[GRASS-SVN] r51035 - grass/branches/releasebranch_6_4
Sun Mar 11 15:50:23 EDT 2012
Author: neteler
Date: 2012-03-11 12:50:23 -0700 (Sun, 11 Mar 2012)
New Revision: 51035
   grass/branches/releasebranch_6_4/configure
   grass/branches/releasebranch_6_4/configure.in
jpeg refs removed
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2012-03-11 15:27:08 UTC (rev 51034)
+++ grass/branches/releasebranch_6_4/configure	2012-03-11 19:50:23 UTC (rev 51035)
@@ -33,8 +33,6 @@
   --with-macosx-sdk[=path/sdk]
                           compile with a system SDK on MacOSX. (default: no)"
 ac_help="$ac_help
-  --with-jpeg             support JPEG functionality (default: yes)"
-ac_help="$ac_help
   --with-tiff             support TIFF functionality (default: yes)"
 ac_help="$ac_help
   --with-png              support PNG functionality (default: yes)"
@@ -112,11 +110,6 @@
   --with-readline-libs=DIRS
                           Readline library files are in DIRS"
 ac_help="$ac_help
-  --with-jpeg-includes=DIRS
-                          JPEG include files are in DIRS"
-ac_help="$ac_help
-  --with-jpeg-libs=DIRS   JPEG library files are in DIRS"
-ac_help="$ac_help
   --with-tiff-includes=DIRS
                           TIFF include files are in DIRS"
 ac_help="$ac_help
@@ -755,7 +748,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:759: checking host system type" >&5
+echo "configure:752: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -778,7 +771,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:782: checking for $ac_word" >&5
+echo "configure:775: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -805,7 +798,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:809: checking for $ac_word" >&5
+echo "configure:802: checking for $ac_word" >&5
@@ -853,7 +846,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:857: checking for $ac_word" >&5
+echo "configure:850: checking for $ac_word" >&5
@@ -882,7 +875,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:886: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:879: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -893,12 +886,12 @@
 cat > conftest.$ac_ext << EOF
-#line 897 "configure"
+#line 890 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -924,19 +917,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:928: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:921: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:933: checking whether we are using GNU C" >&5
+echo "configure:926: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:933: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -954,7 +947,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:958: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:951: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -983,10 +976,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:987: checking for Cygwin environment" >&5
+echo "configure:980: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 990 "configure"
+#line 983 "configure"
 int main() {
@@ -997,7 +990,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:1001: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -1013,17 +1006,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1017: checking for mingw32 environment" >&5
+echo "configure:1010: checking for mingw32 environment" >&5
-#line 1020 "configure"
+#line 1013 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1020: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1041,7 +1034,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1045: checking for executable suffix" >&5
+echo "configure:1038: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1060,23 +1053,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1064: checking for full floating-point support" >&5
+echo "configure:1057: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1069: checking whether "cc -mieee" works" >&5
+echo "configure:1062: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1073 "configure"
+#line 1066 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1080: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1073: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1092,7 +1085,7 @@
 else
-#line 1096 "configure"
+#line 1089 "configure"
 #include <float.h>
@@ -1106,7 +1099,7 @@
 EOF
-if { (eval echo configure:1110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1119,14 +1112,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1123: checking for full floating-point support with -mieee" >&5
+echo "configure:1116: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1130 "configure"
+#line 1123 "configure"
 #include <float.h>
@@ -1140,7 +1133,7 @@
 EOF
-if { (eval echo configure:1144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1177,7 +1170,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1181: checking for $ac_word" >&5
+echo "configure:1174: checking for $ac_word" >&5
 case "$pwd" in
@@ -1215,7 +1208,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1219: checking for source directory" >&5
+echo "configure:1212: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1226,7 +1219,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1230: checking for build directory" >&5
+echo "configure:1223: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1294,7 +1287,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
-echo "configure:1298: checking for $ac_word" >&5
+echo "configure:1291: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1353,7 +1346,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1357: checking for MacOSX App" >&5
+echo "configure:1350: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1365,7 +1358,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1369: checking for MacOSX architectures" >&5
+echo "configure:1362: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1394,7 +1387,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1398: checking for MacOSX SDK" >&5
+echo "configure:1391: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1404,7 +1397,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1408: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1401: checking for $with_macosx_sdk/SDKSettings.plist" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1448,7 +1441,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1452: checking how to build libraries" >&5
+echo "configure:1445: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1491,7 +1484,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1495: checking for $ac_word" >&5
+echo "configure:1488: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1516,7 +1509,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1520: checking how to run the C preprocessor" >&5
+echo "configure:1513: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1529,13 +1522,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1533 "configure"
+#line 1526 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1539: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1532: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1546,13 +1539,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1550 "configure"
+#line 1543 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1563,13 +1556,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1567 "configure"
+#line 1560 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1566: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1597,7 +1590,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1601: checking if 64bit support is requested" >&5
+echo "configure:1594: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1617,7 +1610,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1621: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1614: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1641,7 +1634,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1645: checking system version (for dynamic loading)" >&5
+echo "configure:1638: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1667,13 +1660,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1671: checking for dlopen in -ldl" >&5
+echo "configure:1664: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1677 "configure"
+#line 1670 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1684,7 +1677,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1731,7 +1724,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1735: checking for $ac_word" >&5
+echo "configure:1728: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1860,13 +1853,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1864: checking for gettimeofday in -lbsd" >&5
+echo "configure:1857: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1870 "configure"
+#line 1863 "configure"
@@ -1877,7 +1870,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1918,13 +1911,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1922: checking for inet_ntoa in -lbind" >&5
+echo "configure:1915: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1928 "configure"
+#line 1921 "configure"
@@ -1935,7 +1928,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1996,13 +1989,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:2000: checking for shl_load in -ldld" >&5
+echo "configure:1993: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 2006 "configure"
+#line 1999 "configure"
@@ -2013,7 +2006,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2078,13 +2071,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:2082: checking for shl_load in -ldld" >&5
+echo "configure:2075: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 2088 "configure"
+#line 2081 "configure"
@@ -2095,7 +2088,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2217,15 +2210,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2221: checking for dld.h" >&5
+echo "configure:2214: checking for dld.h" >&5
-#line 2224 "configure"
+#line 2217 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2285,15 +2278,15 @@
 	    else
-echo "configure:2289: checking for dld.h" >&5
+echo "configure:2282: checking for dld.h" >&5
-#line 2292 "configure"
+#line 2285 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2390,9 +2383,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2394: checking for ELF" >&5
+echo "configure:2387: checking for ELF" >&5
-#line 2396 "configure"
+#line 2389 "configure"
 #ifdef __ELF__
@@ -2422,15 +2415,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2426: checking for dlfcn.h" >&5
+echo "configure:2419: checking for dlfcn.h" >&5
-#line 2429 "configure"
+#line 2422 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2454,9 +2447,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2458: checking for ELF" >&5
+echo "configure:2451: checking for ELF" >&5
-#line 2460 "configure"
+#line 2453 "configure"
 #ifdef __ELF__
@@ -2780,17 +2773,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2784: checking for ld accepts -Bexport flag" >&5
+echo "configure:2777: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2787 "configure"
+#line 2780 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2946,16 +2939,6 @@
 fi
-# Check whether --with-jpeg or --without-jpeg was given.
-if test "${with_jpeg+set}" = set; then
-  withval="$with_jpeg"
-else
-  with_jpeg=yes
-fi
 # Check whether --with-tiff or --without-tiff was given.
 if test "${with_tiff+set}" = set; then
   withval="$with_tiff"
@@ -3251,23 +3234,6 @@
-# Check whether --with-jpeg-includes or --without-jpeg-includes was given.
-if test "${with_jpeg_includes+set}" = set; then
-  withval="$with_jpeg_includes"
-fi
-# Check whether --with-jpeg-libs or --without-jpeg-libs was given.
