[GRASS-SVN] r52226 - grass/trunk/raster/r.cost
svn_grass at osgeo.org
Tue Jun 26 00:46:55 PDT 2012
Author: hamish
Date: 2012-06-26 00:46:55 -0700 (Tue, 26 Jun 2012)
New Revision: 52226
grass/trunk/raster/r.cost/main.c
use boolean macros to aid readability, only show memory use when it is interesting
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2012-06-26 07:15:33 UTC (rev 52225)
+++ grass/trunk/raster/r.cost/main.c 2012-06-26 07:46:55 UTC (rev 52226)
@@ -104,7 +104,7 @@
int maxmem;
int segments_in_memory;
int cost_fd, cum_fd, dir_fd, nearest_fd;
- int have_stop_points = 0, dir = 0;
+ int have_stop_points = FALSE, dir = FALSE;
double my_cost, nearest;
double null_cost, dnullval;
int srows, scols;
@@ -130,6 +130,7 @@
struct History history;
double peak = 0.0;
int dsize, nearest_size;
+ double disk_mb, mem_mb;
G_gisinit(argv[0]);
@@ -392,27 +393,22 @@
segments_in_memory = 1;
/* report disk space and memory requirements */
- G_message("--------------------------------------------");
- if (dir == 1) {
- double disk_mb, mem_mb;
+ if (dir == TRUE) {
disk_mb = (double) nrows * ncols * 32. / 1048576.;
mem_mb = (double) srows * scols * 32. / 1048576. * segments_in_memory;
mem_mb += nrows * ncols * 0.05 * 20. / 1048576.; /* for Dijkstra search */
- G_message(_("Will need at least %.2f MB of disk space"), disk_mb);
- G_message(_("Will need at least %.2f MB of memory"), mem_mb);
else {
disk_mb = (double) nrows * ncols * 24. / 1048576.;
mem_mb = (double) srows * scols * 24. / 1048576. * segments_in_memory;
+ if (disk_mb > 200 || mem_mb > 200 || G_verbose() > G_verbose_std()) {
+ G_message("--------------------------------------------");
if (flag5->answer) {
Rast_close(cost_fd);
@@ -426,7 +422,7 @@
sizeof(struct cc), segments_in_memory) != 1)
G_fatal_error(_("Can not create temporary file"));
- if (dir == 1) {
if (segment_open(&dir_seg, G_tempfile(), nrows, ncols, srows, scols,
sizeof(double), segments_in_memory) != 1)
@@ -487,7 +483,7 @@
G_percent(1, 1, 1);
- if (dir == 1) {
int i;
G_message(_("Initializing directional output "));
@@ -610,7 +606,7 @@
if (!Vect_point_in_box(Points->x[0], Points->y[0], 0, &box))
continue;
- have_stop_points = 1;
+ have_stop_points = TRUE;
col = (int)Rast_easting_to_col(Points->x[0], &window);
row = (int)Rast_northing_to_row(Points->y[0], &window);
@@ -961,7 +957,7 @@
costs.nearest = nearest;
segment_put(&cost_seg, &costs, row, col);
new_cell = insert(min_cost, row, col);
- if (dir == 1) {
segment_put(&dir_seg, &cur_dir, row, col);
@@ -971,7 +967,7 @@
- if (dir == 1) {
@@ -1098,7 +1094,7 @@
G_free(nearest_cell);
- if (dir == 1) {
double *p;
dir_fd = Rast_open_new(move_dir_layer, dir_data_type);
@@ -1119,24 +1115,21 @@
segment_close(&cost_seg); /* release memory */
- if (dir == 1) {
+ if (dir == TRUE)
segment_close(&dir_seg);
- Rast_close(cost_fd);
+ Rast_close(cost_fd);
Rast_close(cum_fd);
- if (dir == 1) {
+ if (dir == TRUE)
Rast_close(dir_fd);
- if (nearest_layer) {
+ if (nearest_layer)
Rast_close(nearest_fd);
/* writing history file */
Rast_short_history(cum_cost_layer, "raster", &history);
Rast_command_history(&history);
Rast_write_history(cum_cost_layer, &history);
- if (dir == 1) {
Rast_short_history(move_dir_layer, "raster", &history);
Rast_write_history(move_dir_layer, &history);
