[GRASS-SVN] r52063 - grass-addons/grass6/raster/r.in.onearth
svn_grass at osgeo.org
Wed Jun 13 21:13:28 PDT 2012
Author: hamish
Date: 2012-06-13 21:13:28 -0700 (Wed, 13 Jun 2012)
New Revision: 52063
grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms
the guts of the tile snapping, download, and patching logic
Modified: grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms
--- grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms 2012-06-13 22:14:07 UTC (rev 52062)
+++ grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms 2012-06-14 04:13:28 UTC (rev 52063)
@@ -5,11 +5,11 @@
# written by Soeren Gebbert 11/2005 soerengebbert AT gmx de #
# and Markus Neteler. Support for pre-tiled WMS server by Hamish Bowman #
-# COPYRIGHT: (C) 2005-2012 by the GRASS Development Team #
+# COPYRIGHT: (C) 2005-2012 by the GRASS Development Team #
-# This program is free software under the GNU General Public #
-# License (>=v2). Read the file COPYING that comes with GRASS #
-# for details. #
+# This program is free software under the GNU General Public #
+# License (>=v2). Read the file COPYING that comes with GRASS #
+# for details. #
@@ -139,6 +139,7 @@
eval `g.region -g`
if [ "$nsres" != "$ewres" ] ; then
g.message -e "East-West and North-South region resolution must be the same"
exit 1
@@ -146,24 +147,42 @@
res="$nsres"
fi
-case "$res" in
- 0.125 | 0.25 | 0.5 | 1 | 2 | 4 | 8 | 16 | 32 | 64)
- value="valid"
- value="invalid"
- g.message -e "Resolution must be one of "
- g.message -e " {0.125 0.25 0.5 1 2 4 8 16 32 64}"
- exit 1
-esac
+#### find appropriate tile resolution
+fixed_res="
+0.000244140625
+0.00048828125
+0.0009765625
+0.001953125
+0.00390625
+0.0078125
+0.015625
+0.03125
+0.0625
+0.125
+0.25
+i=-3
+TAKE=9999
+TAKE_i=9999
+MIN=9999
+for val in $fixed_res ; do
+ # find nearest resolution:
+ #DIFF=`echo "$res $val" | awk '{printf("%.15g", $1 > $2 ? $1 - $2 : $2 - $1)}'`
+ # find nearest finer resolution:
+ DIFF=`echo "$res $val" | awk '{printf("%.15g", $1 > $2 ? $1 - $2 : 9999)}'`
+ NEW_MIN_DIFF=`echo "$MIN $DIFF" | awk '{printf("%d", $1 < $2 ? 0 : 1)}'`
+ if [ "$NEW_MIN_DIFF" -eq 1 ] ; then
+ MIN="$DIFF"
+ TAKE="$val"
+ TAKE_i="$i"
+ fi
+ i=`expr $i + 1`
+done
+tile_res=`echo "$TAKE_i" | awk '{printf("%.15g", 2^$1)}'`
+g.message -d message="min_diff=$MIN [2^$TAKE_i = $tile_res ($TAKE * 512)]"
-# start of todo code dump
#### adjust region to snap to grid
# setup internal region
g.region save="tmp_tiled_wms.$$"
@@ -171,142 +190,166 @@
export WIND_OVERRIDE
+g.region res="$TAKE" -a
+eval `g.region -g`
# snap lat,long to upper-left corner of nearest tile grid node
# Round lat to nearest grid node
-#todo: awkify:
-lat = 90.0 - round((90.0 - lat) / $res) * $res;
-lon = -180.0 + floor((180.0 + lon) / $res) * $res;
+#lat = 90.0 - round( (90.0 - lat) / $res) * $res;
+#lon = -180.0 + floor( (180.0 + lon) / $res) * $res;
-#maybe floor() lower left lat/lon, ceil() for upper right lat/lon
+# diff is always positive here, so int() acts like floor().
