[GRASS-SVN] r52031 - in grass-addons/grass6/vector/v.strahler: . v.mainchannel v.strahler
Mon Jun 11 02:01:11 PDT 2012
Author: neteler
Date: 2012-06-11 02:01:11 -0700 (Mon, 11 Jun 2012)
New Revision: 52031
Added:
   grass-addons/grass6/vector/v.strahler/v.mainchannel/
   grass-addons/grass6/vector/v.strahler/v.mainchannel/Makefile
   grass-addons/grass6/vector/v.strahler/v.mainchannel/description.html
   grass-addons/grass6/vector/v.strahler/v.mainchannel/v.mainchannel
   grass-addons/grass6/vector/v.strahler/v.strahler/
   grass-addons/grass6/vector/v.strahler/v.strahler/Makefile
   grass-addons/grass6/vector/v.strahler/v.strahler/description.html
   grass-addons/grass6/vector/v.strahler/v.strahler/forest2tree.c
   grass-addons/grass6/vector/v.strahler/v.strahler/helper.c
   grass-addons/grass6/vector/v.strahler/v.strahler/main.c
   grass-addons/grass6/vector/v.strahler/v.strahler/strahler.c
   grass-addons/grass6/vector/v.strahler/v.strahler/strahler.h
   grass-addons/grass6/vector/v.strahler/v.strahler/write.c
Removed:
   grass-addons/grass6/vector/v.strahler/description.html
   grass-addons/grass6/vector/v.strahler/forest2tree.c
   grass-addons/grass6/vector/v.strahler/helper.c
   grass-addons/grass6/vector/v.strahler/main.c
   grass-addons/grass6/vector/v.strahler/strahler.c
   grass-addons/grass6/vector/v.strahler/strahler.h
   grass-addons/grass6/vector/v.strahler/v.mainchannel.html
   grass-addons/grass6/vector/v.strahler/v.mainchannel.sh
   grass-addons/grass6/vector/v.strahler/write.c
   grass-addons/grass6/vector/v.strahler/Makefile
cleanup part 2
Modified: grass-addons/grass6/vector/v.strahler/Makefile
--- grass-addons/grass6/vector/v.strahler/Makefile	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/Makefile	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,23 +1,11 @@
 MODULE_TOPDIR = ../..
-PROGRAMS = v.mainchannel r.strahler.sh r.broscoe.sh
+SUBDIRS = \
+	v.mainchannel \
+	r.strahler \
+	r.broscoe \
+	v.strahler
-LIBES        = $(DISPLAYLIB) $(RASTERLIB) $(VECTLIB) $(GRAPHLIB) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(DISPLAYDEP) $(RASTERDEP) $(VECTDEP) $(GISDEP)
-EXTRA_INC = $(VECT_INC)
-EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Dir.make
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
-PGM = v.strahler
-include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd
+default: parsubdirs
Deleted: grass-addons/grass6/vector/v.strahler/description.html
--- grass-addons/grass6/vector/v.strahler/description.html	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/description.html	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,119 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.strahler</em> calculates the Strahler Order for all lines of a given
-dendritic network. The input vector map must be free of cycles. For the
-elaboration a new imported network or a network extracted from DEM by
-using <em><a href="r.watershed.html">r.watershed</a></em> can be used
-(in this case the topology has to be cleaned manually). More than one
-tree in the input data is allowed. No given flow direction is needed.
-To find the outlet of each tree, a DEM must be given.
-There are two additional scripts distributed with v.strahler:<br />
-- <em>r.strahler.sh</em> extracts streams from a DEM and call v.strahler
-  on the result. <br />
-- <em>r.broscoe.sh</em> computes further statistical values for a given
-  basin. <br />
-<h2>NOTES</h2>
-<h3>Problems</h3>
-This program is in beta status. It has the following shortcomings: <br />
-- The input data has to be topologically clean. Use <em>sloppy</em>=0.0 <br />
-- Source code comments are not doxydized. <br />
-<h3>How the algorithm works</h3>
-In a first step, <em>v.strahler</em> identifies all separate networks in
-the input dataset. That means, all connected lines are assigned a common
-<em>Basin ID</em>.<br />
-Consequently, the lowest leaf of each tree is identified as outlet.
-An auxiliary DEM is needed at this point. <br />
-Strahler ordering begins at each leaf of the tree with order N=1
-(excluding the outlet). At a confluence, the order N(r) of the resulting
-stream is equal to the highest order N(max) of the joining streams or is
-raised by one if there are two or more joining streams of order N(max).<br />
-The algorithm returns an ASCII text file with columns: <em>Category</em>
-(from input map), <em>Line</em> (topology), <em>Basin</em>, <em>Order</em>;
-and the output map has the Strahler Order value instead of "category"
-for each line, and no connection with the database.
-See the also the diagrams in the documentation/ directory.
-<h2>EXAMPLE</h2>
-The input map (vector on DEM): <br />
-<br />
-<img src="images/input_vstrahler.jpg"> <br />
-<br />
-<br />
-An example of the sintax in GRASS shell: <br />
-<br />
-<div class="code"><pre>
-GRASS> v.strahler input=esp_1 at mapset output=esp_1 dem=dem_20 at mapset \
-          txout=/home/mapset/esp_1 sloppy=0 layer=1
-</pre></div>
-<br />
-<br />
-An extract from the resultant text file: <br />
-<br />
-== Result of Strahler Order ==
- Category:   Line:   Basin:    Order:
-       22       1       1       4
-       73       2       1       1
-       25       3       1       4
-       27       4       1       4
-       39       5       1       1
-       48       6       1       1
-       56       7       1       4
-       55       8       1       2
-       88       9       1       4
-       59      10       1       1
-       60      11       1       1
-       61      12       1       2
-       83      13       1       2
-       82      14       1       1
-       91      15       1       1
-       87      16       1       4
-       95      17       1       2
-       96      18       1       1
-      106      19       1       1
-      102      20       1       1
-      104      21       1       4
-      111      22       1       1
-      112      23       1       3
-      121      24       1       3
-      126      25       1       1
-      128      26       1       3
-      137      27       1       3
-</pre></div>
-<br />
-<br />
-The output map (vector on DEM) form a snapshot of GRASS display: <br />
-<br />
-<img src="images/output_vstrahler.jpg"> <br />
-<br />
-<br />
-The output map (vector only) from Qgis (different colors for different orders): <br />
-<br />
-<img src="images/Qgisout_vstrahler.jpg"> <br />
-<br />
-<br />
-<h2>SEE ALSO</h2>
-<em><a href="r.watershed.html">r.watershed</a></em><br>
-<h2>AUTHOR</h2>
-Florian Kindl, Univ. Innsbruck.<br />
-<br />
-Modified by: Ivan Marchesini and Annalisa Minelli, Univ. Perugia.<br />
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/vector/v.strahler/forest2tree.c
--- grass-addons/grass6/vector/v.strahler/forest2tree.c	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/forest2tree.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,114 +0,0 @@
-#include "strahler.h"
-/* helper functions for ForestToTrees:
-   push_line: push number of adjacent line on stack
-   pop_line: return number of top line on stack
-   we could do this with some Vect_list but we don't need
-   to handle entire lines, only their identifiers */
-#define STACK_SIZE 65535
-int sp = 0;			/* stack position */
-int stack[STACK_SIZE];		/* generous stack size */
-void push_line(int line)
-    if (sp < STACK_SIZE) {
-	stack[sp++] = line;
-    else {
-	G_fatal_error("ForestToTrees: stack full");
-int pop_line(void)
-    if (sp > 0) {
-	return stack[--sp];
-    else {
-	G_debug(3, "ForestToTrees: stack empty, tree finished");
-	return 0;
-/* or write our own lfind: nexttree() */
-/* start at offset, walk array up until bsnid == 0 and return that offset */
-int nexttree(DBBUF * dbbuf, int offset, int upper)
-    while ((dbbuf[offset].bsnid != 0) && (offset < upper)) {
-	++offset;
-	G_debug(4, "bsnid[%d] is %d", offset, dbbuf[offset].bsnid);
-    return offset;
-/* Find trees, assign basinID */
-int StrahForestToTrees(struct Map_info *In, struct Map_info *Out,
-		       DBBUF * dbbuf)
-    int tree, tree_finished, forest_done;	/* ID of tree (basin), processing status */
-    int l, n, d, degr, node;	/* iterators */
-    int nlines, offset;		/* number of lines, position in dbbuf */
-    int cline, aline;		/* currently harvested line, adjacent line */
-    int lnodes[2];		/* nodes of cline */
-    G_debug(1, "reached StrahForestToTrees");
-    nlines = Vect_get_num_lines(In);
-    forest_done = 0;
-    tree = 1;			/* we start with tree no. 1 */
-    offset = cline = 1;		/* we start at line 1 */
-    while (forest_done == 0) {
-	G_debug(3, "\nProcessing Tree %d", tree);
-	tree_finished = 0;	/* initialize status indicator for this tree */
-	while (tree_finished == 0) {
-	    /* procedure to get adjacent lines and push them on the stack */
-	    Vect_get_line_nodes(In, cline, &lnodes[0], &lnodes[1]);
-	    G_debug(4, "nodes for line %d: %d %d", cline, lnodes[0],
-		    lnodes[1]);
-	    for (n = 0; n <= 1; n++) {	/* loop through array[2] of fnode and tnode */
-		node = lnodes[n];
-		/*degr = Vect_get_node_n_lines( In, node ); */
-		degr = StrahGetDegr(In, node);
-		G_debug(4, "degr %d for node %d", degr, node);
-		for (d = 0; d < degr; d++) {
-		    /*aline = abs( Vect_get_node_line( In, node, d ) ); */
-		    aline = abs(StrahGetNodeLine(In, node, d));
-		    if (dbbuf[aline].bsnid == 0) {	/* push line on stack only if not done yet */
-			G_debug(4, "pushing line %d on sp %d", aline, sp);
-			push_line(aline);
-			G_debug(4, "pushed, sp is now %d", sp);
-			dbbuf[aline].bsnid = tree;	/* line is done when pushed on stack */
-			dbbuf[aline].line = aline;
-	    /* pop a line from stack */
-	    cline = (int)pop_line();
-	    G_debug(4, "popped line %d", cline);
-	    /* tree is finished when pop_line returned 0 */
-	    if (cline == 0) {
-		tree_finished = 1;
-	/* get first cline of next tree */
-	offset = cline = nexttree(dbbuf, ++offset, nlines);
-	G_debug(3, "cline/offset for tree %d is %d", tree, cline);
-	if (offset == nlines) {
-	    forest_done = 1;	/* what if last line still is 0 - it is a tree consisting of this line only - it shall keep bsnid 0 */
-	else {
-	    tree++;		/* continue with next tree */
-    return tree;
Deleted: grass-addons/grass6/vector/v.strahler/helper.c
--- grass-addons/grass6/vector/v.strahler/helper.c	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/helper.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,80 +0,0 @@
-/* Replacement for Vect_get_node_n_lines in sloppy mode
-   Gets adjacent lines by coordinate */
-int StrahGetDegr(struct Map_info *In, int node)
-    extern double sloppy;
-    int degr, onode, j;
-    double x, y;
-    BOUND_BOX *Box;
-    struct ilist *list;
-    if (sloppy != 0.0) {
-	Vect_get_node_coor(In, node, &x, &y, NULL);
-	Box->N = y + sloppy;
-	Box->S = y - sloppy;
-	Box->W = x + sloppy;
-	Box->E = x - sloppy;
-	list = Vect_new_list();
-	   printf( "N %f\n", Box->N );
-	   printf( "S %f\n", Box->S );
-	   printf( "W %f\n", Box->W );
-	   printf( "E %f\n", Box->E );
-	Vect_select_nodes_by_box(In, Box, list);
-	G_debug(3, "  %d nodes selected", list->n_values);
-	/* is always 0 -why? */
-	for (j = 0; j < list->n_values; j++) {
-	    onode = abs(list->value[j]);
-	    G_debug(3, "List %d: %d\n", j, onode);
-	   Vect_list_append ( StArcs, line );
-	   Vect_get_line_nodes ( &Map, line, &node1, &node2);
-	   Vect_list_append ( StNodes, node1 );
-	   Vect_list_append ( StNodes, node2 );
-    else {
-	degr = Vect_get_node_n_lines(In, node);
-    G_debug(4, "node %d degr %d sloppy %f\n", node, degr, sloppy);
-    return degr;
-int StrahGetNodeLine(struct Map_info *In, int node, int d)
-    int aline;
-	G_debug(4, "StrahGetNodeLine at node %d", node);
-	   get all nodes within sloppy from node -> from table StrahGetDegr has written
-	   get all lines for each found node -> Vect_get_node_line(In, foundnode, df)
-	   for ( fn=0; fn<foundnodes.length; fn++ ) {
-	   degrf = Vect_get_node_n_lines( In, fn );
-	   for (df = 0; df < degrf; df++) {
-	   foundline = abs( Vect_get_node_line( In, fn, df ) );
-	   addtolist(foundline);
-	   return line d in list of foundlines;
-    else {
-	/* method if junction is only 1 node */
-	aline = abs(Vect_get_node_line(In, node, d));
-    return aline;
Deleted: grass-addons/grass6/vector/v.strahler/main.c
--- grass-addons/grass6/vector/v.strahler/main.c	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/main.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,384 +0,0 @@
- *  MODULE:       v.strahler
- *  AUTHOR(S):    Florian Kindl, Norbert Pfeifer, The GRASS development team
- *		  Modified by: Ivan Marchesini <marchesini unipg.it> and
-		  Annalisa Minelli <annapatri tiscali.it>
- *  PURPOSE:      Assign Strahler order to dendritic network
- *  COPYRIGHT:    (C) 2006 by the Authors
- *                This program is free software under the
- *                GNU General Public License (v2).
