[GRASS-SVN] r52032 - grass/branches/develbranch_6/vector/v.to.rast
Mon Jun 11 04:37:01 PDT 2012
Author: mmetz
Date: 2012-06-11 04:37:00 -0700 (Mon, 11 Jun 2012)
New Revision: 52032
   grass/branches/develbranch_6/vector/v.to.rast/support.c
v.to.rast: add labels for use=cat
Modified: grass/branches/develbranch_6/vector/v.to.rast/support.c
--- grass/branches/develbranch_6/vector/v.to.rast/support.c	2012-06-11 09:01:11 UTC (rev 52031)
+++ grass/branches/develbranch_6/vector/v.to.rast/support.c	2012-06-11 11:37:00 UTC (rev 52032)
@@ -279,6 +279,7 @@
 	    G_set_raster_cats_title("Labels", &rast_cats);
 	    /* open vector map and database driver */
+	    Vect_set_open_level(1);
 	    Vect_open_old(&Map, vector_map, G_find_vector2(vector_map, ""));
 	    db_CatValArray_init(&cvarr);
@@ -286,6 +287,8 @@
 		G_fatal_error(_("Database connection not defined for layer %d"),
 			      field);
+	    Vect_close(&Map);
 	    if (!
 		(Driver =
 		 db_start_driver_open_database(Fi->driver, Fi->database)))
@@ -419,37 +422,123 @@
 	    mapset = G_mapset();
-	    if (!(fd = G_open_cell_old(rast_name, mapset)))
-		G_fatal_error(_("Unable to open raster map <%s>"), rast_name);
 	    map_type = G_raster_map_type(rast_name, mapset);
-	    if (!(rowbuf = G_allocate_raster_buf(map_type)))
-		G_fatal_error(_("Cannot allocate memory for row buffer"));
+	    if (label_column) {
-	    G_init_cell_stats(&stats);
-	    G_set_raster_cats_title("Categories", &rast_cats);
+		G_set_raster_cats_title("Labels", &rast_cats);
-	    rows = G_window_rows();
+		/* open vector map and database driver */
+		Vect_open_old(&Map, vector_map, G_find_vector2(vector_map, ""));
-	    for (row = 0; row < rows; row++) {
-		if (G_get_raster_row(fd, rowbuf, row, map_type) < 0)
-		    G_fatal_error(_("Unable to read raster map <%s> row %d"),
-				  rast_name, row);
+		db_CatValArray_init(&cvarr);
+		if (!(Fi = Vect_get_field(&Map, field)))
+		    G_fatal_error(_("Database connection not defined for layer %d"),
+				  field);
-		G_update_cell_stats(rowbuf, G_window_cols(), &stats);
+		Vect_close(&Map);
+		if (!
+		    (Driver =
+		     db_start_driver_open_database(Fi->driver, Fi->database)))
+		    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+				  Fi->database, Fi->driver);
+		/* get number of records in label_column */
+		if ((nrec =
+		     db_select_CatValArray(Driver, Fi->table, Fi->key,
+					   label_column, NULL, &cvarr)) == -1)
+		    G_fatal_error(_("Unknown column <%s> in table <%s>"),
+				  label_column, Fi->table);
+		if (nrec < 0)
+		    G_fatal_error(_("No records selected from table <%s>"),
+				  Fi->table);
+		G_debug(3, "nrec = %d", nrec);
+		my_labels_rules =
+		    (struct My_labels_rule *)
+		    G_malloc(sizeof(struct My_labels_rule) * nrec);
+		/* get column type */
+		if ((col_type =
+		     db_column_Ctype(Driver, Fi->table,
+				     label_column)) == -1) {
+		    G_fatal_error(_("Column <%s> not found"), label_column);
+		/* close the database driver */
+		db_close_database_shutdown_driver(Driver);
+		/* for each attribute */
+		for (i = 0; i < cvarr.n_values; i++) {
+		    char tmp[2000];
+		    int cat = cvarr.value[i].cat;
+		    labels_n_values++;
+		    db_init_string(&my_labels_rules[i].label);
+		    /* switch the column type */
+		    switch (col_type) {
+		    case DB_C_TYPE_DOUBLE:
+			sprintf(tmp, "%lf", cvarr.value[i].val.d);
+			db_set_string(&my_labels_rules[i].label, tmp);
+			break;
+		    case DB_C_TYPE_INT:
+			sprintf(tmp, "%d", cvarr.value[i].val.i);
+			break;
+		    case DB_C_TYPE_STRING:
+				      db_get_string(cvarr.value[i].val.s));
+			break;
+		    default:
+			G_warning(_("Column type (%s) not supported"),
+				  db_sqltype_name(col_type));
+		    /* add the raster category to label */
+		    my_labels_rules[i].i = cat;
+		    G_set_raster_cat(&(my_labels_rules[i].i),
+				 &(my_labels_rules[i].i),
+				 db_get_string(&my_labels_rules[i].label),
+				 &rast_cats, map_type);
+		}			/* for each value in database */
+	    else {
+		if (!(fd = G_open_cell_old(rast_name, mapset)))
+		    G_fatal_error(_("Unable to open raster map <%s>"), rast_name);
-	    G_rewind_cell_stats(&stats);
+		if (!(rowbuf = G_allocate_raster_buf(map_type)))
+		    G_fatal_error(_("Cannot allocate memory for row buffer"));
-	    while (G_next_cell_stat(&n, &count, &stats)) {
-		char msg[80];
+		G_init_cell_stats(&stats);
+		G_set_raster_cats_title("Categories", &rast_cats);
-		sprintf(msg, "Category %d", n);
-		G_set_raster_cat(&n, &n, msg, &rast_cats, map_type);
+		rows = G_window_rows();
+		for (row = 0; row < rows; row++) {
+		    if (G_get_raster_row(fd, rowbuf, row, map_type) < 0)
+			G_fatal_error(_("Unable to read raster map <%s> row %d"),
+				      rast_name, row);
+		    G_update_cell_stats(rowbuf, G_window_cols(), &stats);
+		G_rewind_cell_stats(&stats);
+		while (G_next_cell_stat(&n, &count, &stats)) {
+		    char msg[80];
+		    sprintf(msg, "Category %d", n);
+		    G_set_raster_cat(&n, &n, msg, &rast_cats, map_type);
+		G_free(rowbuf);
-	    G_free(rowbuf);
 	break;
     case USE_D:
