[GRASS-SVN] r50976 - in grass-addons/grass6/display: . d.frontline
svn_grass at osgeo.org
Sat Mar 3 03:46:05 EST 2012
Author: amuriy
Date: 2012-03-03 00:46:05 -0800 (Sat, 03 Mar 2012)
New Revision: 50976
Added:
grass-addons/grass6/display/d.frontline/
grass-addons/grass6/display/d.frontline/Makefile
grass-addons/grass6/display/d.frontline/d.frontline
grass-addons/grass6/display/d.frontline/description.html
grass-addons/grass6/display/Makefile
<d.frontline> added to grass6/display
Modified: grass-addons/grass6/display/Makefile
--- grass-addons/grass6/display/Makefile 2012-03-03 05:24:21 UTC (rev 50975)
+++ grass-addons/grass6/display/Makefile 2012-03-03 08:46:05 UTC (rev 50976)
@@ -3,9 +3,11 @@
SUBDIRS = \
d.edit.rast \
d.frame.split \
+ d.frontline \
d.region \
d.region.box \
- d.shortcuts
+ d.shortcuts \
+ d.zoom.keys
include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass-addons/grass6/display/d.frontline/Makefile
--- grass-addons/grass6/display/d.frontline/Makefile (rev 0)
+++ grass-addons/grass6/display/d.frontline/Makefile 2012-03-03 08:46:05 UTC (rev 50976)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = d.frontline
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/display/d.frontline/d.frontline
--- grass-addons/grass6/display/d.frontline/d.frontline (rev 0)
+++ grass-addons/grass6/display/d.frontline/d.frontline 2012-03-03 08:46:05 UTC (rev 50976)
@@ -0,0 +1,595 @@
+#!/bin/sh
+# MODULE: d.frontline
+# AUTHOR(S): Alexander Muriy
+# (Institute of Environmental Geoscience, Moscow, Russia)
+# e-mail: amuriy AT gmail DOT com
+# PURPOSE: Displays frontlines on the graphic monitor using d.graph
+# (optionally save graph file and ps.map file)
+# COPYRIGHT: (C) 05-06/2011 Alexander Muriy / GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%Module
+#% description: Display different types of frontlines on the graphic monitor using d.graph (optionally save graph file and ps.map file)
+#% keywords: display, graphics, vector, symbology
+#%End
+#%Option
+#% key: map
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#% guisection: Select
+#%End
+#%Option
+#% key: where
+#% type: string
+#% description: The WHERE statement for data filtering
+#% label: WHERE conditions of SQL query statement without 'where' keyword
+#% required : no
+#%End
+#%Option
+#% key: hcolor
+#% type: string
+#% description: Standard color name or R:G:B
+#% label: Highlight color for vector interactive selecting
+#% required : no
+#% answer: yellow
+#% gisprompt: old_color,color,color
+#%End
+#%Option
+#% key: list
+#% type: string
+#% description: Example: 1,3,7-9,13
+#% label: Category number(s)
+#% required : no
+#%End
+#%Option
+#% key: layer
+#% type: integer
+#% label: Layer number. If -1, all layers are extracted.
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% required : no
+#% answer: 1
+#%End
+#%Option
+#% key: side
+#% type: string
+#% description: Side of the frontline
+#% options: left,right,both
+#% answer: left
+#%End
+#%Option
+#% key: interval
+#% type: double
+#% required: yes
+#% description: Interval between symbols (in mapset units)
+#%End
+#%Option
+#% key: symbol
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Type of symbol (<front/...> symbols will be produced by script at first use: front/arrow_int, front/arrow_ext, front/box, front/circle, front/half_box, front/line, front/triangle). May be any symbol from $GISBASE/etc/symbol/ or $MAPSET/symbol/ directories.
