[GRASS-SVN] r52118 - grass/branches/develbranch_6/scripts/i.landsat.rgb
Mon Jun 18 01:16:05 PDT 2012
Author: hamish
Date: 2012-06-18 01:16:05 -0700 (Mon, 18 Jun 2012)
New Revision: 52118
   grass/branches/develbranch_6/scripts/i.landsat.rgb/description.html
   grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb
parallelize module, speeding it up 3x more (but using 3x the RAM)
Modified: grass/branches/develbranch_6/scripts/i.landsat.rgb/description.html
--- grass/branches/develbranch_6/scripts/i.landsat.rgb/description.html	2012-06-18 07:07:32 UTC (rev 52117)
+++ grass/branches/develbranch_6/scripts/i.landsat.rgb/description.html	2012-06-18 08:16:05 UTC (rev 52118)
@@ -27,7 +27,12 @@
 similar results by switching to a coarser resolution before the running of
 the module (using <em>g.region</em>) and then back to the original resolution
 afterwards.
+<p>
+By default the module will process all three R,G,B bands in parallel. To
+run serially use the <b>-s</b> flag. Parallel mode requires three times the
+memory while running, but takes one third of the time to complete.
 <h2>EXAMPLE</h2>
 North Carolina sample dataset example:
Modified: grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb
--- grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb	2012-06-18 07:07:32 UTC (rev 52117)
+++ grass/branches/develbranch_6/scripts/i.landsat.rgb/i.landsat.rgb	2012-06-18 08:16:05 UTC (rev 52118)
@@ -64,6 +64,10 @@
 #% key: r
 #% description: Reset to standard color range
 #%end
+#%flag
+#% key: s
+#% description: Process bands serially (default: run in parallel)
+#%end
 if [ -z "$GISBASE" ] ; then
@@ -123,31 +127,102 @@
 BRI_VAR_STR=percentile_`echo "$BRIGHTNESS" | awk '{printf("%.15g", $1)}' | tr '.' '_'`
 if [ 0 -eq $GIS_FLAG_P ] ; then
-   for i in $RED $GREEN $BLUE ; do
-      g.message "Processing <$i>..."
-      eval `r.univar -ge "$i" perc=2,"$BRIGHTNESS" | grep '^percentile_'`
-      MIN="$percentile_2"
-      eval `echo "MAX=\"\\$\$BRI_VAR_STR\""`
-      g.message -d message="<$i>:  min=$MIN   max=$MAX"
-      r.colors $i col=rules << EOF
+   if [ 1 -eq $GIS_FLAG_S ] ; then
+      # Unlocked, run serially
+      for i in $RED $GREEN $BLUE ; do
+   	 g.message "Processing <$i>..."
+   	 eval `r.univar -ge "$i" perc=2,"$BRIGHTNESS" | grep '^percentile_'`
+   	 MIN="$percentile_2"
+   	 eval `echo "MAX=\"\\$\$BRI_VAR_STR\""`
+   	 g.message -d message="<$i>:  min=$MIN   max=$MAX"
+   	 r.colors $i col=rules << EOF
+   	   0% black
+   	   $MIN black
+   	   $MAX white
+   	   100% white
+EOF
+         done
+   else
+      # Unlocked, run in parallel
+      g.message "Processing ..."
+      eval `(
+        r.univar -ge "$RED"   perc=2,"$BRIGHTNESS" | grep '^percentile_' | sed -e 's/^/R_/' &
+        r.univar -ge "$GREEN" perc=2,"$BRIGHTNESS" | grep '^percentile_' | sed -e 's/^/G_/' &
+        r.univar -ge "$BLUE"  perc=2,"$BRIGHTNESS" | grep '^percentile_' | sed -e 's/^/B_/'
+        wait
+      R_MIN="$R_percentile_2"
+      eval `echo "R_MAX=\"\\$R_\$BRI_VAR_STR\""`
+      G_MIN="$G_percentile_2"
+      eval `echo "G_MAX=\"\\$G_\$BRI_VAR_STR\""`
+      B_MIN="$B_percentile_2"
+      eval `echo "B_MAX=\"\\$B_\$BRI_VAR_STR\""`
+      r.colors "$RED" col=rules << EOF
 	0% black
-	$MIN black
-	$MAX white
+	$R_MIN black
+	$R_MAX white
 	100% white
 EOF
+      r.colors "$GREEN" col=rules << EOF
+	0% black
+	$G_MIN black
+	$G_MAX white
+	100% white
+EOF
+       r.colors "$BLUE" col=rules << EOF
+	0% black
+	$B_MIN black
+	$B_MAX white
+	100% white
+EOF
+   fi
+else
+      # Bands are locked, run serially
+      # we can combine all 3 bands into one r.univar call:
+      # [disabled: uses 3x the RAM and actually runs slightly slower than 3 in a row]
+      #eval `r.univar -ge "$RED,$GREEN,$BLUE" perc=2,"$BRIGHTNESS" | grep '^percentile_'`
+      #ALL_MIN="$percentile_2"
+      #eval `echo "ALL_MAX=\"\\$\$BRI_VAR_STR\""`
+      # using 3 separate r.univar calls:
+      ALL_MAX=0
+      ALL_MIN=999999
+   	 ALL_MAX=`echo "$MAX $ALL_MAX" | awk '{if ($1 > $2) print $1; else print $2}'`
+   	 ALL_MIN=`echo "$MIN $ALL_MIN" | awk '{if ($1 < $2) print $1; else print $2}'`
       done
-else
-   ALL_MAX=0
-   ALL_MIN=999999
-      ALL_MAX=`echo "$MAX $ALL_MAX" | awk '{if ($1 > $2) print $1; else print $2}'`
-      ALL_MIN=`echo "$MIN $ALL_MIN" | awk '{if ($1 < $2) print $1; else print $2}'`
-   done
+   else
+      # Bands are locked, run in parallel
+      eval `(
+        wait
+      ALL_MAX=0
+      ALL_MIN=999999
+      for i in R G B ; do
+         eval `echo "MIN=\"\\$\${i}_percentile_2\""`
+         eval `echo "MAX=\"\\$\${i}_\$BRI_VAR_STR\""`
+      done
+   fi
    g.message -d message="all_min=$ALL_MIN   all_max=$ALL_MAX"
