[GRASS-SVN] r52217 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Mon Jun 25 20:33:26 PDT 2012
Author: momsen
Date: 2012-06-25 20:33:25 -0700 (Mon, 25 Jun 2012)
New Revision: 52217
Added:
grass-addons/grass7/imagery/i.segment/times.txt
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/main.c
grass-addons/grass7/imagery/i.segment/open_files.c
grass-addons/grass7/imagery/i.segment/parse_args.c
grass-addons/grass7/imagery/i.segment/write_output.c
added mask/null handling of input bands, updated segmentation algorithm (delay candidate flag check until after find mutually best neighbor), general clean up and TODO resolution.
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-26 03:22:09 UTC (rev 52216)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-26 03:33:25 UTC (rev 52217)
@@ -373,16 +373,24 @@
/*process candidate pixels */
G_verbose_message("Row percent complete for pass number %d: ", t);
/*check each pixel, start the processing only if it is a candidate pixel */
+ /* for validation, select one of the two... could make this IFDEF or input parameter */
+ /* reverse order
+ for (row = files->nrows; row >= 0; row--) {
+ for (col = files->ncols; col >= 0 ; col--) {
+ G_percent(files->nrows-row, files->nrows, 1);
+end reverse order */
+/* "normal" order */
for (row = 0; row < files->nrows; row++) {
for (col = 0; col < files->ncols; col++) {
+ G_percent(row, files->nrows, 1); /*end normal order */ /* TODO, can a message be included with G_percent? */
- G_percent(row, files->nrows, 1); /* TODO, can a message be included with G_percent? */
G_debug(4,
"Next starting pixel from next row/col, not from Rk");
segment_get(&files->out_seg, (void *)files->out_val, row, col); /*TODO small time savings - if candidate_count reaches zero, bail out of these loops too? */
- if (files->out_val[1] == 1) { /* out_val[1] is the candidate pixel flag, want to process the 1's */
+ if (files->out_val[1] == 1 && files->out_val != NULL) { /* out_val[1] is the candidate pixel flag, want to process the 1's */ /*TODO MASK handling - checking if we have a segment ID already, in open_files() we will put nulls in [0] slot... better/faster way to do this?*/
G_debug(4, "going to free memory on linked lists...");
/*free memory for linked lists */
my_dispose_list(files->token, &Ri_head);
@@ -472,6 +480,7 @@
G_debug(4,
"simularity = %g for neighbor : row: %d, col %d.",
tempsim, current->row, current->col);
if (tempsim < Ri_similarity) {
Ri_similarity = tempsim;
Ri_bestn = current; /*TODO want to point to the current pixel...confirm when current changes need this to stay put! */
@@ -482,12 +491,19 @@
- if (Ri_bestn != NULL)
+ if (Ri_bestn != NULL){
G_debug(4,
"Lowest Ri_similarity = %g, for neighbor pixel row: %d col: %d",
Ri_similarity, Ri_bestn->row,
Ri_bestn->col);
+ segment_get(&files->out_seg, (void *)files->out_val, Ri_bestn->row, Ri_bestn->col);
+ if (files->out_val[1] == 0)
+ /* this check is important:
+ * best neighbor is not a valid candidate, was already merged earlier in this time step */
+ Ri_similarity = threshold + 1;
if (Ri_bestn != NULL && Ri_similarity < threshold) { /* small TODO: should this be < or <= for threshold? */
/* we'll have the neighbor pixel to start with. */
G_debug(4, "3a: Working with Rk");
@@ -526,6 +542,7 @@
for (current = Rkn_head; current != NULL; current = current->next) { /* for each of Rk's neighbors */
tempsim = functions->calculate_similarity(Rk_head, current, files, functions); /*TODO: need an error trap here, if something goes wrong with calculating similarity? */
if (tempsim < Rk_similarity) {
Rk_similarity = tempsim;
break; /* exit for Rk's neighbors loop here, we know that Ri and Rk aren't mutually best neighbors */
@@ -559,9 +576,17 @@
} /*end else (from if mutually best neighbors) */
- else
+ else {
+ /* no valid best neighbor for this Ri
+ * exclude this Ri from further comparisons