+#% guisection: Symbol
+#%End
+#%Option
+#% key: size
+#% type: integer
+#% required: no
+#% description: Symbol size
+#% answer: 20
+#%End
+#%Option
+#% key: line_color
+#% type: string
+#% required: no
+#% description: Color for line (standard color name or R:G:B)
+#% answer: black
+#%End
+#%Option
+#% key: fill_color
+#% type: string
+#% required: no
+#% description: Color for fill (standard color name or R:G:B)
+#% answer: grey
+#%End
+#%Option
+#% key: width
+#% type: integer
+#% required: no
+#% description: Width of symbol's line
+#% answer: 0
+#%End
+#%Option
+#% key: graph
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Output file to save the d.graph commands
+#% gisprompt: new_file,file,output
+#%End
+#%Option
+#% key: psmap
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Output file to save the ps.map commands
+#%End
+#%Flag
+#% key: m
+#% description: Select vector features interactively (with a mouse)
+#%End
+#%Flag
+#% key: s
+#% description: Save graphics commands in file(s) (for use with d.graph and/or ps.map)
+#%End
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+## set environment so that awk works properly in all languages ##
+unset LC_ALL
+export LC_NUMERIC=C
+cleanup()
+ g.mremove -f vect="TMP*" --quiet
+ \rm -f $TMP1* $TMP2* $TMP3* $TMP4* $TMP5*
+## what to do in case of user break:
+exitprocedure()
+ echo "User break!"
+ cleanup
+ exit 1
+## shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+## check for awk
+if [ ! -x "$(which awk)" ] ; then
+ g.message -e "awk required, please install awk or gawk first"
+ exit 1
+fi
+## does map exist?
+eval "$(g.gisenv)"
+eval "$(g.findfile mapset="$MAPSET" element=vector file="$GIS_OPT_MAP")"
+if [ ! "$file" ]; then
+ g.message -e "Vector map <"$GIS_OPT_MAP"> not found"
+ exit 1
+fi
+## check for lines and boundaries in input map
+eval "$(v.info -t "$GIS_OPT_MAP")"
+if [ "$lines" -eq 0 ] && [ "$boundaries" -eq 0 ]; then
+ g.message -e "Input vector map not contain lines or boundaries"
+ exit 1
+fi
+for vars in "$(v.info -t "$GIS_OPT_MAP" | cut -d"=" -f1)"; do
+ unset -v "$vars"
+done
+## check if monitor started
+if [ "$(d.mon -p | cut -f1 -d' ')" != "Currently" ] ; then
+ g.message -e "No active monitors. Please start <d.mon ...> first"
+ exit 1
+fi
+## check for "-m" flag and "where" option
+if [ "$GIS_FLAG_M" -eq 1 ] && [ -n "$GIS_OPT_WHERE" -o -n "$GIS_OPT_LIST" ]; then
+ g.message -e "Please choose only one of selection methods:
+interactive (flag <"-m">) OR non-interactive -- (<"where"> statement or <"list"> of category values )"
+ exit 1
+fi
+## check for "list" and "where" options
+if [ -n "$GIS_OPT_WHERE" ] && [ -n "$GIS_OPT_LIST" ]; then
+ g.message -e "Please choose only one of non-interactive selection methods: <"where"> statement or <"list"> of category values"
+ exit 1
+fi
+## is input vector displayed now ?
+d.save -oc | grep -e "d.vect map=" | cut -d'"' -f2 | grep -e "$GIS_OPT_MAP" --quiet
+if [ "$?" -eq 1 ]; then
+ g.message -e "Input vector map <""$GIS_OPT_MAP""> is not on the monitor. Please use <d.vect "$GIS_OPT_MAP" ..> to display it"
+ exit 1
+fi
+## setup temporary files ##
+# create temporary file for segments azimuth
+TMP1="$(g.tempfile pid=$$)"
+if [ "$?" -ne 0 ] || [ -z "$TMP1" ] ; then
+ g.message -e "ERROR: Unable to create temporary files."
