[GRASS-SVN] r52170 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Wed Jun 20 14:52:11 PDT 2012
Author: momsen
Date: 2012-06-20 14:52:11 -0700 (Wed, 20 Jun 2012)
New Revision: 52170
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/open_files.c
grass-addons/grass7/imagery/i.segment/parse_args.c
Added scaling of input rasters and switched to squared euclidean distance.
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-20 16:34:48 UTC (rev 52169)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-20 21:52:11 UTC (rev 52170)
@@ -4,7 +4,7 @@
#include <stdlib.h>
#include <float.h> /* to get value of LDBL_MAX -> change this if there is a more usual grass way */
-#include <math.h> /* for sqrt() and pow() */
+ /* #include <math.h> *//* for sqrt() and pow() */
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/segment.h> /* segmentation library */
@@ -26,6 +26,7 @@
G_debug(1, "Threshold: %g", functions->threshold);
G_debug(1, "segmentation method: %d", functions->method);
+ functions->threshold = functions->threshold * functions->threshold * files->nbands; /* use modified threshold to account for scaled input and to avoid square root in similarity comparison. *//* Todo, small, could put this in main outside of polygon loop */
if (functions->method == 0)
successflag = io_debug(files, functions); /* TODO: why does it want `&files` in main, but `files` here ??? */
@@ -56,12 +57,17 @@
/* **************write fake data to test I/O portion of module */
- G_verbose_message("writing fake data to segmentation file");
+ /* G_verbose_message("writing fake data to segmentation file"); */
+ G_verbose_message("writing scaled input (layer 1) to output file");
+ G_verbose_message("weighted flag = %d", files->weighted);
for (row = 0; row < files->nrows; row++) {
G_percent(row, files->nrows, 1); /* TODO this didn't get displayed in the output??? Does it get erased when done? */
for (col = 0; col < files->ncols; col++) {
/*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
- files->out_val[0] = col + row;
+ /* files->out_val[0] = col + row; */
+ segment_get(&files->bands_seg, (void *)files->bands_val, row,
+ col);
+ files->out_val[0] = files->bands_val[0] * 100; /*pushing DCELL into CELL */
files->out_val[1] = 1; /*processing flag */
segment_put(&files->out_seg, (void *)files->out_val, row, col);
@@ -301,9 +307,7 @@
do {
/* do while loop on t to slowly lower threshold. also check that endflag==0 (no merges were made) */
- G_debug(1,
- "########## Starting outer do loop! t = %d ##########",
- t);
+ G_debug(3, "####### Starting outer do loop! t = %d #######", t);
threshold = functions->threshold; /* TODO, consider making this a function of t. */
@@ -326,7 +330,7 @@
- G_debug(1, "Starting to process %d candidate pixels",
+ G_debug(4, "Starting to process %d candidate pixels",
files->candidate_count);
/*process candidate pixels */
@@ -335,22 +339,22 @@
- G_verbose_message("Completion for pass number %d: ", t);
+ /* G_verbose_message("Completion for pass number %d: ", t); */
G_percent(row, files->nrows, 1); /*this didn't get displayed in the output??? Does it get erased when done? */
- G_debug(1,
+ G_debug(4,
"Next starting pixel from next row/col, not from Rk");
segment_get(&files->out_seg, (void *)files->out_val, row, col); /*TODO small time savings - if candidate_count reaches zero, bail out of these loops too? */
if (files->out_val[1] == 1) { /* out_val[1] is the candidate pixel flag, want to process the 1's */
- G_debug(1, "going to free memory on linked lists...");
+ G_debug(4, "going to free memory on linked lists...");
/*free memory for linked lists */
my_dispose_list(files->token, &Ri_head);
my_dispose_list(files->token, &Rk_head);
my_dispose_list(files->token, &Rin_head);
my_dispose_list(files->token, &Rkn_head); /* TODO, better style for repeating this for all structures? */
Rk_count = 0;
- G_debug(1, "finished free memory on linked lists...");
+ G_debug(4, "finished free memory on linked lists...");
/* First pixel in Ri is current row/col pixel. We may add more later if it is part of a segment */
Ri_count = 1;
@@ -364,26 +368,26 @@
// while (pathflag == 1 && files->candidate_count > 0) { /*if don't find mutual neighbors on first try, will use Rk as next Ri. */
- G_debug(1, "Next starting pixel: row, %d, col, %d",
+ G_debug(4, "Next starting pixel: row, %d, col, %d",
Ri_head->row, Ri_head->col);
/* Setting Ri to be not a candidate allows using "itself" when at edge of raster.