+ * because we checked already Ri for a mutually best neighbor with all valid candidates
+ * thus Ri can not be the mutually best neighbor later on during this pass
+ * unfortunately this does happen sometimes */
+ set_candidate_flag(Ri_head, 0, files); /* TODO: error trap? */
+ files->candidate_count++; /*first pixel was already set*/
G_debug(4,
- "3b Rk didn't didn't exist or similarity was > threshold");
+ "3b Rk didn't didn't exist, was not valid candidate, or similarity was > threshold");
+ } /*end else - Ri's best neighbor was not a candidate */
} /* end else - Ri did have neighbors */
// } /*end pathflag do loop */
} /*end if pixel is candidate pixel */
@@ -572,7 +597,7 @@
G_debug(4, "Finished one pass, t was = %d", t);
t++;
- } while (t < 90 && endflag == 0);
+ } while (t <= functions->end_t && endflag == 0);
/*end t loop *//*TODO, should there be a max t that it can iterate for? Include t in G_message? */
/* free memory *//*TODO: anything ? */
@@ -689,7 +714,8 @@
segment_get(&files->out_seg, (void *)files->out_val, pixel_neighbors[n][0], pixel_neighbors[n][1]); /*TODO : do I need a second "out_val" data structure? */
- if (files->out_val[1] == 1) { /* valid candidate pixel */
+ if (files->out_val[1] == 1 || files->out_val[1] == 0) { /* all pixels, not just valid pixels */
+ /* TODO: use -1 for NULL/MASKED pixels? */
G_debug(5, "\tfiles->out_val[0] = %d Ri_seg_ID = %d",
files->out_val[0], Ri_seg_ID);
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-26 03:22:09 UTC (rev 52216)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-26 03:33:25 UTC (rev 52217)
@@ -34,8 +34,9 @@
int nrows, ncols;
/* files *//* TODO, for all map names, is this better for any reason, saw it in manual example: char name[GNAME_MAX]; */
- char *out_name; /* name of output raster map */
+ char *out_name; /* name of output raster map */
char *seeds, *bounds_map, *bounds_mapset; /* optional segment seeds and polygon constraints/boundaries */
+ char *out_band; /* for debug */
/* file processing */
int nbands; /* number of rasters in the image group */
@@ -68,9 +69,7 @@
/* Todo: Additional data to be stored in this structure:
- * vector constraints
* seeds (Put directly into output map?)
- * Need to consider if they should be put in RAM or SEGMENT?
@@ -85,6 +84,8 @@
int (*find_pixel_neighbors) (int, int, int[8][2], struct files *); /*parameters: row, col, pixel_neighbors */
double (*calculate_similarity) (struct pixels *, struct pixels *, struct files *, struct functions *); /*parameters: two points (row,col) to compare */
+ /* for debug */
+ int end_t;
@@ -101,9 +102,9 @@
int ll_test(struct files *, struct functions *);
int test_pass_token(struct pixels **, struct files *);
int region_growing(struct files *, struct functions *);
-int find_segment_neighbors(struct pixels **, struct pixels **, int *, struct files *, struct functions *); /* TODO: need data structure for Ri, Rin */
+int find_segment_neighbors(struct pixels **, struct pixels **, int *, struct files *, struct functions *);
int set_candidate_flag(struct pixels *, int, struct files *);
-int merge_values(struct pixels *, struct pixels *, int, int, struct files *); /* I assume this is a weighted mean? */
+int merge_values(struct pixels *, struct pixels *, int, int, struct files *);
int find_four_pixel_neighbors(int, int, int[][2], struct files *);
int find_eight_pixel_neighbors(int, int, int[8][2], struct files *);
double calculate_euclidean_similarity(struct pixels *, struct pixels *,
Modified: grass-addons/grass7/imagery/i.segment/main.c
--- grass-addons/grass7/imagery/i.segment/main.c 2012-06-26 03:22:09 UTC (rev 52216)
+++ grass-addons/grass7/imagery/i.segment/main.c 2012-06-26 03:33:25 UTC (rev 52217)
@@ -3,7 +3,7 @@
* MODULE: i.segment
* AUTHOR(S): Eric Momsen <eric.momsen at gmail com>
- * PURPOSE: Provide short description of module here...