+ exit 1
+fi
+# create temporary file for symbols' points coordinates
+TMP2="$(g.tempfile pid=$$)"
+if [ "$?" -ne 0 ] || [ -z "$TMP2" ] ; then
+ exit 1
+fi
+# create temporary file for points to lines query
+TMP3="$(g.tempfile pid=$$)"
+if [ "$?" -ne 0 ] || [ -z "$TMP3" ] ; then
+ exit 1
+fi
+# create temporary file for d.graph commands file
+TMP4="$(g.tempfile pid=$$)"
+if [ "$?" -ne 0 ] || [ -z "$TMP4" ] ; then
+ exit 1
+fi
+TMP5="$(g.tempfile pid=$$)"
+ exit 1
+fi
+# create temporary file for psmap file
+TMP6="$(g.tempfile pid=$$)"
+if [ "$?" -ne 0 ] || [ -z "$TMP5" ] ; then
+ exit 1
+fi
+## vector selecting
+if [ "$GIS_FLAG_M" -eq 1 ]; then
+ echo "Select vector(s) with mouse
+- L: draw box with left mouse button to select
+- M: draw box with middle mouse button to remove from display
+- R: quit and save selected vectors to new map"
+ d.extract input="$GIS_OPT_MAP" output=TMP_select type=line,boundary hcolor="$GIS_OPT_HCOLOR" --quiet
+elif [ "$GIS_FLAG_M" -eq 0 -a -z "$GIS_OPT_WHERE" -a -z "$GIS_OPT_LIST" ]; then
+ g.copy vect="$GIS_OPT_MAP",TMP_select --quiet
+fi
+if [ -n "$GIS_OPT_WHERE" ]; then
+ v.extract -t input="$GIS_OPT_MAP" output=TMP_select type=line,boundary where="$GIS_OPT_WHERE" layer="$GIS_OPT_LAYER" --quiet
+elif [ -n "$GIS_OPT_LIST" ]; then
+ v.extract -t input="$GIS_OPT_MAP" output=TMP_select type=line,boundary list="$GIS_OPT_LIST" layer="$GIS_OPT_LAYER" --quiet
+fi
+## TODO: maybe use v.segment for more precise segments splitting ???
+## In that case --> generate split-file with points for v.segment with v.to.db
+## (line length) and AWK
+## bounds to lines (if needed)
+eval "$(v.info -t TMP_select)"
+if [ "$boundaries" -ne 0 ]; then
+ v.type input=TMP_select output=TMP_select_lines type=boundary,line --quiet
+else
+ g.rename vect=TMP_select,TMP_select_lines --quiet
+fi
+for vars in "$(v.info -t TMP_select_lines | cut -d"=" -f1)"; do
+ unset -v "$vars"
+done
+## split line into segments; delete old cats, add new cats
+v.split input=TMP_select_lines output=TMP_select_lines_split vertices=2 --quiet > /dev/null
+v.category input=TMP_select_lines_split output=TMP_select_lines_split_catdel option=del --quiet
+v.category input=TMP_select_lines_split_catdel output=TMP_select_lines_split_catdel_cats option=add step=1 --quiet
+SEGM=TMP_select_lines_split_catdel_cats
+## find azimuth of each segment in a line or boundary
+v.to.db -p map="$SEGM" option=azimuth --quiet >> "$TMP1"
+## take points for future symbols
+v.to.points -t -i input=TMP_select_lines type=line dmax="$GIS_OPT_INTERVAL" output=TMP_pts --quiet
+## take coordinates of points
+v.to.db -p map=TMP_pts layer=2 option=coor --quiet >> "$TMP2"
+## points to segments' categories query
