[GRASS-SVN] r52203 - grass/trunk/scripts/i.landsat.rgb
svn_grass at osgeo.org
Sun Jun 24 03:45:10 PDT 2012
Author: hamish
Date: 2012-06-24 03:45:10 -0700 (Sun, 24 Jun 2012)
New Revision: 52203
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
add support for multiprocessing python lib (somewhat experimental);
bugfix: preserve flag now sets from all_max,min not blue channel.
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2012-06-24 08:27:02 UTC (rev 52202)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2012-06-24 10:45:10 UTC (rev 52203)
@@ -63,6 +63,12 @@
import os
import string
import grass.script as grass
+try:
+ # new for python 2.6, in 2.5 it may be easy_install'd.
+ import multiprocessing as mp
+ do_mp = True
+except:
+ do_mp = False
def get_percentile(map, percentiles):
@@ -78,6 +84,18 @@
val_str2 = ('percentile_%.15g' % float(val2)).replace('.','_')
return (float(kv[val_str1]), float(kv[val_str2]))
+# wrapper to handle multiprocesses communications back to the parent
+def get_percentile_mp(map, percentiles, conn):
+ # Process() doesn't like storing connection parts in
+ # separate dictionaries, only wants to pass through tuples,
+ # so instead of just sending the sending the pipe we have to
+ # send both parts then keep the one we want. ??
+ output_pipe, input_pipe = conn
+ input_pipe.close()
+ result = get_percentile(map, percentiles)
+ grass.debug('child (%s) (%.1f, %.1f)' % (map, result[0], result[1]))
+ output_pipe.send(result)
+ output_pipe.close()
def set_colors(map, v0, v1):
rules = [
@@ -113,25 +131,74 @@
grass.run_command('r.colors', map = i, color = 'grey255')
sys.exit(0)
if not preserve:
- for i in [red, green, blue]:
- grass.message(_("Processing <%s>...") % i)
- (v0, v1) = get_percentile(i, ['2', brightness])
- grass.debug("<%s>: min=%f max=%f" % (i, v0, v1))
- set_colors(i, v0, v1)
+ if do_mp:
+ grass.message(_("Processing ..."))
+ # set up jobs and launch jobs
+ proc = {}
+ conn = {}
+ for i in [red, green, blue]:
+ conn[i] = mp.Pipe()
+ proc[i] = mp.Process(target = get_percentile_mp,
+ args = (i, ['2', brightness],
+ conn[i],))
+ proc[i].start()
+ # collect results and wait for jobs to finish
+ output_pipe, input_pipe = conn[i]
+ (v0, v1) = input_pipe.recv()
+ grass.debug('parent (%s) (%.1f, %.1f)' % (i, v0, v1))
+ proc[i].join()
+ set_colors(i, v0, v1)
+ else:
+ grass.message(_("Processing <%s>...") % i)
+ (v0, v1) = get_percentile(i, ['2', brightness])
+ grass.debug("<%s>: min=%f max=%f" % (i, v0, v1))
else:
all_max = 0
all_min = 999999
- all_min = min(all_min, v0)
- all_max = max(all_max, v1)
+ if do_mp:
+ proc = {}
+ conn = {}
+ conn[i],))
+ proc[i].start()
+ proc[i].join()
+ all_min = min(all_min, v0)
+ all_max = max(all_max, v1)
+ else:
grass.debug("all_min=%f all_max=%f" % (all_min, all_max))
+ set_colors(i, all_min, all_max)
# write cmd history:
mapset = grass.gisenv()['MAPSET']