+ * PURPOSE: Segments an image group.
* COPYRIGHT: (C) 2012 by Eric Momsen, and the GRASS Development Team
* This program is free software under the GNU General Public
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <grass/gis.h>
-#include <grass/glocale.h> /* message translation */
+#include <grass/glocale.h>
#include "iseg.h"
int main(int argc, char *argv[])
@@ -35,7 +35,7 @@
G_add_keyword(_("imagery"));
G_add_keyword(_("segmentation"));
module->description =
- _("Outputs a single segmention map (raster) based on input values in an image group.");
+ _("Outputs a single segmented map (raster) based on input values in an image group.");
if (parse_args(argc, argv, &files, &functions) != 0)
G_debug(1, "Error in parse_args()"); /* TODO: should these be debug or G_fatal_error() or nested if statement? want to clean up mem and temp files */
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-26 03:22:09 UTC (rev 52216)
+++ grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-26 03:33:25 UTC (rev 52217)
@@ -10,8 +10,8 @@
int open_files(struct files *files)
struct Ref Ref; /* group reference list */
- int *in_fd, bounds_fd;
- int n, row, col, srows, scols, inlen, outlen, nseg;
+ int *in_fd, bounds_fd, null_check;
+ int n, s, row, col, srows, scols, inlen, outlen, nseg;
DCELL **inbuf; /* buffer array, to store lines from each of the imagery group rasters */
CELL *boundsbuf;
struct FPRange *fp_range; /* for getting min/max values on each input raster */
@@ -22,8 +22,7 @@
/* ****** open the input rasters ******* */
- /* TODO, this is from i.smap/openfiles.c lines 17-23 checked if subgroup had maps, does API handles the checks? */
+ /* TODO: I confirmed, the API does not check this. Should this be checked in parse_args / validation ? Or best to do here where I want to use the REF data? */
if (!I_get_group_ref(files->image_group, &Ref))
G_fatal_error(_("Unable to read REF file for group <%s>"),
files->image_group);
@@ -52,10 +51,10 @@
for (n = 0; n < Ref.nfiles; n++) {
if (Rast_read_fp_range
(Ref.file[n].name, Ref.file[n].mapset, &fp_range[n]) < 0)
- G_fatal_error(_("Unable to read fp range for raster map <%s>"), Ref.file[n].name); /* TODO, still should close files? */
+ G_fatal_error(_("Unable to read fp range for raster map <%s>"), Ref.file[n].name); /* TODO, still should free memory and close files? */
Rast_get_fp_range_min_max(&(fp_range[n]), &min[n], &max[n]);
- G_verbose_message("scaling, for first layer, min: %f, max: %f",
+ G_debug(1, "scaling, for first layer, min: %f, max: %f",
min[0], max[0]);
@@ -106,46 +105,51 @@
if (segment_open(&files->no_check, G_tempfile(), files->nrows, files->ncols, srows, scols, sizeof(int), nseg) != 1) /* todo could make this smaller ? just need 0 or 1 */
G_fatal_error("Unable to create flag temporary files");
- /* load input bands to segment structure */
+ /* load input bands to segment structure and initialize output segmentation file */
G_debug(1, "Reading input rasters into segmentation data files...");
files->bands_val = (double *)G_malloc(inlen);
files->second_val = (double *)G_malloc(inlen);
+ files->out_val = (int *)G_malloc(2 * sizeof(int));
+ s = 1; /* initial segment ID */
Rast_get_d_row(in_fd[n], inbuf[n], row);
+ /*tempval = 0; Doesn't work, no "null" for doubles in c */ /* want a number, not null */
+ null_check = 1; /*Assume there is data*/
+ /*tempval += inbuf[n][col]; */ /* if mask/null, adding a null value should set tempval to NULL */
+ if(Rast_is_d_null_value(&inbuf[n][col]))
