[GRASS-SVN] r52064 - grass-addons/grass6/raster/r.in.onearth
svn_grass at osgeo.org
Wed Jun 13 23:35:44 PDT 2012
Author: hamish
Date: 2012-06-13 23:35:44 -0700 (Wed, 13 Jun 2012)
New Revision: 52064
grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms
a couple of bug fixes
Modified: grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms
--- grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms 2012-06-14 04:13:28 UTC (rev 52063)
+++ grass-addons/grass6/raster/r.in.onearth/r.in.onearth.twms 2012-06-14 06:35:44 UTC (rev 52064)
@@ -178,11 +178,15 @@
fi
i=`expr $i + 1`
done
+if [ "$MIN" = "9999" ] ; then
+ #finer than the finest tested
+ TAKE_i=-3
+ TAKE=0.000244140625
+fi
tile_res=`echo "$TAKE_i" | awk '{printf("%.15g", 2^$1)}'`
-g.message -d message="min_diff=$MIN [2^$TAKE_i = $tile_res ($TAKE * 512)]"
+g.message -i message="min_diff=$MIN [2^$TAKE_i = $tile_res ($TAKE * 512)]"
#### adjust region to snap to grid
# setup internal region
g.region save="tmp_tiled_wms.$$"
@@ -210,9 +214,9 @@
printf("%.15g", 90.0 - ceil((90.0 - $1) / $2) * $2)
-e=`echo "$e $tile_res" | \
+w=`echo "$w $tile_res" | \
awk '{ printf("%.15g", -180.0 + int((180.0 + $1) / $2) * $2) }'`
-w=`echo "$w $tile_res" | awk '
+e=`echo "$e $tile_res" | awk '
function ceil(x)
return (x == int(x)) ? x : int(x)+1
@@ -224,12 +228,13 @@
#needed?
#g.region n=$n s=$s e=$e w=$w
+#NUM_TILES_x=`echo "$e $w $tile_res" | awk '{ printf("%d", 1 + (($1 - $2) / $3)) }'`
+#NUM_TILES_y=`echo "$n $s $tile_res" | awk '{ printf("%d", 1 + (($1 - $2) / $3)) }'`
NUM_TILES_x=`echo "$e $w $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
NUM_TILES_y=`echo "$n $s $tile_res" | awk '{ printf("%d", ($1 - $2) / $3) }'`
TOTAL_TILES=`expr $NUM_TILES_x \* $NUM_TILES_y`
-if [ "$TOTAL_TILES" -gt 100 ] ; then
+if [ "$TOTAL_TILES" -gt 200 ] ; then
g.message -w "You've told it to download $TOTAL_TILES tiles from NASA's server. Are you sure you want to do that?"
read result
case $result in
@@ -278,15 +283,13 @@
MODULUS=`echo "$j $MAX_DL_JOBS" | awk '{print $1 % $2}'`
g.message -d message="modulus=$MODULUS"
if [ "$MODULUS" = "0" ] || [ "$j" = "$NUM_TILES_y" ] ; then
- # stall to let the background jobs finish
- g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y]."
- eval $CMD
- sleep 0.08
- wait
+ # stall to let the background jobs finish
+ g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y]."
+ eval $CMD
+ wait
else
- g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y],"
- eval $CMD &
- sleep 0.08
+ g.message -v "Downloading tile [$i,$j] of [${NUM_TILES_x}x$NUM_TILES_y],"
+ eval $CMD &
fi
wait
done
@@ -333,8 +336,12 @@
rm -f twms_*.pnm twms_*.jpg row*.pnm
+#not needed
+#far_e=$(echo "$e $tile_res" | awk '{printf("%.9f", $1 + $2)}')
+#far_s=$(echo "$s $tile_res" | awk '{printf("%.9f", $1 - $2)}')
gdal_translate mosaic_$$.jpg mosaic_$$.tif \
- -a_srs EPSG:4326 -a_ullr $w $n $e $s
+ -a_srs EPSG:4326 -a_ullr $w $n $e $s
#-co COMPRESS=DEFLATE
r.in.gdal in="mosaic_$$.tif" out="tmp_rio_$$" \
