[GRASS-SVN] r52171 - in grass/trunk/raster/r.to.rast3: . test_suite
svn_grass at osgeo.org
Wed Jun 20 18:26:09 PDT 2012
Author: hamish
Date: 2012-06-20 18:26:08 -0700 (Wed, 20 Jun 2012)
New Revision: 52171
Added:
grass/trunk/raster/r.to.rast3/test_suite/
grass/trunk/raster/r.to.rast3/test_suite/test.r.to.rast3.sh
grass/trunk/raster/r.to.rast3/test_suite/test_volume_3_raster.ref
grass/trunk/raster/r.to.rast3/test_suite/test_volume_6_raster.ref
grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster.ref
grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster_res.ref
grass/trunk/raster/r.to.rast3/test_suite/test_volume_float_raster.ref
Removed:
grass/trunk/raster/r.to.rast3/test.r.to.rast3.sh
grass/trunk/raster/r.to.rast3/test_volume_3_raster.ref
grass/trunk/raster/r.to.rast3/test_volume_6_raster.ref
grass/trunk/raster/r.to.rast3/test_volume_double_raster.ref
grass/trunk/raster/r.to.rast3/test_volume_double_raster_res.ref
grass/trunk/raster/r.to.rast3/test_volume_float_raster.ref
test files -> test_suite/ subdir
Deleted: grass/trunk/raster/r.to.rast3/test.r.to.rast3.sh
--- grass/trunk/raster/r.to.rast3/test.r.to.rast3.sh 2012-06-20 21:52:11 UTC (rev 52170)
+++ grass/trunk/raster/r.to.rast3/test.r.to.rast3.sh 2012-06-21 01:26:08 UTC (rev 52171)
@@ -1,42 +0,0 @@
-# This script tests the conversion of raster maps
-# into a single voxel map with r.to.rast3
-# We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster data with r.mapcalc
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=100 b=0 t=50 res=10 res3=10 -p3
-# We create several evlevation maps to create slices of the voxel map
-# We start from bottom and raise to the top
-r.mapcalc --o expr="elev_double = double(if(row() == 2, null(), row()))"
-r.mapcalc --o expr="elev_float = float(if(row() == 2, null(), row()))"
-r.mapcalc --o expr="elev_1 = 5"
-r.mapcalc --o expr="elev_2 = 15"
-r.mapcalc --o expr="elev_3 = 25"
-r.mapcalc --o expr="elev_4 = 35"
-r.mapcalc --o expr="elev_5 = 45"
-# We @test several methods to generate @raster3d maps from raster maps
-# For validation a @precision=0 should be used. We start with 5 raster maps,
-# then 3 raster maps then using single float and double raster maps
-# with differen tile sizes and null data
-r.to.rast3 --o input=elev_1,elev_2,elev_3,elev_4,elev_5 output=test_volume_6_raster tilesize=1
-r.to.rast3 --o input=elev_1,elev_2,elev_3 output=test_volume_3_raster tilesize=1
-r.to.rast3 --o input=elev_float output=test_volume_float_raster tilesize=2
-r.to.rast3 --o input=elev_double output=test_volume_double_raster tilesize=2
-# Uncomment for reference data export
-# r3.out.ascii input=test_volume_6_raster output=test_volume_6_raster.ref dp=0
-# r3.out.ascii input=test_volume_3_raster output=test_volume_3_raster.ref dp=0
-# r3.out.ascii input=test_volume_float_raster output=test_volume_float_raster.ref dp=0
-# r3.out.ascii input=test_volume_double_raster output=test_volume_double_raster.ref dp=0
-# We need another @preprocess step to generate a different region
-g.region s=0 n=80 w=0 e=100 b=0 t=50 res=5 res3=10 -p3
-# We @test the automatic resolution correction for @raster3d maps in case
-# 2d and 3d region are different
-r.to.rast3 --o input=elev_double output=test_volume_double_raster_res tilesize=2
-# r3.out.ascii input=test_volume_double_raster_res output=test_volume_double_raster_res.ref dp=0
\ No newline at end of file
Copied: grass/trunk/raster/r.to.rast3/test_suite/test.r.to.rast3.sh (from rev 52170, grass/trunk/raster/r.to.rast3/test.r.to.rast3.sh)
--- grass/trunk/raster/r.to.rast3/test_suite/test.r.to.rast3.sh (rev 0)