+ null_check=-1;
if (files->weighted == 1)
files->bands_val[n] = inbuf[n][col]; /*unscaled */
else
files->bands_val[n] = (inbuf[n][col] - min[n]) / (max[n] - min[n]); /*scaled version */
segment_put(&files->bands_seg, (void *)files->bands_val, row,
- col);
- /* Initialize output segmentation file */
- /* TODO: Need to carry MASK over to the output file as well. Need an additional flag that is set, during input read? */
- G_debug(1, "G_malloc size: = <%d>", (int)(2 * sizeof(int)));
- files->out_val = (int *)G_malloc(2 * sizeof(int));
- n = 1;
- for (row = 0; row < files->nrows; row++) {
- for (col = 0; col < files->ncols; col++) {
- files->out_val[0] = n; /*starting segment number TODO: for seeds this will be different */
+ col); /* store input bands */
+ if (null_check != -1){ /*good pixel*/
+ files->out_val[0] = s; /*starting segment number TODO: for seeds this will be different */
files->out_val[1] = 0; /*flag */
- segment_put(&files->out_seg, (void *)files->out_val, row, col);
- n++; /* sequentially number all pixels with their own segment ID */
+ else /*don't use this pixel*/
+ files->out_val[0] = -1; /*starting segment number*/
+ files->out_val[1] = -1; /*flag */
+ segment_put(&files->out_seg, (void *)files->out_val, row, col); /* initialize input */
+ s++; /* sequentially number all pixels with their own segment ID */
/* bounds/constraints */
+ /* TODO: You should also handle NULL cells in the bounds
+ * raster map, I would suggest to replace NULL with min(bounds) - 1 or
+ +* max(bounds) + 1. */
if (files->bounds_map != NULL) {
if (segment_open
(&files->bounds_seg, G_tempfile(), files->nrows, files->ncols,
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-26 03:22:09 UTC (rev 52216)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-26 03:33:25 UTC (rev 52217)
@@ -13,7 +13,8 @@
/* reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing */
struct Option *group, *seeds, *bounds, *output, *method, *threshold; /* Establish an Option pointer for each option */
- struct Flag *diagonal, *weighted; /* Establish a Flag pointer for each option */
+ struct Flag *diagonal, *weighted; /* Establish a Flag pointer for each option */
+ struct Option *outband, *endt; /* debugging parameters... TODO: leave in code or remove? hidden options? */
/* required parameters */
group = G_define_standard_option(G_OPT_I_GROUP); /* TODO: OK to require the user to create a group? Otherwise later add an either/or option to give just a single raster map... */
@@ -31,7 +32,7 @@
method->type = TYPE_STRING;
method->required = YES;
method->answer = "region_growing";
- method->options = "region_growing, io_debug, ll_test"; /*io_debug just writes row+col to each output pixel, ll_test for testing linked list data structure */
+ method->options = "region_growing, io_debug, ll_test"; /* TODO at end, remove these from list: io_debug just writes row+col to each output pixel, ll_test for testing linked list data structure */
method->description = _("Segmentation method.");
/* optional parameters */
@@ -62,41 +63,37 @@
_("Optional bounding/constraining raster map, must be integer values, each area will be segmented independent of the others.");
/* bounds->description = _("Optional vector map with polygons to bound (constrain) segmentation."); */
/* TODO: if performing second segmentation, will already have raster map from this module
- * If have preexisting boundaries (landuse, etc) will have vector map
+ * If have preexisting boundaries (landuse, etc) will have vector map?