-if test "${with_jpeg_libs+set}" = set; then
-  withval="$with_jpeg_libs"
-fi
 # Check whether --with-tiff-includes or --without-tiff-includes was given.
 if test "${with_tiff_includes+set}" = set; then
   withval="$with_tiff_includes"
@@ -3615,7 +3581,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3619: checking for additional include dirs" >&5
+echo "configure:3585: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3638,7 +3604,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3642: checking for additional library dirs" >&5
+echo "configure:3608: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3672,7 +3638,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3676: checking for a BSD compatible install" >&5
+echo "configure:3642: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3725,7 +3691,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3729: checking for $ac_word" >&5
+echo "configure:3695: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3756,13 +3722,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3760: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3726: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3766 "configure"
+#line 3732 "configure"
@@ -3773,7 +3739,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3798,7 +3764,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3802: checking for $ac_word" >&5
+echo "configure:3768: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3838,7 +3804,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3842: checking for $ac_word" >&5
+echo "configure:3808: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3869,7 +3835,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3873: checking for $ac_word" >&5
+echo "configure:3839: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3907,7 +3873,7 @@
-echo "configure:3911: checking for $ac_word" >&5
+echo "configure:3877: checking for $ac_word" >&5
@@ -3936,7 +3902,7 @@
-echo "configure:3940: checking for $ac_word" >&5
+echo "configure:3906: checking for $ac_word" >&5
@@ -3967,7 +3933,7 @@
-echo "configure:3971: checking for $ac_word" >&5
+echo "configure:3937: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3996,7 +3962,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:4000: checking for $ac_word" >&5
+echo "configure:3966: checking for $ac_word" >&5
 case "$PERL" in
@@ -4027,10 +3993,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:4031: checking for ANSI C header files" >&5
+echo "configure:3997: checking for ANSI C header files" >&5
-#line 4034 "configure"
+#line 4000 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -4038,7 +4004,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:4042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4055,7 +4021,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4059 "configure"
+#line 4025 "configure"
 #include <string.h>
 EOF
@@ -4073,7 +4039,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4077 "configure"
+#line 4043 "configure"
 #include <stdlib.h>
 EOF
@@ -4094,7 +4060,7 @@
 else
-#line 4098 "configure"
+#line 4064 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4105,7 +4071,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4132,15 +4098,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4136: checking for $ac_hdr" >&5
+echo "configure:4102: checking for $ac_hdr" >&5
-#line 4139 "configure"
+#line 4105 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4144: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4169,15 +4135,15 @@
 do
-echo "configure:4173: checking for $ac_hdr" >&5
+echo "configure:4139: checking for $ac_hdr" >&5
-#line 4176 "configure"
+#line 4142 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4206,15 +4172,15 @@
 do
-echo "configure:4210: checking for $ac_hdr" >&5
+echo "configure:4176: checking for $ac_hdr" >&5
-#line 4213 "configure"
+#line 4179 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4243,15 +4209,15 @@
 do
-echo "configure:4247: checking for $ac_hdr" >&5
+echo "configure:4213: checking for $ac_hdr" >&5
-#line 4250 "configure"
+#line 4216 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4280,15 +4246,15 @@
 do
-echo "configure:4284: checking for $ac_hdr" >&5
+echo "configure:4250: checking for $ac_hdr" >&5
-#line 4287 "configure"
+#line 4253 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4314,10 +4280,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4318: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4284: checking whether time.h and sys/time.h may both be included" >&5
-#line 4321 "configure"
+#line 4287 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4326,7 +4292,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4346,10 +4312,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4350: checking for off_t" >&5
+echo "configure:4316: checking for off_t" >&5
-#line 4353 "configure"
+#line 4319 "configure"
 #if STDC_HEADERS
@@ -4376,10 +4342,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4380: checking for uid_t in sys/types.h" >&5
+echo "configure:4346: checking for uid_t in sys/types.h" >&5
-#line 4383 "configure"
+#line 4349 "configure"
 EOF
@@ -4407,10 +4373,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4411: checking return type of signal handlers" >&5
+echo "configure:4377: checking return type of signal handlers" >&5
-#line 4414 "configure"
+#line 4380 "configure"
 #include <signal.h>
@@ -4427,7 +4393,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4445,10 +4411,10 @@
-echo "configure:4449: checking for Cygwin environment" >&5
+echo "configure:4415: checking for Cygwin environment" >&5
-#line 4452 "configure"
+#line 4418 "configure"
 int main() {
@@ -4459,7 +4425,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4463: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4477,10 +4443,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4481: checking for $ac_func" >&5
+echo "configure:4447: checking for $ac_func" >&5
-#line 4484 "configure"
+#line 4450 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4503,7 +4469,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4529,10 +4495,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4533: checking for $ac_func" >&5
+echo "configure:4499: checking for $ac_func" >&5
-#line 4536 "configure"
+#line 4502 "configure"
@@ -4555,7 +4521,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4581,10 +4547,10 @@
 for ac_func in drand48
 do
-echo "configure:4585: checking for $ac_func" >&5
+echo "configure:4551: checking for $ac_func" >&5
-#line 4588 "configure"
+#line 4554 "configure"
@@ -4607,7 +4573,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4633,10 +4599,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4637: checking for $ac_func" >&5
+echo "configure:4603: checking for $ac_func" >&5
-#line 4640 "configure"
+#line 4606 "configure"
@@ -4659,7 +4625,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4685,10 +4651,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4689: checking for $ac_func" >&5
+echo "configure:4655: checking for $ac_func" >&5
-#line 4692 "configure"
+#line 4658 "configure"
@@ -4711,7 +4677,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4736,13 +4702,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4740: checking whether setpgrp takes no argument" >&5
+echo "configure:4706: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4746 "configure"
+#line 4712 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4762,7 +4728,7 @@
 EOF
-if { (eval echo configure:4766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4790,16 +4756,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4794: checking for long long int" >&5
+echo "configure:4760: checking for long long int" >&5
-#line 4796 "configure"
+#line 4762 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4819,7 +4785,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4823: checking for W11" >&5
+echo "configure:4789: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4847,7 +4813,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4851: checking for X" >&5
+echo "configure:4817: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4907,12 +4873,12 @@