- *                Read the file COPYING that comes with GRASS
- *                for details.
-/*! \file main.c
-   \brief Assign Strahler order to dendritic network
-   \author Florian Kindl
-   \todo Deal with poor topology
-   \li implemement sloppy mode or
-   \li force clean topology
-   \todo ...
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <search.h>
-#include <time.h>
-#include <grass/gis.h>
-#include <grass/Vect.h>
-#include <grass/dgl.h>
-#include <grass/dbmi.h>
-#include <grass/glocale.h>
-#define COPYBLAH 1
-#define DDFIELDBLAH 1
-#define BADDCOLUMNBLAH 1
-#define RITEDBLAH 1
-#define EBUG 1
-#define REATEDBLAH 1
-int ret, type;			/* return and type related to Vect_read_line and Vect_write_line */
-int fdrast;			/* file descriptor for raster file is int */
-int ntrees;			/* number of trees in dataset, returned by StrahForestToTrees */
-double sloppy;
-int main(int argc, char **argv)
-    int line, node;
-    char buf[1024];
-    int nnodes, nlines, tlines;
-    DBBUF *dbbuf;
-    NODEV *nodev;
-    struct Option *input, *output, *dem_opt, *txout_opt, *sloppy_opt,
-	*field_opt;
-    struct GModule *module;
-    char *inputset, *demset;
-    struct Map_info In, Out;
-    struct Map_info Trees;
-    FILE *txout;
-    struct Cell_head window;	/* for cell sampling */
-    extern int ntrees;		/* number of trees calculated by StrahForestToTrees */
-    extern int fdrast;
-    /* Attribute table (from v.net.path/path.c) */
-    struct line_cats *Cats;	/* introduced and initialized the structures line_cats and line_pnts */
-    static struct line_pnts *Points;
-    Points = Vect_new_line_struct();
-    Cats = Vect_new_cats_struct();
-    dbString sql;
-    dbDriver *driver;
-    dbColumn *column;
-    struct field_info *Fi;
-    int field;
-    /* Initialize the GIS calls */
-    G_gisinit(argv[0]);
-    input = G_define_standard_option(G_OPT_V_INPUT);
-    output = G_define_standard_option(G_OPT_V_OUTPUT);
-    module = G_define_module();
-    module->description = _("Strahler order");
-    dem_opt = G_define_standard_option(G_OPT_R_INPUT);
-    dem_opt->key = "dem";
-    dem_opt->description = _("Underlying DEM");
-    txout_opt = G_define_option();
-    txout_opt->key = "txout";
-    txout_opt->type = TYPE_STRING;
-    txout_opt->required = NO;
-    txout_opt->multiple = NO;
-    txout_opt->gisprompt = "new_file,file,output";
-    txout_opt->description =
-	_("Path to ASCII file where results will be written");
-    /* option sloppy for bad topology */
-    sloppy_opt = G_define_option();
-    sloppy_opt->key = "sloppy";
-    sloppy_opt->type = TYPE_DOUBLE;
-    sloppy_opt->required = NO;
-    sloppy_opt->answer = "0.0";
-    sloppy_opt->multiple = NO;
-    sloppy_opt->description =
-	_("Threshold for distance within different nodes are considered the same node - may not work");
-    field_opt = G_define_standard_option(G_OPT_V_FIELD);
-    field = atoi(field_opt->answer);
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    Vect_check_input_output_name(input->answer, output->answer,
-				 GV_FATAL_EXIT);
-    inputset = G_find_vector2(input->answer, NULL);
-    if (inputset == NULL) {
-	G_fatal_error(_("Could not find input input <%s>"), input->answer);
-    /* open datasets at topology level 2 */
-    Vect_set_open_level(2);
-    Vect_open_old(&In, input->answer, inputset);
-    G_debug(1, "Input vector opened");
-    /* Open new vector, make 3D if input is 3D */
-    if (1 > Vect_open_new(&Out, output->answer, Vect_is_3d(&In))) {
-	Vect_close(&In);
-	G_fatal_error("Failed opening output vector file %s", output->answer);
-    /* Open DEM */
-    demset = G_find_cell2(dem_opt->answer, NULL);
-    if (demset == NULL) {
-	G_fatal_error("DEM file %s not found", dem_opt->answer);
-    if (1 > (fdrast = G_open_cell_old(dem_opt->answer, demset))) {
-	G_fatal_error("Failed opening DEM file %s", dem_opt->answer);
-    /* Open text file for results if given */
-    if (txout_opt->answer) {
-	txout = fopen(txout_opt->answer, "w");
-	if (txout == NULL)
-	    G_fatal_error(_("Cannot open file %s"), txout_opt->answer);
-    sloppy = atof(sloppy_opt->answer);
-    /* printf("blah %f", sloppy*2.4 ); */
-    /* write history */
-    /*Vect_copy_head_data( &In, &Out );
-       Vect_hist_copy( &In, &Out );
-       Vect_hist_command( &Out ); */
-#ifdef COPYBLAH
-    /* this works, we want to continue here and ADD two columns to the &Out */
-    /* Copy input to output (from v.clean/main.c) */
-    /*G_debug( 1, "Copying vector lines to Output" );
-       /* This works for both level 1 and 2 */
-    /*Vect_copy_map_lines ( &In, &Out );        */
-    /* 0: copy all fields, else field number */
-#endif
-#ifdef ADDFIELDBLAH		/* Create table (from v.net.path/path.c) */
-    /* or: add fields to existing table? */
-    /*                                                      *Map, field, field_name, type */
-    Fi = Vect_default_field_info(&Out, field, NULL, GV_1TABLE);
-    Vect_map_add_dblink(&Out, field, NULL, Fi->table, "cat", Fi->database,
-			Fi->driver);
-    driver = db_start_driver_open_database(Fi->driver, Fi->database);
-    driver =
-	db_start_driver_open_database(Fi->driver,
-				      Vect_subst_var(Fi->database, &Out));
-    /* from v.reclass/main.c :
-    if (driver == NULL) {
-	G_fatal_error("Cannot open database %s by driver %s", Fi->database,
-		      Fi->driver);
-    /* store the statement to create a table with category, basin ID and strahler order of the arc */
-    sprintf(buf,
-	    "CREATE TABLE %s ( cat integer, bsnid integer, sorder integer )",
-	    Fi->table);
-    /* from v.reclass/main.c : */
-    dbString stmt;
-    db_init_string(&stmt);
-    db_set_string(&stmt, buf);
-    if (db_execute_immediate(driver, &stmt) != DB_OK) {
-	Vect_close(&Out);
-	db_close_database_shutdown_driver(driver);
-	G_fatal_error("Cannot create table: %s", db_get_string(&stmt));
-       sprintf ( buf, "ALTER TABLE %s ADD COLUMN cat integer", Fi->table );
-       sprintf ( buf, "ALTER TABLE %s ADD COLUMN bsnid integer", Fi->table );
-       sprintf ( buf, "ALTER TABLE %s ADD COLUMN sorder integer", Fi->table );
-#endif
-#ifdef DBADDCOLUMNBLAH
-    sprintf(buf, "bsnid");
-    db_set_string(&sql, buf);
-    column->columnName = sql;
-    column->sqlDataType = 1;
-    sprintf(buf, "%s", Fi->table);
-    /*db_set_string ( &sql, buf ); */
-    /* why such complicated arguments for db_add_column???