+++ grass/trunk/raster/r.to.rast3/test_suite/test.r.to.rast3.sh 2012-06-21 01:26:08 UTC (rev 52171)
@@ -0,0 +1,42 @@
+# This script tests the conversion of raster maps
+# into a single voxel map with r.to.rast3
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster data with r.mapcalc
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=100 b=0 t=50 res=10 res3=10 -p3
+# We create several evlevation maps to create slices of the voxel map
+# We start from bottom and raise to the top
+r.mapcalc --o expr="elev_double = double(if(row() == 2, null(), row()))"
+r.mapcalc --o expr="elev_float = float(if(row() == 2, null(), row()))"
+r.mapcalc --o expr="elev_1 = 5"
+r.mapcalc --o expr="elev_2 = 15"
+r.mapcalc --o expr="elev_3 = 25"
+r.mapcalc --o expr="elev_4 = 35"
+r.mapcalc --o expr="elev_5 = 45"
+# We @test several methods to generate @raster3d maps from raster maps
+# For validation a @precision=0 should be used. We start with 5 raster maps,
+# then 3 raster maps then using single float and double raster maps
+# with differen tile sizes and null data
+r.to.rast3 --o input=elev_1,elev_2,elev_3,elev_4,elev_5 output=test_volume_6_raster tilesize=1
+r.to.rast3 --o input=elev_1,elev_2,elev_3 output=test_volume_3_raster tilesize=1
+r.to.rast3 --o input=elev_float output=test_volume_float_raster tilesize=2
+r.to.rast3 --o input=elev_double output=test_volume_double_raster tilesize=2
+# Uncomment for reference data export
+# r3.out.ascii input=test_volume_6_raster output=test_volume_6_raster.ref dp=0
+# r3.out.ascii input=test_volume_3_raster output=test_volume_3_raster.ref dp=0
+# r3.out.ascii input=test_volume_float_raster output=test_volume_float_raster.ref dp=0
+# r3.out.ascii input=test_volume_double_raster output=test_volume_double_raster.ref dp=0
+# We need another @preprocess step to generate a different region
+g.region s=0 n=80 w=0 e=100 b=0 t=50 res=5 res3=10 -p3
+# We @test the automatic resolution correction for @raster3d maps in case
+# 2d and 3d region are different
+r.to.rast3 --o input=elev_double output=test_volume_double_raster_res tilesize=2
+# r3.out.ascii input=test_volume_double_raster_res output=test_volume_double_raster_res.ref dp=0
Copied: grass/trunk/raster/r.to.rast3/test_suite/test_volume_3_raster.ref (from rev 52170, grass/trunk/raster/r.to.rast3/test_volume_3_raster.ref)
--- grass/trunk/raster/r.to.rast3/test_suite/test_volume_3_raster.ref (rev 0)
+++ grass/trunk/raster/r.to.rast3/test_suite/test_volume_3_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 100.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 10
+levels: 5
+5 5 5 5 5 5 5 5 5 5
+15 15 15 15 15 15 15 15 15 15
+25 25 25 25 25 25 25 25 25 25
Copied: grass/trunk/raster/r.to.rast3/test_suite/test_volume_6_raster.ref (from rev 52170, grass/trunk/raster/r.to.rast3/test_volume_6_raster.ref)
--- grass/trunk/raster/r.to.rast3/test_suite/test_volume_6_raster.ref (rev 0)
+++ grass/trunk/raster/r.to.rast3/test_suite/test_volume_6_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 100.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 10
+levels: 5
+35 35 35 35 35 35 35 35 35 35
+45 45 45 45 45 45 45 45 45 45
Copied: grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster.ref (from rev 52170, grass/trunk/raster/r.to.rast3/test_volume_double_raster.ref)
--- grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster.ref (rev 0)
+++ grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 100.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 10
+levels: 5
+1 1 1 1 1 1 1 1 1 1
+3 3 3 3 3 3 3 3 3 3