* Seems we need to have it in raster format for processing, is it OK to have the user run v.to.rast before doing the segmentation?
* Or for hierarchical segmentation, will it be easier to have the polygons?
- * ....will start with rasters, quickest to implement.... */
/* TODO input for distance function */
+ /* debug parameters */
+ endt = G_define_option();
+ endt->key = "endt";
+ endt->type = TYPE_INTEGER;
+ endt->required = YES; /* TODO, could put as optional, and if not supplied put in something large. */
+ endt->description = _("Maximum number of time steps to complete.");
+ outband = G_define_standard_option(G_OPT_R_INPUT);
+ outband->key = "final_mean";
+ outband->type = TYPE_STRING;
+ outband->required = YES;
+ outband->description =
+ _("debug - save band mean, currently implemented for only 1 band.");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- /* G_debug(1, "For the option <%s> you chose: <%s>",
- group->description, group->answer);
- G_debug(1, "For the option <%s> you chose: <%s>",
- seeds->description, seeds->answer);
- output->description, output->answer);
- method->description, method->answer);
- threshold->description, threshold->answer);
- G_debug(1, "The value of the diagonal flag is: %d", diagonal->answer); */
/* Validation */
/* TODO: use checker for any of the data validation steps!? */
/* ToDo The most important things to check are if the
input and output raster maps can be opened (non-negative file
- descriptor). Do this here or in open_files? */
+ descriptor). ??? Do this here or in open_files? */
/* Check and save parameters */
@@ -112,7 +109,7 @@
/* reference r.cost line 313
if (sscanf(opt5->answer, "%d", &maxcost) != 1 || maxcost < 0)
G_fatal_error(_("Inappropriate maximum cost: %d"), maxcost); */
- sscanf(threshold->answer, "%f", &functions->threshold); /* Note: this gets changed after we know more at beginning of create_isegs() */
+ sscanf(threshold->answer, "%f", &functions->threshold); /* Note: this threshold is scaled after we know more at the beginning of create_isegs() */
/* segmentation methods: 0 = debug, 1 = region growing */
/* TODO, instead of string compare, does the Option structure have these already numbered? */
@@ -145,23 +142,30 @@
files->seeds = seeds->answer;
- /*todo, check error trapping here, what if nothing is entered? what if nothing is found? what if in same mapset */
if (bounds->answer == NULL) { /*no polygon constraints */
files->bounds_map = NULL;
else { /* polygon constraints given */
- files->bounds_map = bounds->answer; /*todo, this needs to set files->bounds = NULL if no answer was given to the parameter */
+ files->bounds_map = bounds->answer;
if ((files->bounds_mapset = G_find_raster(files->bounds_map, "")) == NULL) { /* TODO, warning here: parse_args.c:149:27: warning: assignment discards ‘const’ qualifier from pointer target type [enabled by default] */
G_fatal_error(_("Segmentation constraint/boundary map not found."));
+ if (Rast_map_type(files->bounds_map, files->bounds_mapset) != CELL_TYPE) {
+ G_fatal_error(_("Segmentation constraint map must be CELL type (integers)"));
- /* todo, check raster type, needs to be CELL (integer) */
- /*todo print out what these were before and after */
/* other data */
files->nrows = Rast_window_rows();
files->ncols = Rast_window_cols();
+ /* debug help */
+ if (G_legal_filename(outband->answer) == 1)
+ files->out_band = outband->answer; /* name of current means */
+ else
+ G_fatal_error("Invalid output raster name for means.");
+ sscanf(endt->answer, "%d", &functions->end_t); /* Note: this threshold is scaled after we know more at the beginning of create_isegs() */
return 0;
Added: grass-addons/grass7/imagery/i.segment/times.txt
--- grass-addons/grass7/imagery/i.segment/times.txt (rev 0)
+++ grass-addons/grass7/imagery/i.segment/times.txt 2012-06-26 03:33:25 UTC (rev 52217)
@@ -0,0 +1,41 @@
+Using version from around June 20, SVN 52181, it does not remember fragment membership.