* Otherwise need to use a list/count/something to know the number of pixel neighbors */
set_candidate_flag(Ri_head, 0, files); /* TODO: error trap? */
- G_debug(1, "line 165, \t\t\t\tcc = %d",
+ G_debug(4, "line 165, \t\t\t\tcc = %d",
/* what is passed to find segment neighors: */
- /* G_debug(1, "calling find_segment_neigors() with:");
+ /* G_debug(4, "calling find_segment_neigors() with:");
for (current = Ri_head; current != NULL;
current = current->next)
- G_debug(1, "Ri: row: %d, col: %d", current->row,
+ G_debug(4, "Ri: row: %d, col: %d", current->row,
current->col);
for (current = Rin_head; current != NULL;
- G_debug(1, "Rin: row: %d, col: %d", current->row,
+ G_debug(4, "Rin: row: %d, col: %d", current->row,
current->col);
- G_debug(1, "also passing Ri_count: %d", Ri_count);
+ G_debug(4, "also passing Ri_count: %d", Ri_count);
/* find segment neighbors */
if (find_segment_neighbors
@@ -393,29 +397,29 @@
} /* TODO - shouldn't be just fatal error - need to still close_files(). Just put that here then fatal error? */
if (Rin_head == NULL) {
- G_debug(1, "2a, Segment had no valid neighbors"); /*this could happen if there is a segment surrounded by pixels that have already been processed */
+ G_debug(4, "2a, Segment had no valid neighbors"); /*this could happen if there is a segment surrounded by pixels that have already been processed */
pathflag = 0;
Ri_count = 0;
files->candidate_count++; /* already counted out Ri[0]; */
- G_debug(1, "line 176, \t\t\t\tcc = %d",
+ G_debug(4, "line 176, \t\t\t\tcc = %d",
else { /*found neighbors, go ahead until find mutually agreeing neighbors */
- G_debug(1, "2b, Found Ri's pixels");
+ G_debug(4, "2b, Found Ri's pixels");
/*print out neighbors */
current->col);
- G_debug(1, "2b, Found Ri's neighbors");
+ G_debug(4, "2b, Found Ri's neighbors");
current->col);
/* find Ri's most similar neighbor */
@@ -429,13 +433,13 @@
current,
files,
functions);
- G_debug(1,
+ G_debug(4,
"simularity = %g for neighbor : row: %d, col %d.",
tempsim, current->row, current->col);
if (tempsim < Ri_similarity) {
Ri_similarity = tempsim;
Ri_bestn = current; /*TODO want to point to the current pixel...confirm when current changes need this to stay put! */
- G_debug(1,
+ G_debug(4,
"Current lowest Ri_similarity = %g, for neighbor pixel row: %d col: %d",
Ri_similarity, Ri_bestn->row,
Ri_bestn->col);
@@ -443,14 +447,14 @@
if (Ri_bestn != NULL)
- G_debug(1,
+ G_debug(4,
"Lowest Ri_similarity = %g, for neighbor pixel row: %d col: %d",
Ri_bestn->col);
if (Ri_bestn != NULL && Ri_similarity < threshold) { /* small TODO: should this be < or <= for threshold? */
/* we'll have the neighbor pixel to start with. */
- G_debug(1, "3a: Working with Rk");
+ G_debug(4, "3a: Working with Rk");
Rk_count = 1;
newpixel =
(struct pixels *)link_new(files->token);
@@ -466,18 +470,18 @@
find_segment_neighbors(&Rk_head, &Rkn_head, &Rk_count, files, functions); /* data structure for Rk's neighbors, and pixels in Rk if we don't already have it */
- G_debug(1, "Found Rk's pixels");
+ G_debug(4, "Found Rk's pixels");
for (current = Rk_head; current != NULL;
- G_debug(1, "Rk: row: %d, col: %d",
+ G_debug(4, "Rk: row: %d, col: %d",
- G_debug(1, "Found Rk's neighbors");
+ G_debug(4, "Found Rk's neighbors");
for (current = Rkn_head; current != NULL;
- G_debug(1, "Rkn: row: %d, col: %d",
+ G_debug(4, "Rkn: row: %d, col: %d",
/*find Rk's most similar neighbor */
@@ -498,14 +502,14 @@
pathflag = 0; /* go to next row,column pixel - end of Rk -> Ri chain since we found mutual best neighbors */
else { /* they weren't mutually best neighbors */
- G_debug(1,
+ G_debug(4,
"Ri was not Rk's best neighbor, Ri_sim: %g, Rk_sim, %g",
Ri_similarity, Rk_similarity);
/* did this at beginning of path loop */
set_candidate_flag(Ri_head, 0, files); /* remove all Ri members from candidate pixels (set flag) */
files->candidate_count++; /* add one back, we had already set Ri[0] flag at the beginning. */