+n=`echo "$n $tile_res" | \
+ awk '{ printf("%.15g", 90.0 - int((90.0 - $1) / $2) * $2) }'`
+s=`echo "$s $tile_res" | awk '
+ function ceil(x)
+ return (x == int(x)) ? x : int(x)+1
+ printf("%.15g", 90.0 - ceil((90.0 - $1) / $2) * $2)
+e=`echo "$e $tile_res" | \
+ awk '{ printf("%.15g", -180.0 + int((180.0 + $1) / $2) * $2) }'`
+w=`echo "$w $tile_res" | awk '
+ function ceil(x)
+ printf("%.15g", -180.0 + ceil((180.0 + $1) / $2) * $2)
-BASE_URL="http://onearth.jpl.nasa.gov/wms.cgi"
-BASE_REQUEST="request=GetMap&layers=$LAYER&srs=EPSG:4326&width=512&height=512"
-BASE_META="format=image/jpeg&version=1.1.1&styles=$STYLE"
-URL="$BASE_URL?$BASE_REQUEST&$BBOX&$BASE_META"
+#needed?
+#g.region n=$n s=$s e=$e w=$w
-#bbox=minx,miny,maxx,maxy
+NUM_TILES_x=`echo "$e $w $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
+NUM_TILES_y=`echo "$n $s $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
-#top row
-minx=$(echo "$lon $res" | awk '{printf("%.9f", $1 - $2)}')
-miny="$lat"
-maxx="$lon"
-maxy=$(echo "$lat $res" | awk '{printf("%.9f", $1 + $2)}')
-BBOX_11="$minx,$miny,$maxx,$maxy"
+TOTAL_TILES=`expr $NUM_TILES_x \* $NUM_TILES_y`
-minx="$lon"
-miny="$lat"
-maxx=$(echo "$lon $res" | awk '{printf("%.9f", $1 + $2)}')
-BBOX_21="$minx,$miny,$maxx,$maxy"
+if [ "$TOTAL_TILES" -gt 100 ] ; then
+ g.message -w "You've told it to download $TOTAL_TILES tiles from NASA's server. Are you sure you want to do that?"
+ read result
+ case $result in
+ y | yes | Y | Yes | YES)
+ g.message -i "Aborting."
+ exit 1
+ esac
+fi
-minx=$(echo "$lon $res" | awk '{printf("%.9f", $1 + $2)}')
-miny="$lat"
-maxx=$(echo "$lon $res" | awk '{printf("%.9f", $1 + (2 * $2))}')
-BBOX_31="$minx,$miny,$maxx,$maxy"
-#bottom row
-miny=$(echo "$lat $res" | awk '{printf("%.9f", $1 - $2)}')
-maxx="$lon"
-maxy="$lat"
-BBOX_12="$minx,$miny,$maxx,$maxy"
+# start of todo code dump
-minx="$lon"
-maxy="$lat"
-BBOX_22="$minx,$miny,$maxx,$maxy"
-maxy="$lat"
-BBOX_32="$minx,$miny,$maxx,$maxy"
+LAYER="global_mosaic_base"
+STYLE="visual"
+BASE_URL="http://onearth.jpl.nasa.gov/wms.cgi"
+BASE_REQUEST="request=GetMap&layers=$LAYER&srs=EPSG:4326&width=512&height=512"
+BASE_META="format=image/jpeg&version=1.1.1&styles=$STYLE"
-#top row
-URL="$BASE_URL?$BASE_REQUEST&bbox=$BBOX_11&$BASE_META"
-wget -nv "$URL" -O twms_11.jpg &
