[GRASS-SVN] r52049 - grass/trunk/lib/ogsf
Tue Jun 12 06:59:46 PDT 2012
Author: mmetz
Date: 2012-06-12 06:59:45 -0700 (Tue, 12 Jun 2012)
New Revision: 52049
   grass/trunk/lib/ogsf/GS2.c
   grass/trunk/lib/ogsf/gs.c
   grass/trunk/lib/ogsf/gsd_img_tif.c
   grass/trunk/lib/ogsf/gsd_wire.c
   grass/trunk/lib/ogsf/gsds.c
ogsf lib: fix return types and var types
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c	2012-06-12 13:20:39 UTC (rev 52048)
+++ grass/trunk/lib/ogsf/GS2.c	2012-06-12 13:59:45 UTC (rev 52049)
@@ -1730,13 +1730,13 @@
 	    atty = ATTY_INT;
-	if (0 > gs_malloc_att_buff(gs, att, ATTY_NULL)) {
+	if (0 == gs_malloc_att_buff(gs, att, ATTY_NULL)) {
 	    G_fatal_error(_("GS_load_att_map(): Out of memory. Unable to load map"));
 	switch (atty) {
 	case ATTY_MASK:
-	    if (0 > gs_malloc_att_buff(gs, att, ATTY_MASK)) {
+	    if (0 == gs_malloc_att_buff(gs, att, ATTY_MASK)) {
@@ -1744,7 +1744,7 @@
 	    break;
 	case ATTY_CHAR:
-	    if (0 > gs_malloc_att_buff(gs, att, ATTY_CHAR)) {
+	    if (0 == gs_malloc_att_buff(gs, att, ATTY_CHAR)) {
@@ -1753,7 +1753,7 @@
 	    break;
 	case ATTY_SHORT:
-	    if (0 > gs_malloc_att_buff(gs, att, ATTY_SHORT)) {
+	    if (0 == gs_malloc_att_buff(gs, att, ATTY_SHORT)) {
@@ -1761,7 +1761,7 @@
 				      tbuff->nm, &has_null);
 	    break;
 	case ATTY_FLOAT:
-	    if (0 > gs_malloc_att_buff(gs, att, ATTY_FLOAT)) {
+	    if (0 == gs_malloc_att_buff(gs, att, ATTY_FLOAT)) {
@@ -1771,7 +1771,7 @@
 	    break;
 	case ATTY_INT:
 	default:
-	    if (0 > gs_malloc_att_buff(gs, att, ATTY_INT)) {
+	    if (0 == gs_malloc_att_buff(gs, att, ATTY_INT)) {
@@ -1819,7 +1819,7 @@
 	else if (ATTY_FLOAT == atty) {
 	    if (!reuse) {
Modified: grass/trunk/lib/ogsf/gs.c
--- grass/trunk/lib/ogsf/gs.c	2012-06-12 13:20:39 UTC (rev 52048)
+++ grass/trunk/lib/ogsf/gs.c	2012-06-12 13:59:45 UTC (rev 52049)
@@ -731,7 +731,7 @@
-    return (-1);
+    return 0;
Modified: grass/trunk/lib/ogsf/gsd_img_tif.c
--- grass/trunk/lib/ogsf/gsd_img_tif.c	2012-06-12 13:20:39 UTC (rev 52048)
+++ grass/trunk/lib/ogsf/gsd_img_tif.c	2012-06-12 13:59:45 UTC (rev 52049)
@@ -51,7 +51,7 @@
 int GS_write_tif(const char *name)
     TIFF *out;
-    int y, x;
+    unsigned int y, x;
     unsigned int xsize, ysize;
     int mapsize, linebytes;
     unsigned char *buf, *tmpptr;
@@ -96,7 +96,7 @@
     /* Done with Header Info */
     for (y = 0; y < ysize; y++) {
-	int yy = ysize - y - 1;
+	unsigned int yy = ysize - y - 1;
 	tmpptr = buf;
Modified: grass/trunk/lib/ogsf/gsd_wire.c
--- grass/trunk/lib/ogsf/gsd_wire.c	2012-06-12 13:20:39 UTC (rev 52048)
+++ grass/trunk/lib/ogsf/gsd_wire.c	2012-06-12 13:59:45 UTC (rev 52049)
@@ -485,6 +485,7 @@
     check_color = 1;
+    curcolor = 0;
     coloratt = &(surf->att[ATT_COLOR]);
     col_src = surf->att[ATT_COLOR].att_src;
@@ -690,6 +691,7 @@
     /* will need to check for color source of FUNC_ATT & NOTSET_ATT,
        or else use more general and inefficient gets */
     check_color = 1;
+    curcolor = 0;
Modified: grass/trunk/lib/ogsf/gsds.c
--- grass/trunk/lib/ogsf/gsds.c	2012-06-12 13:20:39 UTC (rev 52048)
+++ grass/trunk/lib/ogsf/gsds.c	2012-06-12 13:59:45 UTC (rev 52049)
@@ -502,11 +502,11 @@
 	case ATTY_NULL:
 	    if (ndims != 2) {
 		/* higher dimension bitmaps not supported */
-		return (-1);
+		return 0;
 	    if (NULL == (ds->databuff.nm = BM_create(dims[1], dims[0]))) {
-		return (-1);
+		return 0;
 	    siz = BM_get_map_size(ds->databuff.nm);
@@ -520,7 +520,7 @@
 	    if (NULL == (ds->databuff.bm = BM_create(dims[1], dims[0]))) {
-		return (-1);
+		return 0;
 	    siz = BM_get_map_size(ds->databuff.bm);
@@ -533,11 +533,11 @@
 	    if (siz) {
 		if (NULL ==
 		    (ds->databuff.cb = (unsigned char *)G_malloc(siz))) {
-		    return (-1);
+		    return 0;
 	    else {
-		return (-1);
+		return 0;
 	    break;
@@ -547,11 +547,11 @@
 	    if (siz) {
 		if (NULL == (ds->databuff.sb = (short *)G_malloc(siz))) {
-		    return (-1);
+		    return 0;
 	    else {
-		return (-1);
+		return 0;
 	    break;
@@ -561,11 +561,11 @@
 	    if (siz) {
 		if (NULL == (ds->databuff.ib = (int *)G_malloc(siz))) {
-		    return (-1);
+		    return 0;
 	    else {
-		return (-1);
+		return 0;
 	    break;
@@ -575,17 +575,17 @@
 	    if (siz) {
 		if (NULL == (ds->databuff.fb = (float *)G_malloc(siz))) {
-		    return (-1);
+		    return 0;
 	    else {
-		return (-1);
+		return 0;
 	    break;
 	default:
-	    return (-1);
+	    return 0;
 	ds->changed = 0;	/* starting with clean slate */
@@ -601,7 +601,7 @@
 	return (siz);
-    return (-1);
+    return 0;