   # First, try using that file with no special directory specified.
-#line 4911 "configure"
+#line 4877 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4981,14 +4947,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4985 "configure"
+#line 4951 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -5093,17 +5059,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5097: checking whether -R must be followed by a space" >&5
+echo "configure:5063: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5100 "configure"
+#line 5066 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5119,14 +5085,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5123 "configure"
+#line 5089 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5158,13 +5124,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5162: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5128: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5168 "configure"
+#line 5134 "configure"
@@ -5175,7 +5141,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5196,13 +5162,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5200: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5166: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5206 "configure"
+#line 5172 "configure"
@@ -5213,7 +5179,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5241,10 +5207,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5245: checking for gethostbyname" >&5
+echo "configure:5211: checking for gethostbyname" >&5
-#line 5248 "configure"
+#line 5214 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5267,7 +5233,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5287,13 +5253,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5291: checking for gethostbyname in -lnsl" >&5
+echo "configure:5257: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5297 "configure"
+#line 5263 "configure"
@@ -5304,7 +5270,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5333,10 +5299,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5337: checking for connect" >&5
+echo "configure:5303: checking for connect" >&5
-#line 5340 "configure"
+#line 5306 "configure"
     which can conflict with char connect(); below.  */
@@ -5359,7 +5325,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5379,13 +5345,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5383: checking for connect in -lsocket" >&5
+echo "configure:5349: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5389 "configure"
+#line 5355 "configure"
@@ -5396,7 +5362,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5419,10 +5385,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5423: checking for remove" >&5
+echo "configure:5389: checking for remove" >&5
-#line 5426 "configure"
+#line 5392 "configure"
     which can conflict with char remove(); below.  */
@@ -5445,7 +5411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5465,13 +5431,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5469: checking for remove in -lposix" >&5
+echo "configure:5435: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5475 "configure"
+#line 5441 "configure"
@@ -5482,7 +5448,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5505,10 +5471,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5509: checking for shmat" >&5
+echo "configure:5475: checking for shmat" >&5
-#line 5512 "configure"
+#line 5478 "configure"
     which can conflict with char shmat(); below.  */
@@ -5531,7 +5497,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5551,13 +5517,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5555: checking for shmat in -lipc" >&5
+echo "configure:5521: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5561 "configure"
+#line 5527 "configure"
@@ -5568,7 +5534,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5600,13 +5566,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5604: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5570: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5610 "configure"
+#line 5576 "configure"
@@ -5617,7 +5583,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5655,7 +5621,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5659: checking whether to use Curses" >&5
+echo "configure:5625: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5674,15 +5640,15 @@
 do
-echo "configure:5678: checking for $ac_hdr" >&5
+echo "configure:5644: checking for $ac_hdr" >&5
-#line 5681 "configure"
+#line 5647 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5713,10 +5679,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5717: checking curses.h WINDOW structure component" >&5
+echo "configure:5683: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5720 "configure"
+#line 5686 "configure"
 #include <curses.h>
@@ -5725,7 +5691,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5729: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5695: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5734,7 +5700,7 @@
 fi
 rm -f conftest*
-#line 5738 "configure"
+#line 5704 "configure"
 #include <curses.h>
@@ -5743,7 +5709,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5747: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5759,13 +5725,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5763: checking for initscr in -lncurses" >&5
+echo "configure:5729: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5769 "configure"
+#line 5735 "configure"
@@ -5776,7 +5742,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5795,13 +5761,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5799: checking for initscr in -lcurses" >&5
+echo "configure:5765: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5805 "configure"
+#line 5771 "configure"
@@ -5812,7 +5778,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5841,13 +5807,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5845: checking for keypad in -lncurses" >&5
+echo "configure:5811: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5851 "configure"
+#line 5817 "configure"
@@ -5858,7 +5824,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5880,13 +5846,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5884: checking for keypad in -lcurses" >&5
+echo "configure:5850: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5890 "configure"
+#line 5856 "configure"
@@ -5897,7 +5863,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5927,13 +5893,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5931: checking for gtty in -lcompat" >&5
+echo "configure:5897: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5937 "configure"
+#line 5903 "configure"
@@ -5944,7 +5910,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5963,13 +5929,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5967: checking for gtty in -lbsd-compat" >&5
+echo "configure:5933: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5973 "configure"
+#line 5939 "configure"
@@ -5980,7 +5946,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5999,13 +5965,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:6003: checking for gtty in -lbsd" >&5
+echo "configure:5969: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 6009 "configure"
+#line 5975 "configure"
@@ -6016,7 +5982,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:6020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6050,12 +6016,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6054: checking for library containing cuserid" >&5
+echo "configure:6020: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 6059 "configure"
+#line 6025 "configure"
@@ -6066,7 +6032,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -6077,7 +6043,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 6081 "configure"
+#line 6047 "configure"
@@ -6088,7 +6054,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -6114,10 +6080,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6118: checking for xdrmem_create" >&5
+echo "configure:6084: checking for xdrmem_create" >&5
-#line 6121 "configure"
+#line 6087 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -6140,7 +6106,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6158,13 +6124,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6162: checking for xdrmem_create in -lsun" >&5
+echo "configure:6128: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6168 "configure"
+#line 6134 "configure"
@@ -6175,7 +6141,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6194,13 +6160,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6198: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6164: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6204 "configure"
+#line 6170 "configure"
@@ -6211,7 +6177,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6230,13 +6196,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6234: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6200: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6240 "configure"
+#line 6206 "configure"
@@ -6247,7 +6213,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6266,13 +6232,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6270: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6236: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6276 "configure"
+#line 6242 "configure"
@@ -6283,7 +6249,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6317,10 +6283,10 @@
 for ac_func in asprintf
 do
-echo "configure:6321: checking for $ac_func" >&5
+echo "configure:6287: checking for $ac_func" >&5
-#line 6324 "configure"
+#line 6290 "configure"
@@ -6343,7 +6309,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6370,10 +6336,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6374: checking for atan" >&5
+echo "configure:6340: checking for atan" >&5
-#line 6377 "configure"
+#line 6343 "configure"
     which can conflict with char atan(); below.  */
@@ -6396,7 +6362,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6414,13 +6380,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6418: checking for atan in -lm" >&5
+echo "configure:6384: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6424 "configure"
+#line 6390 "configure"
@@ -6431,7 +6397,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6458,10 +6424,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6462: checking for dlsym" >&5
+echo "configure:6428: checking for dlsym" >&5
-#line 6465 "configure"
+#line 6431 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6484,7 +6450,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6502,13 +6468,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6506: checking for dlsym in -ldl" >&5
+echo "configure:6472: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6512 "configure"
+#line 6478 "configure"
@@ -6519,7 +6485,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6546,10 +6512,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6550: checking for iconv" >&5
+echo "configure:6516: checking for iconv" >&5
-#line 6553 "configure"
+#line 6519 "configure"
     which can conflict with char iconv(); below.  */
@@ -6572,7 +6538,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6590,13 +6556,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6594: checking for iconv in -liconv" >&5
+echo "configure:6560: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6600 "configure"
+#line 6566 "configure"
@@ -6607,7 +6573,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6626,13 +6592,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6630: checking for iconv in -lgiconv" >&5
+echo "configure:6596: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6636 "configure"
+#line 6602 "configure"
@@ -6643,7 +6609,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6662,10 +6628,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6666: checking for libiconv" >&5
+echo "configure:6632: checking for libiconv" >&5
-#line 6669 "configure"
+#line 6635 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6688,7 +6654,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6706,13 +6672,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6710: checking for libiconv in -liconv" >&5
+echo "configure:6676: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6716 "configure"
+#line 6682 "configure"
@@ -6723,7 +6689,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6742,13 +6708,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6746: checking for libiconv in -lgiconv" >&5
+echo "configure:6712: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6752 "configure"
+#line 6718 "configure"
@@ -6759,7 +6725,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6796,10 +6762,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6800: checking for socket" >&5
+echo "configure:6766: checking for socket" >&5
-#line 6803 "configure"
+#line 6769 "configure"
     which can conflict with char socket(); below.  */
@@ -6822,7 +6788,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6840,13 +6806,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6844: checking for socket in -lsocket" >&5
+echo "configure:6810: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6850 "configure"
+#line 6816 "configure"
@@ -6857,7 +6823,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6905,7 +6871,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6909: checking for location of zlib includes" >&5
+echo "configure:6875: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6931,15 +6897,15 @@