+# try a few at once, but don't get abusive
+MAX_DL_JOBS=4
-URL="$BASE_URL?$BASE_REQUEST&bbox=$BBOX_21&$BASE_META"
-wget -nv "$URL" -O twms_21.jpg &
+for i in `seq $NUM_TILES_x` ; do
+ i_str=`echo "$i" | awk '{printf("%04d", $1)}'`
+ for j in `seq $NUM_TILES_y` ; do
+ j_str=`echo "$j" | awk '{printf("%04d", $1)}'`
+ minx=$(echo "$w $i $tile_res" | awk '{printf("%.9f", $1 + (($2 - 1) * $3))}')
+ maxx=$(echo "$w $i $tile_res" | awk '{printf("%.9f", $1 + ($2 * $3))}')
+ maxy=$(echo "$n $j $tile_res" | awk '{printf("%.9f", $1 - (($2 - 1) * $3))}')
+ miny=$(echo "$n $j $tile_res" | awk '{printf("%.9f", $1 - ($2 * $3))}')
-URL="$BASE_URL?$BASE_REQUEST&bbox=$BBOX_31&$BASE_META"
-wait
+ BBOX_TILE="$minx,$miny,$maxx,$maxy"
+ BBOX="bbox=$BBOX_TILE"
+ g.message -d message=" $BBOX"
+ URL="$BASE_URL?$BASE_REQUEST&$BBOX&$BASE_META"
-#bottom row
-URL="$BASE_URL?$BASE_REQUEST&bbox=$BBOX_12&$BASE_META"
-wget -nv "$URL" -O twms_12.jpg &
+ CMD="wget -nv \"$URL\" -O twms_${i_str}_${j_str}.jpg"
-URL="$BASE_URL?$BASE_REQUEST&bbox=$BBOX_22&$BASE_META"
-wget -nv "$URL" -O twms_22.jpg &
+ MODULUS=`echo "$j $MAX_DL_JOBS" | awk '{print $1 % $2}'`
+ g.message -d message="modulus=$MODULUS"
+ if [ "$MODULUS" = "0" ] || [ "$j" = "$NUM_TILES_y" ] ; then
+ # stall to let the background jobs finish
+ g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y]."
+ eval $CMD
+ sleep 0.08
+ wait
+ else
+ g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y],"
+ eval $CMD &
+ sleep 0.08
+ fi
+ wait
+ done
+done
-URL="$BASE_URL?$BASE_REQUEST&bbox=$BBOX_32&$BASE_META"
-wait
#### some checks before going on
-if [ `ls -1 twms_*.jpg | wc -l` -lt 6 ] ; then
- echo "ERROR: Tile(s) appear to be missing." 1>&2
- if [ "$verbose" = "true" ] ; then
- fi
- # todo: look to see which one is missing and try again.
- cd ..
- rm -rf "$TEMPDIR2"
+if [ `ls -1 twms_*.jpg | wc -l` -lt "$TOTAL_TILES" ] ; then
+ g.message -e "Tile(s) appear to be missing."
exit 1
fi
for file in twms_*.jpg ; do
if [ ! -s "$file" ] ; then
- echo "ERROR: <$file> appears to be empty." 1>&2
- fi
- cd ..
- exit 1
+ echo "ERROR: <$file> appears to be empty." 1>&2
+ exit 1
fi
if [ `file "$file" | grep -c JPEG` -eq 0 ] ; then
- echo "ERROR: <$file> appears to be bogus." 1>&2
- if [ `file "$file" | grep -c XML` -eq 1 ] && [ "$verbose" = "true" ] ; then
- cat "$file"
- fi
- cd ..