-       dbDriver, dbString, dbColumn */
-    if (db_add_column(driver, &sql, column) != DB_OK) {
-	G_fatal_error("Cannot add column column in table %s", Fi->table);
-#endif
-    /* execute statement */
-#ifdef CREATEDBLAH
-    sprintf(buf,
-	    Fi->table);
-    G_debug(2, db_get_string(&sql));
-    if (db_execute_immediate(driver, &sql) != DB_OK) {
-	G_fatal_error("Cannot create table: %s", db_get_string(&sql));
-    else
-	printf("table created\n");
-    if (db_create_index2(driver, Fi->table, "cat") != DB_OK) {
-	G_warning("Cannot create index");
-    else
-	printf("index created\n");
-    if (db_grant_on_table
-	(driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK) {
-	G_fatal_error("Cannot grant privileges on table %s", Fi->table);
-    else
-	printf("privileges granted\n");
-#endif
-    nnodes = Vect_get_num_nodes(&In);
-    nlines = Vect_get_num_lines(&In);
-    G_debug(1, "Number of lines: %d", nlines);
-    G_debug(1, "Number of nodes: %d", nnodes);
-    /* Create table to store ordering */
-    dbbuf = (DBBUF *) G_malloc((nlines + 1) * ((int)sizeof(DBBUF)));
-    nodev = (NODEV *) G_malloc((nnodes + 1) * ((int)sizeof(NODEV)));
-    /* initialize properly */
-    for (line = 1; line <= nlines; line++) {
-	dbbuf[line].category = dbbuf[line].line = dbbuf[line].bsnid =
-	    dbbuf[line].sorder = 0;
-    for (node = 1; node <= nnodes; node++) {
-	nodev[node].node = nodev[node].degree = nodev[node].visited = 0;
-    ntrees = (int)StrahForestToTrees(&In, &Out, dbbuf);
-    G_debug(1, "Number of trees: %d", ntrees);
-    StrahFindLeaves(&In, dbbuf, nodev, ntrees, fdrast);
-    G_debug(2, "dbbuf after FindLeaves:\nline\tbsnid\tsorder");
-	sprintf(buf, "%d\t%d\t%d\n", dbbuf[line].line, dbbuf[line].bsnid,
-		dbbuf[line].sorder);
-	G_debug(2, "%s", buf);
-    G_debug(2, "nodev after FindLeaves:\nnode\tdegree\tvisited");
-	sprintf(buf, "%d\t%d\t%d\n", (int)nodev[node].node,
-		nodev[node].degree, nodev[node].visited);
-    StrahOrder(&In, dbbuf, nodev);
-    G_debug(2, "dbbuf after StrahOrder:\nline\tbsnid\tsorder\n");
-    G_debug(2, "nodev after StrahOrder:\nnode\tdegree\tvisited\n");
-#ifdef WRITEDBLAH
-    /* and write DB records */
-    db_begin_transaction(driver);
-	sprintf(buf, "insert into %s values ( %d, %d, %d )", Fi->table, line,
-		dbbuf[line].bsnid, dbbuf[line].sorder);
-	/* G_debug ( 3, db_get_string ( &sql ) ); */
-	    G_fatal_error("Insert new row: %s", db_get_string(&sql));
-    db_commit_transaction(driver);
-#endif
-    /* writing StrahOrder instead of category in the output */
-	type = Vect_read_line(&In, Points, Cats, line);
-	ret = Vect_cat_del(Cats, field);
-	G_debug(4, "deleted categories, ret=%d", ret);
-	Vect_cat_set(Cats, field, dbbuf[line].sorder);
-	Vect_write_line(&Out, type, Points, Cats);
-	G_debug(4, "category written for line %d", line);
-    /* assign category values */
-	dbbuf[line].category = Vect_get_line_cat(&In, line, field);
-	G_debug(4, "added category %d for line %d", dbbuf[line].category,
-		dbbuf[line].line);
-    /* Write text file for results if given */
-	StrahWriteToFile(dbbuf, nlines, txout);
-    Vect_close(&In);
-    G_close_cell(fdrast);
-    Vect_build(&Out);
-    Vect_close(&Out);
-	fclose(txout);
-    return (EXIT_SUCCESS);
Deleted: grass-addons/grass6/vector/v.strahler/strahler.c
--- grass-addons/grass6/vector/v.strahler/strahler.c	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/strahler.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,223 +0,0 @@
-/* Find Leaves of tree and distinguish outlet from sources */
-int StrahFindLeaves(struct Map_info *In, DBBUF * dbbuf, NODEV * nodev,
-		    int ntrees, int fdrast)
-    int nnodes, degr, aline, node, unode, dnode, tree, outlet;
-    double x, y, z, z_init;
-    int n;
-    INTERP_TYPE method = NEAREST;
-    OUTLETS *outlets;
-    nnodes = Vect_get_num_nodes(In);
-    z = z_init = 27000000.0;	/* is it safe to initialize lowest z with the height of Olympus Mons above Martian Datum in millimeters? */
-    outlets = (OUTLETS *) G_malloc((ntrees + 1) * ((int)sizeof(OUTLETS)));
-    /* initialize outlet table properly */
-    for (n = 1; n <= ntrees; n++) {
-	outlets[n].z = z_init;
-	outlets[n].leaf = 0;
-    G_debug(1, "Reached StrahFindLeaves with %d trees", ntrees);
-    G_get_window(&window);
-    G_debug(2, "window: N %f S %f W %f E %f", window.north, window.south,
-	    window.west, window.east);
-    G_debug(2, "%d nodes in map", nnodes);
-	nodev[node].node = node;
-	nodev[node].degree = degr;
-	G_debug(4, "node %d: degr=%d", node, degr);
-	if (degr == 1) {
-	    unode = node;
-	    nodev[node].visited = 1;	/*set the "visited" parameter to 1... can't be less */
-	    /*aline = abs( Vect_get_node_line( In, unode, 0 ) ); */
-	    aline = abs(StrahGetNodeLine(In, unode, 0));
-	    /*Vect_get_line_nodes( In, aline, &unode, &dnode); */
-	    /* these are not necessarily up-node and down-node but we need not distinguish here... */
-	    dbbuf[aline].sorder = 1;
-	    /* no, do not visit yet
-	       nodev[node].visited += 1;
-	       nodev[unode].visited += 1;
-	       nodev[dnode].visited += 1;
-	    /* get z value or DEM value under node here, remember lowest */
-	    if (Vect_is_3d(In)) {
-		Vect_get_node_coor(In, node, &x, &y, &z);
-	    else {
-		z = (double)G_get_raster_sample(fdrast, &window, NULL, y, x,
-						0, method);
-	    G_debug(5, "fdrast=%d node=%d y=%f x=%f z=%f", fdrast, node, y,
-		    x, z);
-	    tree = dbbuf[aline].bsnid;
-	    if (z < outlets[tree].z) {
-		outlets[tree].z = z;
-		outlets[tree].leaf = aline;
-    /* reset outlets to 0 */
-	G_debug(2, "outlet tree %d: line %d with %f", n, outlets[n].leaf,
-		outlets[n].z);
-	outlet = outlets[n].leaf;
-	dbbuf[outlet].sorder = 0;
-	   Vect_get_line_nodes( In, outlet, &unode, &dnode);
-	   nodev[unode].visited = 0;
-	   nodev[dnode].visited = 0;
-    return 1;
-/* assign strahler order */
-int StrahOrder(struct Map_info *In, DBBUF * dbbuf, NODEV * nodev)
-    int nlines, line;
-    int fnode, tnode, unode, dnode;	/* from-, to-, up-, down- node */
-    int degr, d, aline, aorder;	/* find adjacent lines */
-    int corder, norder, dorder, dline;	/* assign order */
-    int cline, rfinish;		/* follow one line until this stop-condition is 1 */
-    struct dbbuf;
-    struct nodev;
-    G_debug(1, "reached StrahOrder");
-	if (dbbuf[line].sorder == 1) {	/* get lines of order 1 */
-	    cline = line;	/* and start run downwards */
-	    rfinish = 0;
-	    while (rfinish == 0) {
-		G_debug(3, "reached line %d", cline);
-		Vect_get_line_nodes(In, cline, &fnode, &tnode);	/* and their nodes */
-		/**** BAUSTELLE ****/
-		/* check nodes - we do not rely on flow direction */
-		if (nodev[fnode].visited == 1) {
-		    unode = fnode;
-		    dnode = tnode;
-		else {
-		    unode = tnode;
-		    dnode = fnode;
-		   if (nodev[fnode].visited == nodev[tnode].visited) {
-		   printf("Line %d: both nodes are visited or not - what now?\n", line);
-		   } else if (nodev[fnode].visited == 0) {
-		   node = fnode;
-		   } else {
-		   node = tnode;
-		   if ( (nodev[fnode].degree - nodev[fnode].visited) < (nodev[tnode].degree - nodev[tnode].visited) ) {
-		   unode = fnode;
-		   dnode = tnode;
-		   } else if ( (nodev[fnode].degree - nodev[fnode].visited) > (nodev[tnode].degree - nodev[tnode].visited) ) {
-		   unode = tnode;
-		   dnode = fnode;
-		   } else {
-		   G_message("Line %d: nodes have same diff(degree,visited) - what now?\n", cline);
-		/* ok, what now?
