment_format(seg_out_fd, nrows, ncols, srows, scols, sizeof(data_type)) != 1)
+	close(seg_out_fd);
+	/* Open and initialize all segment files */
+		seg_in_fd[n] = open(in_file[n], 2);  //TODO: second parameter here is different in many places...
+		if (segment_init(&files->bands_seg[n], seg_in_fd[n], seg_in_mem) != 1)
+			G_fatal_error("can not initialize temporary file");
+		seg_out_fd = open(out_file, 2);
+		if (segment_init(&files->out_seg, seg_out_fd, seg_in_mem) != 1)
+    /* convert flat files to segmented files */
+	inbuf = Rast_allocate_buf(data_type);
+	/* allocate memory for buf? */
+	for (n = 0; n < Ref.nfiles; n++)
+		for (row = 0; row < nrows; row++)
+			Rast_get_row(in_fd[n], inbuf, row, data_type);
+			for (col = 0; col < ncols; col++)
+				/*fill buf */
+				// G_incr_void_ptr
+			segment_put_row (&files->bands_seg[n], buf, row);
+	/* repeat for output */
+	/* close stuff!!!  in_fd, seg_in_fd, etc, etc */
+	from r.cost
+	unlink(in_file);		/* remove submatrix files  */
 	return 0;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h	2012-06-01 15:28:53 UTC (rev 51919)
+++ grass-addons/grass7/imagery/i.segment/iseg.h	2012-06-01 16:41:31 UTC (rev 51920)
@@ -2,7 +2,7 @@
  * MODULE:       i.segment
  * AUTHOR(S):    Eric Momsen <eric.momsen at gmail com>
- * PURPOSE:      global variable and function listing
+ * PURPOSE:      structure definition and function listing
  * COPYRIGHT:    (C) 2012 by Eric Momsen, and the GRASS Development Team
  *               This program is free software under the GNU General Public
@@ -11,10 +11,45 @@
-extern struct GModule *module;
-extern struct Option *input, *seeds, *output, *method, *threshold;
-extern struct Flag *diagonal;
-extern int in_fd, out_fd;
+struct files
+	/* int *band_fd, out_fd;  /* Do I need these, or is the SEGMENT enough? */
+	int nbands;
+	SEGMENT *bands_seg, out_seg;
+	// naming using "bands" to follow i.smap but it doesn't need to be just landsat bands
+	// If we want to implement the option to load directly to memory
+	// instead of declaring "SEGMENT" could we declare as void
+	// then assign either a SEGMENT or a matrix during the get_input procedure?
+	// i.smap has this:  struct Categories output_labels;
+	// I don't think I'll be using categories...
+	// i.smap has:  char *isdata;
+	// not sure yet if I'll need that
+	//will need to add something here for the vector contsraints and for seeds
+	// store those directly in RAM instead of SEGMENT library?
+// I think if I use function pointers, I can set up one time in the input
+// what similarity function, etc, will be used later in the processing
+// and make it easier to add additional variations later.
+struct functions
+//based on options, such as diagonal neighbors, etc:
+//	find_neighbor
+//	calc_simularity
+	//not really a function, but input to the functions
+	double threshold;
 /* get_input.c */
-int get_input(int, char *[]);
+/* gets input from user, validates, opens files, and sets up functions */
+int get_input(int, char *[], struct files *, struct functions *);
Modified: grass-addons/grass7/imagery/i.segment/main.c
--- grass-addons/grass7/imagery/i.segment/main.c	2012-06-01 15:28:53 UTC (rev 51919)
+++ grass-addons/grass7/imagery/i.segment/main.c	2012-06-01 16:41:31 UTC (rev 51920)
@@ -8,7 +8,13 @@
  *               License (>=v2). Read the COPYING file that comes with GRASS
  *               for details.
+ *               NOTE: the word "segment" is already used by the Segmentation
+ *               Library for the data files/tiling, so iseg (image segmentation)
+ *               will be used to refer to the image segmentation.
 // #include <grass/config.h>
@@ -19,7 +25,7 @@
 //#include <grass/imagery.h>
 #include <grass/glocale.h>   //defines _()  what exactly is that doing...(something about local language translation?) anything else in glocale.h that I should be aware of...
 #include <grass/raster.h>
+#include "iseg.h"
 //~ (for my reference, order for headers), adding them only as needed...
 //~ 1. Core system headers (stdio.h, ctype.h, ...)
@@ -27,19 +33,12 @@
 //~ 3. Headers for core systems of the package being compiled (grass/gis.h, grass/glocale.h, ...)
 //~ 4. Headers for the specific library/program being compiled (geodesic.h, ...)
-struct GModule *module;
-struct Option *input, *seeds, *output, *method, *threshold;       /* Establish an Option pointer for each option */
-struct Flag *diagonal;        /* Establish a Flag pointer for each option */
-int in_fd, out_fd;
-RASTER_MAP_TYPE data_type;
-int row, col, nrows, ncols;
-void *inbuf;
-// ? Any reasons not to use "modular global" variables for this application?
 int main(int argc, char *argv[])
+	struct files files;		/* input and output file descriptors, data structure, buffers */
+	struct functions functions;		/* function pointers and parameters for the calculations */
+	struct GModule *module;
 	G_gisinit(argv[0]);
 	module = G_define_module();
@@ -47,47 +46,13 @@
 	G_add_keyword(_("segmentation"));
 	module->description = _("Segments an image.");
-	get_input(argc, argv);
+	get_input(argc, argv, files, functions);
-	G_debug(1, "For the option <%s> you chose: <%s>",
-		  input->description, input->answer);
-		  seeds->description, seeds->answer);
-		  output->description, output->answer);
-		  method->description, method->answer);
-		  threshold->description, threshold->answer);
-    G_debug(1, "The value of the diagonal flag is: %d", diagonal->answer);
-    in_fd = Rast_open_old(input->answer, "");
-    data_type = Rast_get_map_type(in_fd);  /*TODO: when add group/subgroup, need to check if all input are same data_type*/
-	out_fd = Rast_open_new(output->answer, data_type);
-	inbuf = Rast_allocate_buf(data_type);
-	nrows = Rast_window_rows();
-	ncols = Rast_window_cols();
-	for (row = 0; row < nrows; row++) {
-		Rast_get_row(in_fd, inbuf, row, data_type);
-		//~ for (col = 0; col < ncols; col++) {
-		Rast_put_row(out_fd, inbuf, data_type);
+//need to update this part still:
 	G_free(inbuf);
 	Rast_close(in_fd);
     Rast_close(out_fd);
 	G_done_msg("Number of segments created: ");
