[GRASS-SVN] r52227 - grass-addons/grass7/vector/v.surf.icw
svn_grass at osgeo.org
Tue Jun 26 03:23:25 PDT 2012
Author: hamish
Date: 2012-06-26 03:23:24 -0700 (Tue, 26 Jun 2012)
New Revision: 52227
grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
fixes, now it works
Modified: grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
--- grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py 2012-06-26 07:46:55 UTC (rev 52226)
+++ grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py 2012-06-26 10:23:24 UTC (rev 52227)
@@ -118,8 +118,16 @@
import sys
import os
+import atexit
import grass.script as grass
+def cleanup():
+ grass.verbose(_("Cleanup.."))
+ tmp_base = 'tmp_icw_' + str(os.getpid()) + '_'
+ grass.run_command('g.mremove', flags = 'f', rast = tmp_base + '*', quiet = True)
def main():
pts_input = options['input']
@@ -127,7 +135,7 @@
cost_map = options['cost_map']
post_mask = options['post_mask']
column = options['column']
- friction = options['friction']
+ friction = float(options['friction'])
layer = options['layer']
where = options['where']
workers = int(options['workers'])
@@ -138,13 +146,15 @@
pid = str(os.getpid())
tmp_base = 'tmp_icw_' + pid + '_'
- # does map exist?
+ # do the maps exist?
if not grass.find_file(pts_input, element = 'vector')['file']:
grass.fatal(_("Vector map <%s> not found") % pts_input)
+ if post_mask:
+ if grass.find_file('MASK')['file']:
+ grass.fatal(_("A MASK already exists; remove it before using the post_mask option."))
+ if not grass.find_file(post_mask)['file']:
+ grass.fatal(_("Raster map <%s> not found") % post_mask)
- if grass.findfile(post_mask):
- grass.fatal(_("A MASK already exists; remove it before using the post_mask option."))
grass.verbose(_("v.surf.icw -- Inverse Cost Weighted Interpolation"))
grass.verbose(_("Processing %s -> %s, column=%s, Cf=%g") % (pts_input, output, column, friction))
@@ -154,14 +164,10 @@
grass.verbose("------------------------------------------------------------------------")
# adjust so that tiny numbers don't hog all the FP precision space
- #if friction = 4:
- # divisor = 10.0
- #if friction = 5:
- # divisor = 100.0
- #if friction = 6:
- # divisor = 500.0
- # fp version:
- if friction > 4:
+ # if friction = 4: divisor ~ 10.0
+ # if friction = 5: divisor ~ 100.0
+ # if friction = 6: divisor ~ 500.0
+ if friction >= 4:
divisor = 0.01 * pow(friction, 6)
else:
divisor = 1
@@ -176,37 +182,22 @@
grass.fatal(_("Data column must be numberic"))
# cleanse cost area mask to a flat =1 for my porpoises
+ area_mask = tmp_base + 'area'
grass.mapcalc("$result = if($cost_map, 1, null())",
- result = tmp_base + 'area', cost_map = cost_map,
- overwrite = True)
+ result = area_mask, cost_map = cost_map)
+ ## done with prep work,
## Commence crunching ..
- tmp_points = grass.tempfile()
- #crop out only points in region
- grass.run_command('v.in.region', output = tmp_base + 'region', quiet = True)
- grass.run_command('v.select',
- ainput = pts_file, alayer = layer, atype = 'point',
- binput = tmp_base + 'region', btype = 'area',
- output = tmp_base + 'points_sel')
+ # crop out only points in region
+ addl_opts = {}
if where:
- grass.run_command('v.select', input = tmp_base + 'points_sel',
- layer = layer, where = where,
- output = tmp_base + 'points')
- else:
- grass.run_command('g.rename', rast = (tmp_base + 'points_sel',
- tmp_base + 'points'), quiet = True)
+ addl_opts['where'] = '%s' % where
- if where:
- points_list = grass.read_command('v.out.ascii', input = pts_file,
- where = where, output = '-',
- flags = 'r').splitlines()
- else:
- output = '-', flags = 'r').splitlines()
+ points_list = grass.read_command('v.out.ascii', input = pts_input,
+ output = '-', flags = 'r',
+ **addl_opts).splitlines()
# convert into a 2D list, drop unneeded cat column
# to drop cat col, add this to the end of the line [:-1]
@@ -214,43 +205,53 @@
for i in range(len(points_list)):
points_list[i] = points_list[i].split('|')
- # count number of starting points (n)
+ # count number of starting points (n). This value will later be decremented
+ # if points are found to be off the cost map or out of region.
n = len(points_list)
if n > 200:
- grass.warning(_("Computation is expensive! Please consider fewer points or get ready to wait a while ..."))
