[GRASS-SVN] r52216 - grass/trunk/raster/r.what
svn_grass at osgeo.org
Mon Jun 25 20:22:09 PDT 2012
Author: hamish
Date: 2012-06-25 20:22:09 -0700 (Mon, 25 Jun 2012)
New Revision: 52216
grass/trunk/raster/r.what/main.c
grass/trunk/raster/r.what/r.what.html
rename input= to map=, sync help page
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c 2012-06-26 03:18:36 UTC (rev 52215)
+++ grass/trunk/raster/r.what/main.c 2012-06-26 03:22:09 UTC (rev 52216)
@@ -43,9 +43,7 @@
static int tty = 0;
int main(int argc, char *argv[])
int i, j;
@@ -98,7 +96,7 @@
module->description =
_("Queries raster maps on their category values and category labels.");
- opt.input = G_define_standard_option(G_OPT_R_INPUTS);
+ opt.input = G_define_standard_option(G_OPT_R_MAPS);
opt.input->description = _("Name of existing raster map(s) to query");
opt.coords = G_define_standard_option(G_OPT_M_COORDS);
Modified: grass/trunk/raster/r.what/r.what.html
--- grass/trunk/raster/r.what/r.what.html 2012-06-26 03:18:36 UTC (rev 52215)
+++ grass/trunk/raster/r.what/r.what.html 2012-06-26 03:22:09 UTC (rev 52216)
@@ -23,14 +23,13 @@
<h2>EXAMPLES</h2>
<h3>Input from <tt>stdin</tt> on the command line</h3>
Input coordinates may be given directly from <tt>stdin</tt>, for example:
<br> (input data appears between the "<tt>EOF</tt>" markers)
<div class="code"><pre>
-r.what input=soils,aspect << EOF
+r.what map=soils,aspect << EOF
635342.21 7654321.09 site 1
653324.88 7563412.42 site 2
EOF
@@ -40,7 +39,7 @@
</pre></div>
-echo "635342.21 7654321.09" | r.what input=soils,aspect
+echo "635342.21 7654321.09" | r.what map=soils,aspect
635342.21|7654321.09|45|21
</pre></div>
@@ -53,7 +52,7 @@
coordinates and labels given in the example above:
-r.what input=soils,aspect < input_coord.txt
+r.what map=soils,aspect < input_coord.txt
635342.21|7654321.09|site 1|45|21
653324.88|7563412.42|site 2|44|20
@@ -67,7 +66,7 @@
maximum input line length (e.g. 4096 characters).
-r.what input=soils,aspect east_north=635342.21,7654321.09,653324.88,7563412.42
+r.what map=soils,aspect coordinates=635342.21,7654321.09,653324.88,7563412.42
653324.88|7563412.42|44|20
@@ -76,33 +75,35 @@
<h3>Input coordinates piped from another program</h3>
-The input coordinates may be "piped" from the <tt>stdout</tt> of another program.
+The input coordinates may be "piped" from the <tt>stdout</tt> of another
+program.
+<!-- (d.where is still present in grass7, but not very useful in this context)
For example:
-d.where | r.what input=soils,aspect
+d.where | r.what map=soils,aspect
</pre></div>
In the next example, vector point coordinates are piped from the
-<em>v.out.ascii</em> module . The standard UNIX program "<tt>tr</tt>" is
+<em>v.out.ascii</em> module. The standard UNIX program "<tt>tr</tt>" is
used to convert the column separators in <em>v.out.ascii</em>'s output into
spaces for <em>r.what</em>.
-v.out.ascii bugsites fs=' ' | r.what input=soils,aspect
+v.out.ascii bugsites fs=' ' | r.what map=soils,aspect
</pre></div>
<h3>Output containing raster map category labels</h3>
Here we use the <b>-f</b> label flag to enable the output of category labels
associated with the raster cell(s), as well as values. (categorical maps only)
-r.what -f input=soils,aspect << EOF
+r.what -f map=soils,aspect << EOF
EOF
@@ -133,8 +134,10 @@
<a href="v.what.vect.html">v.what.vect</a>
</em>
<h2>AUTHOR</h2>
Michael Shapiro,
U.S. Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
