[GRASS-SVN] r52169 - in grass/branches/develbranch_6/vector: v.net.allpairs v.net.centrality v.net.connectivity v.net.distance v.net.flow
svn_grass at osgeo.org
Wed Jun 20 09:34:48 PDT 2012
Author: mmetz
Date: 2012-06-20 09:34:48 -0700 (Wed, 20 Jun 2012)
New Revision: 52169
grass/branches/develbranch_6/vector/v.net.allpairs/main.c
grass/branches/develbranch_6/vector/v.net.centrality/main.c
grass/branches/develbranch_6/vector/v.net.connectivity/main.c
grass/branches/develbranch_6/vector/v.net.distance/main.c
grass/branches/develbranch_6/vector/v.net.flow/main.c
v.net modules: partial backport from trunk
Modified: grass/branches/develbranch_6/vector/v.net.allpairs/main.c
--- grass/branches/develbranch_6/vector/v.net.allpairs/main.c 2012-06-20 14:47:15 UTC (rev 52168)
+++ grass/branches/develbranch_6/vector/v.net.allpairs/main.c 2012-06-20 16:34:48 UTC (rev 52169)
@@ -126,11 +126,16 @@
/* parse filter option and select appropriate lines */
layer = atoi(field_opt->answer);
- chcat =
- (NetA_initialise_varray
- (&In, layer, GV_POINT, where_opt->answer, cat_opt->answer,
- &varray) == 1);
+ if (where_opt->answer || cat_opt->answer) {
+ chcat = (NetA_initialise_varray(&In, layer, GV_POINT,
+ where_opt->answer,
+ cat_opt->answer, &varray) > 0);
+ else
+ chcat = 0;
/* Create table */
Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
Vect_map_add_dblink(&Out, 1, NULL, Fi->table, "cat", Fi->database,
Modified: grass/branches/develbranch_6/vector/v.net.centrality/main.c
--- grass/branches/develbranch_6/vector/v.net.centrality/main.c 2012-06-20 14:47:15 UTC (rev 52168)
+++ grass/branches/develbranch_6/vector/v.net.centrality/main.c 2012-06-20 16:34:48 UTC (rev 52169)
@@ -205,10 +205,13 @@
- chcat =
- (&In, layer, mask_type, where_opt->answer, cat_opt->answer,
- &varray) == 1);
+ else
+ chcat = 0;
/* Create table */
Modified: grass/branches/develbranch_6/vector/v.net.connectivity/main.c
--- grass/branches/develbranch_6/vector/v.net.connectivity/main.c 2012-06-20 14:47:15 UTC (rev 52168)
+++ grass/branches/develbranch_6/vector/v.net.connectivity/main.c 2012-06-20 16:34:48 UTC (rev 52169)
@@ -126,14 +126,18 @@
if (NetA_initialise_varray
(&In, atoi(fieldset1_opt->answer), GV_POINT, whereset1_opt->answer,
- catset1_opt->answer, &varray_set1) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catset1_opt->key,
- whereset1_opt->key);
+ catset1_opt->answer, &varray_set1) <= 0) {
+ G_fatal_error(_("No features for %s selected. "
+ "Please check options '%s', '%s'."),
+ "set1", catset1_opt->key, whereset1_opt->key);
(&In, atoi(fieldset2_opt->answer), GV_POINT, whereset2_opt->answer,
- catset2_opt->answer, &varray_set2) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catset2_opt->key,
- whereset2_opt->key);
+ catset2_opt->answer, &varray_set2) <= 0) {
+ "set2", catset2_opt->key, whereset2_opt->key);
set1_list = Vect_new_list();
set2_list = Vect_new_list();
Modified: grass/branches/develbranch_6/vector/v.net.distance/main.c
--- grass/branches/develbranch_6/vector/v.net.distance/main.c 2012-06-20 14:47:15 UTC (rev 52168)
+++ grass/branches/develbranch_6/vector/v.net.distance/main.c 2012-06-20 16:34:48 UTC (rev 52169)
@@ -193,6 +193,9 @@
nodest = Vect_new_list();
NetA_varray_to_nodes(&In, varrayt, nodest, nodes_to_features);
+ if (nodest->n_values == 0)
+ G_fatal_error(_("No 'to' features"));
Vect_net_build_graph(&In, GV_LINES, 1, 0, afcol->answer, abcol->answer,
NULL, geo, 0);
graph = &(In.graph);
Modified: grass/branches/develbranch_6/vector/v.net.flow/main.c
--- grass/branches/develbranch_6/vector/v.net.flow/main.c 2012-06-20 14:47:15 UTC (rev 52168)
+++ grass/branches/develbranch_6/vector/v.net.flow/main.c 2012-06-20 16:34:48 UTC (rev 52169)
@@ -148,7 +148,7 @@
/* Create table */
- Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
+ Fi = Vect_default_field_info(&Out, layer, NULL, GV_1TABLE);
Fi->driver);
db_init_string(&sql);
@@ -182,16 +182,19 @@
(&In, atoi(fieldsource_opt->answer), GV_POINT,
- wheresource_opt->answer, catsource_opt->answer, &varray_source) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catsource_opt->key,
- wheresource_opt->key);
+ wheresource_opt->answer, catsource_opt->answer, &varray_source) <= 0) {
+ G_fatal_error(_("No source features selected. "
+ catsource_opt->key, wheresource_opt->key);
(&In, atoi(fieldsink_opt->answer), GV_POINT, wheresink_opt->answer,
- catsink_opt->answer, &varray_sink) == 2)
- G_fatal_error(_("Neither %s nor %s was given"), catsink_opt->key,
- wheresink_opt->key);
+ catsink_opt->answer, &varray_sink) <= 0) {
+ G_fatal_error(_("No sink features selected. "
+ catsink_opt->key, wheresink_opt->key);
NetA_varray_to_nodes(&In, varray_source, source_list, NULL);
NetA_varray_to_nodes(&In, varray_sink, sink_list, NULL);
@@ -228,7 +231,7 @@
int type = Vect_read_line(&In, Points, Cats, i);
Vect_write_line(&Out, type, Points, Cats);
- if (type == GV_LINE) {
+ if (type & mask_type) {
int cat;
Vect_cat_get(Cats, layer, &cat);