+ grass.warning(_("Computation is expensive! Please consider " \
+ + "fewer points or get ready to wait a while ..."))
import time
time.sleep(5)
#### generate cost maps for each site in range
- grass.verbose(_("Generating cost maps.."))
+ grass.message(_("Generating cost maps.."))
+ # avoid do-it-yourself brain surgery
+ points_list_orig = list(points_list)
+ proc = {}
num = 1
- for position in points_list:
+ for i in range(n):
+ position = points_list_orig[i]
easting = position[0]
northing = position[1]
- cat = position[-1]
+ cat = int(position[-1])
# retrieve data value from vector's attribute table:
- data_value = grass.vector_db_select(pts_file, column = column)['values'][cat]
+ data_value = grass.vector_db_select(pts_input, columns = column)['values'][cat][0]
- grass.message(_("Site %d of %d e=%.4f n=%.4f data=%.3g"),
- num, n, easting, northing, data_value)
if not data_value:
- grass.messsage(_(" Skipping, no data here."))
- n = n - 1
+ grass.message(_("Site %d of %d, e=%.4f n=%.4f cat=%d data=?")
+ % (num, n, float(easting), float(northing), cat))
+ grass.message(_(" -- Skipping, no data here."))
+ del(points_list[num-1])
+ n -= 1
continue
+ else:
+ grass.message(_("Site %d of %d, e=%.4f n=%.4f cat=%d data=%.8g") % (num, n,
+ float(easting), float(northing), cat, float(data_value)))
# we know the point is in the region, but is it in a non-null area of the cost surface?
- rast_val = grass.read_command('r.what', map = tmp_base + 'area',
- coordinates = '%s,%s' % (position[0], position[1])
+ rast_val = grass.read_command('r.what', input = area_mask,
+ east_north = '%s,%s' % (position[0], position[1])
).strip().split('|')[-1]
if rast_val == '*':
- grass.messsage(_(" Skipping, point lays outside of cost_map."))
- n = n - 1
+ grass.message(_(" -- Skipping, point lays outside of cost_map."))
+ n -= 1
continue
# it's ok to proceed
@@ -259,12 +260,18 @@
except:
grass.fatal('Data value [%s] is non-numeric' % data_value)
- # echo "$EASTING $NORTHING $DATA_VALUE" | v.in.ascii output=tmp_idw_cost_site_$$ fs=space
+ cost_site_name = tmp_base + 'cost_site.' + '%05d' % num
+ ret = grass.run_command('r.cost', flags = 'k', input = area_mask,
+ output = cost_site_name,
+ coordinate = easting + ',' + northing, quiet = True)
+ if ret is not 0:
+ grass.fatal(_('Problem running %s') % 'r.cost')
- cost_site_name = tmp_base + 'cost_site.' + str(num)
- grass.run_command('r.cost', flags = 'k', input = tmp_base + 'area',
- output = cost_site_name, coordinate = easting + ',' + northing)
#max_cost="$GIS_OPT_MAX_COST" : commented out until r.null cleansing/continue code is sorted out
#start_points=tmp_idw_cost_site_$$
@@ -272,12 +279,15 @@
# more efficient to reclass to 1?
grass.mapcalc("$cost_n_cleansed = if($cost_n == 0, 0.1, $cost_n)",
cost_n_cleansed = cost_site_name + '.cleansed',
- cost_n = cost_site_name, overwrite = True)
+ cost_n = cost_site_name)
grass.run_command('g.remove', rast = cost_site_name, quiet = True)
grass.run_command('g.rename', rast = cost_site_name + '.cleansed'
+ ',' + cost_site_name, quiet = True)
# r.to.vect then r.patch output
# v.to.rast in=tmp_idw_cost_site_29978 out=tmp_idw_cost_val_$$ use=val val=10
@@ -286,113 +296,145 @@
# r.mapcalc "1by_cost_site_sqrd.$NUM = 1.0 / exp(cost_site.$NUM , $FRICTION)"
# EXPRESSION="1.0 / pow(cost_site.$NUM $DIVISOR, $FRICTION )"
expr = '1.0 / pow($cost_n / ' + str(divisor) + ', $friction)'
- else
+ else:
