[GRASS-SVN] r50977 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Sat Mar 3 09:49:26 EST 2012
Author: martinl
Date: 2012-03-03 06:49:26 -0800 (Sat, 03 Mar 2012)
New Revision: 50977
grass/branches/develbranch_6/lib/python/core.py
glynn: Add mlist_strings, mlist_pairs
Add flag= option to mlist_*
(merge r50971 from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2012-03-03 08:46:05 UTC (rev 50976)
+++ grass/branches/develbranch_6/lib/python/core.py 2012-03-03 14:49:26 UTC (rev 50977)
@@ -686,7 +686,46 @@
# interface to g.mlist
-def mlist_grouped(type, pattern = None, check_search_path = True):
+def mlist_strings(type, pattern = None, mapset = None, flag = ''):
+ """!List of elements as strings.
+ Returns the output from running g.mlist, as a list of qualified
+ names.
+ @param type element type (rast, vect, rast3d, region, ...)
+ @param pattern pattern string
+ @param mapset mapset name (if not given use search path)
+ @param flag pattern type: 'r' (basic regexp), 'e' (extended regexp), or '' (glob pattern)
+ @return list of elements
+ result = list()
+ for line in read_command("g.mlist",
+ quiet = True,
+ flags = 'm' + flag,
+ type = type,
+ pattern = pattern,
+ mapset = mapset).splitlines():
+ result.append(line.strip())
+ return result
+def mlist_pairs(type, pattern = None, mapset = None, flag = ''):
+ """!List of elements as pairs
+ (name, mapset) pairs
+ return [tuple(map.split('@', 1)) for map in mlist_strings(type, pattern, mapset, flag)]
+def mlist_grouped(type, pattern = None, check_search_path = True, flag = ''):
"""!List of elements grouped by mapsets.
Returns the output from running g.mlist, as a dictionary where the
@@ -701,6 +740,7 @@
@param check_search_path True to add mapsets for the search path with no found elements
@return directory of mapsets/elements
@@ -710,7 +750,7 @@
result[mapset] = []
mapset = None
- for line in read_command("g.mlist", quiet = True, flags = "m",
+ for line in read_command("g.mlist", quiet = True, flags = "m" + flag,
type = type, pattern = pattern).splitlines():
try:
name, mapset = line.split('@')