-		   - occurs when leaf meets node with norder==0 -> visit nodes and continue
-		   - or: is outlet -> assign order
-		/* continue? */
-		   printf("visiting tnode %d and fnode %d for line %d and break\n\n", tnode, fnode, cline);
-		   nodev[tnode].visited += 1;
-		   nodev[fnode].visited += 1;
-		   break;
-		G_debug(3, "unode is %d and dnode is %d", unode, dnode);
-		/*degr = Vect_get_node_n_lines ( In, dnode );            use downward node */
-		degr = StrahGetDegr(In, dnode);
-		G_debug(4, "deg for dnode %d is %d", dnode, degr);
-		corder = dbbuf[cline].sorder;	/* current order - result won't be less than that */
-		norder = dorder = 0;	/* no order - how many lines have none?, highest order of others */
-		    /*aline = abs( Vect_get_node_line ( In, dnode, d ) ); */
-		    aline = abs(StrahGetNodeLine(In, dnode, d));
-		    G_debug(4, "line %d at dnode %d is %d", d, dnode, aline);
-		    if (aline != cline) {	/* we don't need the line we come from */
-			aorder = dbbuf[aline].sorder;
-			if (aorder == 0) {
-			    norder++;
-			    dline = aline;	/* downward line */
-			else if (aorder > dorder) {
-			    dorder = aorder;	/* find highest order */
-		if (norder > 1 || norder == 0) {	/* if (norder > 1: node indeterminate OR norder == 0 : subtree finished) */
-		    G_debug(3, "Finished run at line %d because norder=%d",
-			    cline, norder);
-		    G_debug(4, "visiting unode %d for line %d", unode, cline);
-		    nodev[unode].visited += 1;	/* visit unode, for the sake of completeness */
-		    rfinish = 1;	/* finish this run */
-		else {		/* or */
-		    if (dorder > corder) {
-			;	/* assign highest order of alines */
-		    else if (dorder < corder) {
-			dorder = corder;	/* or keep order of cline */
-		    else {
-			dorder++;	/* or raise order by one */
-		    dbbuf[dline].sorder = dorder;	/* assign order */
-		    G_debug(4, "visiting dnode %d and unode %d for line %d",
-			    dnode, unode, cline);
-		    nodev[dnode].visited += 1;	/* visit dnode */
-		    cline = dline;	/* and continue with this line */
-		    G_debug(3, "StrahOrder for dline %d: %d", dline, dorder);
-	    }			/* while */
-    return 1;
Deleted: grass-addons/grass6/vector/v.strahler/strahler.h
--- grass-addons/grass6/vector/v.strahler/strahler.h	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/strahler.h	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,100 +0,0 @@
-#include <time.h>
-#include "grass/gis.h"
-#include "grass/Vect.h"
-#include "grass/dgl.h"
-#include "grass/dbmi.h"
-/*! \typedef DBBUF
-   \brief Buffer to keep track of assigned tree and Strahler order for each line
-/*! \typedef NODEV
-   \brief Buffer to keep track of valency for each node
-/*! \typedef OUTLETS
-   \brief Buffer to determine lowest leaf of each tree
-typedef struct
-{				/* collect lines in Strahler order */
-    int category;
-    int line;			/* line number */
-    int bsnid;			/* basin ID */
-    int sorder;			/* Strahler order */
-} DBBUF;
-typedef struct
-{				/* visited nodes */
-    int node;			/* node number */
-    int degree;			/* valency */
-    int visited;		/* is between 0 and degr(node) */
-} NODEV;
-typedef struct
-{				/* keep track of lowest leaf (=outlet) of each tree */
-    double z;			/* z-value of leaf */
-    int leaf;			/* line-id of outlet leaf */
-} OUTLETS;
-/* in forest2tree.c */
-/*! \fn int StrahForestToTrees( struct Map_info *In, struct Map_info *Out, DBBUF *dbbuf );
-   \brief Returns the number of trees in *In
-   \param *In The input map
-   \param *Out The output map
-   \param *dbbuf The buffer table for line orders
-/* in strahler.c */
-/*! \fn int StrahFindLeaves( struct Map_info *In, DBBUF *dbbuf, NODEV *nodev, int ntrees, int fdrast );
-   \brief Identifies all leaves of each tree and the one that lies lowest
-   \param *nodev The buffer table for node valency
-   \param ntrees Number of trees in map
-   \param fdrast File descriptor of DEM raster map
-/*! \fn int StrahOrder( struct Map_info *In, DBBUF *dbbuf, NODEV *nodev );
-   \brief Calculates the Strahler order of each line
-/* in write.c */
-/*! \fn int StrahWriteToFile( DBBUF *dbbuf, int nlines, FILE *txout );
-   \brief Writes ASCII representation of calculated order to file
-   \param nlines Number of lines in *In map
-   \param *txout ASCII output file name
-/* in helper.c */
-/*! \fn int StrahGetDegr( struct Map_info *In, int node );
-   \brief Get degree of node (for sloppy mode)
-   \param node Node number in *In
-/*! \fn int StrahNodeLine( struct Map_info *In, int node, int d );
-   \brief Get lines connected in node (for sloppy mode)
-   \param d n-th line connected to node
-		       DBBUF * dbbuf);
-		    int ntrees, int fdrast);
-int StrahOrder(struct Map_info *In, DBBUF * dbbuf, NODEV * nodev);
-int StrahWriteToFile(DBBUF * dbbuf, int nlines, FILE * txout);
-int StrahGetDegr(struct Map_info *In, int node);
-int StrahGetNodeLine(struct Map_info *In, int node, int d);
Added: grass-addons/grass6/vector/v.strahler/v.mainchannel/Makefile
--- grass-addons/grass6/vector/v.strahler/v.mainchannel/Makefile	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.mainchannel/Makefile	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.mainchannel
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Copied: grass-addons/grass6/vector/v.strahler/v.mainchannel/description.html (from rev 51972, grass-addons/grass6/vector/v.strahler/v.mainchannel.html)
--- grass-addons/grass6/vector/v.strahler/v.mainchannel/description.html	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.mainchannel/description.html	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,29 @@
+<h2>DESCRIPTION</h2>
+<em>v.mainchannel</em> Finds the main channel of a basin starting from the vector file of the stream network.
+As first you have to visualize on the GRASS monitor the vector map wich you want to calculate the main channel for; with a scale (so you can realize the distances between the closing section and the sources) you can choose some values for the cost isolines (from the outlet); then you can individuate (by interrogating a DEM underlying the vector map) the outlet cross section coords. These coords, the selected cost values and the input/output map names have to be given in input to the program.<br />
+The program returns the main channel considering two factors:<br />
+<em>distance</em>: often the main channel is the longest track in the network<br />
+<em>height</em>: the source of the main channel is conventionally taken as the higest<br />
+This module can be used for any ordinary vector stream network, but the analisys becomes particoulary interesting if you have a vector stream network ordered by Horton-Strahler (e.g. derived from <em><a href="v.strahler.html">v.strahler</a></em> or <em><a href="r.strahler.sh.html">r.strahler.sh</a></em>) because you can see if the main channel includes the max_ordered stream, and, if not, you can consequently modify the "cost" values assigned. <br />
+<h2>EXAMPLE</h2>
+The syntax:
+<div class="code"><pre>
+  v.mainchannel dem=dem xcoor=483456.23 ycoor=234765.33 cost=500,1000,2500,5000,10000 input=input_map output=output_map
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="v.strahler.html">v.strahler</a></em><br>
+<em><a href="r.strahler.sh.html">r.strahler.sh</a></em><br>
+<em><a href="v.net.iso.html">v.net.iso</a></em><br>
+<h2>AUTHORS</h2>
+Ivan Marchesini and Annalisa Minelli, Univ. Perugia. <br>
+<p>
+<i>Last changed: $Date$</i>
Copied: grass-addons/grass6/vector/v.strahler/v.mainchannel/v.mainchannel (from rev 52030, grass-addons/grass6/vector/v.strahler/v.mainchannel.sh)
--- grass-addons/grass6/vector/v.strahler/v.mainchannel/v.mainchannel	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.mainchannel/v.mainchannel	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,154 @@
+#!/bin/sh
+# MODULE:	v.mainchannel
+# AUTHOR(S):	Annalisa Minelli, Ivan Marchesini
+# PURPOSE:	Find the main channel of a vector stream network (useful to compare with a network ordered by Horton-Strahler)
+# COPYRIGHT:	(C) 2005 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: Find the main channel of a vector stream network (useful to compare with a network ordered by Horton-Strahler)
+#%  keywords: strahler, main_channel, vector
+#%End
+#%option
+#% key: dem
+#% type: string
+#% key_desc: dem
+#% gisprompt: old,cell,raster
+#% description: Name of DEM raster map
+#% required : yes
+#%END
+#%option
+#% key: xcoor
+#% type: double
+#% description: x coord of outlet (read by dem in the pixel where is the vector file cross section)
+#% required : yes
+#%end
+#%option
+#% key: ycoor
+#% type: double
+#% description: y coord of outlet (read by dem in the pixel where is the vector file cross section)
+#% required : yes
+#%end
+#%option
+#% key: cost
+#% type: integer
+#% description: Distance between isolines (separated by <comma>)
+#% required : yes
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Vector map of Strahler-ordered streams
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,vector,vector
+#% description: Name of the main_channel vector map
+#% required : yes
+#%END
+#%flag
+#% key: d
+#% label: Display results
+#% description: Plot the result of elaboration in relation to the strahler ordered stream network
+#%end
+if  [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." >&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    exec g.parser "$0" "$@"
+fi
+dem="$GIS_OPT_DEM"
+xcoor="$GIS_OPT_XCOOR"
+ycoor="$GIS_OPT_YCOOR"
+cost="$GIS_OPT_COST"
+input="$GIS_OPT_INPUT"
+output="$GIS_OPT_OUTPUT"
+### setup enviro vars ###
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+g.remove vect=end_basin,out_1del,out_1add,out_basin,out_isodistance,out_2,out_2del,out_2points,out_2addp,out_3D,out_path
+echo "$xcoor|$ycoor|1" | v.in.ascii out=end_basin
+thr=`g.region -p | grep nsres | cut -f2 -d':' | tr -d ' '`
+thresh=`echo "$thr*1.5" | bc -l | cut -f1 -d'.'`
+#### setup temporary files
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+    g.message -e "Unable to create temporary files"
+    exit 1
+fi
+v.category input=$input output=out_1del type=line option=del cat=1 layer=1 step=1
+v.category input=out_1del output=out_1add type=line option=add cat=1 layer=1 step=1
+v.net input=out_1add points=end_basin output=out_basin operation=connect \
+   alayer=1 nlayer=2 thresh="$thresh"
+v.net.iso input=out_basin output=out_isodistance type=line \
+   alayer=1 nlayer=2 ccats=1-99999999 costs=$cost
+echo "v.net.iso executed"
+v.category input=out_isodistance opt=report -g > "$TMP.1"
+grep 'line' "$TMP.1" | cut -f5 -d ' ' > "$TMP.2"
+v.extract input=out_isodistance output=out_2 type=line layer=1 new=-1 file="$TMP.2"
+v.category input=out_2 output=out_2del option=del \
+   type=point,line,boundary,centroid,area cat=1 layer=1 step=1
+v.net input=out_2del output=out_2points operation=nodes alayer=1 nlayer=2
+v.category input=out_2points output=out_2addp type=point option=add \
+   cat=1 layer=2 step=1
+v.drape input=out_2addp type=point,line rast=$dem method=nearest output=out_3D
+v.db.addtable map=out_3D table=tab_coord layer=2 \
+   'columns=cat integer, x double precision, y double precision, z integer'
+v.to.db map=out_3D type=point layer=2 qlayer=1 option=coor units=meters 'column=x, y, z'
+v.univar -g map=out_3D type=point column=z layer=2 percentile=90 > "$TMP.3"
+max=`cat "$TMP.3" | grep max | cut -f2 -d'='`
+db_driver=`db.connect -p | grep driver | cut -f2 -d':'`
+db_database=`db.connect -p | grep database | cut -f2 -d':'`
+x_max=`db.select -c table=tab_coord database=$db_database driver=$db_driver 'sql=select x from tab_coord where z='$max''`
+y_max=`db.select -c table=tab_coord database=$db_databese driver=$db_driver 'sql=select y from tab_coord where z='$max''`
+echo "x_max e y_max valgono: $x_max e $y_max"
+echo "1 $x_max $y_max $xcoor $ycoor" |  v.net.path input=out_isodistance \
+   output=$output type=line alayer=1 nlayer=2
+if [ "$GIS_FLAG_D" -eq 1 ] ; then
+   #plot the result of elaboration in relation to the strahler ordered stream network
+   #d.mon stop=x0
+   d.mon start=x0
+   d.vect "$input" display=shape,cat
+   d.vect map="$output" color=red lcolor=black fcolor=170:170:170 \
+      display=shape type=line icon=basic/x size=5 width=2 layer=1 lsize=8
+   d.barscale tcolor=black bcolor=white at=2,2
+fi
+#g.remove vect=end_basin,out_1del,out_1add,out_basin,out_2,out_2del,out_2points,out_2addp,out_3D
+\rm "$TMP" "$TMP".[1-3]
+#you can modify the "cost" distances in order to have main channel including the max_ordered channel
Deleted: grass-addons/grass6/vector/v.strahler/v.mainchannel.html
--- grass-addons/grass6/vector/v.strahler/v.mainchannel.html	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/v.mainchannel.html	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,29 +0,0 @@
-<em>v.mainchannel</em> Finds the main channel of a basin starting from the vector file of the stream network.