+v.distance -p from=TMP_pts to="$SEGM" from_layer=2 to_type=line,boundary upload=cat column=dummy_nearest_cats --quiet >> "$TMP3"
+awk 'NR>1 {print $0}' "$TMP3" | tr '|' ' ' > "$TMP3.clean"
+awk -F"|" 'BEGIN { OFMT="%.6f" } {print $1,$2,$3}' "$TMP2" >> "$TMP2.pts.coor"
+join -j 1 "$TMP2.pts.coor" "$TMP3.clean" > "$TMP2.pts.segm"
+## find angles of symbols
+left_front()
+ awk -F"|" 'BEGIN { OFMT="%.0f" } {print $1,450-$2}' "$TMP1" > "$TMP1.left.angle"
+ awk 'NR==FNR{a[$1]=$2;next}$4 in a{$4=a[$4]}1' "$TMP1.left.angle" "$TMP2.pts.segm" > "$TMP1.left.table"
+ awk '{print "'"rotation"'", $4, "'"symbol $GIS_OPT_SYMBOL"'", "'"$GIS_OPT_SIZE"'", $2, $3, "'"$GIS_OPT_LINE_COLOR"'", "'"$GIS_OPT_FILL_COLOR"'", "'"width"'", "'"$GIS_OPT_WIDTH"'"}' "$TMP1.left.table" >> "$TMP4"
+ if [ -n "$GIS_OPT_PSMAP" ]; then
+ awk '{print "'"point"'", $2, $3, "'"color $GIS_OPT_LINE_COLOR"'", "'"fcolor $GIS_OPT_FILL_COLOR"'", "'"symbol $GIS_OPT_SYMBOL"'", "'"size $GIS_OPT_SIZE"'", "'"rotate"'", $4, "'"end"'"}' "$TMP1.left.table" >> "$TMP6"
+ fi
+right_front()
+ awk -F"|" 'BEGIN { OFMT="%.0f" } {print $1,270-$2}' "$TMP1" > "$TMP1.right.angle"
+ awk 'NR==FNR{a[$1]=$2;next}$4 in a{$4=a[$4]}1' "$TMP1.right.angle" "$TMP2.pts.segm" > "$TMP1.right.table"
+ awk '{print "'"rotation"'", $4, "'"symbol $GIS_OPT_SYMBOL"'", "'"$GIS_OPT_SIZE"'", $2, $3, "'"$GIS_OPT_LINE_COLOR"'", "'"$GIS_OPT_FILL_COLOR"'", "'"width"'", "'"$GIS_OPT_WIDTH"'"}' "$TMP1.right.table" >> "$TMP4"
+ awk '{print "'"point"'", $2, $3, "'"color $GIS_OPT_LINE_COLOR"'", "'"fcolor $GIS_OPT_FILL_COLOR"'", "'"symbol $GIS_OPT_SYMBOL"'", "'"size $GIS_OPT_SIZE"'", "'"rotate"'", $4, "'"end"'"}' "$TMP1.right.table" >> "$TMP6"
+ fi
+case "$GIS_OPT_SIDE" in
+ left)
+ left_front
+ right)
+ right_front
+ both)
+ left_front
+ right_front
+esac
+## make custom front symbols in the user's mapset ($MAPSET/symbol/type/name) ???
+echo "VERSION 1.0
+BOX -0.5 -0.5 1.5 1.5
+STRING
+ LINE
+ 0 0
+ 0 1.5
+ END
+END
+STRING
+ LINE
+ 0.4 0.75
+ 0 0
+ END
+END
+STRING
+ LINE
+ -0.4 0.75
+ 0 0
+ END
+END" > "$TMP5.arrow.int"
+echo "VERSION 1.0
+STRING
+ LINE
+ 0 0
+ 0 1.5
+ END
+END
+STRING
+ LINE
+ 0.4 0.75
+ 0 1.5
+ END
+END
+STRING
+ LINE
+ -0.4 0.75
+ 0 1.5
+ END
+END" > "$TMP5.arrow.ext"
+echo "VERSION 1.0
+BOX -0.5 -0.5 0.5 0.5
+POLYGON
+ RING
+ LINE
+ -0.2 0
+ -0.2 0.4
+ 0.2 0.4
+ 0.2 0
+ END
+ END
+END" > "$TMP5.box"
+echo "VERSION 1.0
+POLYGON
+ RING
+ ARC 0 0 0.333 0 180
+ END
+END" > "$TMP5.circle"
+echo "VERSION 1.0
+POLYGON
+ RING
+ LINE
+ -0.2 0
+ -0.2 0.2
+ 0.2 0.2
+ 0.2 0
+ END
+ END
+END" > "$TMP5.half_box"
+echo "VERSION 1.0
+STRING
+ LINE
+ 0 0
+ 0 0.5
+ END
+END" > "$TMP5.line"
+echo "VERSION 1.0
+POLYGON
+ RING
+ LINE
+ -0.25 0
+ 0 0.5
+ 0.25 0
+ END
+ END
+END" > "$TMP5.triangle"