 do
-echo "configure:6935: checking for $ac_hdr" >&5
+echo "configure:6901: checking for $ac_hdr" >&5
-#line 6938 "configure"
+#line 6904 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6973,7 +6939,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6977: checking for location of zlib library" >&5
+echo "configure:6943: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6998,13 +6964,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:7002: checking for deflate in -lz" >&5
+echo "configure:6968: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 7008 "configure"
+#line 6974 "configure"
@@ -7015,7 +6981,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:7019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7063,7 +7029,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7067: checking for location of External PROJ.4 includes" >&5
+echo "configure:7033: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7089,15 +7055,15 @@
 do
-echo "configure:7093: checking for $ac_hdr" >&5
+echo "configure:7059: checking for $ac_hdr" >&5
-#line 7096 "configure"
+#line 7062 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7134,7 +7100,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7138: checking External PROJ.4 version" >&5
+echo "configure:7104: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7142,7 +7108,7 @@
 else
   cat > conftest.$ac_ext <<EOF
-#line 7146 "configure"
+#line 7112 "configure"
 #include <stdio.h>
@@ -7154,7 +7120,7 @@
 EOF
-if { (eval echo configure:7158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7179,7 +7145,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7183: checking for location of External PROJ.4 library" >&5
+echo "configure:7149: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7204,13 +7170,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7208: checking for pj_get_def in -lproj" >&5
+echo "configure:7174: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7214 "configure"
+#line 7180 "configure"
@@ -7221,7 +7187,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7255,7 +7221,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7259: checking for location of External PROJ.4 data files" >&5
+echo "configure:7225: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7279,14 +7245,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7283: checking for epsg" >&5
+echo "configure:7249: checking for epsg" >&5
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7290: checking for $PROJSHARE/epsg" >&5
+echo "configure:7256: checking for $PROJSHARE/epsg" >&5
 if test "$cross_compiling" = yes; then
@@ -7318,7 +7284,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7322: checking for $ac_word" >&5
+echo "configure:7288: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7358,7 +7324,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7362: checking whether to use regex" >&5
+echo "configure:7328: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7378,7 +7344,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7382: checking for location of regex includes" >&5
+echo "configure:7348: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7404,15 +7370,15 @@
 do
-echo "configure:7408: checking for $ac_hdr" >&5
+echo "configure:7374: checking for $ac_hdr" >&5
-#line 7411 "configure"
+#line 7377 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7382: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7446,7 +7412,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7450: checking for location of regex library" >&5
+echo "configure:7416: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7471,10 +7437,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7475: checking for regcomp" >&5
+echo "configure:7441: checking for regcomp" >&5
-#line 7478 "configure"
+#line 7444 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7497,7 +7463,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7524,13 +7490,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7528: checking for regcomp in -lregex" >&5
+echo "configure:7494: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7534 "configure"
+#line 7500 "configure"
@@ -7541,7 +7507,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7591,7 +7557,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7595: checking whether to use Readline" >&5
+echo "configure:7561: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7612,7 +7578,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7616: checking for location of Readline includes" >&5
+echo "configure:7582: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7638,15 +7604,15 @@
 do
-echo "configure:7642: checking for $ac_hdr" >&5
+echo "configure:7608: checking for $ac_hdr" >&5
-#line 7645 "configure"
+#line 7611 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7650: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7682,15 +7648,15 @@
 do
-echo "configure:7686: checking for $ac_hdr" >&5
+echo "configure:7652: checking for $ac_hdr" >&5
-#line 7689 "configure"
+#line 7655 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7724,7 +7690,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7728: checking for location of Readline library" >&5
+echo "configure:7694: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7749,13 +7715,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7753: checking for readline in -lreadline" >&5
+echo "configure:7719: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7759 "configure"
+#line 7725 "configure"
@@ -7766,7 +7732,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7801,13 +7767,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7805: checking for add_history in -lhistory" >&5
+echo "configure:7771: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7811 "configure"
+#line 7777 "configure"
@@ -7818,7 +7784,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7857,228 +7823,10 @@
 # Done checking Readline
-# Enable JPEG option
-echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7865: checking whether to use JPEG" >&5
-echo "$ac_t"""$with_jpeg"" 1>&6
-case "$with_jpeg" in
-	"no")	USE_JPEG=	;;
-	"yes")	USE_JPEG="1"	;;
-	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
-esac
-JPEGINCPATH=
-JPEGLIBPATH=
-JPEGLIB=
-if test -n "$USE_JPEG"; then
-# With JPEG includes directory
-echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7885: checking for location of JPEG includes" >&5
-case "$with_jpeg_includes" in
-y | ye | yes | n | no)
-	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_jpeg_includes" 1>&6
-if test -n "$with_jpeg_includes" ; then
-    for dir in $with_jpeg_includes; do
-        if test -d "$dir"; then
-            JPEGINCPATH="$JPEGINCPATH -I$dir"
-        else
-            { echo "configure: error: *** JPEG includes directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$JPEGINCPATH $CPPFLAGS"
-for ac_hdr in jpeglib.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7911: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 7914 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=yes"
-else
-  echo "$ac_err" >&5
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
-  cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-  echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate JPEG includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-# With JPEG library directory
-echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7953: checking for location of JPEG library" >&5
-case "$with_jpeg_libs" in
-	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_jpeg_libs" 1>&6
-if test -n "$with_jpeg_libs"; then
-    for dir in $with_jpeg_libs; do
-            JPEGLIBPATH="$JPEGLIBPATH -L$dir"
-        else
-            { echo "configure: error: *** JPEG library directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$JPEGLIBPATH $LDFLAGS"
-echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7980: checking for jpeg_start_compress in -ljpeg" >&5
-ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-ljpeg  $LIBS"
-#line 7986 "configure"
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char jpeg_start_compress();
-int main() {
-jpeg_start_compress()
-; return 0; }
-EOF
-if { (eval echo configure:7997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  JPEGLIB="$JPEGLIB -ljpeg "
-else
-echo "configure:8016: checking for jpeg_start_compress in -ljpeg" >&5
-LIBS="-ljpeg $ZLIB $LIBS"
-#line 8022 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:8033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  JPEGLIB="$JPEGLIB -ljpeg $ZLIB"
-else
-LDFLAGS=${ac_save_ldflags}
-    { echo "configure: error: *** Unable to locate JPEG library." 1>&2; exit 1; }
-fi
-fi
-fi # $USE_JPEG
-# Done checking JPEG
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:8082: checking whether to use GDAL" >&5
+echo "configure:7830: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -8096,7 +7844,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:8100: checking for $ac_word" >&5
+echo "configure:7848: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -8151,14 +7899,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 8155 "configure"
+#line 7903 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:8162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -8167,14 +7915,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8171 "configure"
+#line 7919 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:8178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -8206,7 +7954,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:8210: checking whether to use GEOS" >&5
+echo "configure:7958: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -8224,7 +7972,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:8228: checking for $ac_word" >&5
+echo "configure:7976: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -8272,15 +8020,15 @@
 do
-echo "configure:8276: checking for $ac_hdr" >&5
+echo "configure:8024: checking for $ac_hdr" >&5
-#line 8279 "configure"
+#line 8027 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8316,13 +8064,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:8320: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:8068: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 8326 "configure"
+#line 8074 "configure"
@@ -8333,7 +8081,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8369,13 +8117,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8373: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8121: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 8379 "configure"
+#line 8127 "configure"
@@ -8386,7 +8134,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8431,7 +8179,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8435: checking whether to use TIFF" >&5
+echo "configure:8183: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8451,7 +8199,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8455: checking for location of TIFF includes" >&5
+echo "configure:8203: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8477,15 +8225,15 @@
 do
-echo "configure:8481: checking for $ac_hdr" >&5
+echo "configure:8229: checking for $ac_hdr" >&5
-#line 8484 "configure"
+#line 8232 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8519,7 +8267,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8523: checking for location of TIFF library" >&5
+echo "configure:8271: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8550,13 +8298,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8554: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8302: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8560 "configure"
+#line 8308 "configure"
@@ -8567,7 +8315,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8586,13 +8334,13 @@
-echo "configure:8590: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8338: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8596 "configure"
+#line 8344 "configure"
@@ -8603,7 +8351,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8622,13 +8370,13 @@
-echo "configure:8626: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8374: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8632 "configure"
+#line 8380 "configure"
@@ -8639,7 +8387,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8658,13 +8406,13 @@
-echo "configure:8662: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8410: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8668 "configure"
+#line 8416 "configure"
@@ -8675,7 +8423,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8694,13 +8442,13 @@
-echo "configure:8698: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8446: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
+LIBS="-ltiff -ljpeg $LIBS"
-#line 8704 "configure"
+#line 8452 "configure"
@@ -8711,7 +8459,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8725,18 +8473,18 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg"
 else
-echo "configure:8734: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8482: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
+LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8740 "configure"
+#line 8488 "configure"
@@ -8747,7 +8495,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8761,18 +8509,18 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg $MATHLIB"
 else