# use log10() or ln() ?
# EXPRESSION="1.0 / ( pow(cost_site.$NUM, $FRICTION) * log (cost_site.$NUM) )"
expr = '1.0 / ( pow($cost_n, $friction) * log($cost_n) )"'
grass.debug("r.mapcalc expression is: [%s]" % expr)
- grass.mapcalc("$result.$num = " + expr,
- result = tmp_base + '1by_cost_site_sqrd',
- num = str(num), cost_n = cost_site_name,
- friction = friction, overwrite = True)
+ one_by_cost_site_sq_n = tmp_base + '1by_cost_site_sq.' + '%05d' % num
+ proc[num-1] = grass.mapcalc_start("$result = " + expr,
+ result = one_by_cost_site_sq_n,
+ cost_n = cost_site_name,
+ friction = friction)
+ # stall to wait for the nth worker to complete,
+ if num % workers is 0:
+ proc[num-1].wait()
# r.patch in=1by_cost_site_sqrd.${NUM},tmp_idw_cost_val_$$ out=1by_cost_site_sqrd.${NUM} --o
# g.remove rast=cost_site.$NUM
num += 1
- done
+ # make sure everyone is finished
+ proc[i].wait()
- # Step 3) find sum(cost^2)
+ #### Step 3) find sum(cost^2)
grass.message("")
grass.message(_("Finding sum of squares.."))
-INPUT_MAPS=1by_cost_site_sqrd.1
-NUM=2
-while [ $NUM -le $N ] ; do
- INPUT_MAPS="$INPUT_MAPS,1by_cost_site_sqrd.$NUM"
- NUM="`expr $NUM + 1`"
-done
+ #todo: test if MASK exists already, fatal exit if it does?
if post_mask:
grass.message(_("Setting post_mask <%s>"), post_mask)
grass.mapcalc("MASK = $maskmap", maskmap = post_mask, overwrite = True)
grass.message(_("Summation of cost weights.."))
+ input_maps = tmp_base + '1by_cost_site_sq.%05d' % 1
+ for i in range(2, n+1):
+ input_maps += ',%s1by_cost_site_sq.%05d' % (tmp_base, i)
+ sum_of_1by_cost_sqs = tmp_base + 'sum_of_1by_cost_sqs'
grass.run_command('r.series', method = 'sum', input = input_maps,
- output = tmp_base + 'sum_of_1by_cost_sqs')
+ output = sum_of_1by_cost_sqs)
if post_mask:
grass.message(_("Removing post_mask <%s>"), post_mask)
grass.run_command('g.remove', rast = 'MASK', quiet = True)
- # Step 4) ( 1/di^2 / sum(1/d^2) ) * ai
+ #### Step 4) ( 1/di^2 / sum(1/d^2) ) * ai
grass.message("")
grass.message(_("Creating partial weights.."))
+ proc = {}
num = 1
-for POS in `cat "$TMP_POINTS"` ; do
+ for position in points_list:
+ easting = position[0]
+ northing = position[1]
+ data_value = float(data_value)
- EASTING=`echo "$POS" | cut -f1 -d"|"`
- NORTHING=`echo "$POS" | cut -f2 -d"|"`
- CAT=`echo "$POS" | cut -f"$CATCOL" -d"|"`
- DATA_VALUE="`v.db.select -c tmp_icw_points_$$ column="$COL_NAME" where="cat=${CAT}"`"
- grass.message(_("Site %d of %d, data value = %.3f") % (num, n, data_value))
+ # failsafe: at this point the data values should all be valid
if not data_value:
- grass.message(_(" Skipping, no data here."))
+ grass.message(_("Site %d of %d, cat = %d, data value = ?") % (num, n, cat))
+ grass.message(_(" -- Skipping, no data here. [Probably programmer error]"))
+ n -= 1
continue
+ else:
+ grass.message(_("Site %d of %d, cat = %d, data value = %.8g")
+ % (num, n, cat, data_value))
- if [ -z "`r.what input=tmp_icw_area_$$ east_north=$EASTING,$NORTHING | grep -v "*"`" ] ; then
- grass.message(_(" Skipping, site lays outside of cost_map."))
+ # we know the point is in the region, but is it in a non-null area of the cost surface?