+eval "$(g.gisenv)"
+symbol_path="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"/symbol/front
+if [ ! -d "$symbol_path" ]; then
+ mkdir -p "$symbol_path"
+ cp -f "$TMP5.arrow.int" "$symbol_path"/arrow_int
+ cp -f "$TMP5.arrow.ext" "$symbol_path"/arrow_ext
+ cp -f "$TMP5.box" "$symbol_path"/box
+ cp -f "$TMP5.circle" "$symbol_path"/circle
+ cp -f "$TMP5.half_box" "$symbol_path"/half_box
+ cp -f "$TMP5.line" "$symbol_path"/line
+ cp -f "$TMP5.triangle" "$symbol_path"/triangle
+fi
+## format d.graph input file and ps.map points file
+awk '{print $1,$2,"'"\n"'",$10,$11,"'"\n"'",$3,$4,$5,$6,$7,$8,$9}' "$TMP4" >> "$TMP4.fmt"
+awk '{print $1,$2,$3,"'"\n"'",$4,$5,"'"\n"'",$6,$7,"'"\n"'",$8,$9,"'"\n"'",$10,$11,"'"\n"'",$12,$13,"'"\n"'","'"end"'"}' "$TMP6" >> "$TMP6.fmt"
+## draw frontlines and (optionally) save graph file and psmap file
+if [ "$GIS_FLAG_S" -eq 0 ] && [ -n "$GIS_OPT_GRAPH" ]; then
+ g.message -e "Please use flag <"-s"> to save line graphics in file <"$GIS_OPT_GRAPH">"
+ cleanup
+ exit 1
+fi
+if [ "$GIS_FLAG_S" -eq 1 ]; then
+ if [ -n "$GIS_OPT_GRAPH" ]; then
+ cp -f "$TMP4.fmt" "$GIS_OPT_GRAPH"
+ d.graph -m input="$GIS_OPT_GRAPH" color=none
+ else
+ SYMBOL="$(echo $GIS_OPT_SYMBOL | tr '/' '_')"
+ GRAPH_FILE=""$GISDBASE"/"$LOCATION_NAME"/"$GIS_OPT_MAP"__"$SYMBOL"_"$GIS_OPT_INTERVAL"_"$GIS_OPT_SIDE"_"$GIS_OPT_LINE_COLOR"".graph
+# cp -f "$TMP4.fmt" "$GRAPH_FILE"
+ cat "$TMP4.fmt" >> "$GRAPH_FILE"
+ d.graph -m input="$GRAPH_FILE" color=none
+ fi
+else
+ d.graph -m input="$TMP4.fmt" color=none
+fi
+if [ "$GIS_FLAG_S" -eq 0 ] && [ -n "$GIS_OPT_PSMAP" ]; then
+ g.message -e "Please use flag <"-s"> to save line graphics in file <"$GIS_OPT_PSMAP"> for use with ps.map"
+ cleanup
+ exit 1
+fi
+if [ -n "$GIS_OPT_PSMAP" ]; then
+# cp -f "$TMP6.fmt" "$GIS_OPT_PSMAP"
+ cat "$TMP6.fmt" >> "$GIS_OPT_PSMAP"
+fi
+cleanup
+exit 0
Property changes on: grass-addons/grass6/display/d.frontline/d.frontline
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass6/display/d.frontline/description.html
--- grass-addons/grass6/display/d.frontline/description.html (rev 0)
+++ grass-addons/grass6/display/d.frontline/description.html 2012-03-03 08:46:05 UTC (rev 50976)
@@ -0,0 +1,93 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>GRASS GIS manual: d.frontline</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<h2>NAME</h2>
+<em><b>d.frontline</b></em> - Display different types of frontlines on the graphic monitor using d.graph (optionally save graph file and ps.map file)
+<h2>KEYWORDS</h2>
+display, graphics, vector, symbology
+<h2>SYNOPSIS</h2>
+<b>d.frontline</b><br>
+<b>d.frontline help</b><br>