-As first you have to visualize on the GRASS monitor the vector map wich you want to calculate the main channel for; with a scale (so you can realize the distances between the closing section and the sources) you can choose some values for the cost isolines (from the outlet); then you can individuate (by interrogating a DEM underlying the vector map) the outlet cross section coords. These coords, the selected cost values and the input/output map names have to be given in input to the program.<br />
-The program returns the main channel considering two factors:<br />
-<em>distance</em>: often the main channel is the longest track in the network<br />
-<em>height</em>: the source of the main channel is conventionally taken as the higest<br />
-This module can be used for any ordinary vector stream network, but the analisys becomes particoulary interesting if you have a vector stream network ordered by Horton-Strahler (e.g. derived from <em><a href="v.strahler.html">v.strahler</a></em> or <em><a href="r.strahler.sh.html">r.strahler.sh</a></em>) because you can see if the main channel includes the max_ordered stream, and, if not, you can consequently modify the "cost" values assigned. <br />
-<h2>EXAMPLE</h2>
-The syntax:
-  v.mainchannel dem=dem xcoor=483456.23 ycoor=234765.33 cost=500,1000,2500,5000,10000 input=input_map output=output_map
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="v.strahler.html">v.strahler</a></em><br>
-<em><a href="r.strahler.sh.html">r.strahler.sh</a></em><br>
-<em><a href="v.net.iso.html">v.net.iso</a></em><br>
-<h2>AUTHORS</h2>
-Ivan Marchesini and Annalisa Minelli, Univ. Perugia. <br>
-<p>
Deleted: grass-addons/grass6/vector/v.strahler/v.mainchannel.sh
--- grass-addons/grass6/vector/v.strahler/v.mainchannel.sh	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/v.mainchannel.sh	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,154 +0,0 @@
-#!/bin/sh
-# MODULE:	v.mainchannel
-# AUTHOR(S):	Annalisa Minelli, Ivan Marchesini
-# PURPOSE:	Find the main channel of a vector stream network (useful to compare with a network ordered by Horton-Strahler)
-# COPYRIGHT:	(C) 2005 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#%Module
-#%  description: Find the main channel of a vector stream network (useful to compare with a network ordered by Horton-Strahler)
-#%  keywords: strahler, main_channel, vector
-#%End
-#%option
-#% key: dem
-#% type: string
-#% key_desc: dem
-#% gisprompt: old,cell,raster
-#% description: Name of DEM raster map
-#% required : yes
-#%END
-#%option
-#% key: xcoor
-#% type: double
-#% description: x coord of outlet (read by dem in the pixel where is the vector file cross section)
-#% required : yes
-#%end
-#%option
-#% key: ycoor
-#% type: double
-#% description: y coord of outlet (read by dem in the pixel where is the vector file cross section)
-#% required : yes
-#%end
-#%option
-#% key: cost
-#% type: integer
-#% description: Distance between isolines (separated by <comma>)
-#% required : yes
-#%end
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Vector map of Strahler-ordered streams
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,vector,vector
-#% description: Name of the main_channel vector map
-#% required : yes
-#%END
-#%flag
-#% key: d
-#% label: Display results
-#% description: Plot the result of elaboration in relation to the strahler ordered stream network
-#%end
-if  [ -z "$GISBASE" ] ; then
-    echo "You must be in GRASS GIS to run this program." >&2
-    exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    exec g.parser "$0" "$@"
-fi
-dem="$GIS_OPT_DEM"
-xcoor="$GIS_OPT_XCOOR"
-ycoor="$GIS_OPT_YCOOR"
-cost="$GIS_OPT_COST"
-input="$GIS_OPT_INPUT"
-output="$GIS_OPT_OUTPUT"
-### setup enviro vars ###
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-g.remove vect=end_basin,out_1del,out_1add,out_basin,out_isodistance,out_2,out_2del,out_2points,out_2addp,out_3D,out_path
-echo "$xcoor|$ycoor|1" | v.in.ascii out=end_basin
-thr=`g.region -p | grep nsres | cut -f2 -d':' | tr -d ' '`
-thresh=`echo "$thr*1.5" | bc -l | cut -f1 -d'.'`
-#### setup temporary files
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
-    g.message -e "Unable to create temporary files"
-    exit 1
-fi
-v.category input=$input output=out_1del type=line option=del cat=1 layer=1 step=1
-v.category input=out_1del output=out_1add type=line option=add cat=1 layer=1 step=1
-v.net input=out_1add points=end_basin output=out_basin operation=connect \
-   alayer=1 nlayer=2 thresh="$thresh"
-v.net.iso input=out_basin output=out_isodistance type=line \
-   alayer=1 nlayer=2 ccats=1-99999999 costs=$cost
-echo "v.net.iso executed"
-v.category input=out_isodistance opt=report -g > "$TMP.1"
-grep 'line' "$TMP.1" | cut -f5 -d ' ' > "$TMP.2"
-v.extract input=out_isodistance output=out_2 type=line layer=1 new=-1 file="$TMP.2"
-v.category input=out_2 output=out_2del option=del \
-   type=point,line,boundary,centroid,area cat=1 layer=1 step=1
-v.net input=out_2del output=out_2points operation=nodes alayer=1 nlayer=2
-v.category input=out_2points output=out_2addp type=point option=add \
-   cat=1 layer=2 step=1
-v.drape input=out_2addp type=point,line rast=$dem method=nearest output=out_3D
-v.db.addtable map=out_3D table=tab_coord layer=2 \
-   'columns=cat integer, x double precision, y double precision, z integer'
-v.to.db map=out_3D type=point layer=2 qlayer=1 option=coor units=meters 'column=x, y, z'
-v.univar -g map=out_3D type=point column=z layer=2 percentile=90 > "$TMP.3"
-max=`cat "$TMP.3" | grep max | cut -f2 -d'='`
-db_driver=`db.connect -p | grep driver | cut -f2 -d':'`
-db_database=`db.connect -p | grep database | cut -f2 -d':'`
-x_max=`db.select -c table=tab_coord database=$db_database driver=$db_driver 'sql=select x from tab_coord where z='$max''`
-y_max=`db.select -c table=tab_coord database=$db_databese driver=$db_driver 'sql=select y from tab_coord where z='$max''`
-echo "x_max e y_max valgono: $x_max e $y_max"
-echo "1 $x_max $y_max $xcoor $ycoor" |  v.net.path input=out_isodistance \
-   output=$output type=line alayer=1 nlayer=2
-if [ "$GIS_FLAG_D" -eq 1 ] ; then
-   #plot the result of elaboration in relation to the strahler ordered stream network
-   #d.mon stop=x0
-   d.mon start=x0
-   d.vect "$input" display=shape,cat
-   d.vect map="$output" color=red lcolor=black fcolor=170:170:170 \
-      display=shape type=line icon=basic/x size=5 width=2 layer=1 lsize=8
-   d.barscale tcolor=black bcolor=white at=2,2
-fi
-#g.remove vect=end_basin,out_1del,out_1add,out_basin,out_2,out_2del,out_2points,out_2addp,out_3D
-\rm "$TMP" "$TMP".[1-3]
-#you can modify the "cost" distances in order to have main channel including the max_ordered channel
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/Makefile (from rev 51972, grass-addons/grass6/vector/v.strahler/Makefile)
--- grass-addons/grass6/vector/v.strahler/v.strahler/Makefile	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/Makefile	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,13 @@
+PGM = v.strahler
+LIBES     = $(VECTLIB) $(GPROJLIB) $(DBMILIB) $(GISLIB) $(GDALLIBS)
+DEPENDENCIES = $(VECTDEP) $(GPROJDEP) $(DBMIDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC) $(PROJINC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/description.html (from rev 51972, grass-addons/grass6/vector/v.strahler/description.html)
--- grass-addons/grass6/vector/v.strahler/v.strahler/description.html	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/description.html	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,119 @@
+<em>v.strahler</em> calculates the Strahler Order for all lines of a given
+dendritic network. The input vector map must be free of cycles. For the
+elaboration a new imported network or a network extracted from DEM by
+using <em><a href="r.watershed.html">r.watershed</a></em> can be used
+(in this case the topology has to be cleaned manually). More than one
+tree in the input data is allowed. No given flow direction is needed.
+To find the outlet of each tree, a DEM must be given.
+There are two additional scripts distributed with v.strahler:<br />
+- <em>r.strahler.sh</em> extracts streams from a DEM and call v.strahler
+  on the result. <br />
+- <em>r.broscoe.sh</em> computes further statistical values for a given
+  basin. <br />
+<h2>NOTES</h2>
+<h3>Problems</h3>
+This program is in beta status. It has the following shortcomings: <br />
+- The input data has to be topologically clean. Use <em>sloppy</em>=0.0 <br />
+- Source code comments are not doxydized. <br />
+<h3>How the algorithm works</h3>
+In a first step, <em>v.strahler</em> identifies all separate networks in
+the input dataset. That means, all connected lines are assigned a common
+<em>Basin ID</em>.<br />
+Consequently, the lowest leaf of each tree is identified as outlet.
+An auxiliary DEM is needed at this point. <br />
+Strahler ordering begins at each leaf of the tree with order N=1
+(excluding the outlet). At a confluence, the order N(r) of the resulting
+stream is equal to the highest order N(max) of the joining streams or is
+raised by one if there are two or more joining streams of order N(max).<br />
+The algorithm returns an ASCII text file with columns: <em>Category</em>
+(from input map), <em>Line</em> (topology), <em>Basin</em>, <em>Order</em>;
+and the output map has the Strahler Order value instead of "category"
+for each line, and no connection with the database.
+See the also the diagrams in the documentation/ directory.