- G_debug(1, "line 247, \t\t\t\tcc = %d",
+ G_debug(4, "line 247, \t\t\t\tcc = %d",
//~ /* Use Rk as next Ri: this is the eCognition technique. Seems this is a bit faster, we already have segment membership pixels */
//~ Ri_count = Rk_count;
@@ -520,7 +524,7 @@
} /*end else (from if mutually best neighbors) */
else
- G_debug(1,
+ G_debug(4,
"3b Rk didn't didn't exist or similarity was > threshold");
} /* end else - Ri did have neighbors */
// } /*end pathflag do loop */
@@ -530,7 +534,7 @@
/* finished one pass for processing candidate pixels */
- G_debug(1, "Finished one pass, t was = %d", t);
+ G_debug(4, "Finished one pass, t was = %d", t);
t++;
} while (t < 90 && endflag == 0);
/*end t loop *//*TODO, should there be a max t that it can iterate for? Include t in G_message? */
@@ -564,12 +568,12 @@
/* show what was sent to function *//*
- G_debug(1, "in find_segment_neigors() with:");
+ G_debug(5, "in find_segment_neigors() with:");
for (current = *R_head; current != NULL; current = current->next)
- G_debug(1, "R: row: %d, col: %d", current->row, current->col);
+ G_debug(5, "R: row: %d, col: %d", current->row, current->col);
for (current = *neighbors_head; current != NULL; current = current->next)
- G_debug(1, "neig: row: %d, col: %d", current->row, current->col);
- G_debug(1, "also passing Ri_count: %d", *seg_count); */
+ G_debug(5, "neig: row: %d, col: %d", current->row, current->col);
+ G_debug(5, "also passing Ri_count: %d", *seg_count); */
/*initialize data.... TODO: maybe remember min max row/col that was looked at each time, initialize in open_files, and reset smaller region at end of this functions */
for (n = 0; n < files->nrows; n++) {
@@ -605,7 +609,7 @@
Ri_seg_ID = files->out_val[0];
while (to_check != NULL) { /* removing from to_check list as we go, NOT iterating over the list. */
- G_debug(1,
+ G_debug(5,
"\tfind_pixel_neighbors for row: %d , col %d",
to_check->row, to_check->col);
@@ -620,26 +624,26 @@
link_dispose(files->token, (VOID_T *) current);
/*print out to_check */
- G_debug(1, "remaining pixel's in to_check, after popping:");
+ G_debug(5, "remaining pixel's in to_check, after popping:");
for (current = to_check; current != NULL; current = current->next)
- G_debug(1, "to_check... row: %d, col: %d", current->row,
+ G_debug(5, "to_check... row: %d, col: %d", current->row,
current->col);
- G_debug(1, "Rn... row: %d, col: %d", current->row, current->col);
+ G_debug(5, "Rn... row: %d, col: %d", current->row, current->col);
/*now check the pixel neighbors and add to the lists */
/*debug what neighbors were found: */
/* for (n = 0; n < functions->num_pn; n++){
- G_debug(1, "\tpixel_neighbors[n][0]: %d, pixel_neighbors[n][1]: %d", pixel_neighbors[n][0], pixel_neighbors[n][1]);
+ G_debug(5, "\tpixel_neighbors[n][0]: %d, pixel_neighbors[n][1]: %d", pixel_neighbors[n][0], pixel_neighbors[n][1]);
for (n = 0; n < functions->num_pn; n++) { /* with pixel neighbors */
segment_get(&files->no_check, &val_no_check,
- G_debug(1,
+ G_debug(5,
"\twith pixel neigh %d, row: %d col: %d, val_no_check = %d",
n, pixel_neighbors[n][0], pixel_neighbors[n][1],
val_no_check);
@@ -651,10 +655,10 @@
if (files->out_val[1] == 1) { /* valid candidate pixel */
- G_debug(1, "\tfiles->out_val[0] = %d Ri_seg_ID = %d",
+ G_debug(5, "\tfiles->out_val[0] = %d Ri_seg_ID = %d",
files->out_val[0], Ri_seg_ID);
if (files->out_val[0] == Ri_seg_ID) {
- G_debug(1, "\tputing pixel_neighbor in Ri");
+ G_debug(5, "\tputing pixel_neighbor in Ri");
/* put pixel_neighbor[n] in Ri */
newpixel = (struct pixels *)link_new(files->token);
newpixel->next = *R_head; /*point the new pixel to the current first pixel */
@@ -662,7 +666,7 @@
newpixel->col = pixel_neighbors[n][1];
*R_head = newpixel; /*change the first pixel to be the new pixel. */
*seg_count = *seg_count + 1; /* zero index... Ri[0] had first pixel and set count =1. increment after save data. */