- exit 1
+ echo "ERROR: <$file> appears to be bogus." 1>&2
+ if [ `file "$file" | grep -c XML` -eq 1 ] && [ "$GRASS_VERBOSE" = "true" ] ; then
+ cat "$file"
+ fi
+ exit 1
fi
done
-if [ "$verbose" = "true" ] ; then
- echo "Converting to pnm ..." 1>&2
-fi
+g.message -v "Converting to pnm ..." 1>&2
jpegtopnm "$file" > `basename "$file" .jpg`.pnm
done
- echo "Patching ..." 1>&2
-fi
-pnmcat -lr twms_11.pnm twms_21.pnm twms_31.pnm > row1.pnm
-pnmcat -lr twms_12.pnm twms_22.pnm twms_32.pnm > row2.pnm
-pnmcat -tb row1.pnm row2.pnm | pnmcut 0 0 1280 1024 | \
-rm -f twms_*.pnm twms_*.jpg row[0-9].pnm
+g.message -v "Patching ..." 1>&2
+for j in `seq $NUM_TILES_y` ; do
+ tilefiles=`ls twms_*_${j_str}.pnm`
+ #echo $tilefiles
+ pnmcat -lr $tilefiles > "row_${j_str}.pnm"
+done
+rm -f twms_*.pnm twms_*.jpg row*.pnm
+gdal_translate mosaic_$$.jpg mosaic_$$.tif \
+ -a_srs EPSG:4326 -a_ullr $w $n $e $s
+ #-co COMPRESS=DEFLATE
+r.in.gdal in="mosaic_$$.tif" out="tmp_rio_$$" \
+ title="NASA OnEarth WMS $LAYER ($STYLE)"
+for COLOR in red green blue ; do
+ r.support "tmp_rio_$$.$COLOR" \
+ history="Data downloaded from NASA's OnEarth WMS server with r.in.onearth"
+done
+# free up the disk space ASAP
+\rm "mosaic_$$.tif"
# end of todo code dump
@@ -351,19 +394,19 @@
WarpData()
if [ "$USE_GDALWARP" = "true" ] ; then
- g.message -v "**** CONVERT DATA ****"
- #create the new imagename
+ g.message -v "**** CONVERT DATA ****"
+ #create the new imagename
IMAGEFILE_GDALWARP="$TMPDIR/Image_${LAYER}_${STYLE}_${HEIGHT}_${WIDTH}_gdalwarp"
- #convert the data to the current location, create Erdas Imagine Images (HFA)
+ #convert the data to the current location, create Erdas Imagine Images (HFA)
gdalwarp -s_srs "$SRC" -t_srs "`g.proj -wf`" -of HFA \
"$IMAGEFILE" "$IMAGEFILE_GDALWARP"
if [ $? -ne 0 ] ; then
- g.message -i '!-------- CAN NOT CONVERT DATA --------!'
- g.message -i '!------------ WILL BREAK --------------!'
+ g.message -i '!-------- CAN NOT CONVERT DATA --------!'
+ g.message -i '!------------ WILL BREAK --------------!'
exitprocedure
fi
- g.message -v "**** DATA CONVERTED ****"
+ g.message -v "**** DATA CONVERTED ****"
#remove the old image and convert the name
rm -f "$IMAGEFILE"
IMAGEFILE="$IMAGEFILE_GDALWARP"
@@ -417,9 +460,9 @@
g.message " "
g.message "Message from Server $NASASERVER"
echo " "
- echo '!------------BEGIN-ERROR-MESSGAE--------------!'
+ echo '!------------BEGIN-ERROR-MESSGAE--------------!'
cat "$IMAGEFILE"
- echo '!-------------END-ERROR-MESSGAE---------------!'
+ echo '!-------------END-ERROR-MESSGAE---------------!'
fi
fi
rm -rf "$IMAGEFILE"
@@ -450,7 +493,7 @@
#Check if a file or a map should be created
if [ "$GIS_FLAG_F" -eq 1 ] ; then
if [ -z "$GIS_OPT_FILE"] ; then
- g.message -e "Please specify the output filename"
+ g.message -e "Please specify the output filename"
exit 1
fi
fi
@@ -502,7 +545,7 @@
grep -i 'proj: ll' "$PERM/PROJ_INFO" > /dev/null
if [ $? -ne 0 ] && [ "$USE_GDALWARP" = "false" ] ; then
g.message -e "NASA OnEarth data are in Latitude/Longitude. The \
- current location projection differs and you don't \
+ current location projection differs and you don't \
have gdalwarp! STOP."
exit 1
fi