-echo "configure:8770: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8518: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
+LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8776 "configure"
+#line 8524 "configure"
@@ -8783,7 +8531,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8797,18 +8545,18 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $ZLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg $ZLIB"
 else
-echo "configure:8806: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8554: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
+LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8812 "configure"
+#line 8560 "configure"
@@ -8819,7 +8567,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8833,7 +8581,7 @@
-  TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB"
+  TIFFLIB="$TIFFLIB -ltiff -ljpeg $ZLIB $MATHLIB"
 else
@@ -8917,7 +8665,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8921: checking whether to use PNG" >&5
+echo "configure:8669: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8936,7 +8684,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8940: checking for location of PNG includes" >&5
+echo "configure:8688: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8962,15 +8710,15 @@
 do
-echo "configure:8966: checking for $ac_hdr" >&5
+echo "configure:8714: checking for $ac_hdr" >&5
-#line 8969 "configure"
+#line 8717 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9004,7 +8752,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:9008: checking for location of PNG library" >&5
+echo "configure:8756: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -9029,13 +8777,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:9033: checking for png_read_image in -lpng" >&5
+echo "configure:8781: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 9039 "configure"
+#line 8787 "configure"
@@ -9046,7 +8794,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:9050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9088,7 +8836,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9092: checking whether to use PostgreSQL" >&5
+echo "configure:8840: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9115,7 +8863,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9119: checking for location of PostgreSQL includes" >&5
+echo "configure:8867: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9141,15 +8889,15 @@
 do
-echo "configure:9145: checking for $ac_hdr" >&5
+echo "configure:8893: checking for $ac_hdr" >&5
-#line 9148 "configure"
+#line 8896 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9153: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9187,7 +8935,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9191: checking for location of PostgreSQL library" >&5
+echo "configure:8939: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9216,13 +8964,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9220: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8968: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9226 "configure"
+#line 8974 "configure"
@@ -9233,7 +8981,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9252,13 +9000,13 @@
-echo "configure:9256: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9004: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9262 "configure"
+#line 9010 "configure"
@@ -9269,7 +9017,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9288,13 +9036,13 @@
-echo "configure:9292: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9040: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9298 "configure"
+#line 9046 "configure"
@@ -9305,7 +9053,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9324,13 +9072,13 @@
-echo "configure:9328: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9076: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9334 "configure"
+#line 9082 "configure"
@@ -9341,7 +9089,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9398,13 +9146,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9402: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9150: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9408 "configure"
+#line 9156 "configure"
@@ -9415,7 +9163,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9437,13 +9185,13 @@
-echo "configure:9441: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9189: checking for PQcmdTuples in -lpq" >&5
-#line 9447 "configure"
+#line 9195 "configure"
@@ -9454,7 +9202,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9497,7 +9245,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9501: checking whether to use MySQL" >&5
+echo "configure:9249: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9517,7 +9265,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9521: checking for location of MySQL includes" >&5
+echo "configure:9269: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9543,15 +9291,15 @@
 do
-echo "configure:9547: checking for $ac_hdr" >&5
+echo "configure:9295: checking for $ac_hdr" >&5
-#line 9550 "configure"
+#line 9298 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9588,7 +9336,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9592: checking for location of MySQL library" >&5
+echo "configure:9340: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9619,13 +9367,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9623: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9371: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9629 "configure"
+#line 9377 "configure"
@@ -9636,7 +9384,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9655,13 +9403,13 @@
-echo "configure:9659: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9407: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9665 "configure"
+#line 9413 "configure"
@@ -9672,7 +9420,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9691,13 +9439,13 @@
-echo "configure:9695: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9443: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9701 "configure"
+#line 9449 "configure"
@@ -9708,7 +9456,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9727,13 +9475,13 @@
-echo "configure:9731: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9479: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9737 "configure"
+#line 9485 "configure"
@@ -9744,7 +9492,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9763,13 +9511,13 @@
-echo "configure:9767: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9515: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9773 "configure"
+#line 9521 "configure"
@@ -9780,7 +9528,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9799,13 +9547,13 @@
-echo "configure:9803: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9551: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9809 "configure"
+#line 9557 "configure"
@@ -9816,7 +9564,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9835,13 +9583,13 @@
-echo "configure:9839: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9587: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9845 "configure"
+#line 9593 "configure"
@@ -9852,7 +9600,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9871,13 +9619,13 @@
-echo "configure:9875: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9623: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9881 "configure"
+#line 9629 "configure"
@@ -9888,7 +9636,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9978,7 +9726,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9982: checking for $ac_word" >&5
+echo "configure:9730: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10019,10 +9767,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10023: checking for mysql_server_init" >&5
+echo "configure:9771: checking for mysql_server_init" >&5
-#line 10026 "configure"
+#line 9774 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10045,7 +9793,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10083,7 +9831,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10087: checking whether to use SQLite" >&5
+echo "configure:9835: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10103,7 +9851,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10107: checking for location of SQLite includes" >&5
+echo "configure:9855: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10129,15 +9877,15 @@
 do
-echo "configure:10133: checking for $ac_hdr" >&5
+echo "configure:9881: checking for $ac_hdr" >&5
-#line 10136 "configure"
+#line 9884 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10180,7 +9928,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10184: checking for location of SQLite library" >&5
+echo "configure:9932: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10209,13 +9957,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10213: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9961: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10219 "configure"
+#line 9967 "configure"
@@ -10226,7 +9974,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10245,13 +9993,13 @@
-echo "configure:10249: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9997: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10255 "configure"
+#line 10003 "configure"
@@ -10262,7 +10010,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10281,13 +10029,13 @@
-echo "configure:10285: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10033: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10291 "configure"
+#line 10039 "configure"
@@ -10298,7 +10046,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10317,13 +10065,13 @@
-echo "configure:10321: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10069: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10327 "configure"
+#line 10075 "configure"
@@ -10334,7 +10082,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10403,7 +10151,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10407: checking whether to use FFMPEG" >&5
+echo "configure:10155: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10423,7 +10171,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10427: checking for location of FFMPEG includes" >&5
+echo "configure:10175: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10449,15 +10197,15 @@
 do
-echo "configure:10453: checking for $ac_hdr" >&5
+echo "configure:10201: checking for $ac_hdr" >&5
-#line 10456 "configure"
+#line 10204 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10461: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10493,15 +10241,15 @@
 do
-echo "configure:10497: checking for $ac_hdr" >&5
+echo "configure:10245: checking for $ac_hdr" >&5
-#line 10500 "configure"
+#line 10248 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10537,15 +10285,15 @@
 do
-echo "configure:10541: checking for $ac_hdr" >&5
+echo "configure:10289: checking for $ac_hdr" >&5
-#line 10544 "configure"
+#line 10292 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10588,7 +10336,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10592: checking for location of FFMPEG library" >&5
+echo "configure:10340: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10615,13 +10363,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10619: checking for av_free in -lavutil" >&5
+echo "configure:10367: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10625 "configure"
+#line 10373 "configure"
@@ -10632,7 +10380,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10651,13 +10399,13 @@
-echo "configure:10655: checking for av_free in -lavutil" >&5
+echo "configure:10403: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10661 "configure"
+#line 10409 "configure"
@@ -10668,7 +10416,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10713,13 +10461,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10717: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10465: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10723 "configure"
+#line 10471 "configure"
@@ -10730,7 +10478,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10749,13 +10497,13 @@
-echo "configure:10753: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10501: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10759 "configure"
+#line 10507 "configure"
@@ -10766,7 +10514,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10811,13 +10559,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10815: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10563: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10821 "configure"
+#line 10569 "configure"
@@ -10828,7 +10576,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10847,13 +10595,13 @@
-echo "configure:10851: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10599: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10857 "configure"
+#line 10605 "configure"
@@ -10864,7 +10612,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10923,7 +10671,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10927: checking whether to use OpenGL" >&5
+echo "configure:10675: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10957,7 +10705,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10961: checking for location of OpenGL includes" >&5
+echo "configure:10709: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10983,15 +10731,15 @@
 do
-echo "configure:10987: checking for $ac_hdr" >&5
+echo "configure:10735: checking for $ac_hdr" >&5