+<h2>EXAMPLE</h2>
+The input map (vector on DEM): <br />
+<br />
+<img src="images/input_vstrahler.jpg"> <br />
+<br />
+<br />
+An example of the sintax in GRASS shell: <br />
+<br />
+GRASS> v.strahler input=esp_1 at mapset output=esp_1 dem=dem_20 at mapset \
+          txout=/home/mapset/esp_1 sloppy=0 layer=1
+</pre></div>
+<br />
+<br />
+An extract from the resultant text file: <br />
+<br />
+== Result of Strahler Order ==
+ Category:   Line:   Basin:    Order:
+       22       1       1       4
+       73       2       1       1
+       25       3       1       4
+       27       4       1       4
+       39       5       1       1
+       48       6       1       1
+       56       7       1       4
+       55       8       1       2
+       88       9       1       4
+       59      10       1       1
+       60      11       1       1
+       61      12       1       2
+       83      13       1       2
+       82      14       1       1
+       91      15       1       1
+       87      16       1       4
+       95      17       1       2
+       96      18       1       1
+      106      19       1       1
+      102      20       1       1
+      104      21       1       4
+      111      22       1       1
+      112      23       1       3
+      121      24       1       3
+      126      25       1       1
+      128      26       1       3
+      137      27       1       3
+</pre></div>
+<br />
+<br />
+The output map (vector on DEM) form a snapshot of GRASS display: <br />
+<br />
+<img src="images/output_vstrahler.jpg"> <br />
+<br />
+<br />
+The output map (vector only) from Qgis (different colors for different orders): <br />
+<br />
+<img src="images/Qgisout_vstrahler.jpg"> <br />
+<br />
+<br />
+<h2>SEE ALSO</h2>
+<em><a href="r.watershed.html">r.watershed</a></em><br>
+<h2>AUTHOR</h2>
+Florian Kindl, Univ. Innsbruck.<br />
+<br />
+Modified by: Ivan Marchesini and Annalisa Minelli, Univ. Perugia.<br />
+<p>
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/forest2tree.c (from rev 51972, grass-addons/grass6/vector/v.strahler/forest2tree.c)
--- grass-addons/grass6/vector/v.strahler/v.strahler/forest2tree.c	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/forest2tree.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,114 @@
+#include "strahler.h"
+/* helper functions for ForestToTrees:
+   push_line: push number of adjacent line on stack
+   pop_line: return number of top line on stack
+   we could do this with some Vect_list but we don't need
+   to handle entire lines, only their identifiers */
+#define STACK_SIZE 65535
+int sp = 0;			/* stack position */
+int stack[STACK_SIZE];		/* generous stack size */
+void push_line(int line)
+    if (sp < STACK_SIZE) {
+	stack[sp++] = line;
+    else {
+	G_fatal_error("ForestToTrees: stack full");
+int pop_line(void)
+    if (sp > 0) {
+	return stack[--sp];
+    else {
+	G_debug(3, "ForestToTrees: stack empty, tree finished");
+	return 0;
+/* or write our own lfind: nexttree() */
+/* start at offset, walk array up until bsnid == 0 and return that offset */
+int nexttree(DBBUF * dbbuf, int offset, int upper)
+    while ((dbbuf[offset].bsnid != 0) && (offset < upper)) {
+	++offset;
+	G_debug(4, "bsnid[%d] is %d", offset, dbbuf[offset].bsnid);
+    return offset;
+/* Find trees, assign basinID */
+int StrahForestToTrees(struct Map_info *In, struct Map_info *Out,
+		       DBBUF * dbbuf)
+    int tree, tree_finished, forest_done;	/* ID of tree (basin), processing status */
+    int l, n, d, degr, node;	/* iterators */
+    int nlines, offset;		/* number of lines, position in dbbuf */
+    int cline, aline;		/* currently harvested line, adjacent line */
+    int lnodes[2];		/* nodes of cline */
+    G_debug(1, "reached StrahForestToTrees");
+    nlines = Vect_get_num_lines(In);
+    forest_done = 0;
+    tree = 1;			/* we start with tree no. 1 */
+    offset = cline = 1;		/* we start at line 1 */
+    while (forest_done == 0) {
+	G_debug(3, "\nProcessing Tree %d", tree);
+	tree_finished = 0;	/* initialize status indicator for this tree */
+	while (tree_finished == 0) {
+	    /* procedure to get adjacent lines and push them on the stack */
+	    Vect_get_line_nodes(In, cline, &lnodes[0], &lnodes[1]);
+	    G_debug(4, "nodes for line %d: %d %d", cline, lnodes[0],
+		    lnodes[1]);
+	    for (n = 0; n <= 1; n++) {	/* loop through array[2] of fnode and tnode */
+		node = lnodes[n];
+		/*degr = Vect_get_node_n_lines( In, node ); */
+		degr = StrahGetDegr(In, node);
+		G_debug(4, "degr %d for node %d", degr, node);
+		for (d = 0; d < degr; d++) {
+		    /*aline = abs( Vect_get_node_line( In, node, d ) ); */
+		    aline = abs(StrahGetNodeLine(In, node, d));
+		    if (dbbuf[aline].bsnid == 0) {	/* push line on stack only if not done yet */
+			G_debug(4, "pushing line %d on sp %d", aline, sp);
+			push_line(aline);
+			G_debug(4, "pushed, sp is now %d", sp);
+			dbbuf[aline].bsnid = tree;	/* line is done when pushed on stack */
+			dbbuf[aline].line = aline;
+	    /* pop a line from stack */
+	    cline = (int)pop_line();
+	    G_debug(4, "popped line %d", cline);
+	    /* tree is finished when pop_line returned 0 */
+	    if (cline == 0) {
+		tree_finished = 1;
+	/* get first cline of next tree */
+	offset = cline = nexttree(dbbuf, ++offset, nlines);
+	G_debug(3, "cline/offset for tree %d is %d", tree, cline);
+	if (offset == nlines) {
+	    forest_done = 1;	/* what if last line still is 0 - it is a tree consisting of this line only - it shall keep bsnid 0 */
+	else {
+	    tree++;		/* continue with next tree */
+    return tree;
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/helper.c (from rev 51972, grass-addons/grass6/vector/v.strahler/helper.c)
--- grass-addons/grass6/vector/v.strahler/v.strahler/helper.c	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/helper.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,80 @@
+/* Replacement for Vect_get_node_n_lines in sloppy mode
+   Gets adjacent lines by coordinate */
+int StrahGetDegr(struct Map_info *In, int node)
+    extern double sloppy;
+    int degr, onode, j;
+    double x, y;
+    BOUND_BOX *Box;
+    struct ilist *list;
+    if (sloppy != 0.0) {
+	Vect_get_node_coor(In, node, &x, &y, NULL);
+	Box->N = y + sloppy;
+	Box->S = y - sloppy;
+	Box->W = x + sloppy;
+	Box->E = x - sloppy;
+	list = Vect_new_list();
+	   printf( "N %f\n", Box->N );
+	   printf( "S %f\n", Box->S );
+	   printf( "W %f\n", Box->W );
+	   printf( "E %f\n", Box->E );
+	Vect_select_nodes_by_box(In, Box, list);
+	G_debug(3, "  %d nodes selected", list->n_values);
+	/* is always 0 -why? */
+	for (j = 0; j < list->n_values; j++) {
+	    onode = abs(list->value[j]);
+	    G_debug(3, "List %d: %d\n", j, onode);
+	   Vect_list_append ( StArcs, line );
+	   Vect_get_line_nodes ( &Map, line, &node1, &node2);
+	   Vect_list_append ( StNodes, node1 );
+	   Vect_list_append ( StNodes, node2 );
+    else {
+	degr = Vect_get_node_n_lines(In, node);
+    G_debug(4, "node %d degr %d sloppy %f\n", node, degr, sloppy);
+    return degr;
+int StrahGetNodeLine(struct Map_info *In, int node, int d)
+    int aline;
+	G_debug(4, "StrahGetNodeLine at node %d", node);
+	   get all nodes within sloppy from node -> from table StrahGetDegr has written
+	   get all lines for each found node -> Vect_get_node_line(In, foundnode, df)
+	   for ( fn=0; fn<foundnodes.length; fn++ ) {
+	   degrf = Vect_get_node_n_lines( In, fn );
+	   for (df = 0; df < degrf; df++) {
+	   foundline = abs( Vect_get_node_line( In, fn, df ) );
+	   addtolist(foundline);
+	   return line d in list of foundlines;
+    else {
+	/* method if junction is only 1 node */
+	aline = abs(Vect_get_node_line(In, node, d));
+    return aline;
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/main.c (from rev 51972, grass-addons/grass6/vector/v.strahler/main.c)
--- grass-addons/grass6/vector/v.strahler/v.strahler/main.c	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/main.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,384 @@
+ *  MODULE:       v.strahler
+ *  AUTHOR(S):    Florian Kindl, Norbert Pfeifer, The GRASS development team
+ *		  Modified by: Ivan Marchesini <marchesini unipg.it> and
+		  Annalisa Minelli <annapatri tiscali.it>
+ *  PURPOSE:      Assign Strahler order to dendritic network
+ *  COPYRIGHT:    (C) 2006 by the Authors
+ *                This program is free software under the
+ *                GNU General Public License (v2).
+ *                Read the file COPYING that comes with GRASS
+ *                for details.
+/*! \file main.c
+   \brief Assign Strahler order to dendritic network
+   \author Florian Kindl
+   \todo Deal with poor topology
+   \li implemement sloppy mode or
+   \li force clean topology
+   \todo ...