- G_debug(1, "\t*seg_count now = %d", *seg_count);
+ G_debug(5, "\t*seg_count now = %d", *seg_count);
/* put pixel_neighbor[n] in to_check -- want to check this pixels neighbors */
@@ -674,7 +678,7 @@
else { /* segment id's were different */
/* put pixel_neighbor[n] in Rin */
- G_debug(1, "Put in neighbors_head");
+ G_debug(5, "Put in neighbors_head");
/* TODO - helper function for adding pixel to a list */
newpixel->next = *neighbors_head; /*point the new pixel to the current first pixel */
@@ -685,18 +689,18 @@
} /*end if valid candidate pixel */
else
- G_debug(1,
+ G_debug(5,
"pixel row: %d col: %d was not a valid candidate pixel",
} /*end if for pixel_neighbor was in "don't check" list */
} /* end for loop - next pixel neighbor */
- G_debug(1,
+ G_debug(5,
"remaining pixel's in to_check, after processing the last pixel's neighbors:");
current->col);
- G_debug(1, "\t### end of pixel neighors");
+ G_debug(5, "\t### end of pixel neighors");
} /* while to_check has more elements */
return 0;
@@ -706,9 +710,9 @@
struct files *files)
- G_debug(1,"\t\tin find 4 pixel neighbors () ");
- G_debug(1,"\t\tpixel row: %d pixel col: %d", p_row, p_col);
- G_debug(1, "\t\tTotal rows: %d, total cols: %d", files->nrows, files->ncols); *//*check that we have files... */
+ G_debug(5,"\t\tin find 4 pixel neighbors () ");
+ G_debug(5,"\t\tpixel row: %d pixel col: %d", p_row, p_col);
+ G_debug(5, "\t\tTotal rows: %d, total cols: %d", files->nrows, files->ncols); *//*check that we have files... */
/* north */
pixel_neighbors[0][1] = p_col;
@@ -769,10 +773,13 @@
/* euclidean distance, sum the square differences for each dimension */
for (n = 0; n < files->nbands; n++) {
- val = val + pow(files->bands_val[n] - files->second_val[n], 2);
+ val =
+ val + (files->bands_val[n] -
+ files->second_val[n]) * (files->bands_val[n] -
+ files->second_val[n]);
- val = sqrt(val);
+ /* val = sqrt(val); *//* use squared distance, save the calculation time */
return val;
@@ -804,7 +811,7 @@
/* if separate out candidate flag, can do all changes with helper function...otherwise remember: */
- G_debug(1, "\t\tMerging, segment number: %d, including pixels:",
+ G_debug(4, "\t\tMerging, segment number: %d, including pixels:",
files->out_val[0]);
/* for each member of Ri and Rk, write new average bands values and segment values */
@@ -814,8 +821,8 @@
segment_put(&files->out_seg, (void *)files->out_val, current->row,
current->col);
files->candidate_count--;
- G_debug(1, "line 508, \t\t\t\tcc = %d", files->candidate_count);
- G_debug(1, "\t\tRi row: %d, col: %d", current->row, current->col);
+ G_debug(4, "line 508, \t\t\t\tcc = %d", files->candidate_count);
+ G_debug(4, "\t\tRi row: %d, col: %d", current->row, current->col);
for (current = Rk_head; current != NULL; current = current->next) {
segment_put(&files->bands_seg, (void *)files->bands_val, current->row,
@@ -823,13 +830,13 @@
current->col);
- G_debug(1, "line 516, \t\t\t\tcc = %d", files->candidate_count);
- G_debug(1, "\t\tRk row: %d, col: %d", current->row, current->col);
+ G_debug(4, "line 516, \t\t\t\tcc = %d", files->candidate_count);
+ G_debug(4, "\t\tRk row: %d, col: %d", current->row, current->col);
files->candidate_count++; /* had already counted down the starting pixel Ri[0] at the beginning... */
- G_debug(1, "line 522, \t\t\t\tcc = %d", files->candidate_count);
+ G_debug(4, "line 522, \t\t\t\tcc = %d", files->candidate_count);
return 0;
@@ -851,7 +858,7 @@
else if (value == 1)
- G_debug(1, "line 544, \t\t\t\tcc = %d", files->candidate_count);
+ G_debug(4, "line 544, \t\t\t\tcc = %d", files->candidate_count);
return 0;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-20 16:34:48 UTC (rev 52169)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-20 21:52:11 UTC (rev 52170)
@@ -27,6 +27,7 @@
/* user parameters */
char *image_group;
+ int weighted; /* 0 if false/not selected, so we should scale input. 1 if the scaling should be skipped */