-#line 10990 "configure"
+#line 10738 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10995: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11025,7 +10773,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11029: checking for location of OpenGL library" >&5
+echo "configure:10777: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11054,13 +10802,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11058: checking for glBegin in -lGL" >&5
+echo "configure:10806: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11064 "configure"
+#line 10812 "configure"
@@ -11071,7 +10819,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11090,13 +10838,13 @@
-echo "configure:11094: checking for glBegin in -lGL" >&5
+echo "configure:10842: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11100 "configure"
+#line 10848 "configure"
@@ -11107,7 +10855,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11126,13 +10874,13 @@
-echo "configure:11130: checking for glBegin in -lGL" >&5
+echo "configure:10878: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11136 "configure"
+#line 10884 "configure"
@@ -11143,7 +10891,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11162,13 +10910,13 @@
-echo "configure:11166: checking for glBegin in -lGL" >&5
+echo "configure:10914: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11172 "configure"
+#line 10920 "configure"
@@ -11179,7 +10927,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11241,13 +10989,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11245: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10993: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11251 "configure"
+#line 10999 "configure"
@@ -11258,7 +11006,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11277,13 +11025,13 @@
-echo "configure:11281: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11029: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11287 "configure"
+#line 11035 "configure"
@@ -11294,7 +11042,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11338,10 +11086,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11342: checking for glXCreatePbuffer" >&5
+echo "configure:11090: checking for glXCreatePbuffer" >&5
-#line 11345 "configure"
+#line 11093 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11364,7 +11112,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11386,10 +11134,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11390: checking for glXCreateGLXPixmap" >&5
+echo "configure:11138: checking for glXCreateGLXPixmap" >&5
-#line 11393 "configure"
+#line 11141 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11412,7 +11160,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11451,7 +11199,7 @@
-echo "configure:11455: checking for location of OpenGL includes" >&5
+echo "configure:11203: checking for location of OpenGL includes" >&5
@@ -11477,15 +11225,15 @@
 do
-echo "configure:11481: checking for $ac_hdr" >&5
+echo "configure:11229: checking for $ac_hdr" >&5
-#line 11484 "configure"
+#line 11232 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11520,10 +11268,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11524: checking for glBegin" >&5
+echo "configure:11272: checking for glBegin" >&5
-#line 11527 "configure"
+#line 11275 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11546,7 +11294,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11561,10 +11309,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11565: checking for gluBeginCurve" >&5
+echo "configure:11313: checking for gluBeginCurve" >&5
-#line 11568 "configure"
+#line 11316 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11587,7 +11335,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11631,7 +11379,7 @@
-echo "configure:11635: checking for location of OpenGL includes" >&5
+echo "configure:11383: checking for location of OpenGL includes" >&5
@@ -11657,15 +11405,15 @@
 do
-echo "configure:11661: checking for $ac_hdr" >&5
+echo "configure:11409: checking for $ac_hdr" >&5
-#line 11664 "configure"
+#line 11412 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11699,7 +11447,7 @@
-echo "configure:11703: checking for location of OpenGL library" >&5
+echo "configure:11451: checking for location of OpenGL library" >&5
@@ -11724,18 +11472,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11728: checking for OpenGL library" >&5
+echo "configure:11476: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11732 "configure"
+#line 11480 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11759,18 +11507,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11763: checking for GLU library" >&5
+echo "configure:11511: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11767 "configure"
+#line 11515 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11819,7 +11567,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11823: checking whether to use Tcl/Tk" >&5
+echo "configure:11571: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11839,7 +11587,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11843: checking for location of Tcl/Tk includes" >&5
+echo "configure:11591: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11865,15 +11613,15 @@
 do
-echo "configure:11869: checking for $ac_hdr" >&5
+echo "configure:11617: checking for $ac_hdr" >&5
-#line 11872 "configure"
+#line 11620 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11877: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11910,15 +11658,15 @@
 do
-echo "configure:11914: checking for $ac_hdr" >&5
+echo "configure:11662: checking for $ac_hdr" >&5
-#line 11917 "configure"
+#line 11665 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11922: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11951,7 +11699,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11955: checking Tcl version" >&5
+echo "configure:11703: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
@@ -11959,7 +11707,7 @@
 else
-#line 11963 "configure"
+#line 11711 "configure"
 #include <stdio.h>
@@ -11971,7 +11719,7 @@
 EOF
-if { (eval echo configure:11975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11989,7 +11737,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11993: checking Tk version" >&5
+echo "configure:11741: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11997,7 +11745,7 @@
 else
-#line 12001 "configure"
+#line 11749 "configure"
 #include <stdio.h>
@@ -12009,7 +11757,7 @@
 EOF
-if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -12040,7 +11788,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:12044: checking for location of Tcl/Tk library" >&5
+echo "configure:11792: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -12080,13 +11828,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:12084: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11832: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 12090 "configure"
+#line 11838 "configure"
@@ -12097,7 +11845,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12116,13 +11864,13 @@
-echo "configure:12120: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11868: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 12126 "configure"
+#line 11874 "configure"
@@ -12133,7 +11881,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12160,13 +11908,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12164: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11912: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 12170 "configure"
+#line 11918 "configure"
@@ -12177,7 +11925,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12196,13 +11944,13 @@
-echo "configure:12200: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11948: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12206 "configure"
+#line 11954 "configure"
@@ -12213,7 +11961,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12240,13 +11988,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12244: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11992: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12250 "configure"
+#line 11998 "configure"
@@ -12257,7 +12005,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12276,13 +12024,13 @@
-echo "configure:12280: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12028: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12286 "configure"
+#line 12034 "configure"
@@ -12293,7 +12041,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12371,13 +12119,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12375: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12123: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12381 "configure"
+#line 12129 "configure"
@@ -12388,7 +12136,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12407,13 +12155,13 @@
-echo "configure:12411: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12159: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12417 "configure"
+#line 12165 "configure"
@@ -12424,7 +12172,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12451,13 +12199,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12455: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12203: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12461 "configure"
+#line 12209 "configure"
@@ -12468,7 +12216,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12487,13 +12235,13 @@
-echo "configure:12491: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12239: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12497 "configure"
+#line 12245 "configure"
@@ -12504,7 +12252,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12531,13 +12279,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12535: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12283: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12541 "configure"
+#line 12289 "configure"
@@ -12548,7 +12296,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12567,13 +12315,13 @@
-echo "configure:12571: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12319: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12577 "configure"
+#line 12325 "configure"
@@ -12584,7 +12332,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12674,13 +12422,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12678: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12426: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12684 "configure"
+#line 12432 "configure"
@@ -12691,7 +12439,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12740,7 +12488,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12744: checking whether to use ODBC" >&5
+echo "configure:12492: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12759,7 +12507,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12763: checking for location of ODBC includes" >&5
+echo "configure:12511: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12785,15 +12533,15 @@
 do
-echo "configure:12789: checking for $ac_hdr" >&5
+echo "configure:12537: checking for $ac_hdr" >&5
-#line 12792 "configure"
+#line 12540 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12827,7 +12575,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12831: checking for location of ODBC library" >&5
+echo "configure:12579: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12852,13 +12600,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12856: checking for SQLConnect in -lodbc" >&5
+echo "configure:12604: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12862 "configure"
+#line 12610 "configure"
@@ -12869,7 +12617,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12894,13 +12642,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12898: checking for SQLConnect in -liodbc" >&5
+echo "configure:12646: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12904 "configure"
+#line 12652 "configure"
 #include "confdefs.h"
@@ -12911,7 +12659,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12936,11 +12684,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12940: checking for ODBC library" >&5
+echo "configure:12688: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12944 "configure"
+#line 12692 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12948,7 +12696,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12997,7 +12745,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:13001: checking whether to use FFTW" >&5
+echo "configure:12749: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -13016,7 +12764,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:13020: checking for location of FFTW includes" >&5
+echo "configure:12768: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -13042,15 +12790,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13046: checking for $ac_hdr" >&5
+echo "configure:12794: checking for $ac_hdr" >&5
-#line 13049 "configure"
+#line 12797 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13054: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12802: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13078,15 +12826,15 @@
 do
-echo "configure:13082: checking for $ac_hdr" >&5
+echo "configure:12830: checking for $ac_hdr" >&5
-#line 13085 "configure"
+#line 12833 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13090: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13114,15 +12862,15 @@
 do
-echo "configure:13118: checking for $ac_hdr" >&5