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <search.h>
+#include <time.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/dgl.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+#define COPYBLAH 1
+#define DDFIELDBLAH 1
+#define BADDCOLUMNBLAH 1
+#define RITEDBLAH 1
+#define EBUG 1
+#define REATEDBLAH 1
+int ret, type;			/* return and type related to Vect_read_line and Vect_write_line */
+int fdrast;			/* file descriptor for raster file is int */
+int ntrees;			/* number of trees in dataset, returned by StrahForestToTrees */
+double sloppy;
+int main(int argc, char **argv)
+    int line, node;
+    char buf[1024];
+    int nnodes, nlines, tlines;
+    DBBUF *dbbuf;
+    NODEV *nodev;
+    struct Option *input, *output, *dem_opt, *txout_opt, *sloppy_opt,
+	*field_opt;
+    struct GModule *module;
+    char *inputset, *demset;
+    struct Map_info In, Out;
+    struct Map_info Trees;
+    FILE *txout;
+    struct Cell_head window;	/* for cell sampling */
+    extern int ntrees;		/* number of trees calculated by StrahForestToTrees */
+    extern int fdrast;
+    /* Attribute table (from v.net.path/path.c) */
+    struct line_cats *Cats;	/* introduced and initialized the structures line_cats and line_pnts */
+    static struct line_pnts *Points;
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    dbString sql;
+    dbDriver *driver;
+    dbColumn *column;
+    struct field_info *Fi;
+    int field;
+    /* Initialize the GIS calls */
+    G_gisinit(argv[0]);
+    input = G_define_standard_option(G_OPT_V_INPUT);
+    output = G_define_standard_option(G_OPT_V_OUTPUT);
+    module = G_define_module();
+    module->description = _("Strahler order");
+    dem_opt = G_define_standard_option(G_OPT_R_INPUT);
+    dem_opt->key = "dem";
+    dem_opt->description = _("Underlying DEM");
+    txout_opt = G_define_option();
+    txout_opt->key = "txout";
+    txout_opt->type = TYPE_STRING;
+    txout_opt->required = NO;
+    txout_opt->multiple = NO;
+    txout_opt->gisprompt = "new_file,file,output";
+    txout_opt->description =
+	_("Path to ASCII file where results will be written");
+    /* option sloppy for bad topology */
+    sloppy_opt = G_define_option();
+    sloppy_opt->key = "sloppy";
+    sloppy_opt->type = TYPE_DOUBLE;
+    sloppy_opt->required = NO;
+    sloppy_opt->answer = "0.0";
+    sloppy_opt->multiple = NO;
+    sloppy_opt->description =
+	_("Threshold for distance within different nodes are considered the same node - may not work");
+    field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    field = atoi(field_opt->answer);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    Vect_check_input_output_name(input->answer, output->answer,
+				 GV_FATAL_EXIT);
+    inputset = G_find_vector2(input->answer, NULL);
+    if (inputset == NULL) {
+	G_fatal_error(_("Could not find input input <%s>"), input->answer);
+    /* open datasets at topology level 2 */
+    Vect_set_open_level(2);
+    Vect_open_old(&In, input->answer, inputset);
+    G_debug(1, "Input vector opened");
+    /* Open new vector, make 3D if input is 3D */
+    if (1 > Vect_open_new(&Out, output->answer, Vect_is_3d(&In))) {
+	Vect_close(&In);
+	G_fatal_error("Failed opening output vector file %s", output->answer);
+    /* Open DEM */
+    demset = G_find_cell2(dem_opt->answer, NULL);
+    if (demset == NULL) {
+	G_fatal_error("DEM file %s not found", dem_opt->answer);
+    if (1 > (fdrast = G_open_cell_old(dem_opt->answer, demset))) {
+	G_fatal_error("Failed opening DEM file %s", dem_opt->answer);
+    /* Open text file for results if given */
+    if (txout_opt->answer) {
+	txout = fopen(txout_opt->answer, "w");
+	if (txout == NULL)
+	    G_fatal_error(_("Cannot open file %s"), txout_opt->answer);
+    sloppy = atof(sloppy_opt->answer);
+    /* printf("blah %f", sloppy*2.4 ); */
+    /* write history */
+    /*Vect_copy_head_data( &In, &Out );
+       Vect_hist_copy( &In, &Out );
+       Vect_hist_command( &Out ); */
+#ifdef COPYBLAH
+    /* this works, we want to continue here and ADD two columns to the &Out */
+    /* Copy input to output (from v.clean/main.c) */
+    /*G_debug( 1, "Copying vector lines to Output" );
+       /* This works for both level 1 and 2 */
+    /*Vect_copy_map_lines ( &In, &Out );        */
+    /* 0: copy all fields, else field number */
+#endif
+#ifdef ADDFIELDBLAH		/* Create table (from v.net.path/path.c) */
+    /* or: add fields to existing table? */
+    /*                                                      *Map, field, field_name, type */
+    Fi = Vect_default_field_info(&Out, field, NULL, GV_1TABLE);
+    Vect_map_add_dblink(&Out, field, NULL, Fi->table, "cat", Fi->database,
+			Fi->driver);
+    driver = db_start_driver_open_database(Fi->driver, Fi->database);
+    driver =
+	db_start_driver_open_database(Fi->driver,
+				      Vect_subst_var(Fi->database, &Out));
+    /* from v.reclass/main.c :
+    if (driver == NULL) {
+	G_fatal_error("Cannot open database %s by driver %s", Fi->database,
+		      Fi->driver);
+    /* store the statement to create a table with category, basin ID and strahler order of the arc */
+    sprintf(buf,
+	    "CREATE TABLE %s ( cat integer, bsnid integer, sorder integer )",
+	    Fi->table);
+    /* from v.reclass/main.c : */
+    dbString stmt;
+    db_init_string(&stmt);
+    db_set_string(&stmt, buf);
+    if (db_execute_immediate(driver, &stmt) != DB_OK) {
+	Vect_close(&Out);
+	db_close_database_shutdown_driver(driver);
+	G_fatal_error("Cannot create table: %s", db_get_string(&stmt));
+       sprintf ( buf, "ALTER TABLE %s ADD COLUMN cat integer", Fi->table );
+       sprintf ( buf, "ALTER TABLE %s ADD COLUMN bsnid integer", Fi->table );
+       sprintf ( buf, "ALTER TABLE %s ADD COLUMN sorder integer", Fi->table );
+#endif
+#ifdef DBADDCOLUMNBLAH
+    sprintf(buf, "bsnid");
+    db_set_string(&sql, buf);
+    column->columnName = sql;
+    column->sqlDataType = 1;
+    sprintf(buf, "%s", Fi->table);
+    /*db_set_string ( &sql, buf ); */
+    /* why such complicated arguments for db_add_column???
+       dbDriver, dbString, dbColumn */
+    if (db_add_column(driver, &sql, column) != DB_OK) {
+	G_fatal_error("Cannot add column column in table %s", Fi->table);
+#endif
+    /* execute statement */
+#ifdef CREATEDBLAH
+    sprintf(buf,
+	    Fi->table);
+    G_debug(2, db_get_string(&sql));
+    if (db_execute_immediate(driver, &sql) != DB_OK) {
+	G_fatal_error("Cannot create table: %s", db_get_string(&sql));
+    else
+	printf("table created\n");
+    if (db_create_index2(driver, Fi->table, "cat") != DB_OK) {
+	G_warning("Cannot create index");
+    else
+	printf("index created\n");
+    if (db_grant_on_table
+	(driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK) {
+	G_fatal_error("Cannot grant privileges on table %s", Fi->table);
+    else
+	printf("privileges granted\n");
+#endif
+    nnodes = Vect_get_num_nodes(&In);
+    nlines = Vect_get_num_lines(&In);
+    G_debug(1, "Number of lines: %d", nlines);
+    G_debug(1, "Number of nodes: %d", nnodes);
+    /* Create table to store ordering */
+    dbbuf = (DBBUF *) G_malloc((nlines + 1) * ((int)sizeof(DBBUF)));
+    nodev = (NODEV *) G_malloc((nnodes + 1) * ((int)sizeof(NODEV)));
+    /* initialize properly */
+    for (line = 1; line <= nlines; line++) {
+	dbbuf[line].category = dbbuf[line].line = dbbuf[line].bsnid =
+	    dbbuf[line].sorder = 0;
+    for (node = 1; node <= nnodes; node++) {
+	nodev[node].node = nodev[node].degree = nodev[node].visited = 0;
+    ntrees = (int)StrahForestToTrees(&In, &Out, dbbuf);
+    G_debug(1, "Number of trees: %d", ntrees);
+    StrahFindLeaves(&In, dbbuf, nodev, ntrees, fdrast);
+    G_debug(2, "dbbuf after FindLeaves:\nline\tbsnid\tsorder");
+	sprintf(buf, "%d\t%d\t%d\n", dbbuf[line].line, dbbuf[line].bsnid,
+		dbbuf[line].sorder);
+	G_debug(2, "%s", buf);
+    G_debug(2, "nodev after FindLeaves:\nnode\tdegree\tvisited");
+	sprintf(buf, "%d\t%d\t%d\n", (int)nodev[node].node,
+		nodev[node].degree, nodev[node].visited);
+    StrahOrder(&In, dbbuf, nodev);
+    G_debug(2, "dbbuf after StrahOrder:\nline\tbsnid\tsorder\n");
+    G_debug(2, "nodev after StrahOrder:\nnode\tdegree\tvisited\n");
+#ifdef WRITEDBLAH
+    /* and write DB records */
+    db_begin_transaction(driver);
+	sprintf(buf, "insert into %s values ( %d, %d, %d )", Fi->table, line,
+		dbbuf[line].bsnid, dbbuf[line].sorder);
+	/* G_debug ( 3, db_get_string ( &sql ) ); */
+	    G_fatal_error("Insert new row: %s", db_get_string(&sql));
+    db_commit_transaction(driver);
+#endif
+    /* writing StrahOrder instead of category in the output */
+	type = Vect_read_line(&In, Points, Cats, line);
+	ret = Vect_cat_del(Cats, field);
+	G_debug(4, "deleted categories, ret=%d", ret);
+	Vect_cat_set(Cats, field, dbbuf[line].sorder);
+	Vect_write_line(&Out, type, Points, Cats);
+	G_debug(4, "category written for line %d", line);
+    /* assign category values */
+	dbbuf[line].category = Vect_get_line_cat(&In, line, field);
+	G_debug(4, "added category %d for line %d", dbbuf[line].category,
+		dbbuf[line].line);
+    /* Write text file for results if given */
+	StrahWriteToFile(dbbuf, nlines, txout);
+    Vect_close(&In);
+    G_close_cell(fdrast);
+    Vect_build(&Out);
+    Vect_close(&Out);
+	fclose(txout);
+    return (EXIT_SUCCESS);
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/strahler.c (from rev 51972, grass-addons/grass6/vector/v.strahler/strahler.c)
--- grass-addons/grass6/vector/v.strahler/v.strahler/strahler.c	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/strahler.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,223 @@
+/* Find Leaves of tree and distinguish outlet from sources */
+int StrahFindLeaves(struct Map_info *In, DBBUF * dbbuf, NODEV * nodev,
+		    int ntrees, int fdrast)
+    int nnodes, degr, aline, node, unode, dnode, tree, outlet;
+    double x, y, z, z_init;
+    int n;
+    INTERP_TYPE method = NEAREST;
+    OUTLETS *outlets;