+ ).strip().split('|')[-1]
+ if rast_val == '*':
+ grass.message(_(" -- Skipping, point lays outside of cost_map. [Probably programmer error]"))
+ n -= 1
continue
- fi
- partial_n = tmp_base + 'partial.' + str(num)
- grass.mapcalc("$partial_n = ($data * $1by_cost_sq) / $sum_of_1by_cost_sqs",
- partial_n = partial_n, data = data_value, overwrite = True)
- r.mapcalc "$result = ( $data_value * $one_by_cost_site_sqrd ) / \
- $sum_of_1by_cost_sqs",
- data_value = data_value,
- result = tmp_base + 'partial_icw.' + str(num),
- one_by_cost_site_sqrd = tmp_base + '1by_cost_site_sqrd' + str(num),
- sum_of_1by_cost_sqs = tmp_base + 'sum_of_1by_cost_sqs', overwrite = True)
+ partial_n = tmp_base + 'partial.' + '%05d' % num
+ one_by_cost_site_sq = tmp_base + '1by_cost_site_sq.' + '%05d' % num
#"( $DATA_VALUE / $N ) * (1.0 - ( cost_sq_site.$NUM / sum_of_cost_sqs ))"
#"( cost_sq_site.$NUM / sum_of_cost_sqs ) * ( $DATA_VALUE / $N )"
- # g.remove rast=1by_cost_site_sqrd.$NUM
+ proc[num-1] = grass.mapcalc_start("$partial_n = ($data * $one_by_cost_sq) / $sum_of_1by_cost_sqs",
+ partial_n = partial_n,
+ data = data_value,
+ one_by_cost_sq = one_by_cost_site_sq,
+ sum_of_1by_cost_sqs = sum_of_1by_cost_sqs)
- num = num + 1
+ # free up disk space ASAP
+ #grass.run_command('g.remove', rast = one_by_cost_site_sq, quiet = True)
+ num += 1
if num > n:
break
- # done
-INPUT_MAPS=partial_icw.1
-NUM=2
- INPUT_MAPS=$INPUT_MAPS,partial_icw.$NUM
-done
+ proc[i].wait()
grass.message("")
grass.message(_("Calculating final values.."))
- grass.run_command('r.series', method = 'sum', input = input_maps,
+ input_maps = tmp_base + 'partial.%05d' % 1
+ input_maps += ',%spartial.%05d' % (tmp_base, i)
+ ret = grass.run_command('r.series', method = 'sum', input = input_maps,
output = output)
+ if ret is not 0:
+ grass.fatal(_('Problem running %s') % 'r.series')
#TODO: r.patch in v.to.rast of values at exact seed site locations. currently set to null
- grass.run_command('r.colors', map = output, color = 'bcyr')
+ grass.run_command('r.colors', map = output, color = 'bcyr', quiet = True)
grass.run_command('r.support', map = output, history = '',
title = 'Inverse cost-weighted interpolation')
history = 'v.surf.icw interpolation:')
- history = ' input map=' + input + ' attribute column=' + column)
+ history = ' input map=' + pts_input + ' attribute column=' + column)
- history = ' cost map=' + cost_map + ' coefficient of friction=' + friction)
+ history = ' cost map=' + cost_map + ' coefficient of friction=' + str(friction))
if flags['r']:
history = ' (d^n)*log(d) as radial basis function')
@@ -405,46 +447,16 @@
# save layer #? to metadata? command line hist?
# Step 5) rm cost and cost_sq maps, tmp_icw_points, etc
-cleanup:
- grass.verbose(_("Cleanup.."))
- grass.run_command('g.mremove', flags = 'f', rast = tmp_base + '*', quiet = True)
+ cleanup()
- g.mremove -f rast=cost_site.*
- g.mremove -f rast=1by_cost_site_sqrd.*
- g.mremove -f rast=partial_icw.*
- #g.mremove -f rast=tmp_icw_*_$$
- #g.mremove -f vect=tmp_icw_*_$$
- g.remove rast=sum_of_1by_cost_sqs
- #g.remove vect=tmp_idw_cost_site_$$
- g.remove rast=tmp_icw_area_$$
- g.remove vect=tmp_icw_region_$$,tmp_icw_points_$$
- # check if it exists
- eval `g.findfile element=vector file="tmp_icw_points_sel_$$"`
- if [ -e "$file" ] ; then
- g.remove vect=tmp_icw_points_sel_$$
- fi
- rm -f "$TMP_POINTS"
-# TODO: trap ^C
-# what to do in case of user break:
-#exitprocedure()
-# g.message -e 'User break!'
-# cleanup
-# exit 1
-# shell check for user break (signal list: trap -l)
-#trap "exitprocedure" 2 3 15
-cleanup
# Step 6) done!
- grass.message(_("Done! Results written to <%s>." % output)
+ grass.message(_("Done! Results written to <%s>." % output))
if __name__ == "__main__":
options, flags = grass.parser()
+ atexit.register(cleanup)
main()