+<b>d.frontline</b> [-<b>ms</b>] <b>map</b>=<em>name</em> [<b>where</b>=<em>string</em>] [<b>hcolor</b>=<em>string</em>] [<b>list</b>=<em>string</em>] [<b>layer</b>=<em>integer</em>] [<b>side</b>=<em>string</em>] <b>interval</b>=<em>float</em> <b>symbol</b>=<em>string</em> [<b>size</b>=<em>integer</em>] [<b>line_color</b>=<em>string</em>] [<b>fill_color</b>=<em>string</em>] [<b>width</b>=<em>integer</em>] [<b>graph</b>=<em>name</em>] [<b>psmap</b>=<em>name</em>] [--<b>verbose</b>] [--<b>quiet</b>]
+<h3>Flags:</h3>
+<DL>
+<DT><b>-m</b></DT>
+<DD>Select vector features interactively (with a mouse)</DD>
+<DT><b>-s</b></DT>
+<DD>Save graphics commands in file(s) (for use with d.graph and/or ps.map)</DD>
+<DT><b>--verbose</b></DT>
+<DD>Verbose module output</DD>
+<DT><b>--quiet</b></DT>
+<DD>Quiet module output</DD>
+</DL>
+<h3>Parameters:</h3>
+<DL>
+<DT><b>map</b>=<em>name</em></DT>
+<DD>Name of input vector map</DD>
+<DT><b>where</b>=<em>string</em></DT>
+<DD>WHERE conditions of SQL query statement without 'where' keyword</DD>
+<DD>The WHERE statement for data filtering</DD>
+<DT><b>hcolor</b>=<em>string</em></DT>
+<DD>Highlight color for vector interactive selecting</DD>
+<DD>Standard color name or R:G:B</DD>
+<DD>Default: <em>yellow</em></DD>
+<DT><b>list</b>=<em>string</em></DT>
+<DD>Category number(s)</DD>
+<DD>Example: 1,3,7-9,13</DD>
+<DT><b>layer</b>=<em>integer</em></DT>
+<DD>Layer number. If -1, all layers are extracted.</DD>
+<DD>A single vector map can be connected to multiple database tables. This number determines which table to use.</DD>
+<DD>Default: <em>1</em></DD>
+<DT><b>side</b>=<em>string</em></DT>
+<DD>Side of the frontline</DD>
+<DD>Options: <em>left,right,both</em></DD>
+<DD>Default: <em>left</em></DD>
+<DT><b>interval</b>=<em>float</em></DT>
+<DD>Interval between symbols (in mapset units)</DD>
+<DT><b>symbol</b>=<em>string</em></DT>
+<DD>Type of symbol (<front/...> symbols will be produced by script at first use: front/arrow_int, front/arrow_ext, front/box, front/circle, front/half_box, front/line, front/triangle). May be any symbol from $GISBASE/etc/symbol/ or $MAPSET/symbol/ directories.</DD>
+<DT><b>size</b>=<em>integer</em></DT>
+<DD>Symbol size</DD>
+<DD>Default: <em>20</em></DD>
+<DT><b>line_color</b>=<em>string</em></DT>
+<DD>Color for line (standard color name or R:G:B)</DD>
+<DD>Default: <em>black</em></DD>
+<DT><b>fill_color</b>=<em>string</em></DT>
+<DD>Color for fill (standard color name or R:G:B)</DD>
+<DD>Default: <em>grey</em></DD>
+<DT><b>width</b>=<em>integer</em></DT>
+<DD>Width of symbol's line</DD>
+<DD>Default: <em>0</em></DD>
+<DT><b>graph</b>=<em>name</em></DT>
+<DD>Output file to save the d.graph commands</DD>
+<DT><b>psmap</b>=<em>name</em></DT>
+<DD>Output file to save the ps.map commands</DD>
+</DL>
+</body>
+</html>