+50 x 50 = 2500 pixels
+real 0m5.767s
+user 0m5.704s
+sys 0m0.028s
+ 0.00228 s/pixel
+100 x 100 = 10,000 pixels
+real 4m8.335s
+user 4m7.363s
+sys 0m0.048s
+0.0248 s/pixel
+140 x 140 = 19,600 pixels
+real 150m7.509s
+user 149m27.656s
+sys 0m9.025s
+0.45 s/pixel
+Rough target:
+10,000 x 10,000 = 100,000,000 pixels
+10 hours?
+removing squareroot
+17s --> 4s at 50x50 resolution
+23 --> 17s at 70x70
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c 2012-06-26 03:22:09 UTC (rev 52216)
+++ grass-addons/grass7/imagery/i.segment/write_output.c 2012-06-26 03:33:25 UTC (rev 52217)
@@ -9,36 +9,62 @@
int write_output(struct files *files)
- int out_fd, row, col;
+ int out_fd, mean_fd, row, col; /* mean_fd for validiating/debug of means, todo, could add array... */
CELL *outbuf;
+ DCELL *meanbuf;
outbuf = Rast_allocate_c_buf(); /*hold one row of data to put into raster */
+ meanbuf = Rast_allocate_d_buf();
/* Todo: return codes are 1 for these, need to check and react to errors? programmer's manual didn't include it... */
segment_flush(&files->out_seg); /* force all data to disk */
+ segment_flush(&files->bands_seg); /* TODO use IFDEF or just delete for all these parts? for debug/validation output */
G_debug(1, "preparing output raster");
/* open output raster map */
out_fd = Rast_open_new(files->out_name, CELL_TYPE);
+ mean_fd = Rast_open_new(files->out_band, DCELL_TYPE);
G_debug(1, "start data transfer from segmentation file to raster");
/* transfer data from segmentation file to raster */
/* output segmentation file: each element includes the segment ID then processing flag(s). So just need the first part of it. */
- G_percent(row, files->nrows, 1); /*TODO: Why isn't this getting printed? */
+ Rast_set_c_null_value(outbuf, files->ncols); /*set buffer to NULLs, only write those that weren't originally masked */
+ Rast_set_d_null_value(meanbuf, files->ncols);
G_debug(5, "outval[0] = %i", files->out_val[0]);
- outbuf[col] = files->out_val[0]; /*just want segment assignment, not the other processing flag(s) */
+ if(files->out_val[0] >= 0) /* only write positive segment ID's, using -1 as indicator of Null/Masked pixels. TODO: OK to use -1 as flag for this? */
+ {outbuf[col] = files->out_val[0]; /*just want segment assignment, not the other processing flag(s) */
+ // meanbuf[col] = files->out_val[0];
+ segment_get(&files->bands_seg, (void *)files->bands_val, row, col);
+ meanbuf[col] = files->bands_val[0];
Rast_put_row(out_fd, outbuf, CELL_TYPE);
+ Rast_put_row(mean_fd, meanbuf, DCELL_TYPE);
+/* TODO: I don't understand the header/history/etc for raster storage. Can/should we save any information about the segmentation
+ * settings used to create the raster? What the input image group was? Anything else the statistics module would need?
+/* TODO after we have a count of create segments... if(total segments == 0) G_warning(_("No segments were created. Verify threshold and region settings.")); */
/* close and save file */
Rast_close(out_fd);
+ Rast_close(mean_fd);
+ /* free memory */
+ G_free(outbuf);
+ G_free(meanbuf);
return 0;
