[GRASS-SVN] r52117 - grass/branches/develbranch_6/scripts/i.landsat.rgb
svn_grass at osgeo.org
Mon Jun 18 00:07:32 PDT 2012
Author: hamish
Date: 2012-06-18 00:07:32 -0700 (Mon, 18 Jun 2012)
New Revision: 52117
grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb
make it run twice as fast by combining similar r.univar calls
Modified: grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb
--- grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb 2012-06-18 00:17:05 UTC (rev 52116)
+++ grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb 2012-06-18 07:07:32 UTC (rev 52117)
@@ -10,7 +10,7 @@
# PURPOSE: create pretty LANDSAT RGBs: the trick is to remove outliers
# using percentiles (area under the histogram curve)
-# COPYRIGHT: (C) 2006-2008 by the GRASS Development Team
+# COPYRIGHT: (C) 2006-2012 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -120,11 +120,14 @@
exit 0
fi
+BRI_VAR_STR=percentile_`echo "$BRIGHTNESS" | awk '{printf("%.15g", $1)}' | tr '.' '_'`
if [ 0 -eq $GIS_FLAG_P ] ; then
for i in $RED $GREEN $BLUE ; do
g.message "Processing <$i>..."
- MIN=`r.univar -ge $i perc=2 | grep "^percentile_" | cut -d'=' -f2`
- MAX=`r.univar -ge $i perc=$BRIGHTNESS | grep "^percentile_" | cut -d'=' -f2`
+ eval `r.univar -ge "$i" perc=2,"$BRIGHTNESS" | grep '^percentile_'`
+ MIN="$percentile_2"
+ eval `echo "MAX=\"\\$\$BRI_VAR_STR\""`
g.message -d message="<$i>: min=$MIN max=$MAX"
r.colors $i col=rules << EOF
0% black
@@ -138,8 +141,9 @@
ALL_MIN=999999
ALL_MAX=`echo "$MAX $ALL_MAX" | awk '{if ($1 > $2) print $1; else print $2}'`
ALL_MIN=`echo "$MIN $ALL_MIN" | awk '{if ($1 < $2) print $1; else print $2}'`
@@ -157,20 +161,20 @@
# write cmd history (only if raster maps are located in the current mapset)
CURRENT_MAPSET=`g.gisenv MAPSET`
-RED_MAPSET=`g.findfile -n elem=cell file=$RED | grep mapset | cut -d'=' -f2`
-BLUE_MAPSET=`g.findfile -n elem=cell file=$BLUE | grep mapset | cut -d'=' -f2`
-GREEN_MAPSET=`g.findfile -n elem=cell file=$GREEN | grep mapset | cut -d'=' -f2`
+RED_MAPSET=`g.findfile -n elem=cell file="$RED" | grep mapset | cut -d'=' -f2`
+BLUE_MAPSET=`g.findfile -n elem=cell file="$BLUE" | grep mapset | cut -d'=' -f2`
+GREEN_MAPSET=`g.findfile -n elem=cell file="$GREEN" | grep mapset | cut -d'=' -f2`
if [ "$BLUE_MAPSET" = "$CURRENT_MAPSET" ] ; then
- r.support ${BLUE} history="${CMDLINE}"
+ r.support "$BLUE" history="${CMDLINE}"
fi
if [ "$GREEN_MAPSET" = "$CURRENT_MAPSET" ] ; then
- r.support ${GREEN} history="${CMDLINE}"
+ r.support "$GREEN" history="${CMDLINE}"
fi
if [ "$RED_MAPSET" = "$CURRENT_MAPSET" ] ; then
- r.support ${RED} history="${CMDLINE}"
+ r.support "$RED" history="${CMDLINE}"
fi
exit 0