+echo "configure:12866: checking for $ac_hdr" >&5
-#line 13121 "configure"
+#line 12869 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13168,7 +12916,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:13172: checking for location of FFTW library" >&5
+echo "configure:12920: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13193,13 +12941,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13197: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12945: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13203 "configure"
+#line 12951 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13210,7 +12958,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:13214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13235,13 +12983,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13239: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12987: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 13245 "configure"
+#line 12993 "configure"
@@ -13252,7 +13000,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13277,13 +13025,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13281: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13029: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13287 "configure"
+#line 13035 "configure"
@@ -13294,7 +13042,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13351,7 +13099,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13355: checking whether to use BLAS" >&5
+echo "configure:13103: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -13372,7 +13120,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13376: checking for location of BLAS includes" >&5
+echo "configure:13124: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13392,7 +13140,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13396: checking for location of BLAS library" >&5
+echo "configure:13144: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13418,15 +13166,15 @@
 do
-echo "configure:13422: checking for $ac_hdr" >&5
+echo "configure:13170: checking for $ac_hdr" >&5
-#line 13425 "configure"
+#line 13173 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13461,13 +13209,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13465: checking for dnrm2_ in -lblas" >&5
+echo "configure:13213: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13471 "configure"
+#line 13219 "configure"
@@ -13478,7 +13226,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13497,13 +13245,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:13501: checking for dnrm2_ in -lblas" >&5
+echo "configure:13249: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13507 "configure"
+#line 13255 "configure"
@@ -13514,7 +13262,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13558,13 +13306,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13562: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13310: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13568 "configure"
+#line 13316 "configure"
@@ -13575,7 +13323,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13590,13 +13338,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13594: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13342: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13600 "configure"
+#line 13348 "configure"
@@ -13607,7 +13355,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13622,13 +13370,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13626: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13374: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13632 "configure"
+#line 13380 "configure"
@@ -13639,7 +13387,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13685,16 +13433,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13689: checking for sgemm in $vlib_flags" >&5
+echo "configure:13437: checking for sgemm in $vlib_flags" >&5
-#line 13691 "configure"
+#line 13439 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13712,13 +13460,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13716: checking for sgemm_ in -lblas" >&5
+echo "configure:13464: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13722 "configure"
+#line 13470 "configure"
@@ -13729,7 +13477,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13744,13 +13492,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13748: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13496: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13754 "configure"
+#line 13502 "configure"
@@ -13761,7 +13509,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13776,13 +13524,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13780: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13528: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13786 "configure"
+#line 13534 "configure"
@@ -13793,7 +13541,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13827,13 +13575,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13831: checking for acosp in -lsunmath" >&5
+echo "configure:13579: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13837 "configure"
+#line 13585 "configure"
@@ -13844,7 +13592,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13859,13 +13607,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13863: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13611: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13869 "configure"
+#line 13617 "configure"
@@ -13876,7 +13624,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13906,13 +13654,13 @@
 # Generic BLAS library
-echo "configure:13910: checking for sgemm_ in -lblas" >&5
+echo "configure:13658: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13916 "configure"
+#line 13664 "configure"
@@ -13923,7 +13671,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13962,7 +13710,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13966: checking whether to use LAPACK" >&5
+echo "configure:13714: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13987,7 +13735,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13991: checking for location of LAPACK includes" >&5
+echo "configure:13739: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -14007,7 +13755,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:14011: checking for location of LAPACK library" >&5
+echo "configure:13759: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -14033,15 +13781,15 @@
 do
-echo "configure:14037: checking for $ac_hdr" >&5
+echo "configure:13785: checking for $ac_hdr" >&5
-#line 14040 "configure"
+#line 13788 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14073,10 +13821,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:14077: checking for dsegv_" >&5
+echo "configure:13825: checking for dsegv_" >&5
-#line 14080 "configure"
+#line 13828 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -14099,7 +13847,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -14126,13 +13874,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14130: checking for desgv_ in -llapack" >&5
+echo "configure:13878: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 14136 "configure"
+#line 13884 "configure"
@@ -14143,7 +13891,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14175,13 +13923,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14179: checking for dgesv_ in -llapack" >&5
+echo "configure:13927: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 14185 "configure"
+#line 13933 "configure"
@@ -14192,7 +13940,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14211,13 +13959,13 @@
-echo "configure:14215: checking for dgesv_ in -llapack" >&5
+echo "configure:13963: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14221 "configure"
+#line 13969 "configure"
@@ -14228,7 +13976,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14284,7 +14032,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14288: checking whether to use Motif" >&5
+echo "configure:14036: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -14303,7 +14051,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14307: checking for location of Motif includes" >&5
+echo "configure:14055: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14329,15 +14077,15 @@
 do
-echo "configure:14333: checking for $ac_hdr" >&5
+echo "configure:14081: checking for $ac_hdr" >&5
-#line 14336 "configure"
+#line 14084 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14089: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14371,7 +14119,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14375: checking for location of Motif library" >&5
+echo "configure:14123: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14396,13 +14144,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14400: checking for XmStringCreate in -lXm" >&5
+echo "configure:14148: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14406 "configure"
+#line 14154 "configure"
@@ -14413,7 +14161,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14454,7 +14202,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14458: checking whether to use Cairo" >&5
+echo "configure:14206: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14486,7 +14234,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14490: checking for location of cairo includes" >&5
+echo "configure:14238: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14512,15 +14260,15 @@
 do
-echo "configure:14516: checking for $ac_hdr" >&5
+echo "configure:14264: checking for $ac_hdr" >&5
-#line 14519 "configure"
+#line 14267 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14524: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14556,7 +14304,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14560: checking for location of cairo library" >&5
+echo "configure:14308: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14576,7 +14324,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14580: checking for cairo linking flags" >&5
+echo "configure:14328: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14592,10 +14340,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14596: checking for cairo_create" >&5
+echo "configure:14344: checking for cairo_create" >&5
-#line 14599 "configure"
+#line 14347 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14618,7 +14366,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14652,10 +14400,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14656: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14404: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14659 "configure"
+#line 14407 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14678,7 +14426,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14711,10 +14459,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14715: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14463: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14718 "configure"
+#line 14466 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14737,7 +14485,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14779,7 +14527,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14783: checking whether to use GLw" >&5
+echo "configure:14531: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14798,7 +14546,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14802: checking for location of GLw includes" >&5
+echo "configure:14550: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14824,15 +14572,15 @@
 do
-echo "configure:14828: checking for $ac_hdr" >&5
+echo "configure:14576: checking for $ac_hdr" >&5
-#line 14831 "configure"
+#line 14579 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14860,15 +14608,15 @@
 do
-echo "configure:14864: checking for $ac_hdr" >&5
+echo "configure:14612: checking for $ac_hdr" >&5
-#line 14867 "configure"
+#line 14615 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14908,7 +14656,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14912: checking for location of GLw library" >&5
+echo "configure:14660: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14933,13 +14681,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14937: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14685: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14943 "configure"
+#line 14691 "configure"
@@ -14950,7 +14698,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14975,13 +14723,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14979: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14727: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14985 "configure"
+#line 14733 "configure"
@@ -14992,7 +14740,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15017,13 +14765,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:15021: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14769: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15027 "configure"
+#line 14775 "configure"
@@ -15034,7 +14782,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:15038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15059,13 +14807,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15063: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14811: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15069 "configure"
+#line 14817 "configure"
@@ -15076,7 +14824,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15101,13 +14849,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15105: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14853: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 15111 "configure"
