[GRASS-SVN] r52050 - in grass-addons/grass7/imagery: . i.histo.match
svn_grass at osgeo.org
Tue Jun 12 09:44:20 PDT 2012
Author: lucadelu
Date: 2012-06-12 09:44:19 -0700 (Tue, 12 Jun 2012)
New Revision: 52050
Added:
grass-addons/grass7/imagery/i.histo.match/
grass-addons/grass7/imagery/i.histo.match/Makefile
grass-addons/grass7/imagery/i.histo.match/i.histo.match.html
grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
first release of i.histo.match for histogram matching
Added: grass-addons/grass7/imagery/i.histo.match/Makefile
--- grass-addons/grass7/imagery/i.histo.match/Makefile (rev 0)
+++ grass-addons/grass7/imagery/i.histo.match/Makefile 2012-06-12 16:44:19 UTC (rev 52050)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.histo.match
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/imagery/i.histo.match/i.histo.match.html
--- grass-addons/grass7/imagery/i.histo.match/i.histo.match.html (rev 0)
+++ grass-addons/grass7/imagery/i.histo.match/i.histo.match.html 2012-06-12 16:44:19 UTC (rev 52050)
@@ -0,0 +1,27 @@
+<h2>DESCRIPTION</h2>
+<em>i.histo.match</em> performs histogram matching on the given input images.
+<h2>NOTES</h2>
+The histogram matching method is based on the method Cumulative Distribution
+Function (CDF) of two or more histograms. Each value of original CDF is compared
+with the target histogram in order to obtain the target CDF value closest to
+the original value.
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.ortho.photo.html">i.ortho.photo</a>,
+<a href="i.rectify.html">i.rectify</a>
+</em>
+<h2>AUTHORS</h2>
+Luca Delucchi, Fondazione E. Mach (Italy)
+<p>
+based on original PERL code was
+developed by: Laura Zampa (2004), student of Dipartimento di Informatica e
+Telecomunicazioni, Facolta' di Ingegneria, University of Trento and ITC-irst,
+Trento (Italy)
+<p><i>Last changed: $Date$</i>
\ No newline at end of file
Property changes on: grass-addons/grass7/imagery/i.histo.match/i.histo.match.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
--- grass-addons/grass7/imagery/i.histo.match/i.histo.match.py (rev 0)
+++ grass-addons/grass7/imagery/i.histo.match/i.histo.match.py 2012-06-12 16:44:19 UTC (rev 52050)
@@ -0,0 +1,209 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: i.histo.match
+# AUTHOR(S): Luca Delucchi, Fondazione E. Mach (Italy)
+# original PERL code was developed by:
+# Laura Zampa (2004) student of Dipartimento di Informatica e
+# Telecomunicazioni, Facoltà di Ingegneria,
+# University of Trento and ITC-irst, Trento (Italy)
+# PURPOSE: Calculate histogram matching of several images
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% description: Calculate histogram matching of several images.
+#% keywords: raster
+#%end
+#%option G_OPT_R_INPUTS
+#% description: Name of raster maps to analize
+#% required: yes
+#%end
+#%option G_OPT_R_OUTPUT
+#% description: Suffix for output maps
+#% required: no
+#% answer: match
+#%end
+#%option G_OPT_DB_DATABASE
+#% required : no
+#% answer: $GISDBASE/$LOCATION_NAME/$MAPSET/histo.db
+#%end
+#%option
+#% key: max
+#% type: integer
+#% gisprompt: Number of the maximum value for raster maps
+#% description: Number of the maximum value for raster maps
+#% required: no
+#% answer: 255
+#%end
+import sys, os, sqlite3
+import grass.script as grass
+def main():
+ # split input images
+ images = options['input'].split(',')
+ # number of images
+ n_images = len(images)
+ # database path
+ dbopt = options['database']
+ # output suffix
+ suffix = options['output']
+ # name for average table
+ table_ave = "t%s_average" % suffix
+ # increment of one the maximum value for a correct use of range function
+ max_value = int(options['max']) + 1
+ # if the db path is the default one
+ if dbopt.find('$GISDBASE/$LOCATION_NAME/$MAPSET') == 0:
+ dbopt_split = dbopt.split(os.sep)[-1]
+ env = grass.gisenv()
+ path = os.path.join(env['GISDBASE'],env['LOCATION_NAME'],env['MAPSET'])
+ dbpath = os.path.join(path,dbopt_split)
+ else:
+ if os.access(os.path.dirname(dbopt),os.W_OK):
+ path = os.path.dirname(dbopt)
