[GRASS-SVN] r52140 - grass/branches/develbranch_6/vector/v.net.distance
svn_grass at osgeo.org
Tue Jun 19 09:31:12 PDT 2012
Author: mmetz
Date: 2012-06-19 09:31:12 -0700 (Tue, 19 Jun 2012)
New Revision: 52140
grass/branches/develbranch_6/vector/v.net.distance/main.c
v.net.distance: backport fixes from trunk, keep compatibility
Modified: grass/branches/develbranch_6/vector/v.net.distance/main.c
--- grass/branches/develbranch_6/vector/v.net.distance/main.c 2012-06-19 16:30:15 UTC (rev 52139)
+++ grass/branches/develbranch_6/vector/v.net.distance/main.c 2012-06-19 16:31:12 UTC (rev 52140)
@@ -29,7 +29,7 @@
struct Map_info In, Out;
static struct line_pnts *Points;
- struct line_cats *Cats;
+ struct line_cats *Cats, *TCats;
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *map_in, *map_out, *abcol, *afcol;
struct Option *catf_opt, *fieldf_opt, *wheref_opt;
@@ -43,6 +43,7 @@
struct ilist *nodest;
int i, nnodes, nlines;
int *dst, *nodes_to_features;
+ int from_nr; /* 'from' features not reachable */
dglInt32_t **prev;
struct line_cats **on_path;
char buf[2000];
@@ -61,8 +62,8 @@
module->label = _("Computes shortest distance via the network between "
"the given sets of features.");
module->description =
- _("Finds the shortest paths from a feature 'to' to every feature 'from' "
- "and various information about this realtion are uploaded to the attribute table.");
+ _("Finds the shortest paths from a point 'from' to every feature 'to' "
+ "and various information about this relation are uploaded to the attribute table.");
/* Define the different options as defined in gis.h */
map_in = G_define_standard_option(G_OPT_V_INPUT);
@@ -109,7 +110,7 @@
afcol = G_define_standard_option(G_OPT_COLUMN);
afcol->key = "afcolumn";
- afcol->required = YES;
+ afcol->required = NO;
afcol->description = _("Arc forward/both direction(s) cost column");
abcol = G_define_standard_option(G_OPT_COLUMN);
@@ -130,6 +131,7 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
+ TCats = Vect_new_cats_struct();
Vect_check_input_output_name(map_in->answer, map_out->answer,
GV_FATAL_EXIT);
@@ -173,15 +175,25 @@
/*initialise varrays and nodes list appropriatelly */
flayer = atoi(fieldf_opt->answer);
tlayer = atoi(fieldt_opt->answer);
- NetA_initialise_varray(&In, flayer, GV_POINT, wheref_opt->answer,
- catf_opt->answer, &varrayf);
- NetA_initialise_varray(&In, tlayer, mask_type, wheret_opt->answer,
- catt_opt->answer, &varrayt);
+ if (NetA_initialise_varray(&In, flayer, GV_POINT, wheref_opt->answer,
+ catf_opt->answer, &varrayf) <= 0) {
+ G_fatal_error(_("No 'from' features selected. "
+ "Please check options '%s', '%s', '%s'."),
+ fieldf_opt->key, wheref_opt->key, catf_opt->key);
+ if (NetA_initialise_varray(&In, tlayer, mask_type, wheret_opt->answer,
+ catt_opt->answer, &varrayt) <= 0) {
+ G_fatal_error(_("No 'to' features selected. "
+ fieldt_opt->key, wheret_opt->key, catt_opt->key);
nodest = Vect_new_list();
NetA_varray_to_nodes(&In, varrayt, nodest, nodes_to_features);
- Vect_net_build_graph(&In, mask_type, 1, 0, afcol->answer, abcol->answer,
+ Vect_net_build_graph(&In, GV_LINES, 1, 0, afcol->answer, abcol->answer,
NULL, geo, 0);
graph = &(In.graph);
NetA_distance_from_points(graph, nodest, dst, prev);
@@ -221,8 +233,8 @@
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
- for (i = 1; i <= nlines; i++)
+ from_nr = 0;
+ for (i = 1; i <= nlines; i++) {
if (varrayf->c[i]) {
int type = Vect_read_line(&In, Points, Cats, i);
int node, tcat, cat;
@@ -232,7 +244,11 @@
if (!Vect_cat_get(Cats, flayer, &cat))
continue;
Vect_get_line_nodes(&In, i, &node, NULL);
- Vect_write_line(&Out, type, Points, Cats);
+ if (dst[node] < 0) {
+ /* unreachable */
+ from_nr++;
+ continue;
cost = dst[node] / (double)In.cost_multip;
vertex = dglGetNode(graph, node);
vertex_id = node;
@@ -243,9 +259,12 @@
vertex = dglEdgeGet_Head(graph, prev[vertex_id]);
vertex_id = dglNodeGet_Id(graph, vertex);
- Vect_read_line(&In, NULL, Cats, nodes_to_features[vertex_id]);
- if (!Vect_cat_get(Cats, tlayer, &tcat))
+ G_debug(3, "read line %d, vertex id %d", nodes_to_features[vertex_id], (int)vertex_id);
+ Vect_read_line(&In, NULL, TCats, nodes_to_features[vertex_id]);
+ if (!Vect_cat_get(TCats, tlayer, &tcat))
continue;
+ Vect_write_line(&Out, type, Points, Cats);
sprintf(buf, "insert into %s values (%d, %d, %f)", Fi->table, cat,
tcat, cost);
@@ -257,6 +276,7 @@
db_get_string(&sql));
if (on_path[i]->n_cats > 0) {
@@ -280,5 +300,8 @@
G_free(dst);
G_free(prev);
+ if (from_nr)
+ G_warning(_("%d 'from' features were not reachable"), from_nr);
exit(EXIT_SUCCESS);
