[GRASS-SVN] r51921 - in grass/trunk: lib/python/temporal temporal/t.rast.aggregate temporal/t.rast.aggregate.ds temporal/t.vect.what.strds
svn_grass at osgeo.org
Fri Jun 1 11:42:46 PDT 2012
Author: huhabla
Date: 2012-06-01 11:42:45 -0700 (Fri, 01 Jun 2012)
New Revision: 51921
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
Support for aggregation in t.vect.what.strds. Aggregation interface simplified.
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2012-06-01 16:41:31 UTC (rev 51920)
+++ grass/trunk/lib/python/temporal/aggregation.py 2012-06-01 18:42:45 UTC (rev 51921)
@@ -23,6 +23,7 @@
from space_time_datasets import *
+import grass.lib.gis as libgis
@@ -80,12 +81,9 @@
-def aggregate_raster_maps(orig_ds, dataset, mapset, inputs, base, start, end, count, method, register_null, dbif):
+def aggregate_raster_maps(inputs, base, start, end, count, method, register_null, dbif):
"""!Aggregate a list of raster input maps with r.series
- @param orig_ds: Original space time raster dataset from which the maps are selected
- @param dataset: The new space time raster dataset to insert the aggregated map
- @param mapset: The current mapset
@param inputs: The names of the raster maps to be aggregated
@param base: The basename of the new created raster maps
@param start: The start time of the sample interval, may be relative or absolute
@@ -98,17 +96,19 @@
core.verbose(_("Aggregate %s raster maps") %(len(inputs)))
output = "%s_%i" % (base, count)
+ mapset = libgis.G_mapset()
map_id = output + "@" + mapset
- new_map = dataset.get_new_map_instance(map_id)
+ new_map = raster_dataset(map_id)
# Check if new map is in the temporal database
if new_map.is_in_db(dbif):
if core.overwrite() == True:
# Remove the existing temporal database entry
new_map.delete(dbif)
else:
core.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
return
@@ -130,6 +130,7 @@
if ret != 0:
dbif.close()
core.fatal(_("Error while r.series computation"))
# Read the raster map data
new_map.load()
@@ -138,15 +139,6 @@
if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
if not register_null:
core.run_command("g.remove", rast=output)
- return
- # Set the time stamp and write it to the raster map
- if dataset.is_time_absolute():
- new_map.set_absolute_time(start, end, None)
- else:
- new_map.set_relative_time(start, end, orig_ds.get_relative_time_unit())
- # Insert map in temporal database
- new_map.insert(dbif)
- dataset.register_map(new_map, dbif)
+ return None
+ return new_map
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-06-01 16:41:31 UTC (rev 51920)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-06-01 18:42:45 UTC (rev 51921)
@@ -151,10 +151,21 @@
input_map_names = tgis.collect_map_names(sp, dbif, start, end, sampling)
if input_map_names:
- tgis.aggregate_raster_maps(sp, new_sp, mapset, input_map_names, base, start, end, count, method, register_null, dbif)
- count += 1
+ new_map = tgis.aggregate_raster_maps(input_map_names, base, start, end, count, method, register_null, dbif)
+ if new_map:
+ # Set the time stamp and write it to the raster map
+ if sp.is_time_absolute():
+ new_map.set_absolute_time(start, end, None)
+ else:
+ new_map.set_relative_time(start, end, sp.get_relative_time_unit())
+ # Insert map in temporal database
+ new_map.insert(dbif)
+ new_sp.register_map(new_map, dbif)
+ count += 1
# Update the spatio-temporal extent and the raster metadata table entries
new_sp.update_from_registered_maps(dbif)
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2012-06-01 16:41:31 UTC (rev 51920)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2012-06-01 18:42:45 UTC (rev 51921)
@@ -161,8 +161,19 @@
if input_map_names:
+ if new_map:
+ else:
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2012-06-01 16:41:31 UTC (rev 51920)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2012-06-01 18:42:45 UTC (rev 51921)
@@ -5,7 +5,7 @@
# MODULE: t.vect.what.strds
# AUTHOR(S): Soeren Gebbert
-# PURPOSE: Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets
+# PURPOSE: Uploads raster map values at spatial and temporal positions of vector points to the tables.
# COPYRIGHT: (C) 2011 by the GRASS Development Team
# This program is free software under the GNU General Public
@@ -15,7 +15,7 @@
#%module
-#% description: Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets.
+#% description: Uploads raster map values at spatial and temporal positions of vector points to the tables.
#% keywords: temporal
#% keywords: sampling
#%end
@@ -36,6 +36,16 @@
#% multiple: no
#%end
+#%option
+#% key: method
+#% type: string
+#% description: Aggregate operation to be performed on the raster maps
+#% required: yes
+#% multiple: no
+#% options: disabled,average,count,median,mode,minimum,min_raster,maximum,max_raster,stddev,range,sum,variance,diversity,slope,offset,detcoeff,quart1,quart3,perc90,quantile,skewness,kurtosis
+#% answer: disabled
+#%end
#%option G_OPT_DB_WHERE
#%end
@@ -46,7 +56,7 @@
#%option G_OPT_T_SAMPLE
#%end
+import os
import grass.script as grass
import grass.temporal as tgis
import grass.script.raster as raster
@@ -60,6 +70,7 @@
strds = options["strds"]
where = options["where"]
column = options["column"]
+ method = options["method"]
tempwhere = options["t_where"]
sampling = options["sampling"]
@@ -127,11 +138,24 @@
end = row["end_time"]
vectmap = row["name"] + "@" + row["mapset"]
layer = row["layer"]
+ count = 0
raster_maps = tgis.collect_map_names(strds_sp, dbif, start, end, sampling)
+ aggreagated_map_name = None
if raster_maps:
- # Collect the names of the raster maps
+ # Aggregation
+ if method != "disabled" and len(raster_maps) > 1:
+ # Generate the temporary map name
+ aggreagated_map_name = "aggreagated_map_name_"+ str(os.getpid())
+ new_map = tgis.aggregate_raster_maps(raster_maps, aggreagated_map_name, start, end, 0, method, False, dbif)
+ aggreagated_map_name = aggreagated_map_name + "_0"
+ if new_map == None:
+ continue
+ # We overwrite the raster_maps list
+ raster_maps = (new_map.get_id(), )
for rastermap in raster_maps:
if column:
@@ -164,6 +188,12 @@
dbif.close()
grass.fatal(_("Unable to run v.what.rast for vector map <%s> and raster map <%s>")%(vectmap, rastermap))
+ if aggreagated_map_name:
+ ret = grass.run_command("g.remove", rast=aggreagated_map_name)
+ if ret != 0:
+ dbif.close()
+ grass.fatal(_("Unable to remove raster map <%s>")%(aggreagated_map_name))
# Use the first map in case a column names was provided
if column:
break
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh 2012-06-01 16:41:31 UTC (rev 51920)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh 2012-06-01 18:42:45 UTC (rev 51921)
@@ -37,6 +37,11 @@
v.db.select map=soil_2
v.db.select map=soil_3
+t.vect.what.strds --v input=soil_abs1 strds=precip_abs1 sampling=during column=map_vals method=average
+v.db.select map=soil_1
+v.db.select map=soil_2
+v.db.select map=soil_3
t.vect.what.strds --v input=soil_abs1 strds=precip_abs1 sampling=start,during