/* region info */
int nrows, ncols;
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-20 16:34:48 UTC (rev 52169)
+++ grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-20 21:52:11 UTC (rev 52170)
@@ -13,8 +13,9 @@
int *in_fd;
int n, row, col, srows, scols, inlen, outlen, nseg;
DCELL **inbuf; /* buffer array, to store lines from each of the imagery group rasters */
+ struct FPRange *fp_range; /* for getting min/max values on each input raster */
+ DCELL *min, *max;
G_debug(1, "Checking image group...");
/* references: i.cost r.watershed/seg and http://grass.osgeo.org/programming7/segmentlib.html */
@@ -34,6 +35,9 @@
in_fd = G_malloc(Ref.nfiles * sizeof(int));
inbuf = (DCELL **) G_malloc(Ref.nfiles * sizeof(DCELL *));
+ fp_range = G_malloc(Ref.nfiles * sizeof(struct FPRange)); /* TODO, is this correct memory allocation for these three? */
+ min = G_malloc(Ref.nfiles * sizeof(DCELL));
+ max = G_malloc(Ref.nfiles * sizeof(DCELL));
G_debug(1, "Opening input rasters...");
for (n = 0; n < Ref.nfiles; n++) {
@@ -41,7 +45,19 @@
in_fd[n] = Rast_open_old(Ref.file[n].name, Ref.file[n].mapset);
+ /* Get min/max values of each input raster for scaling */
+ if (files->weighted == 0) { /*default, we will scale */
+ for (n = 0; n < Ref.nfiles; n++) {
+ if (Rast_read_fp_range
+ (Ref.file[n].name, Ref.file[n].mapset, &fp_range[n]) < 0)
+ G_fatal_error(_("Unable to read fp range for raster map <%s>"), Ref.file[n].name); /* TODO, still should close files? */
+ Rast_get_fp_range_min_max(&(fp_range[n]), &min[n], &max[n]);
+ G_verbose_message("scaling, for first layer, min: %f, max: %f",
+ min[0], max[0]);
/* ********** find out file segmentation size ************ */
G_debug(1, "Calculate temp file sizes...");
@@ -101,7 +117,10 @@
- files->bands_val[n] = inbuf[n][col];
+ if (files->weighted == 1)
+ files->bands_val[n] = inbuf[n][col]; /*unscaled */
+ else
+ files->bands_val[n] = (inbuf[n][col] - min[n]) / (max[n] - min[n]); /*scaled version */
segment_put(&files->bands_seg, (void *)files->bands_val, row,
col);
@@ -141,6 +160,9 @@
G_free(inbuf);
G_free(in_fd);
+ G_free(fp_range);
+ G_free(min);
+ G_free(max);
/* Need to clean up anything else? */
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-20 16:34:48 UTC (rev 52169)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-20 21:52:11 UTC (rev 52170)
@@ -13,7 +13,7 @@
/* reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing */
struct Option *group, *seeds, *output, *method, *threshold; /* Establish an Option pointer for each option */
- struct Flag *diagonal; /* Establish a Flag pointer for each option */
+ struct Flag *diagonal, *weighted; /* Establish a Flag pointer for each option */
group = G_define_standard_option(G_OPT_I_GROUP);
@@ -47,8 +47,12 @@
diagonal->description =
_("Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel.");
+ weighted = G_define_flag();
+ weighted->key = 'w';
+ weighted->description =
+ _("Weighted input, don't perform the default scaling of input maps.");
- /* input for distance function */
+ /* TODO input for distance function */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -107,7 +111,7 @@
/* reference r.cost line 313
if (sscanf(opt5->answer, "%d", &maxcost) != 1 || maxcost < 0)
G_fatal_error(_("Inappropriate maximum cost: %d"), maxcost); */
- sscanf(threshold->answer, "%f", &functions->threshold);
+ sscanf(threshold->answer, "%f", &functions->threshold); /* Note: this gets changed after we know more at beginning of create_isegs() */
if (diagonal->answer == 0) {
functions->find_pixel_neighbors = &find_four_pixel_neighbors;
@@ -120,6 +124,8 @@
G_debug(1, "eight (3x3) pixel neighborhood");
+ files->weighted = weighted->answer; /* default/0 for performing the scaling, but selected/1 if user has weighted values so scaling should be skipped. */
/* TODO add user input for this */
functions->calculate_similarity = &calculate_euclidean_similarity;