+ dbpath = dbopt
+ else:
+ grass.fatal(_("Folder to write database files does not" \
+ + " exist or is not writeable"))
+ # connect to the db
+ db = sqlite3.connect(dbpath)
+ curs = db.cursor()
+ # for each image
+ for i in images:
+ # drop table if exist
+ query_drop = "DROP TABLE if exists t%s" % i
+ curs.execute(query_drop)
+ # create table
+ query_create = "CREATE TABLE t%s (grey_value integer,pixel_frequency " % i
+ query_create += "integer, cumulative_histogram integer, cdf real)"
+ curs.execute(query_create)
+ # set the region on the raster
+ grass.run_command('g.region', rast = i)
+ # calculate statistics
+ stats_out = grass.pipe_command('r.stats', flags='c', input= i, fs=':')
+ stats = stats_out.communicate()[0].split('\n')[:-1]
+ stats_dict = dict( s.split(':', 1) for s in stats)
+ cdf = 0
+ # for each number in the range
+ for n in range(0,max_value):
+ # try to insert the values otherwise insert 0
+ try:
+ val = int(stats_dict[str(n)])
+ cdf += val
+ insert = "INSERT INTO t%s VALUES (%i, %i, %i, 0.000000)" % (i, n, val, cdf)
+ curs.execute(insert)
+ except:
+ cdf += 0
+ insert = "INSERT INTO t%s VALUES (%i, 0, %i, 0.000000)" % (i, n, cdf)
+ db.commit()
+ # number of pixel is the cdf value
+ numPixel = cdf
+ # select value for cumulative_histogram for the range number
+ select_ch="SELECT cumulative_histogram FROM t%s WHERE (grey_value=%i)" % (i, n)
+ result = curs.execute(select_ch)
+ val = result.fetchone()[0]
+ # update cdf with new value
+ if val != 0 and numPixel != 0:
+ update_cdf = round(float(val) / float(numPixel),6)
+ update_cdf = "UPDATE t%s SET cdf=%s WHERE (grey_value=%i)" % (i, update_cdf, n)
+ curs.execute(update_cdf)
+ db.commit()
+ db.commit()
+ pixelTot = 0
+ numPixel = 0
+ # for each image
+ for i in images:
+ pixel_freq = "SELECT pixel_frequency FROM t%s WHERE (grey_value=%i)" % (i, n)
+ result = curs.execute(pixel_freq)
+ numPixel += val
+ # calculate number of pixel divide by number of images
+ div = (int(numPixel/n_images))
+ pixelTot += div
+ # drop average table
+ query_drop = "DROP TABLE if exists %s" % table_ave
+ # create average table
+ query_create = "CREATE TABLE %s (grey_value integer,average " % table_ave
+ cHist = 0
+ tot = 0
+ # for each image
+ for i in images:
+ # select pixel frequency
+ tot += val
+ # calculate new value of pixel_frequency
+ average = (tot/n_images)
+ cHist = cHist + int(average)
+ # insert new values into average table
+ if cHist != 0 and pixelTot != 0:
+ cdf = round(float(cHist) / float(pixelTot),6)
+ insert = "INSERT INTO %s VALUES (%i, %i, %i, %s)" % (table_ave, n, int(average), cHist, cdf)
+ db.commit()
+ # for each image
+ for i in images:
+ # write average rules file
+ outfile = open(os.path.join(path,'%s.reclass' % i),'w')
+ new_grey = 0
+ select_min = "SELECT min(abs(a.cdf - b.cdf)) FROM t%s as a," % i \
+ + " %s as b WHERE (a.grey_value=%i)" % (table_ave, n)
+ result_min = curs.execute(select_min)
+ min_abs = result_min.fetchone()[0]
+ select_cdf = "SELECT cdf FROM t%s WHERE grey_value=%i" % (i, n)
+ result_cdf = curs.execute(select_cdf)
+ cdf = result_cdf.fetchone()[0]
+ select_newgrey = "SELECT grey_value FROM %s WHERE " % table_ave \
+ + "cdf=(%s-%s) OR cdf=(%s+%s)" % (cdf,min_abs,cdf,min_abs)
+ # write line with old and new value
+ try:
+ result_new = curs.execute(select_newgrey)
+ new_grey = result_new.fetchone()[0]
+ out_line = "%d = %d\n" % (n, new_grey)
+ outfile.write(out_line)
+ except:
+ outfile.close()
+ outname = '%s.%s' % (i, suffix)
+ # check if a output map already exists
+ result = grass.core.find_file(outname, element = 'cell')
+ if result['fullname'] and grass.overwrite():
+ grass.run_command('g.remove', rast=outname)
+ grass.run_command('r.reclass', input= i, out = outname, rules = outfile.name)
+ elif result['fullname'] and not grass.overwrite():
+ grass.warning(_("Raster map %s already exists and it will be not overwrite" % i))
+ else:
+ # remove the rules file
+ grass.try_remove(outfile.name)
+ db.commit()
+ db.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
+ text/x-python
+ native
