[GRASS-SVN] r52139 - grass/branches/develbranch_6/lib/vector/neta
svn_grass at osgeo.org
Tue Jun 19 09:30:16 PDT 2012
Author: mmetz
Date: 2012-06-19 09:30:15 -0700 (Tue, 19 Jun 2012)
New Revision: 52139
grass/branches/develbranch_6/lib/vector/neta/utils.c
netalib: backport fixes from trunk
Modified: grass/branches/develbranch_6/lib/vector/neta/utils.c
--- grass/branches/develbranch_6/lib/vector/neta/utils.c 2012-06-19 16:29:39 UTC (rev 52138)
+++ grass/branches/develbranch_6/lib/vector/neta/utils.c 2012-06-19 16:30:15 UTC (rev 52139)
@@ -174,7 +174,7 @@
for (i = 1; i <= nnodes; i++)
nodes_to_features[i] = -1;
- for (i = 1; i <= nlines; i++)
+ for (i = 1; i <= nlines; i++) {
if (varray->c[i]) {
int type = Vect_read_line(map, NULL, NULL, i);
@@ -196,6 +196,7 @@
nodes_to_features[node1] = nodes_to_features[node2] = i;
@@ -208,39 +209,58 @@
\param cat ?
\param[out] pointer to varray structure
- \return ?
+ \return number of items set
+ \return -1 on error
int NetA_initialise_varray(struct Map_info *In, int layer, int mask_type,
char *where, char *cat, struct varray **varray)
+ int n, ni;
+ if (layer < 1)
+ G_fatal_error(_("'%s' must be > 0"), "layer");
+ n = Vect_get_num_lines(In);
+ *varray = Vect_new_varray(n);
+ ni = 0;
/* parse filter option and select appropriate lines */
if (where) {
- if (layer < 1)
- G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
if (cat)
G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
- *varray = Vect_new_varray(Vect_get_num_lines(In));
- if (Vect_set_varray_from_db
- (In, layer, where, mask_type, 1, *varray) == -1) {
+ ni = Vect_set_varray_from_db(In, layer, where, mask_type, 1, *varray);
+ if (ni == -1) {
G_warning(_("Unable to load data from database"));
- return 0;
- return 1;
+ return ni;
else if (cat) {
- if (layer < 1)
- G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "cat");
- if (Vect_set_varray_from_cat_string
- (In, layer, cat, mask_type, 1, *varray) == -1) {
+ ni = Vect_set_varray_from_cat_string(In, layer, cat, mask_type, 1, *varray);
+ if (ni == -1) {
G_warning(_("Problem loading category values"));
- return 0;
- return 1;
+ return ni;
- else {
- return 2;
+ else { /* all features of given layer */
+ int i, cat;
+ int ltype; /* line type */
+ struct line_cats *Cats;
+ Cats = Vect_new_cats_struct();
+ for (i = 1; i <= n; i++) {
+ ltype = Vect_read_line(In, NULL, Cats, i);
+ if (!(ltype & mask_type))
+ continue; /* is not specified type */
+ if (Vect_cat_get(Cats, layer, &cat)) {
+ (*varray)->c[i] = 1;
+ ni++;
+ Vect_destroy_cats_struct(Cats);
+ return ni;