+4 4 4 4 4 4 4 4 4 4
+6 6 6 6 6 6 6 6 6 6
+7 7 7 7 7 7 7 7 7 7
+8 8 8 8 8 8 8 8 8 8
Copied: grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster_res.ref (from rev 52170, grass/trunk/raster/r.to.rast3/test_volume_double_raster_res.ref)
--- grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster_res.ref (rev 0)
+++ grass/trunk/raster/r.to.rast3/test_suite/test_volume_double_raster_res.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 100.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 10
+levels: 5
Copied: grass/trunk/raster/r.to.rast3/test_suite/test_volume_float_raster.ref (from rev 52170, grass/trunk/raster/r.to.rast3/test_volume_float_raster.ref)
--- grass/trunk/raster/r.to.rast3/test_suite/test_volume_float_raster.ref (rev 0)
+++ grass/trunk/raster/r.to.rast3/test_suite/test_volume_float_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -0,0 +1,51 @@
+version: grass7
+order: nsbt
+north: 80.000000
+south: 0.000000
+east: 100.000000
+west: 0.000000
+top: 50.000000
+bottom: 0.000000
+rows: 8
+cols: 10
+levels: 5
Deleted: grass/trunk/raster/r.to.rast3/test_volume_3_raster.ref
--- grass/trunk/raster/r.to.rast3/test_volume_3_raster.ref 2012-06-20 21:52:11 UTC (rev 52170)
+++ grass/trunk/raster/r.to.rast3/test_volume_3_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -1,51 +0,0 @@
-version: grass7
-order: nsbt
-north: 80.000000
-south: 0.000000
-east: 100.000000
-west: 0.000000
-top: 50.000000
-bottom: 0.000000
-rows: 8
-cols: 10
-levels: 5
-5 5 5 5 5 5 5 5 5 5
-15 15 15 15 15 15 15 15 15 15
-25 25 25 25 25 25 25 25 25 25
Deleted: grass/trunk/raster/r.to.rast3/test_volume_6_raster.ref
--- grass/trunk/raster/r.to.rast3/test_volume_6_raster.ref 2012-06-20 21:52:11 UTC (rev 52170)
+++ grass/trunk/raster/r.to.rast3/test_volume_6_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -1,51 +0,0 @@
-version: grass7
-order: nsbt
-north: 80.000000
-south: 0.000000
-east: 100.000000
-west: 0.000000
-top: 50.000000
-bottom: 0.000000
-rows: 8
-cols: 10
-levels: 5
-35 35 35 35 35 35 35 35 35 35
-45 45 45 45 45 45 45 45 45 45
Deleted: grass/trunk/raster/r.to.rast3/test_volume_double_raster.ref
--- grass/trunk/raster/r.to.rast3/test_volume_double_raster.ref 2012-06-20 21:52:11 UTC (rev 52170)
+++ grass/trunk/raster/r.to.rast3/test_volume_double_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -1,51 +0,0 @@
-version: grass7
-order: nsbt
-north: 80.000000
-south: 0.000000
-east: 100.000000
-west: 0.000000
-top: 50.000000
-bottom: 0.000000
-rows: 8
-cols: 10
-levels: 5
-1 1 1 1 1 1 1 1 1 1
-3 3 3 3 3 3 3 3 3 3
-4 4 4 4 4 4 4 4 4 4
-6 6 6 6 6 6 6 6 6 6
-7 7 7 7 7 7 7 7 7 7
-8 8 8 8 8 8 8 8 8 8
Deleted: grass/trunk/raster/r.to.rast3/test_volume_double_raster_res.ref
--- grass/trunk/raster/r.to.rast3/test_volume_double_raster_res.ref 2012-06-20 21:52:11 UTC (rev 52170)
+++ grass/trunk/raster/r.to.rast3/test_volume_double_raster_res.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -1,51 +0,0 @@
-version: grass7
-order: nsbt
-north: 80.000000
-south: 0.000000
-east: 100.000000
-west: 0.000000
-top: 50.000000
-bottom: 0.000000
-rows: 8
-cols: 10
-levels: 5
Deleted: grass/trunk/raster/r.to.rast3/test_volume_float_raster.ref
--- grass/trunk/raster/r.to.rast3/test_volume_float_raster.ref 2012-06-20 21:52:11 UTC (rev 52170)
+++ grass/trunk/raster/r.to.rast3/test_volume_float_raster.ref 2012-06-21 01:26:08 UTC (rev 52171)
@@ -1,51 +0,0 @@
-version: grass7
-order: nsbt
-north: 80.000000
-south: 0.000000
-east: 100.000000
-west: 0.000000
-top: 50.000000
-bottom: 0.000000
-rows: 8
-cols: 10
-levels: 5
