[GRASS-SVN] r52168 - in grass/trunk/vector: v.net.allpairs v.net.centrality v.net.connectivity v.net.distance v.net.flow
svn_grass at osgeo.org
Wed Jun 20 07:47:15 PDT 2012
Author: mmetz
Date: 2012-06-20 07:47:15 -0700 (Wed, 20 Jun 2012)
New Revision: 52168
grass/trunk/vector/v.net.allpairs/main.c
grass/trunk/vector/v.net.centrality/main.c
grass/trunk/vector/v.net.connectivity/main.c
grass/trunk/vector/v.net.distance/main.c
grass/trunk/vector/v.net.flow/main.c
v.net modules: add safety checks
Modified: grass/trunk/vector/v.net.allpairs/main.c
--- grass/trunk/vector/v.net.allpairs/main.c 2012-06-20 14:35:14 UTC (rev 52167)
+++ grass/trunk/vector/v.net.allpairs/main.c 2012-06-20 14:47:15 UTC (rev 52168)
@@ -145,10 +145,13 @@
afield = Vect_get_field_number(&In, afield_opt->answer);
nfield = Vect_get_field_number(&In, nfield_opt->answer);
- chcat =
- (NetA_initialise_varray
- (&In, nfield, GV_POINT, where_opt->answer, cat_opt->answer,
- &varray) == 1);
+ if (where_opt->answer || cat_opt->answer) {
+ chcat = (NetA_initialise_varray(&In, nfield, GV_POINT,
+ where_opt->answer,
+ cat_opt->answer, &varray) > 0);
+ else
+ chcat = 0;
/* Create table */
Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
Modified: grass/trunk/vector/v.net.centrality/main.c
--- grass/trunk/vector/v.net.centrality/main.c 2012-06-20 14:35:14 UTC (rev 52167)
+++ grass/trunk/vector/v.net.centrality/main.c 2012-06-20 14:47:15 UTC (rev 52168)
@@ -228,10 +228,13 @@
- chcat =
- (&In, afield, mask_type, where_opt->answer, cat_opt->answer,
- &varray) == 1);
+ chcat = (NetA_initialise_varray(&In, afield, GV_POINT,
+ else
+ chcat = 0;
/* Create table */
@@ -340,11 +343,10 @@
if (type == GV_POINT && (!chcat || varray->c[i])) {
int cat, node;
- if (!Vect_cat_get(Cats, afield, &cat))
+ if (!Vect_cat_get(Cats, nfield, &cat))
continue;
Vect_write_line(&Out, type, Points, Cats);
node = Vect_find_node(&In, Points->x[0], Points->y[0], Points->z[0], 0, 0);
- /* Vect_get_line_nodes(&In, i, &node, NULL); */
process_node(node, cat);
covered[node] = 1;
Modified: grass/trunk/vector/v.net.connectivity/main.c
--- grass/trunk/vector/v.net.connectivity/main.c 2012-06-20 14:35:14 UTC (rev 52167)
+++ grass/trunk/vector/v.net.connectivity/main.c 2012-06-20 14:47:15 UTC (rev 52168)
@@ -144,14 +144,18 @@
if (NetA_initialise_varray
(&In, nfield, GV_POINT, whereset1_opt->answer,
- catset1_opt->answer, &varray_set1) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catset1_opt->key,
- whereset1_opt->key);
+ catset1_opt->answer, &varray_set1) <= 0) {
+ G_fatal_error(_("No features for %s selected. "
+ "Please check options '%s', '%s'."),
+ "set1", catset1_opt->key, whereset1_opt->key);
(&In, nfield, GV_POINT, whereset2_opt->answer,
- catset2_opt->answer, &varray_set2) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catset2_opt->key,
- whereset2_opt->key);
+ catset2_opt->answer, &varray_set2) <= 0) {
+ "set2", catset2_opt->key, whereset2_opt->key);
set1_list = Vect_new_list();
set2_list = Vect_new_list();
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2012-06-20 14:35:14 UTC (rev 52167)
+++ grass/trunk/vector/v.net.distance/main.c 2012-06-20 14:47:15 UTC (rev 52168)
@@ -230,6 +230,9 @@
nodest = Vect_new_list();
NetA_varray_to_nodes(&In, varrayt, nodest, nodes_to_features);
+ if (nodest->n_values == 0)
+ G_fatal_error(_("No 'to' features"));
Vect_net_build_graph(&In, atype, afield, nfield, afcol->answer, abcol->answer,
ncol->answer, geo, 0);
Modified: grass/trunk/vector/v.net.flow/main.c
--- grass/trunk/vector/v.net.flow/main.c 2012-06-20 14:35:14 UTC (rev 52167)
+++ grass/trunk/vector/v.net.flow/main.c 2012-06-20 14:47:15 UTC (rev 52168)
@@ -194,16 +194,19 @@
- wheresource_opt->answer, catsource_opt->answer, &varray_source) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catsource_opt->key,
- wheresource_opt->key);
+ wheresource_opt->answer, catsource_opt->answer, &varray_source) <= 0) {
+ G_fatal_error(_("No source features selected. "
+ catsource_opt->key, wheresource_opt->key);
(&In, nfield, GV_POINT, wheresink_opt->answer,
- catsink_opt->answer, &varray_sink) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catsink_opt->key,
- wheresink_opt->key);
+ catsink_opt->answer, &varray_sink) <= 0) {
+ G_fatal_error(_("No sink features selected. "
+ catsink_opt->key, wheresink_opt->key);
NetA_varray_to_nodes(&In, varray_source, source_list, NULL);
NetA_varray_to_nodes(&In, varray_sink, sink_list, NULL);