+    nnodes = Vect_get_num_nodes(In);
+    z = z_init = 27000000.0;	/* is it safe to initialize lowest z with the height of Olympus Mons above Martian Datum in millimeters? */
+    outlets = (OUTLETS *) G_malloc((ntrees + 1) * ((int)sizeof(OUTLETS)));
+    /* initialize outlet table properly */
+    for (n = 1; n <= ntrees; n++) {
+	outlets[n].z = z_init;
+	outlets[n].leaf = 0;
+    G_debug(1, "Reached StrahFindLeaves with %d trees", ntrees);
+    G_get_window(&window);
+    G_debug(2, "window: N %f S %f W %f E %f", window.north, window.south,
+	    window.west, window.east);
+    G_debug(2, "%d nodes in map", nnodes);
+	nodev[node].node = node;
+	nodev[node].degree = degr;
+	G_debug(4, "node %d: degr=%d", node, degr);
+	if (degr == 1) {
+	    unode = node;
+	    nodev[node].visited = 1;	/*set the "visited" parameter to 1... can't be less */
+	    /*aline = abs( Vect_get_node_line( In, unode, 0 ) ); */
+	    aline = abs(StrahGetNodeLine(In, unode, 0));
+	    /*Vect_get_line_nodes( In, aline, &unode, &dnode); */
+	    /* these are not necessarily up-node and down-node but we need not distinguish here... */
+	    dbbuf[aline].sorder = 1;
+	    /* no, do not visit yet
+	       nodev[node].visited += 1;
+	       nodev[unode].visited += 1;
+	       nodev[dnode].visited += 1;
+	    /* get z value or DEM value under node here, remember lowest */
+	    if (Vect_is_3d(In)) {
+		Vect_get_node_coor(In, node, &x, &y, &z);
+	    else {
+		z = (double)G_get_raster_sample(fdrast, &window, NULL, y, x,
+						0, method);
+	    G_debug(5, "fdrast=%d node=%d y=%f x=%f z=%f", fdrast, node, y,
+		    x, z);
+	    tree = dbbuf[aline].bsnid;
+	    if (z < outlets[tree].z) {
+		outlets[tree].z = z;
+		outlets[tree].leaf = aline;
+    /* reset outlets to 0 */
+	G_debug(2, "outlet tree %d: line %d with %f", n, outlets[n].leaf,
+		outlets[n].z);
+	outlet = outlets[n].leaf;
+	dbbuf[outlet].sorder = 0;
+	   Vect_get_line_nodes( In, outlet, &unode, &dnode);
+	   nodev[unode].visited = 0;
+	   nodev[dnode].visited = 0;
+    return 1;
+/* assign strahler order */
+int StrahOrder(struct Map_info *In, DBBUF * dbbuf, NODEV * nodev)
+    int nlines, line;
+    int fnode, tnode, unode, dnode;	/* from-, to-, up-, down- node */
+    int degr, d, aline, aorder;	/* find adjacent lines */
+    int corder, norder, dorder, dline;	/* assign order */
+    int cline, rfinish;		/* follow one line until this stop-condition is 1 */
+    struct dbbuf;
+    struct nodev;
+    G_debug(1, "reached StrahOrder");
+	if (dbbuf[line].sorder == 1) {	/* get lines of order 1 */
+	    cline = line;	/* and start run downwards */
+	    rfinish = 0;
+	    while (rfinish == 0) {
+		G_debug(3, "reached line %d", cline);
+		Vect_get_line_nodes(In, cline, &fnode, &tnode);	/* and their nodes */
+		/**** BAUSTELLE ****/
+		/* check nodes - we do not rely on flow direction */
+		if (nodev[fnode].visited == 1) {
+		    unode = fnode;
+		    dnode = tnode;
+		else {
+		    unode = tnode;
+		    dnode = fnode;
+		   if (nodev[fnode].visited == nodev[tnode].visited) {
+		   printf("Line %d: both nodes are visited or not - what now?\n", line);
+		   } else if (nodev[fnode].visited == 0) {
+		   node = fnode;
+		   } else {
+		   node = tnode;
+		   if ( (nodev[fnode].degree - nodev[fnode].visited) < (nodev[tnode].degree - nodev[tnode].visited) ) {
+		   unode = fnode;
+		   dnode = tnode;
+		   } else if ( (nodev[fnode].degree - nodev[fnode].visited) > (nodev[tnode].degree - nodev[tnode].visited) ) {
+		   unode = tnode;
+		   dnode = fnode;
+		   } else {
+		   G_message("Line %d: nodes have same diff(degree,visited) - what now?\n", cline);
+		/* ok, what now?
+		   - occurs when leaf meets node with norder==0 -> visit nodes and continue
+		   - or: is outlet -> assign order
+		/* continue? */
+		   printf("visiting tnode %d and fnode %d for line %d and break\n\n", tnode, fnode, cline);
+		   nodev[tnode].visited += 1;
+		   nodev[fnode].visited += 1;
+		   break;
+		G_debug(3, "unode is %d and dnode is %d", unode, dnode);
+		/*degr = Vect_get_node_n_lines ( In, dnode );            use downward node */
+		degr = StrahGetDegr(In, dnode);
+		G_debug(4, "deg for dnode %d is %d", dnode, degr);
+		corder = dbbuf[cline].sorder;	/* current order - result won't be less than that */
+		norder = dorder = 0;	/* no order - how many lines have none?, highest order of others */
+		    /*aline = abs( Vect_get_node_line ( In, dnode, d ) ); */
+		    aline = abs(StrahGetNodeLine(In, dnode, d));
+		    G_debug(4, "line %d at dnode %d is %d", d, dnode, aline);
+		    if (aline != cline) {	/* we don't need the line we come from */
+			aorder = dbbuf[aline].sorder;
+			if (aorder == 0) {
+			    norder++;
+			    dline = aline;	/* downward line */
+			else if (aorder > dorder) {
+			    dorder = aorder;	/* find highest order */
+		if (norder > 1 || norder == 0) {	/* if (norder > 1: node indeterminate OR norder == 0 : subtree finished) */
+		    G_debug(3, "Finished run at line %d because norder=%d",
+			    cline, norder);
+		    G_debug(4, "visiting unode %d for line %d", unode, cline);
+		    nodev[unode].visited += 1;	/* visit unode, for the sake of completeness */
+		    rfinish = 1;	/* finish this run */
+		else {		/* or */
+		    if (dorder > corder) {
+			;	/* assign highest order of alines */
+		    else if (dorder < corder) {
+			dorder = corder;	/* or keep order of cline */
+		    else {
+			dorder++;	/* or raise order by one */
+		    dbbuf[dline].sorder = dorder;	/* assign order */
+		    G_debug(4, "visiting dnode %d and unode %d for line %d",
+			    dnode, unode, cline);
+		    nodev[dnode].visited += 1;	/* visit dnode */
+		    cline = dline;	/* and continue with this line */
+		    G_debug(3, "StrahOrder for dline %d: %d", dline, dorder);
+	    }			/* while */
+    return 1;
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/strahler.h (from rev 51972, grass-addons/grass6/vector/v.strahler/strahler.h)
--- grass-addons/grass6/vector/v.strahler/v.strahler/strahler.h	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/strahler.h	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,100 @@
+#include <time.h>
+#include "grass/gis.h"
+#include "grass/Vect.h"
+#include "grass/dgl.h"
+#include "grass/dbmi.h"
+/*! \typedef DBBUF
+   \brief Buffer to keep track of assigned tree and Strahler order for each line
+/*! \typedef NODEV
+   \brief Buffer to keep track of valency for each node
+/*! \typedef OUTLETS
+   \brief Buffer to determine lowest leaf of each tree
+typedef struct
+{				/* collect lines in Strahler order */
+    int category;
+    int line;			/* line number */
+    int bsnid;			/* basin ID */
+    int sorder;			/* Strahler order */
+} DBBUF;
+typedef struct
+{				/* visited nodes */
+    int node;			/* node number */
+    int degree;			/* valency */
+    int visited;		/* is between 0 and degr(node) */
+} NODEV;
+typedef struct
+{				/* keep track of lowest leaf (=outlet) of each tree */
+    double z;			/* z-value of leaf */
+    int leaf;			/* line-id of outlet leaf */
+} OUTLETS;
+/* in forest2tree.c */
+/*! \fn int StrahForestToTrees( struct Map_info *In, struct Map_info *Out, DBBUF *dbbuf );
+   \brief Returns the number of trees in *In
+   \param *In The input map
+   \param *Out The output map
+   \param *dbbuf The buffer table for line orders
+/* in strahler.c */
+/*! \fn int StrahFindLeaves( struct Map_info *In, DBBUF *dbbuf, NODEV *nodev, int ntrees, int fdrast );
+   \brief Identifies all leaves of each tree and the one that lies lowest
+   \param *nodev The buffer table for node valency
+   \param ntrees Number of trees in map
+   \param fdrast File descriptor of DEM raster map
+/*! \fn int StrahOrder( struct Map_info *In, DBBUF *dbbuf, NODEV *nodev );
+   \brief Calculates the Strahler order of each line
+/* in write.c */
+/*! \fn int StrahWriteToFile( DBBUF *dbbuf, int nlines, FILE *txout );
+   \brief Writes ASCII representation of calculated order to file
+   \param nlines Number of lines in *In map
+   \param *txout ASCII output file name
+/* in helper.c */
+/*! \fn int StrahGetDegr( struct Map_info *In, int node );
+   \brief Get degree of node (for sloppy mode)
+   \param node Node number in *In
+/*! \fn int StrahNodeLine( struct Map_info *In, int node, int d );
+   \brief Get lines connected in node (for sloppy mode)
+   \param d n-th line connected to node
+		       DBBUF * dbbuf);
+		    int ntrees, int fdrast);
+int StrahOrder(struct Map_info *In, DBBUF * dbbuf, NODEV * nodev);
+int StrahWriteToFile(DBBUF * dbbuf, int nlines, FILE * txout);
+int StrahGetDegr(struct Map_info *In, int node);
+int StrahGetNodeLine(struct Map_info *In, int node, int d);
Copied: grass-addons/grass6/vector/v.strahler/v.strahler/write.c (from rev 51972, grass-addons/grass6/vector/v.strahler/write.c)
--- grass-addons/grass6/vector/v.strahler/v.strahler/write.c	                        (rev 0)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/write.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -0,0 +1,15 @@
+    int line;
+    G_debug(1, "Reached WriteToFile - writing %d lines", nlines);
+    fprintf(txout, "== Result of Strahler Order ==\n");
+    fprintf(txout, " Category:   Line:   Basin:    Order:\n");	/*added cat column */
+	fprintf(txout, "%9d%8d%8d%8d\n", dbbuf[line].category,
+		dbbuf[line].line, dbbuf[line].bsnid, dbbuf[line].sorder);
+    return 1;
Deleted: grass-addons/grass6/vector/v.strahler/write.c
--- grass-addons/grass6/vector/v.strahler/write.c	2012-06-11 08:33:16 UTC (rev 52030)
+++ grass-addons/grass6/vector/v.strahler/write.c	2012-06-11 09:01:11 UTC (rev 52031)
@@ -1,15 +0,0 @@
-#include "strahler.h"
-    int line;
-    G_debug(1, "Reached WriteToFile - writing %d lines", nlines);
-    fprintf(txout, "== Result of Strahler Order ==\n");
-    fprintf(txout, " Category:   Line:   Basin:    Order:\n");	/*added cat column */
-	fprintf(txout, "%9d%8d%8d%8d\n", dbbuf[line].category,
-		dbbuf[line].line, dbbuf[line].bsnid, dbbuf[line].sorder);
-    return 1;
