[GRASS-SVN] r52202 - grass/trunk/scripts/i.landsat.rgb
svn_grass at osgeo.org
Sun Jun 24 01:27:02 PDT 2012
Author: hamish
Date: 2012-06-24 01:27:02 -0700 (Sun, 24 Jun 2012)
New Revision: 52202
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
run multiple percentiles at the same time, halving execution time
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2012-06-24 03:10:26 UTC (rev 52201)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2012-06-24 08:27:02 UTC (rev 52202)
@@ -64,11 +64,21 @@
import string
import grass.script as grass
-def get_percentile(map, percentile):
- s = grass.read_command('r.univar', flags = 'ge', map = map, percentile = percentile)
+def get_percentile(map, percentiles):
+ # todo: generalize for any list length
+ val1 = percentiles[0]
+ val2 = percentiles[1]
+ values = '%s,%s' % (val1, val2)
+ s = grass.read_command('r.univar', flags = 'ge',
+ map = map, percentile = values)
kv = grass.parse_key_val(s)
- return float(kv['percentile_%s' % percentile])
+ # cleanse to match what the key name will become
+ val_str1 = ('percentile_%.15g' % float(val1)).replace('.','_')
+ val_str2 = ('percentile_%.15g' % float(val2)).replace('.','_')
+ return (float(kv[val_str1]), float(kv[val_str2]))
def set_colors(map, v0, v1):
rules = [
"0% black\n",
@@ -79,6 +89,7 @@
rules = ''.join(rules)
grass.write_command('r.colors', map = map, rules = '-', stdin = rules)
def main():
red = options['red']
green = options['green']
@@ -105,8 +116,7 @@
if not preserve:
for i in [red, green, blue]:
grass.message(_("Processing <%s>...") % i)
- v0 = get_percentile(i, 2)
- v1 = get_percentile(i, brightness)
+ (v0, v1) = get_percentile(i, ['2', brightness])
grass.debug("<%s>: min=%f max=%f" % (i, v0, v1))
set_colors(i, v0, v1)
else:
@@ -114,8 +124,7 @@
all_min = 999999
all_min = min(all_min, v0)
all_max = max(all_max, v1)