+#line 14859 "configure"
@@ -15118,7 +14866,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15143,13 +14891,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15147: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14895: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15153 "configure"
+#line 14901 "configure"
@@ -15160,7 +14908,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15187,13 +14935,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:15191: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14939: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15197 "configure"
+#line 14945 "configure"
@@ -15204,7 +14952,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15223,13 +14971,13 @@
-echo "configure:15227: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14975: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15233 "configure"
+#line 14981 "configure"
@@ -15240,7 +14988,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15267,13 +15015,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15271: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15019: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15277 "configure"
+#line 15025 "configure"
@@ -15284,7 +15032,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15303,13 +15051,13 @@
-echo "configure:15307: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15055: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15313 "configure"
+#line 15061 "configure"
@@ -15320,7 +15068,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15433,7 +15181,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15437: checking whether to use FreeType" >&5
+echo "configure:15185: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15452,7 +15200,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15456: checking for location of FreeType includes" >&5
+echo "configure:15204: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15478,15 +15226,15 @@
 do
-echo "configure:15482: checking for $ac_hdr" >&5
+echo "configure:15230: checking for $ac_hdr" >&5
-#line 15485 "configure"
+#line 15233 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15238: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15520,7 +15268,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15524: checking for location of FreeType library" >&5
+echo "configure:15272: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15545,13 +15293,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15549: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15297: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15555 "configure"
+#line 15303 "configure"
@@ -15562,7 +15310,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15603,7 +15351,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15607: checking whether to use NLS" >&5
+echo "configure:15355: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15623,10 +15371,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15627: checking for gettext" >&5
+echo "configure:15375: checking for gettext" >&5
-#line 15630 "configure"
+#line 15378 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15649,7 +15397,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15667,13 +15415,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15671: checking for gettext in -lintl" >&5
+echo "configure:15419: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15677 "configure"
+#line 15425 "configure"
@@ -15684,7 +15432,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15719,7 +15467,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15723: checking whether to use C++" >&5
+echo "configure:15471: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15735,7 +15483,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15739: checking for $ac_word" >&5
+echo "configure:15487: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15764,7 +15512,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15768: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15516: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15775,12 +15523,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15779 "configure"
+#line 15527 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15806,19 +15554,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15810: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15558: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15815: checking whether we are using GNU C++" >&5
+echo "configure:15563: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15836,7 +15584,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15840: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15588: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15864,7 +15612,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 15626 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15634: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 15644 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15651: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -15877,7 +15676,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15881: checking whether to use openDWG" >&5
+echo "configure:15680: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15897,7 +15696,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15901: checking for location of openDGW includes" >&5
+echo "configure:15700: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15923,15 +15722,15 @@
 do
-echo "configure:15927: checking for $ac_hdr" >&5
+echo "configure:15726: checking for $ac_hdr" >&5
-#line 15930 "configure"
+#line 15729 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15965,7 +15764,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15969: checking for location of openDWG library" >&5
+echo "configure:15768: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -16012,7 +15811,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:16016: checking for special C compiler options needed for large files" >&5
+echo "configure:15815: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -16020,7 +15819,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 16024 "configure"
+#line 15823 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -16036,7 +15835,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16040: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15839: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -16045,7 +15844,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 16049 "configure"
+#line 15848 "configure"
@@ -16061,7 +15860,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15864: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -16081,11 +15880,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:16085: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15884: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 16089 "configure"
+#line 15888 "configure"
@@ -16101,14 +15900,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16105: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15904: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16112 "configure"
+#line 15911 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -16126,7 +15925,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16130: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15929: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -16145,11 +15944,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:16149: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15948: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 16153 "configure"
+#line 15952 "configure"
@@ -16165,14 +15964,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16169: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15968: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16176 "configure"
+#line 15975 "configure"
 #define _LARGE_FILES 1
@@ -16190,7 +15989,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16194: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15993: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -16209,25 +16008,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16213: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16012: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 16217 "configure"
+#line 16016 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16224: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16023: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16231 "configure"
+#line 16030 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -16236,7 +16035,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16240: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -16257,10 +16056,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16261: checking if system supports Large Files at all" >&5
+echo "configure:16060: checking if system supports Large Files at all" >&5
-#line 16264 "configure"
+#line 16063 "configure"
 #include <stdio.h>
@@ -16292,7 +16091,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:16296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16095: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16321,7 +16120,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16325: checking whether to use Python" >&5
+echo "configure:16124: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16341,7 +16140,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:16345: checking for $ac_word" >&5
+echo "configure:16144: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16383,15 +16182,15 @@
 do
-echo "configure:16387: checking for $ac_hdr" >&5
+echo "configure:16186: checking for $ac_hdr" >&5
-#line 16390 "configure"
+#line 16189 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16395: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16194: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16461,7 +16260,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16465: checking whether to use wxWidgets" >&5
+echo "configure:16264: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16482,7 +16281,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16486: checking for $ac_word" >&5
+echo "configure:16285: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16530,7 +16329,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16534: checking wxWidgets version" >&5
+echo "configure:16333: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16553,15 +16352,15 @@
 do
-echo "configure:16557: checking for $ac_hdr" >&5
+echo "configure:16356: checking for $ac_hdr" >&5
-#line 16560 "configure"
+#line 16359 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16565: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16364: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16828,9 +16627,6 @@
 s%@READLINELIBPATH@%$READLINELIBPATH%g
 s%@READLINELIB@%$READLINELIB%g
 s%@HISTORYLIB@%$HISTORYLIB%g
-s%@JPEGINCPATH@%$JPEGINCPATH%g
-s%@JPEGLIBPATH@%$JPEGLIBPATH%g
-s%@JPEGLIB@%$JPEGLIB%g
 s%@GDAL_CONFIG@%$GDAL_CONFIG%g
 s%@GDAL_LIBS@%$GDAL_LIBS%g
 s%@GDAL_CFLAGS@%$GDAL_CFLAGS%g
@@ -17229,8 +17025,6 @@
 echo "  GLw support:                `if test -n "${USE_GLW}" ; then echo yes ; else echo no ; fi`"
-echo "  JPEG support:               `if test -n "${USE_JPEG}" ; then echo yes ; else echo no ; fi`"
 echo "  LAPACK support:             `if test -n "${USE_LAPACK}" ; then echo yes ; else echo no ; fi`"
 echo "  Large File support (LFS):   `if test -n "${USE_LARGEFILES}" ; then echo yes ; else echo no ; fi`"
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in	2012-03-11 15:27:08 UTC (rev 51034)
+++ grass/branches/releasebranch_6_4/configure.in	2012-03-11 19:50:23 UTC (rev 51035)
@@ -244,7 +244,6 @@
 AC_ARG_WITH(macosx-sdk,
 [  --with-macosx-sdk[=path/sdk]
                           compile with a system SDK on MacOSX. (default: no)],, with_macosx_sdk="no")
-LOC_ARG_WITH(jpeg, JPEG)
 LOC_ARG_WITH(tiff, TIFF)
 LOC_ARG_WITH(png, PNG)
 LOC_ARG_WITH(tcltk, Tcl/Tk)
@@ -305,9 +304,6 @@
 LOC_ARG_WITH_INC(readline, Readline)
 LOC_ARG_WITH_LIB(readline, Readline)
-LOC_ARG_WITH_INC(jpeg, JPEG)
-LOC_ARG_WITH_LIB(jpeg, JPEG)
 LOC_ARG_WITH_INC(tiff, TIFF)
 LOC_ARG_WITH_LIB(tiff, TIFF)
@@ -768,36 +764,6 @@
 # Done checking Readline
-# Enable JPEG option
-LOC_CHECK_USE(jpeg,JPEG,USE_JPEG)
-JPEGINCPATH=
-JPEGLIBPATH=
-JPEGLIB=
-if test -n "$USE_JPEG"; then
-# With JPEG includes directory
-LOC_CHECK_INC_PATH(jpeg,JPEG,JPEGINCPATH)
-LOC_CHECK_INCLUDES(jpeglib.h,JPEG,$JPEGINCPATH)
-# With JPEG library directory
-LOC_CHECK_LIB_PATH(jpeg,JPEG,JPEGLIBPATH)
-LOC_CHECK_LIBS(jpeg,jpeg_start_compress,JPEG,$JPEGLIBPATH,JPEGLIB,,,,$ZLIB)
-fi # $USE_JPEG
-AC_SUBST(JPEGINCPATH)
-AC_SUBST(JPEGLIBPATH)
-AC_SUBST(JPEGLIB)
-# Done checking JPEG
 # GDAL option
 AC_MSG_CHECKING(whether to use GDAL)
@@ -917,7 +883,7 @@
 LOC_CHECK_LIB_PATH(tiff,TIFF,TIFF_LIBRARY_DIRS)
-LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,,,,$JPEGLIBPATH $JPEGLIB,$ZLIB,$MATHLIB)
+LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,,,,-ljpeg,$ZLIB,$MATHLIB)
 fi # $USE_TIFF
@@ -2061,7 +2027,6 @@
 LOC_MSG_USE(GDAL support,USE_GDAL)
 LOC_MSG_USE(GEOS support,USE_GEOS)
 LOC_MSG_USE(GLw support,USE_GLW)
-LOC_MSG_USE(JPEG support,USE_JPEG)
 LOC_MSG_USE(LAPACK support,USE_LAPACK)
 LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
 LOC_MSG_USE(Motif support,USE_MOTIF)
